Points stuck at 4,325
I've done either 6 or 7 work units but my stat registers it as 4 jobs... Points stuck at 4,325... What's going on? Is there a problem with the jobs that my computer processes?
Re: Points stuck at 4,325
The stats are not updated in real time, as the servers are overloaded by the surge of new users, so you may need a bit of patience, say 24 hours.
If it takes too long, you can post your log for the jobs you think were left out and an admin can check it out.
ajm wrote:The stats are not updated in real time, as the servers are overloaded by the surge of new users, so you may need a bit of patience, say 24 hours.
ok...thanks
