RTX Server PNY
PNY_Hyssam
RTX Server PNY
Post by PNY_Hyssam »
Hello,
I have a server that would be available to help with the calculations.
hardware configuration:
2x Intel Xeon 6134
12x 32GB Samsung DDR4
8x Nvidia Quadro RTX6000
But I have a problem I installed FAH but I don't see my GPUs.
Maybe a configuration to do but I don't know where to look.
*********************** Log Started 2020-03-26T12:41:12Z ***********************
12:41:12:************************* Folding@home Client *************************
12:41:12:        Website: https://foldingathome.org/
12:41:12:      Copyright: (c) 2009-2018 foldingathome.org
12:41:12:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:41:12:           Args: --open-web-control
12:41:12:         Config: C:\Users\Escape\AppData\Roaming\FAHClient\config.xml
12:41:12:******************************** Build ********************************
12:41:12:        Version: 7.5.1
12:41:12:           Date: May 11 2018
12:41:12:           Time: 13:06:32
12:41:12:     Repository: Git
12:41:12:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
12:41:12:         Branch: master
12:41:12:       Compiler: Visual C++ 2008
12:41:12:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
12:41:12:       Platform: win32 10
12:41:12:           Bits: 32
12:41:12:           Mode: Release
12:41:12:******************************* System ********************************
12:41:12:            CPU: Intel(R) Xeon(R) Gold 6134 CPU @ 3.20GHz
12:41:12:         CPU ID: GenuineIntel Family 6 Model 85 Stepping 4
12:41:12:           CPUs: 32
12:41:12:         Memory: 351.39GiB
12:41:12:    Free Memory: 343.91GiB
12:41:12:        Threads: WINDOWS_THREADS
12:41:12:     OS Version: 6.2
12:41:12:    Has Battery: false
12:41:12:     On Battery: false
12:41:12:     UTC Offset: 1
12:41:12:            PID: 1828
12:41:12:            CWD: C:\Users\Escape\AppData\Roaming\FAHClient
12:41:12:             OS: Windows 10 Enterprise
12:41:12:        OS Arch: AMD64
12:41:12:           GPUs: 0
12:41:12:  CUDA Device 0: Platform:0 Device:0 Bus:26 Slot:0 Compute:7.5 Driver:10.2
12:41:12:  CUDA Device 1: Platform:0 Device:1 Bus:27 Slot:0 Compute:7.5 Driver:10.2
12:41:12:  CUDA Device 2: Platform:0 Device:2 Bus:96 Slot:0 Compute:7.5 Driver:10.2
12:41:12:  CUDA Device 3: Platform:0 Device:3 Bus:97 Slot:0 Compute:7.5 Driver:10.2
12:41:12:  CUDA Device 4: Platform:0 Device:4 Bus:177 Slot:0 Compute:7.5 Driver:10.2
12:41:12:  CUDA Device 5: Platform:0 Device:5 Bus:178 Slot:0 Compute:7.5 Driver:10.2
12:41:12:  CUDA Device 6: Platform:0 Device:6 Bus:218 Slot:0 Compute:7.5 Driver:10.2
12:41:12:  CUDA Device 7: Platform:0 Device:7 Bus:219 Slot:0 Compute:7.5 Driver:10.2
12:41:12:OpenCL Device 0: Platform:0 Device:0 Bus:26 Slot:0 Compute:1.2 Driver:442.74
12:41:12:OpenCL Device 1: Platform:0 Device:1 Bus:27 Slot:0 Compute:1.2 Driver:442.74
12:41:12:OpenCL Device 2: Platform:0 Device:2 Bus:96 Slot:0 Compute:1.2 Driver:442.74
12:41:12:OpenCL Device 3: Platform:0 Device:3 Bus:97 Slot:0 Compute:1.2 Driver:442.74
12:41:12:OpenCL Device 4: Platform:0 Device:4 Bus:177 Slot:0 Compute:1.2 Driver:442.74
12:41:12:OpenCL Device 5: Platform:0 Device:5 Bus:178 Slot:0 Compute:1.2 Driver:442.74
12:41:12:OpenCL Device 6: Platform:0 Device:6 Bus:218 Slot:0 Compute:1.2 Driver:442.74
12:41:12:OpenCL Device 7: Platform:0 Device:7 Bus:219 Slot:0 Compute:1.2 Driver:442.74
12:41:12:  Win32 Service: false
12:41:12:***********************************************************************
12:41:12:<config>
12:41:12:  <!-- Folding Slot Configuration -->
12:41:12:  <client-type v='bigadv'/>
12:41:12:  <extra-core-args v='-np 2'/>
12:41:12:
12:41:12:  <!-- Network -->
12:41:12:  <proxy v=':8080'/>
12:41:12:
12:41:12:  <!-- Slot Control -->
12:41:12:  <power v='FULL'/>
12:41:12:
12:41:12:  <!-- User Information -->
12:41:12:  <team v='240589'/>
12:41:12:  <user v='PNY_EMEAI'/>
12:41:12:
12:41:12:  <!-- Folding Slots -->
12:41:12:  <slot id='0' type='CPU'/>
12:41:12:</config>
12:41:12:Connecting to assign1.foldingathome.org:8080
12:41:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
12:41:12:Connecting to assign2.foldingathome.org:80
12:41:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
12:41:12:Trying to access database...
12:41:12:Successfully acquired database lock
12:41:12:Enabled folding slot 00: READY cpu:32
12:41:13:WU00:FS00:Connecting to 65.254.110.245:8080
12:41:16:16:127.0.0.1:New Web connection
12:41:37:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
12:41:37:WU00:FS00:Connecting to 18.218.241.186:80
12:41:56:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
12:41:56:ERROR:WU00:FS00:Exception: Could not get an assignment ID
12:41:57:WU00:FS00:Connecting to 65.254.110.245:8080
12:42:20:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
12:42:20:WU00:FS00:Connecting to 18.218.241.186:80
12:42:40:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
12:42:40:ERROR:WU00:FS00:Exception: Could not get an assignment ID
12:42:57:WU00:FS00:Connecting to 65.254.110.245:8080
12:43:21:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
12:43:21:WU00:FS00:Connecting to 18.218.241.186:80
12:43:40:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
12:43:40:ERROR:WU00:FS00:Exception: Could not get an assignment ID
12:44:34:WU00:FS00:Connecting to 65.254.110.245:8080
12:45:01:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
12:45:01:WU00:FS00:Connecting to 18.218.241.186:80
12:45:21:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
12:45:21:ERROR:WU00:FS00:Exception: Could not get an assignment ID
12:46:12:Connecting to assign1.foldingathome.org:8080
12:46:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
12:46:12:Connecting to assign2.foldingathome.org:80
12:46:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
12:47:11:WU00:FS00:Connecting to 65.254.110.245:8080
12:47:34:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
12:47:34:WU00:FS00:Connecting to 18.218.241.186:80
12:47:54:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
12:47:54:ERROR:WU00:FS00:Exception: Could not get an assignment ID
12:51:12:Connecting to assign1.foldingathome.org:8080
12:51:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
12:51:12:Connecting to assign2.foldingathome.org:80
12:51:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
12:51:25:WU00:FS00:Connecting to 65.254.110.245:8080
12:51:49:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
12:51:49:WU00:FS00:Connecting to 18.218.241.186:80
12:52:08:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
12:52:08:ERROR:WU00:FS00:Exception: Could not get an assignment ID
12:54:26:FS00:Paused
12:54:30:FS00:Unpaused
12:54:30:WU00:FS00:Connecting to 65.254.110.245:8080
12:54:54:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
12:54:54:WU00:FS00:Connecting to 18.218.241.186:80
12:55:14:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
12:55:14:ERROR:WU00:FS00:Exception: Could not get an assignment ID
12:56:08:WU00:FS00:Connecting to 65.254.110.245:8080
12:56:12:Connecting to assign1.foldingathome.org:8080
12:56:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
12:56:12:Connecting to assign2.foldingathome.org:80
12:56:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
12:56:35:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
12:56:35:WU00:FS00:Connecting to 18.218.241.186:80
12:56:54:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
12:56:54:ERROR:WU00:FS00:Exception: Could not get an assignment ID
12:58:45:WU00:FS00:Connecting to 65.254.110.245:8080
12:59:12:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
12:59:12:WU00:FS00:Connecting to 18.218.241.186:80
12:59:34:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
12:59:34:ERROR:WU00:FS00:Exception: Could not get an assignment ID
13:01:12:Connecting to assign1.foldingathome.org:8080
13:01:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
13:01:12:Connecting to assign2.foldingathome.org:80
13:01:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
13:02:59:WU00:FS00:Connecting to 65.254.110.245:8080
13:03:26:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
13:03:26:WU00:FS00:Connecting to 18.218.241.186:80
13:03:48:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
13:03:48:ERROR:WU00:FS00:Exception: Could not get an assignment ID
13:06:12:Connecting to assign1.foldingathome.org:8080
13:06:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
13:06:12:Connecting to assign2.foldingathome.org:80
13:06:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
13:09:50:WU00:FS00:Connecting to 65.254.110.245:8080
13:10:14:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
13:10:14:WU00:FS00:Connecting to 18.218.241.186:80
13:10:36:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
13:10:36:ERROR:WU00:FS00:Exception: Could not get an assignment ID
13:11:12:Connecting to assign1.foldingathome.org:8080
13:11:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
13:11:12:Connecting to assign2.foldingathome.org:80
13:11:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
13:16:12:Connecting to assign1.foldingathome.org:8080
13:16:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
13:16:12:Connecting to assign2.foldingathome.org:80
13:16:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
13:20:56:WU00:FS00:Connecting to 65.254.110.245:8080
13:21:12:Connecting to assign1.foldingathome.org:8080
13:21:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
13:21:12:Connecting to assign2.foldingathome.org:80
13:21:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
13:21:23:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
13:21:23:WU00:FS00:Connecting to 18.218.241.186:80
13:21:52:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
13:21:52:ERROR:WU00:FS00:Exception: Could not get an assignment ID
13:26:12:Connecting to assign1.foldingathome.org:8080
13:26:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
13:26:12:Connecting to assign2.foldingathome.org:80
13:26:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
13:31:09:Saving configuration to config.xml
13:31:09:<config>
13:31:09:  <!-- Network -->
13:31:09:  <proxy v=':8080'/>
13:31:09:
13:31:09:  <!-- Slot Control -->
13:31:09:  <power v='FULL'/>
13:31:09:
13:31:09:  <!-- User Information -->
13:31:09:  <team v='240589'/>
13:31:09:  <user v='PNY_EMEAI'/>
13:31:09:
13:31:09:  <!-- Folding Slots -->
13:31:09:  <slot id='0' type='CPU'/>
13:31:09:</config>
13:31:12:Connecting to assign1.foldingathome.org:8080
13:31:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
13:31:12:Connecting to assign2.foldingathome.org:80
13:31:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
13:32:02:Saving configuration to config.xml
13:32:02:<config>
13:32:02:  <!-- Network -->
13:32:02:  <proxy v=':8080'/>
13:32:02:
13:32:02:  <!-- Slot Control -->
13:32:02:  <power v='FULL'/>
13:32:02:
13:32:02:  <!-- User Information -->
13:32:02:  <team v='240589'/>
13:32:02:  <user v='PNY_EMEAI'/>
13:32:02:
13:32:02:  <!-- Folding Slots -->
13:32:02:  <slot id='0' type='CPU'/>
13:32:02:</config>
13:36:12:Connecting to assign1.foldingathome.org:8080
13:36:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
13:36:12:Connecting to assign2.foldingathome.org:80
13:36:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
13:38:53:WU00:FS00:Connecting to 65.254.110.245:8080
13:39:20:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
13:39:20:WU00:FS00:Connecting to 18.218.241.186:80
13:39:41:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
13:39:41:ERROR:WU00:FS00:Exception: Could not get an assignment ID
13:41:12:Connecting to assign1.foldingathome.org:8080
13:41:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
13:41:12:Connecting to assign2.foldingathome.org:80
13:41:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
13:46:12:Connecting to assign1.foldingathome.org:8080
13:46:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
13:46:12:Connecting to assign2.foldingathome.org:80
13:46:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
13:51:12:Connecting to assign1.foldingathome.org:8080
13:51:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
13:51:12:Connecting to assign2.foldingathome.org:80
13:51:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
13:56:12:Connecting to assign1.foldingathome.org:8080
13:56:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
13:56:12:Connecting to assign2.foldingathome.org:80
13:56:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
14:01:12:Connecting to assign1.foldingathome.org:8080
14:01:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
14:01:12:Connecting to assign2.foldingathome.org:80
14:01:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
14:06:12:Connecting to assign1.foldingathome.org:8080
14:06:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
14:06:12:Connecting to assign2.foldingathome.org:80
14:06:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
14:07:55:WU00:FS00:Connecting to 65.254.110.245:8080
14:08:22:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': 10002: Received short response, expected 8 bytes, got 0
14:08:22:WU00:FS00:Connecting to 18.218.241.186:80
14:08:48:WARNING:WU00:FS00:Failed to get ID from '18.218.241.186:80': 10002: Received short response, expected 8 bytes, got 0
14:08:48:ERROR:WU00:FS00:Exception: Could not get an assignment ID
14:11:12:Connecting to assign1.foldingathome.org:8080
14:11:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
14:11:12:Connecting to assign2.foldingathome.org:80
14:11:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
14:16:12:Connecting to assign1.foldingathome.org:8080
14:16:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
14:16:12:Connecting to assign2.foldingathome.org:80
14:16:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
14:21:12:Connecting to assign1.foldingathome.org:8080
14:21:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
14:21:12:Connecting to assign2.foldingathome.org:80
14:21:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
14:26:12:Connecting to assign1.foldingathome.org:8080
14:26:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
14:26:12:Connecting to assign2.foldingathome.org:80
14:26:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
14:31:12:Connecting to assign1.foldingathome.org:8080
14:31:12:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
14:31:12:Connecting to assign2.foldingathome.org:80
14:31:12:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
14:33:54:Saving configuration to config.xml
14:33:54:<config>
14:33:54:  <!-- Network -->
14:33:54:  <proxy v=':8080'/>
14:33:54:
14:33:54:  <!-- Slot Control -->
14:33:54:  <power v='FULL'/>
14:33:54:
14:33:54:  <!-- User Information -->
14:33:54:  <team v='240589'/>
14:33:54:  <user v='PNY_EMEAI'/>
14:33:54:
14:33:54:  <!-- Folding Slots -->
14:33:54:  <slot id='0' type='CPU'/>
14:33:54:</config>
14:34:37:Saving configuration to config.xml
14:34:37:<config>
14:34:37:  <!-- Network -->
14:34:37:  <proxy v=':8080'/>
14:34:37:
14:34:37:  <!-- Slot Control -->
14:34:37:  <power v='FULL'/>
14:34:37:
14:34:37:  <!-- User Information -->
14:34:37:  <team v='240589'/>
14:34:37:  <user v='PNY_EMEAI'/>
14:34:37:
14:34:37:  <!-- Folding Slots -->
14:34:37:  <slot id='0' type='CPU'/>
14:34:37:</config>
14:36:12:Connecting to assign1.foldingathome.org:8080
14:36:47:WARNING:Attempting to update GPUs.txt from assign1.foldingathome.org:8080: Failed to read stream
14:36:47:Connecting to assign2.foldingathome.org:80
14:37:09:WARNING:Attempting to update GPUs.txt from assign2.foldingathome.org:80: Failed to read stream
14:37:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
Can someone help me?
Thanks a lot.
PNY_Hyssam
Re: RTX Server PNY
Solved
firewall issue
Re: RTX Server PNY
Glad you fixed it. Nice to see PNY helping us ! :)
PNY_Hyssam
Re: RTX Server PNY
It's normal to help with research, thank you for creating a sharing solution.
Re: RTX Server PNY
Once this containment is over, I should stop by your office to say hello. I work in the area ;)
