problem starting FAH
Blue_Topaz
Post by Blue_Topaz »
Hi,
ok sorry this happened before but I forgot how to fix it. Simple backstory I dual boot windows and opensuse tumbleweed and sometimes when switching the computer crashes. So foah was running fine on the linux system, the computer crashed. I run the
foah as user. When I try to start it now I get: ERROR: Exception: Parse failed: 3: no element found
ERROR :At config.xml:1:0
Root gives no such error message...I am certain someone showed me how to fix this.
any help would be appreciated......mike
Re: problem starting FAH
I guess you broke the config.xml file somewhat ... what does it look like ?
Blue_Topaz
Thanks....the config file was blank so I deleted it and ran configure again.....everybody must be
running FOAH because it is hard to get a work unit.....mike
