Hi,
I can't find the correct command line command for restart FAH.
Is anywhere the simple help site with this commands?
Thanks
meriscz
MacOS command line restart
Re: MacOS command line restart
sudo launchctl unload -w /Library/LaunchDaemons/edu.stanford.folding.fahclient.plist
and then
sudo launchctl load -w /Library/LaunchDaemons/edu.stanford.folding.fahclient.plist
This is on my older installation of 7.5.1 on my MacBook running High Sierra, as far as I know the paths have not changed.
and then
Thanks,
I find it on this path
sudo launchctl unload -w /Library/LaunchDaemons/org.foldingathome.fahclient.plist
I installed my client a few years, so it looks like it takes part of the filename from the download site. Was not aware of that aspect of the installer until this week.
Since launchd will restart the client on macOS, you can instead use
FAHClient —send-command shutdown
If I try FAHClient —send-command shutdown
the client stack on unknown state and only reboot PC help me.
