I'm confused
SPF1000
I'm confused
Post by SPF1000 »
*********************** Log Started 2020-03-25T18:45:10Z ***********************
18:45:10:************************* Folding@home Client *************************
18:45:10:    Website: https://foldingathome.org/
18:45:10:  Copyright: (c) 2009-2018 foldingathome.org
18:45:10:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:45:10:       Args:
18:45:10:     Config: <none>
18:45:10:******************************** Build ********************************
18:45:10:    Version: 7.5.1
18:45:10:       Date: May 11 2018
18:45:10:       Time: 12:57:01
18:45:10: Repository: Git
18:45:10:   Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
18:45:10:     Branch: master
18:45:10:   Compiler: GNU 4.2.1 Compatible Apple LLVM 7.3.0 (clang-703.0.31)
18:45:10:    Options: -std=gnu++98 -O3 -funroll-loops -mmacosx-version-min=10.6
18:45:10:             -Wno-unused-local-typedefs
18:45:10:   Platform: darwin 15.6.0
18:45:10:       Bits: 64
18:45:10:       Mode: Release
18:45:10:******************************* System ********************************
18:45:10:        CPU: Intel(R) Core(TM) i5-2415M CPU @ 2.30GHz
18:45:10:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
18:45:10:       CPUs: 4
18:45:10:     Memory: 16.00GiB
18:45:10:Free Memory: 5.52GiB
18:45:10:    Threads: POSIX_THREADS
18:45:10: OS Version: 10.13
18:45:10:Has Battery: true
18:45:10: On Battery: true
18:45:10: UTC Offset: -6
18:45:10:        PID: 62819
18:45:10:        CWD: /Library/Application Support/FAHClient
18:45:10:         OS: Darwin 17.7.0 x86_64
18:45:10:    OS Arch: AMD64
18:45:10:       GPUs: 0
18:45:10:       CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
18:45:10:             dlopen(libcuda.dylib, 1): image not found
18:45:10:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
18:45:10:             dlopen(libOpenCL.dylib, 1): image not found
18:45:10:***********************************************************************
18:45:10:<config>
18:45:10:  <!-- Folding Slots -->
18:45:10:</config>
18:45:10:Trying to access database...
18:45:10:Successfully acquired database lock
18:45:10:Enabled folding slot 00: PAUSED cpu:1 (not configured)
18:46:11:Saving configuration to config.xml
18:46:11:<config>
18:46:11:  <!-- Folding Slots -->
18:46:11:  <slot id='0' type='CPU'/>
18:46:11:</config>
18:46:11:Set client configured
18:49:55:Saving configuration to config.xml
18:49:55:<config>
18:49:55:  <!-- Network -->
18:49:55:  <proxy v=':8080'/>
18:49:55:
18:49:55:  <!-- Folding Slots -->
18:49:55:  <slot id='0' type='CPU'/>
18:49:55:</config>
18:50:15:Saving configuration to config.xml
18:50:15:<config>
18:50:15:  <!-- Network -->
18:50:15:  <proxy v=':8080'/>
18:50:15:
18:50:15:  <!-- Folding Slots -->
18:50:15:  <slot id='0' type='CPU'/>
18:50:15:</config>
18:53:05:Saving configuration to config.xml
18:53:05:<config>
18:53:05:  <!-- Network -->
18:53:05:  <proxy v=':8080'/>
18:53:05:
18:53:05:  <!-- Slot Control -->
18:53:05:  <pause-on-battery v='false'/>
18:53:05:
18:53:05:  <!-- Folding Slots -->
18:53:05:  <slot id='0' type='CPU'/>
18:53:05:</config>
18:53:18:Saving configuration to config.xml
18:53:18:<config>
18:53:18:  <!-- Network -->
18:53:18:  <proxy v=':8080'/>
18:53:18:
18:53:18:  <!-- Slot Control -->
18:53:18:  <pause-on-battery v='false'/>
18:53:18:
18:53:18:  <!-- Folding Slots -->
18:53:18:  <slot id='0' type='CPU'/>
18:53:18:</config>
19:34:43:Saving configuration to config.xml
19:34:43:<config>
19:34:43:  <!-- Network -->
19:34:43:  <proxy v=':8080'/>
19:34:43:
19:34:43:  <!-- Slot Control -->
19:34:43:  <pause-on-battery v='false'/>
19:34:43:
19:34:43:  <!-- Folding Slots -->
19:34:43:  <slot id='0' type='CPU'/>
19:34:43:</config>
19:35:07:WU00:FS00:Connecting to 65.254.110.245:8080
19:36:23:WARNING:WU00:FS00:Failed to get ID from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: Operation timed out
19:36:23:WU00:FS00:Connecting to 18.218.241.186:80
19:36:23:WU00:FS00:Connecting to 65.254.110.245:8080
19:37:39:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: Operation timed out
19:37:39:WU00:FS00:Connecting to 18.218.241.186:80
19:37:39:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:37:39:ERROR:WU00:FS00:Exception: Could not get an assignment
19:37:39:WU00:FS00:Connecting to 65.254.110.245:8080
19:38:54:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: Operation timed out
19:38:54:WU00:FS00:Connecting to 18.218.241.186:80
19:38:54:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:38:54:ERROR:WU00:FS00:Exception: Could not get an assignment
19:38:55:WU00:FS00:Connecting to 65.254.110.245:8080
19:40:10:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: Operation timed out
19:40:10:WU00:FS00:Connecting to 18.218.241.186:80
19:40:10:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:40:10:ERROR:WU00:FS00:Exception: Could not get an assignment
19:40:32:WU00:FS00:Connecting to 65.254.110.245:8080
19:41:47:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: Operation timed out
19:41:47:WU00:FS00:Connecting to 18.218.241.186:80
19:41:48:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:41:48:ERROR:WU00:FS00:Exception: Could not get an assignment
19:43:09:WU00:FS00:Connecting to 65.254.110.245:8080
19:44:25:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: Operation timed out
19:44:25:WU00:FS00:Connecting to 18.218.241.186:80
19:44:25:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:44:25:ERROR:WU00:FS00:Exception: Could not get an assignment
19:47:24:WU00:FS00:Connecting to 65.254.110.245:8080
19:48:39:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: Operation timed out
19:48:39:WU00:FS00:Connecting to 18.218.241.186:80
19:48:39:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:48:39:ERROR:WU00:FS00:Exception: Could not get an assignment
19:54:15:WU00:FS00:Connecting to 65.254.110.245:8080
19:55:30:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: Operation timed out
19:55:30:WU00:FS00:Connecting to 18.218.241.186:80
19:55:30:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:55:30:ERROR:WU00:FS00:Exception: Could not get an assignment
20:05:21:WU00:FS00:Connecting to 65.254.110.245:8080
20:06:36:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: Operation timed out
20:06:36:WU00:FS00:Connecting to 18.218.241.186:80
20:06:36:WU00:FS00:Assigned to work server 40.114.52.201
20:06:36:WU00:FS00:Requesting new work unit for slot 00: READY cpu:1 from 40.114.52.201
20:06:36:WU00:FS00:Connecting to 40.114.52.201:8080
20:07:51:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
20:07:51:WU00:FS00:Connecting to 40.114.52.201:80
20:08:41:WU00:FS00:Downloading 2.14MiB
20:08:41:WU00:FS00:Download complete
20:08:41:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13850 run:0 clone:38104 gen:1 core:0xa7 unit:0x00000003287234c95e78897c21ad19b9
20:08:41:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah
20:08:41:WU00:FS00:Connecting to cores.foldingathome.org:80
20:08:41:WU00:FS00:FahCore a7: Downloading 6.53MiB
20:08:43:WU00:FS00:FahCore a7: Download complete
20:08:43:WU00:FS00:Valid core signature
20:08:43:WU00:FS00:Unpacked 17.01MiB to cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7
20:08:43:WU00:FS00:Starting
20:08:43:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 62819 -checkpoint 15 -np 1
20:08:43:WU00:FS00:Started FahCore on PID 64193
20:08:44:WU00:FS00:Core PID:64194
20:08:44:WU00:FS00:FahCore 0xa7 started
20:08:44:WU00:FS00:0xa7:*********************** Log Started 2020-03-25T20:08:44Z ***********************
20:08:44:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:08:44:WU00:FS00:0xa7:       Type: 0xa7
20:08:44:WU00:FS00:0xa7:       Core: Gromacs
20:08:44:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 64193 -checkpoint 15 -np
20:08:44:WU00:FS00:0xa7:             1
20:08:44:WU00:FS00:0xa7:************************************ CBang *************************************
20:08:44:WU00:FS00:0xa7:       Date: Oct 26 2019
20:08:44:WU00:FS00:0xa7:       Time: 03:00:53
20:08:44:WU00:FS00:0xa7:   Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
20:08:44:WU00:FS00:0xa7:     Branch: master
20:08:44:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
20:08:44:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
20:08:44:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
20:08:44:WU00:FS00:0xa7:   Platform: darwin 19.0.0
20:08:44:WU00:FS00:0xa7:       Bits: 64
20:08:44:WU00:FS00:0xa7:       Mode: Release
20:08:44:WU00:FS00:0xa7:************************************ System ************************************
20:08:44:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-2415M CPU @ 2.30GHz
20:08:44:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
20:08:44:WU00:FS00:0xa7:       CPUs: 4
20:08:44:WU00:FS00:0xa7:     Memory: 16.00GiB
20:08:44:WU00:FS00:0xa7:Free Memory: 4.16GiB
20:08:44:WU00:FS00:0xa7:    Threads: POSIX_THREADS
20:08:44:WU00:FS00:0xa7: OS Version: 10.13
20:08:44:WU00:FS00:0xa7:Has Battery: true
20:08:44:WU00:FS00:0xa7: On Battery: false
20:08:44:WU00:FS00:0xa7: UTC Offset: -6
20:08:44:WU00:FS00:0xa7:        PID: 64194
20:08:44:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
20:08:44:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
20:08:44:WU00:FS00:0xa7:    Version: 0.0.18
20:08:44:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:08:44:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:08:44:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
20:08:44:WU00:FS00:0xa7:       Time: 03:06:33
20:08:44:WU00:FS00:0xa7:   Revision: fcc08f30b8997509aaba3a213354c363f474e056
20:08:44:WU00:FS00:0xa7:************************************ Build *************************************
20:08:44:WU00:FS00:0xa7:       SIMD: avx_256
20:08:44:WU00:FS00:0xa7:********************************************************************************
20:08:44:WU00:FS00:0xa7:Project: 13850 (Run 0, Clone 38104, Gen 1)
20:08:44:WU00:FS00:0xa7:Unit: 0x00000003287234c95e78897c21ad19b9
20:08:44:WU00:FS00:0xa7:Reading tar file core.xml
20:08:44:WU00:FS00:0xa7:Reading tar file frame1.tpr
20:08:44:WU00:FS00:0xa7:Digital signatures verified
20:08:44:WU00:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -x frame1.xtc -e frame1.edr -cpt 15 -nt 1
20:08:44:WU00:FS00:0xa7:Steps: first=500000 total=500000
20:08:45:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
20:19:06:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
20:28:05:FS00:Shutting core down
20:28:05:WU00:FS00:0xa7:Caught signal SIGINT(2) on PID 64194
20:28:05:WU00:FS00:0xa7:Exiting, please wait. . .
20:28:11:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
20:28:11:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
20:28:12:WU00:FS00:Starting
20:28:12:WARNING:WU00:FS00:Changed SMP threads from 1 to 4 this can cause some work units to fail
20:28:12:WARNING:WU00:FS00:AS lowered CPUs from 4 to 1
20:28:12:WU00:FS00:Running FahCore: /usr/local/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/cores.foldingathome.org/v7/osx/64bit/avx/Core_a7.fah/FahCore_a7" -dir 00 -suffix 01 -version 705 -lifeline 62819 -checkpoint 15 -np 1
20:28:12:WU00:FS00:Started FahCore on PID 64450
20:28:12:WU00:FS00:Core PID:64451
20:28:12:WU00:FS00:FahCore 0xa7 started
20:28:12:WU00:FS00:0xa7:*********************** Log Started 2020-03-25T20:28:12Z ***********************
20:28:12:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:28:12:WU00:FS00:0xa7:       Type: 0xa7
20:28:12:WU00:FS00:0xa7:       Core: Gromacs
20:28:12:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 64450 -checkpoint 15 -np
20:28:12:WU00:FS00:0xa7:             1
20:28:12:WU00:FS00:0xa7:************************************ CBang *************************************
20:28:12:WU00:FS00:0xa7:       Date: Oct 26 2019
20:28:12:WU00:FS00:0xa7:       Time: 03:00:53
20:28:12:WU00:FS00:0xa7:   Revision: 3b1c887e9f30a608262e0d62833b273e843f7c1b
20:28:12:WU00:FS00:0xa7:     Branch: master
20:28:12:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Apple LLVM 11.0.0 (clang-1100.0.33.8)
20:28:12:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -mmacosx-version-min=10.7
20:28:12:WU00:FS00:0xa7:             -Wno-unused-local-typedefs -stdlib=libc++ -fPIC
20:28:12:WU00:FS00:0xa7:   Platform: darwin 19.0.0
20:28:12:WU00:FS00:0xa7:       Bits: 64
20:28:12:WU00:FS00:0xa7:       Mode: Release
20:28:12:WU00:FS00:0xa7:************************************ System ************************************
20:28:12:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-2415M CPU @ 2.30GHz
20:28:12:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
20:28:12:WU00:FS00:0xa7:       CPUs: 4
20:28:12:WU00:FS00:0xa7:     Memory: 16.00GiB
20:28:12:WU00:FS00:0xa7:Free Memory: 5.26GiB
20:28:12:WU00:FS00:0xa7:    Threads: POSIX_THREADS
20:28:12:WU00:FS00:0xa7: OS Version: 10.13
20:28:12:WU00:FS00:0xa7:Has Battery: true
20:28:12:WU00:FS00:0xa7: On Battery: false
20:28:12:WU00:FS00:0xa7: UTC Offset: -6
20:28:12:WU00:FS00:0xa7:        PID: 64451
20:28:12:WU00:FS00:0xa7:        CWD: /Library/Application Support/FAHClient/work
20:28:12:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
20:28:12:WU00:FS00:0xa7:    Version: 0.0.18
20:28:12:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:28:12:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:28:12:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
20:28:12:WU00:FS00:0xa7:       Time: 03:06:33
20:28:12:WU00:FS00:0xa7:   Revision: fcc08f30b8997509aaba3a213354c363f474e056
20:28:12:WU00:FS00:0xa7:************************************ Build *************************************
20:28:12:WU00:FS00:0xa7:       SIMD: avx_256
20:28:12:WU00:FS00:0xa7:********************************************************************************
20:28:12:WU00:FS00:0xa7:Project: 13850 (Run 0, Clone 38104, Gen 1)
20:28:12:WU00:FS00:0xa7:Unit: 0x00000003287234c95e78897c21ad19b9
20:28:12:WU00:FS00:0xa7:Digital signatures verified
20:28:12:WU00:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -x frame1.xtc -e frame1.edr -cpi state.cpt -cpt 15 -nt 1
20:28:12:WU00:FS00:0xa7:Steps: first=500000 total=500000
20:28:13:WU00:FS00:0xa7:Completed 9452 out of 500000 steps (1%)
20:28:52:Saving configuration to config.xml
20:28:52:<config>
20:28:52:  <!-- Network -->
20:28:52:  <proxy v=':8080'/>
20:28:52:
20:28:52:  <!-- Slot Control -->
20:28:52:  <pause-on-battery v='false'/>
20:28:52:  <power v='full'/>
20:28:52:
20:28:52:  <!-- Folding Slots -->
20:28:52:  <slot id='0' type='CPU'/>
20:28:52:</config>
20:29:20:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
20:39:48:WU00:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
20:49:50:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
20:59:46:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
21:09:21:WU00:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
21:19:27:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
21:29:42:WU00:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
21:40:17:WU00:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
21:50:33:WU00:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
22:00:24:WU00:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
22:10:02:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
22:19:39:WU00:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
22:29:17:WU00:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
22:38:54:WU00:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
22:48:32:WU00:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
22:58:22:WU00:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
23:08:51:WU00:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
23:19:21:WU00:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
23:29:53:WU00:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
23:39:58:WU00:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
23:49:28:WU00:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
23:59:01:WU00:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
00:08:30:WU00:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
00:18:01:WU00:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
00:27:31:WU00:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
00:37:01:WU00:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
******************************* Date: 2020-03-26 *******************************
00:46:32:WU00:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
00:56:03:WU00:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
01:05:33:WU00:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
01:15:04:WU00:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
01:24:33:WU00:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
01:34:06:WU00:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
01:43:44:WU00:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
01:53:20:WU00:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
02:02:58:WU00:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
02:12:34:WU00:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
02:22:41:WU00:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
02:33:13:WU00:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
02:43:46:WU00:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
02:54:17:WU00:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
03:04:30:WU00:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
03:14:09:WU00:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
03:23:56:WU00:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
03:34:28:WU00:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
03:45:00:WU00:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
03:55:30:WU00:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
04:05:42:WU00:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
04:15:21:WU00:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
04:24:56:WU00:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
04:34:34:WU00:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
04:44:13:WU00:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
04:54:20:WU00:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
05:04:51:WU00:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
05:15:22:WU00:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
05:25:49:WU00:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
05:35:36:WU00:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
05:45:09:WU00:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
05:54:45:WU00:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
06:04:22:WU00:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
06:14:52:WU00:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
06:25:23:WU00:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
06:35:56:WU00:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
06:46:19:WU00:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
06:55:47:WU00:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
07:05:16:WU00:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
07:14:48:WU00:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
07:24:18:WU00:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
07:33:48:WU00:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
07:43:20:WU00:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
07:52:47:WU00:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
08:02:19:WU00:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
08:11:48:WU00:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
08:21:19:WU00:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
08:30:50:WU00:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
08:40:19:WU00:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
08:49:50:WU00:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
08:59:22:WU00:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
09:08:50:WU00:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
09:18:22:WU00:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
09:27:50:WU00:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
09:37:22:WU00:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
09:46:55:WU00:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
09:56:25:WU00:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
10:05:56:WU00:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
10:15:29:WU00:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
10:24:58:WU00:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
10:34:30:WU00:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
10:44:02:WU00:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
10:53:32:WU00:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
11:03:05:WU00:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
11:12:33:WU00:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
11:22:05:WU00:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
11:31:37:WU00:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
11:41:04:WU00:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
11:50:36:WU00:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
12:00:07:WU00:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
12:09:36:WU00:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
12:19:08:WU00:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
12:19:09:WU01:FS00:Connecting to 65.254.110.245:8080
12:20:24:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: Operation timed out
12:20:24:WU01:FS00:Connecting to 18.218.241.186:80
12:20:24:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:20:24:ERROR:WU01:FS00:Exception: Could not get an assignment
12:20:24:WU01:FS00:Connecting to 65.254.110.245:8080
12:21:40:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: Operation timed out
12:21:40:WU01:FS00:Connecting to 18.218.241.186:80
12:21:40:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:21:40:ERROR:WU01:FS00:Exception: Could not get an assignment
12:21:40:WU01:FS00:Connecting to 65.254.110.245:8080
12:22:55:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: Operation timed out
12:22:55:WU01:FS00:Connecting to 18.218.241.186:80
12:22:56:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:22:56:ERROR:WU01:FS00:Exception: Could not get an assignment
12:23:17:WU01:FS00:Connecting to 65.254.110.245:8080
12:24:33:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: Operation timed out
12:24:33:WU01:FS00:Connecting to 18.218.241.186:80
12:24:33:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:24:33:ERROR:WU01:FS00:Exception: Could not get an assignment
12:25:54:WU01:FS00:Connecting to 65.254.110.245:8080
12:27:10:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: Operation timed out
12:27:10:WU01:FS00:Connecting to 18.218.241.186:80
12:27:10:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:27:10:ERROR:WU01:FS00:Exception: Could not get an assignment
12:28:47:WU00:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
12:28:50:WU00:FS00:0xa7:Saving result file ../logfile_01.txt
12:28:50:WU00:FS00:0xa7:Saving result file frame1.edr
12:28:50:WU00:FS00:0xa7:Saving result file frame1.trr
12:28:50:WU00:FS00:0xa7:Saving result file frame1.xtc
12:28:50:WU00:FS00:0xa7:Saving result file md.log
12:28:50:WU00:FS00:0xa7:Saving result file science.log
12:28:50:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
12:28:51:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:28:51:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13850 run:0 clone:38104 gen:1 core:0xa7 unit:0x00000003287234c95e78897c21ad19b9
12:28:51:WU00:FS00:Uploading 2.48MiB to 40.114.52.201
12:28:51:WU00:FS00:Connecting to 40.114.52.201:8080
12:30:06:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
12:30:06:WU00:FS00:Connecting to 40.114.52.201:80
12:30:09:WU01:FS00:Connecting to 65.254.110.245:8080
12:31:21:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: Operation timed out
12:31:21:WU00:FS00:Trying to send results to collection server
12:31:21:WU00:FS00:Uploading 2.48MiB to 128.252.203.9
12:31:21:WU00:FS00:Connecting to 128.252.203.9:8080
12:31:24:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: Operation timed out
12:31:24:WU01:FS00:Connecting to 18.218.241.186:80
12:31:24:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:31:24:ERROR:WU01:FS00:Exception: Could not get an assignment
12:32:37:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
12:32:37:WU00:FS00:Connecting to 128.252.203.9:80
12:32:39:WU00:FS00:Upload 2.52%
12:33:30:Caught signal SIGPIPE(13) on PID 62819
12:33:30:WU00:FS00:Upload 7.57%
12:33:30:ERROR:WU00:FS00:Exception: Transfer failed
12:33:30:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13850 run:0 clone:38104 gen:1 core:0xa7 unit:0x00000003287234c95e78897c21ad19b9
12:33:30:WU00:FS00:Uploading 2.48MiB to 40.114.52.201
12:33:30:WU00:FS00:Connecting to 40.114.52.201:8080
12:34:45:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
12:34:45:WU00:FS00:Connecting to 40.114.52.201:80
12:35:52:WU00:FS00:Upload 2.52%
12:36:18:WU00:FS00:Upload 10.09%
12:36:21:WU00:FS00:Upload complete
12:36:21:WU00:FS00:Server responded WORK_ACK (400)
12:36:21:WU00:FS00:Final credit estimate, 2763.00 points
12:36:21:WU00:FS00:Cleaning up
12:37:00:WU01:FS00:Connecting to 65.254.110.245:8080
12:38:15:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: Operation timed out
12:38:15:WU01:FS00:Connecting to 18.218.241.186:80
12:38:16:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:38:16:ERROR:WU01:FS00:Exception: Could not get an assignment
12:48:06:WU01:FS00:Connecting to 65.254.110.245:8080
12:49:22:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': Failed to connect to 65.254.110.245:8080: Operation timed out
12:49:22:WU01:FS00:Connecting to 18.218.241.186:80
12:49:22:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:49:22:ERROR:WU01:FS00:Exception: Could not get an assignment
uyaem
Re: I'm confused
Post by uyaem »
Me too. Why are you confused?
jonault
Re: I'm confused
Post by jonault »
What is it you're confused about?
I see you successfully completed & uploaded a work unit, but haven't been able to get another one yet. The servers are very busy right now, it's normal to have some failed attempts at downloading a work unit. Keep the software running & eventually it will get through.
GarethRM
Re: I'm confused
Post by GarethRM »
Hi All,
New to this and have started completing work units, but, the interface isn't working for me it just flashes and doesn't allow me to select anything, the task manager has resources diverted but the interface isn't working I can see my details or log in information, can anyone advise how I fix this?
Many thanks
Gareth
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Re: I'm confused
Post by Jesse_V »
GarethRM wrote:Hi All,
Many thanks
Gareth
Hi Gareth and welcome to the forum,
I assume that Web Control is repeatedly flashing for you. I'm not sure what's happening there. I'd recommend trying to open that URL in a private window or in a different web browser and that may fix the issue. Another option is to find the Folding@home icon in the taskbar down by the click, right-click on it, and select Advanced Control. This will open the FAHControl tool, which is a similar front-end for the software on your PC.
SPF1000
Re: I'm confused
Post by SPF1000 »
Sorry for that, to clarify: is it required to post each log?
Thank you!
uyaem
Re: I'm confused
Post by uyaem »
@SPF1000
I think we're not sure what you are confused about - the logs as a whole, or your client not doing any work?
If it is the latter, then it's because so many new people joined up that there's not enough work on the servers to give out (sometimes). Doesn't look like there's anything wrong on your end, there's at least one WU in the logs that was processed and uploaded.
Just keep the client running, it'll get new things to do eventually.
Regarding server load: See e.g. viewtopic.php?f=24&t=33193
HesletQuillan
Re: I'm confused
Post by HesletQuillan »
The Web Control flashing is a known issue in Chrome and Chromium-based browsers (such as the new Edge.) It is mentioned in a FAQ. Anyway, the temporary solution is to clear your browser cache. Learn how to do this as you'll be doing it often. Using Incognito mode also works.
SPF1000
Re: I'm confused
Post by SPF1000 »
When I going through this post: viewtopic.php?f=61&t=26036
I took it to mean that we needed to post our logs....oof :oops:
Re: I'm confused
Post by Neil-B »
Never be embarrassed for asking a question !! … and personally I would much rather have someone ask a question over confusion when reading the guidance posts than ask a question that is answered in the guidance notes they haven't read :) … Welcome to Folding and Thanks for taking the time to read posts and participate in the forums.
My "Personal Thoughts" for anyone who happens to read this thread:
The post linked above is a really useful first point of information which SPF1000 sensibly used as first point of reference - Most (if not all) questions/problems will have already cropped up "somewhere" in the topics they can sometimes just be hard to find/spot … Using the search tool (top right) might help get you an answer quicker than posting a new topic and hoping one of the (currently flat out) team member … At this busy time any of the folders (everyone is a volunteer) may try to help guide/assist you but the existing posts are an amazing source of knowledge if you can get used to searching them ;)
