Dual Quadro RTX 4000 8GB Pls + dual support.
Kevonator11
Post by Kevonator11 »
I'm running only 50% of one of my GPU's whist folding. Can you please add support for both GPU's? I have dual Quadro RTX 4000 8GB each. Thanks!! :D :D :D :D :D
Kevin, San Diego
Dell Precision 5820
64GB RAM
Single i9 10900X 4.0Ghz
Dual Nvidia RTX 4000 8GB's
2TB Intel Optane PCIe SSD
8TB spinner storage
jonault
Re: Dual Quadro RTX 4000 8GB Pls + dual support.
Post by jonault »
If you have two video cards, you'll need to have two folding slots - one slot per card. AFAIK, F@H doesn't support SLI or any other multi-card hookups.
What does the output of FAHClient --lspci show? Two GPUs?
When a dual GPU is installed, you have to treat them as two different devices. (FAH ignores SLI)
Post the ***SYSTEM*** section from the System_Info tab of FAHControl or from the top of FAH's log
Kevonator11
Kevonator11
Maybe if i run 3 VM's in hyper-V i could have multiple instances running to utilize all my GPU's abilities?
Well, I should have asked for more of FAH's log.
Nevertheless, add a second GPU slot.
Open FAHControl
Configure + Slots + Add + (Select GPU) + OK + Save + ...
Kevonator11
Thanks, Both GPU's already had slots. But for some reason it just doesn't use the second GPU. So for now I have 1 GPU running when Idle with CPU, and 1 GPU running when not idle. What are those folding slot indices and extra slot options for? Anything I could configure there to work the Quadro RTX 4000's a little harder?
Thanks again for all your responses and help.
--Kevin
Welcome to the F@H Forum Kevonator11,
Can you please post your log file. Ensure that you have copied the System configuration which is present at the start of the log file (viewtopic.php?f=2&t=26036). Once we have the log file, we can see how the client is configured and will be able to troubleshoot your issue :)
Kevonator11
01:52:34:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
01:52:34:WU01:FS00:Connecting to 18.218.241.186:80
01:52:35:WU01:FS00:Assigned to work server 13.90.152.57
01:52:35:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:18 from 13.90.152.57
01:52:35:WU01:FS00:Connecting to 13.90.152.57:8080
01:52:35:WU01:FS00:Downloading 4.19MiB
01:52:36:WU01:FS00:Download complete
01:52:36:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13861 run:0 clone:7224 gen:41 core:0xa7 unit:0x000000300d5a98395e730e6632b7e78d
01:52:52:WU00:FS00:0xa7:Completed 62500 out of 62500 steps (100%)
01:52:54:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
01:52:54:WU00:FS00:0xa7:Saving result file frame76.edr
01:52:54:WU00:FS00:0xa7:Saving result file frame76.trr
01:52:54:WU00:FS00:0xa7:Saving result file frame76.xtc
01:52:54:WU00:FS00:0xa7:Saving result file md.log
01:52:54:WU00:FS00:0xa7:Saving result file science.log
01:52:54:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
01:52:55:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:52:55:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13872 run:0 clone:3467 gen:76 core:0xa7 unit:0x000000510d5262775e7bbb2099abf258
01:52:55:WU00:FS00:Uploading 4.74MiB to 13.82.98.119
01:52:55:WU01:FS00:Starting
01:52:55:WU00:FS00:Connecting to 13.82.98.119:8080
01:52:55:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\KevinNorman\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 15344 -checkpoint 15 -np 18
01:52:55:WU01:FS00:Started FahCore on PID 14552
01:52:55:WU01:FS00:Core PID:19124
01:52:55:WU01:FS00:FahCore 0xa7 started
01:52:56:WU01:FS00:0xa7:*********************** Log Started 2020-04-07T01:52:55Z ***********************
01:52:56:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
01:52:56:WU01:FS00:0xa7:       Type: 0xa7
01:52:56:WU01:FS00:0xa7:       Core: Gromacs
01:52:56:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 14552 -checkpoint 15 -np
01:52:56:WU01:FS00:0xa7:             18
01:52:56:WU01:FS00:0xa7:************************************ CBang *************************************
01:52:56:WU01:FS00:0xa7:       Date: Oct 26 2019
01:52:56:WU01:FS00:0xa7:       Time: 01:38:25
01:52:56:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
01:52:56:WU01:FS00:0xa7:     Branch: master
01:52:56:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
01:52:56:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:52:56:WU01:FS00:0xa7:   Platform: win32 10
01:52:56:WU01:FS00:0xa7:       Bits: 64
01:52:56:WU01:FS00:0xa7:       Mode: Release
01:52:56:WU01:FS00:0xa7:************************************ System ************************************
01:52:56:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
01:52:56:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 85 Stepping 7
01:52:56:WU01:FS00:0xa7:       CPUs: 20
01:52:56:WU01:FS00:0xa7:     Memory: 15.71GiB
01:52:56:WU01:FS00:0xa7:Free Memory: 6.23GiB
01:52:56:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
01:52:56:WU01:FS00:0xa7: OS Version: 6.2
01:52:56:WU01:FS00:0xa7:Has Battery: false
01:52:56:WU01:FS00:0xa7: On Battery: false
01:52:56:WU01:FS00:0xa7: UTC Offset: -7
01:52:56:WU01:FS00:0xa7:        PID: 19124
01:52:56:WU01:FS00:0xa7:        CWD: C:\Users\KevinNorman\AppData\Roaming\FAHClient\work
01:52:56:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
01:52:56:WU01:FS00:0xa7:    Version: 0.0.18
01:52:56:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:52:56:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
01:52:56:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
01:52:56:WU01:FS00:0xa7:       Time: 01:52:30
01:52:56:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
01:52:56:WU01:FS00:0xa7:************************************ Build *************************************
01:52:56:WU01:FS00:0xa7:       SIMD: avx_256
01:52:56:WU01:FS00:0xa7:********************************************************************************
01:52:56:WU01:FS00:0xa7:Project: 13861 (Run 0, Clone 7224, Gen 41)
01:52:56:WU01:FS00:0xa7:Unit: 0x000000300d5a98395e730e6632b7e78d
01:52:56:WU01:FS00:0xa7:Reading tar file core.xml
01:52:56:WU01:FS00:0xa7:Reading tar file frame41.tpr
01:52:56:WU01:FS00:0xa7:Digital signatures verified
01:52:56:WU01:FS00:0xa7:Calling: mdrun -s frame41.tpr -o frame41.trr -x frame41.xtc -e frame41.edr -cpt 15 -nt 18
01:52:56:WU01:FS00:0xa7:Steps: first=5125000 total=125000
01:52:57:WU01:FS00:0xa7:Completed 1 out of 125000 steps (0%)
01:53:03:WU00:FS00:Upload complete
01:53:03:WU00:FS00:Server responded WORK_ACK (400)
01:53:03:WU00:FS00:Final credit estimate, 12047.00 points
01:53:03:WU00:FS00:Cleaning up
01:53:15:WU01:FS00:0xa7:Completed 1250 out of 125000 steps (1%)
01:53:34:WU01:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
01:53:53:WU01:FS00:0xa7:Completed 3750 out of 125000 steps (3%)
01:54:12:WU01:FS00:0xa7:Completed 5000 out of 125000 steps (4%)
01:54:30:WU01:FS00:0xa7:Completed 6250 out of 125000 steps (5%)
01:54:49:WU01:FS00:0xa7:Completed 7500 out of 125000 steps (6%)
01:55:08:WU01:FS00:0xa7:Completed 8750 out of 125000 steps (7%)
01:55:26:WU01:FS00:0xa7:Completed 10000 out of 125000 steps (8%)
01:55:45:WU01:FS00:0xa7:Completed 11250 out of 125000 steps (9%)
01:56:04:WU01:FS00:0xa7:Completed 12500 out of 125000 steps (10%)
01:56:22:WU01:FS00:0xa7:Completed 13750 out of 125000 steps (11%)
01:56:41:WU01:FS00:0xa7:Completed 15000 out of 125000 steps (12%)
01:57:00:WU01:FS00:0xa7:Completed 16250 out of 125000 steps (13%)
01:57:19:WU01:FS00:0xa7:Completed 17500 out of 125000 steps (14%)
01:57:37:WU01:FS00:0xa7:Completed 18750 out of 125000 steps (15%)
01:57:56:WU01:FS00:0xa7:Completed 20000 out of 125000 steps (16%)
01:58:15:WU01:FS00:0xa7:Completed 21250 out of 125000 steps (17%)
01:58:33:WU01:FS00:0xa7:Completed 22500 out of 125000 steps (18%)
01:58:52:WU01:FS00:0xa7:Completed 23750 out of 125000 steps (19%)
01:59:11:WU01:FS00:0xa7:Completed 25000 out of 125000 steps (20%)
01:59:30:WU01:FS00:0xa7:Completed 26250 out of 125000 steps (21%)
01:59:48:WU01:FS00:0xa7:Completed 27500 out of 125000 steps (22%)
02:00:07:WU01:FS00:0xa7:Completed 28750 out of 125000 steps (23%)
02:00:26:WU01:FS00:0xa7:Completed 30000 out of 125000 steps (24%)
02:00:45:WU01:FS00:0xa7:Completed 31250 out of 125000 steps (25%)
02:01:03:WU01:FS00:0xa7:Completed 32500 out of 125000 steps (26%)
02:01:22:WU01:FS00:0xa7:Completed 33750 out of 125000 steps (27%)
02:01:41:WU01:FS00:0xa7:Completed 35000 out of 125000 steps (28%)
02:02:00:WU01:FS00:0xa7:Completed 36250 out of 125000 steps (29%)
02:02:18:WU01:FS00:0xa7:Completed 37500 out of 125000 steps (30%)
02:02:37:WU01:FS00:0xa7:Completed 38750 out of 125000 steps (31%)
02:02:56:WU01:FS00:0xa7:Completed 40000 out of 125000 steps (32%)
02:03:15:WU01:FS00:0xa7:Completed 41250 out of 125000 steps (33%)
02:03:33:WU01:FS00:0xa7:Completed 42500 out of 125000 steps (34%)
02:03:52:WU01:FS00:0xa7:Completed 43750 out of 125000 steps (35%)
02:04:11:WU01:FS00:0xa7:Completed 45000 out of 125000 steps (36%)
02:04:29:WU01:FS00:0xa7:Completed 46250 out of 125000 steps (37%)
02:04:48:WU01:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
02:05:07:WU01:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
02:05:25:WU01:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
02:05:44:WU01:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
02:06:03:WU01:FS00:0xa7:Completed 52500 out of 125000 steps (42%)
02:06:22:WU01:FS00:0xa7:Completed 53750 out of 125000 steps (43%)
02:06:41:WU01:FS00:0xa7:Completed 55000 out of 125000 steps (44%)
02:06:59:WU01:FS00:0xa7:Completed 56250 out of 125000 steps (45%)
02:07:18:WU01:FS00:0xa7:Completed 57500 out of 125000 steps (46%)
02:07:37:WU01:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
02:07:56:WU01:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
02:08:15:WU01:FS00:0xa7:Completed 61250 out of 125000 steps (49%)
02:08:33:WU01:FS00:0xa7:Completed 62500 out of 125000 steps (50%)
02:08:52:WU01:FS00:0xa7:Completed 63750 out of 125000 steps (51%)
02:09:11:WU01:FS00:0xa7:Completed 65000 out of 125000 steps (52%)
02:09:29:WU01:FS00:0xa7:Completed 66250 out of 125000 steps (53%)
02:09:48:WU01:FS00:0xa7:Completed 67500 out of 125000 steps (54%)
02:10:07:WU01:FS00:0xa7:Completed 68750 out of 125000 steps (55%)
02:10:26:WU01:FS00:0xa7:Completed 70000 out of 125000 steps (56%)
02:10:44:WU01:FS00:0xa7:Completed 71250 out of 125000 steps (57%)
02:11:03:WU01:FS00:0xa7:Completed 72500 out of 125000 steps (58%)
02:11:22:WU01:FS00:0xa7:Completed 73750 out of 125000 steps (59%)
02:11:41:WU01:FS00:0xa7:Completed 75000 out of 125000 steps (60%)
02:11:59:WU01:FS00:0xa7:Completed 76250 out of 125000 steps (61%)
02:12:18:WU01:FS00:0xa7:Completed 77500 out of 125000 steps (62%)
02:12:37:WU01:FS00:0xa7:Completed 78750 out of 125000 steps (63%)
02:12:56:WU01:FS00:0xa7:Completed 80000 out of 125000 steps (64%)
02:13:14:WU01:FS00:0xa7:Completed 81250 out of 125000 steps (65%)
02:13:33:WU01:FS00:0xa7:Completed 82500 out of 125000 steps (66%)
02:13:52:WU01:FS00:0xa7:Completed 83750 out of 125000 steps (67%)
02:14:11:WU01:FS00:0xa7:Completed 85000 out of 125000 steps (68%)
02:14:29:WU01:FS00:0xa7:Completed 86250 out of 125000 steps (69%)
02:14:48:WU01:FS00:0xa7:Completed 87500 out of 125000 steps (70%)
02:15:07:WU01:FS00:0xa7:Completed 88750 out of 125000 steps (71%)
02:15:25:WU01:FS00:0xa7:Completed 90000 out of 125000 steps (72%)
02:15:44:WU01:FS00:0xa7:Completed 91250 out of 125000 steps (73%)
02:16:03:WU01:FS00:0xa7:Completed 92500 out of 125000 steps (74%)
02:16:22:WU01:FS00:0xa7:Completed 93750 out of 125000 steps (75%)
02:16:40:WU01:FS00:0xa7:Completed 95000 out of 125000 steps (76%)
02:16:59:WU01:FS00:0xa7:Completed 96250 out of 125000 steps (77%)
02:17:18:WU01:FS00:0xa7:Completed 97500 out of 125000 steps (78%)
02:17:36:WU01:FS00:0xa7:Completed 98750 out of 125000 steps (79%)
02:17:55:WU01:FS00:0xa7:Completed 100000 out of 125000 steps (80%)
02:18:14:WU01:FS00:0xa7:Completed 101250 out of 125000 steps (81%)
02:18:33:WU01:FS00:0xa7:Completed 102500 out of 125000 steps (82%)
02:18:51:WU01:FS00:0xa7:Completed 103750 out of 125000 steps (83%)
02:19:10:WU01:FS00:0xa7:Completed 105000 out of 125000 steps (84%)
02:19:29:WU01:FS00:0xa7:Completed 106250 out of 125000 steps (85%)
02:19:48:WU01:FS00:0xa7:Completed 107500 out of 125000 steps (86%)
02:20:06:WU01:FS00:0xa7:Completed 108750 out of 125000 steps (87%)
02:20:25:WU01:FS00:0xa7:Completed 110000 out of 125000 steps (88%)
02:20:44:WU01:FS00:0xa7:Completed 111250 out of 125000 steps (89%)
02:21:03:WU01:FS00:0xa7:Completed 112500 out of 125000 steps (90%)
02:21:21:WU01:FS00:0xa7:Completed 113750 out of 125000 steps (91%)
02:21:40:WU01:FS00:0xa7:Completed 115000 out of 125000 steps (92%)
02:21:59:WU01:FS00:0xa7:Completed 116250 out of 125000 steps (93%)
02:22:18:WU01:FS00:0xa7:Completed 117500 out of 125000 steps (94%)
02:22:36:WU01:FS00:0xa7:Completed 118750 out of 125000 steps (95%)
02:22:55:WU01:FS00:0xa7:Completed 120000 out of 125000 steps (96%)
02:23:14:WU01:FS00:0xa7:Completed 121250 out of 125000 steps (97%)
02:23:33:WU01:FS00:0xa7:Completed 122500 out of 125000 steps (98%)
02:23:52:WU01:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
02:23:52:WU00:FS00:Connecting to 65.254.110.245:8080
02:23:52:WU00:FS00:Assigned to work server 155.247.164.214
02:23:52:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:18 from 155.247.164.214
02:23:52:WU00:FS00:Connecting to 155.247.164.214:8080
02:23:53:ERROR:WU00:FS00:Exception: Server did not assign work unit
02:23:53:WU00:FS00:Connecting to 65.254.110.245:8080
02:23:53:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
02:23:53:WU00:FS00:Connecting to 18.218.241.186:80
02:23:53:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
02:23:53:ERROR:WU00:FS00:Exception: Could not get an assignment
02:24:10:WU01:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
02:24:12:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
02:24:12:WU01:FS00:0xa7:Saving result file frame41.edr
02:24:12:WU01:FS00:0xa7:Saving result file frame41.trr
02:24:12:WU01:FS00:0xa7:Saving result file frame41.xtc
02:24:12:WU01:FS00:0xa7:Saving result file md.log
02:24:12:WU01:FS00:0xa7:Saving result file science.log
02:24:12:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
02:24:13:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:24:13:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13861 run:0 clone:7224 gen:41 core:0xa7 unit:0x000000300d5a98395e730e6632b7e78d
02:24:13:WU01:FS00:Uploading 5.25MiB to 13.90.152.57
02:24:13:WU01:FS00:Connecting to 13.90.152.57:8080
02:24:23:WU01:FS00:Upload complete
02:24:23:WU01:FS00:Server responded WORK_ACK (400)
02:24:23:WU01:FS00:Final credit estimate, 3746.00 points
02:24:23:WU01:FS00:Cleaning up
02:25:40:WU00:FS00:Connecting to 65.254.110.245:8080
02:25:40:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
02:25:40:WU00:FS00:Connecting to 18.218.241.186:80
02:25:41:WU00:FS00:Assigned to work server 155.247.164.213
02:25:41:WU00:FS00:Requesting new work unit for slot 00: READY cpu:18 from 155.247.164.213
02:25:41:WU00:FS00:Connecting to 155.247.164.213:8080
02:25:41:WU00:FS00:Downloading 1.23MiB
02:25:42:WU00:FS00:Download complete
02:25:42:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14198 run:0 clone:620 gen:33 core:0xa7 unit:0x000000249bf7a4d55e66d05bcc129abb
02:25:42:WU00:FS00:Starting
02:25:42:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\KevinNorman\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 15344 -checkpoint 15 -np 18
02:25:42:WU00:FS00:Started FahCore on PID 10740
02:25:42:WU00:FS00:Core PID:20504
02:25:42:WU00:FS00:FahCore 0xa7 started
02:25:42:WU00:FS00:0xa7:*********************** Log Started 2020-04-07T02:25:42Z ***********************
02:25:42:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:25:42:WU00:FS00:0xa7:       Type: 0xa7
02:25:42:WU00:FS00:0xa7:       Core: Gromacs
02:25:42:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 10740 -checkpoint 15 -np
02:25:42:WU00:FS00:0xa7:             18
02:25:42:WU00:FS00:0xa7:************************************ CBang *************************************
02:25:42:WU00:FS00:0xa7:       Date: Oct 26 2019
02:25:42:WU00:FS00:0xa7:       Time: 01:38:25
02:25:42:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
02:25:42:WU00:FS00:0xa7:     Branch: master
02:25:42:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
02:25:42:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:25:42:WU00:FS00:0xa7:   Platform: win32 10
02:25:42:WU00:FS00:0xa7:       Bits: 64
02:25:42:WU00:FS00:0xa7:       Mode: Release
02:25:42:WU00:FS00:0xa7:************************************ System ************************************
02:25:42:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
02:25:42:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 85 Stepping 7
02:25:42:WU00:FS00:0xa7:       CPUs: 20
02:25:42:WU00:FS00:0xa7:     Memory: 15.71GiB
02:25:42:WU00:FS00:0xa7:Free Memory: 6.22GiB
02:25:42:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
02:25:42:WU00:FS00:0xa7: OS Version: 6.2
02:25:42:WU00:FS00:0xa7:Has Battery: false
02:25:42:WU00:FS00:0xa7: On Battery: false
02:25:42:WU00:FS00:0xa7: UTC Offset: -7
02:25:42:WU00:FS00:0xa7:        PID: 20504
02:25:42:WU00:FS00:0xa7:        CWD: C:\Users\KevinNorman\AppData\Roaming\FAHClient\work
02:25:42:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
02:25:42:WU00:FS00:0xa7:    Version: 0.0.18
02:25:42:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:25:42:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
02:25:42:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
02:25:42:WU00:FS00:0xa7:       Time: 01:52:30
02:25:42:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
02:25:42:WU00:FS00:0xa7:************************************ Build *************************************
02:25:42:WU00:FS00:0xa7:       SIMD: avx_256
02:25:42:WU00:FS00:0xa7:********************************************************************************
02:25:42:WU00:FS00:0xa7:Project: 14198 (Run 0, Clone 620, Gen 33)
02:25:42:WU00:FS00:0xa7:Unit: 0x000000249bf7a4d55e66d05bcc129abb
02:25:42:WU00:FS00:0xa7:Reading tar file core.xml
02:25:42:WU00:FS00:0xa7:Reading tar file frame33.tpr
02:25:42:WU00:FS00:0xa7:Digital signatures verified
02:25:42:WU00:FS00:0xa7:Calling: mdrun -s frame33.tpr -o frame33.trr -cpt 15 -nt 18
02:25:42:WU00:FS00:0xa7:Steps: first=16500000 total=500000
02:25:43:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
02:25:58:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
02:26:13:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
02:26:29:WU00:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
02:26:44:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
02:26:59:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
02:27:14:WU00:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
02:27:30:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
02:27:45:WU00:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
02:28:00:WU00:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
02:28:15:WU00:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
02:28:31:WU00:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
02:28:46:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
02:29:01:WU00:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
02:29:16:WU00:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
02:29:32:WU00:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
02:29:47:WU00:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
02:30:02:WU00:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
02:30:17:WU00:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
02:30:32:WU00:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
02:30:48:WU00:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
02:31:03:WU00:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
02:31:18:WU00:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
02:31:33:WU00:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
02:31:49:WU00:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
02:32:04:WU00:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
02:32:19:WU00:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
02:32:34:WU00:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
02:32:50:WU00:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
02:33:05:WU00:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
02:33:20:WU00:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
02:33:36:WU00:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
02:33:51:WU00:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
02:34:06:WU00:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
02:34:21:WU00:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
02:34:37:WU00:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
02:34:52:WU00:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
02:35:07:WU00:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
02:35:22:WU00:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
02:35:38:WU00:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
02:35:53:WU00:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
02:36:08:WU00:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
02:36:23:WU00:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
02:36:38:WU00:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
02:36:54:WU00:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
02:37:09:WU00:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
02:37:24:WU00:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
02:37:40:WU00:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
02:37:55:WU00:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
02:38:10:WU00:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
02:38:25:WU00:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
02:38:40:WU00:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
02:38:56:WU00:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
02:39:11:WU00:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
02:39:26:WU00:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
02:39:42:WU00:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
02:39:57:WU00:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
02:40:12:WU00:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
02:40:27:WU00:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
02:40:42:WU00:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
02:40:58:WU00:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
02:41:13:WU00:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
02:41:28:WU00:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
02:41:44:WU00:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
02:41:59:WU00:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
02:42:14:WU00:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
02:42:29:WU00:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
02:42:44:WU00:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
02:43:00:WU00:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
02:43:15:WU00:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
02:43:30:WU00:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
02:43:45:WU00:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
02:44:01:WU00:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
02:44:16:WU00:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
02:44:31:WU00:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
02:44:46:WU00:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
02:45:02:WU00:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
02:45:17:WU00:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
02:45:32:WU00:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
02:45:47:WU00:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
02:46:02:WU00:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
02:46:18:WU00:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
02:46:33:WU00:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
02:46:48:WU00:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
02:47:04:WU00:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
02:47:19:WU00:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
02:47:34:WU00:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
02:47:49:WU00:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
02:48:04:WU00:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
02:48:20:WU00:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
02:48:35:WU00:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
02:48:51:WU00:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
02:49:06:WU00:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
02:49:21:WU00:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
02:49:36:WU00:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
02:49:51:WU00:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
02:50:07:WU00:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
02:50:22:WU00:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
02:50:37:WU00:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
02:50:53:WU00:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
02:50:53:WU01:FS00:Connecting to 65.254.110.245:8080
02:50:53:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
02:50:53:WU01:FS00:Connecting to 18.218.241.186:80
02:50:54:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
02:50:54:ERROR:WU01:FS00:Exception: Could not get an assignment
02:50:54:WU01:FS00:Connecting to 65.254.110.245:8080
02:50:54:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
02:50:54:WU01:FS00:Connecting to 18.218.241.186:80
02:51:08:WU00:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
02:51:08:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
02:51:08:WU00:FS00:0xa7:Saving result file frame33.trr
02:51:08:WU00:FS00:0xa7:Saving result file md.log
02:51:08:WU00:FS00:0xa7:Saving result file pullf.xvg
02:51:08:WU00:FS00:0xa7:Saving result file pullx.xvg
02:51:08:WU00:FS00:0xa7:Saving result file science.log
02:51:08:WU00:FS00:0xa7:Saving result file traj_comp.xtc
02:51:08:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
02:51:09:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:51:09:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14198 run:0 clone:620 gen:33 core:0xa7 unit:0x000000249bf7a4d55e66d05bcc129abb
02:51:09:WU00:FS00:Uploading 3.20MiB to 155.247.164.213
02:51:09:WU00:FS00:Connecting to 155.247.164.213:8080
02:51:13:WU00:FS00:Upload complete
02:51:14:WU00:FS00:Server responded WORK_ACK (400)
02:51:14:WU00:FS00:Final credit estimate, 3310.00 points
02:51:14:WU00:FS00:Cleaning up
02:51:54:WU01:FS00:Connecting to 65.254.110.245:8080
02:51:54:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
02:51:54:WU01:FS00:Connecting to 18.218.241.186:80
02:51:54:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
02:51:54:ERROR:WU01:FS00:Exception: Could not get an assignment
02:53:31:WU01:FS00:Connecting to 65.254.110.245:8080
02:53:31:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
02:53:31:WU01:FS00:Connecting to 18.218.241.186:80
02:53:32:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
02:53:32:ERROR:WU01:FS00:Exception: Could not get an assignment
02:56:08:WU01:FS00:Connecting to 65.254.110.245:8080
02:56:09:WU01:FS00:Assigned to work server 155.247.164.213
02:56:09:WU01:FS00:Requesting new work unit for slot 00: READY cpu:18 from 155.247.164.213
02:56:09:WU01:FS00:Connecting to 155.247.164.213:8080
02:56:09:WU01:FS00:Downloading 1.24MiB
02:56:10:WU01:FS00:Download complete
02:56:10:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14303 run:7 clone:637 gen:24 core:0xa7 unit:0x0000001b9bf7a4d55e66cb9c34db9fe3
02:56:10:WU01:FS00:Starting
02:56:10:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\KevinNorman\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 15344 -checkpoint 15 -np 18
02:56:10:WU01:FS00:Started FahCore on PID 17860
02:56:10:WU01:FS00:Core PID:17540
02:56:10:WU01:FS00:FahCore 0xa7 started
02:56:10:WU01:FS00:0xa7:*********************** Log Started 2020-04-07T02:56:10Z ***********************
02:56:10:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:56:10:WU01:FS00:0xa7:       Type: 0xa7
02:56:10:WU01:FS00:0xa7:       Core: Gromacs
02:56:10:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 17860 -checkpoint 15 -np
02:56:10:WU01:FS00:0xa7:             18
02:56:10:WU01:FS00:0xa7:************************************ CBang *************************************
02:56:10:WU01:FS00:0xa7:       Date: Oct 26 2019
02:56:10:WU01:FS00:0xa7:       Time: 01:38:25
02:56:10:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
02:56:10:WU01:FS00:0xa7:     Branch: master
02:56:10:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
02:56:10:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:56:10:WU01:FS00:0xa7:   Platform: win32 10
02:56:10:WU01:FS00:0xa7:       Bits: 64
02:56:10:WU01:FS00:0xa7:       Mode: Release
02:56:10:WU01:FS00:0xa7:************************************ System ************************************
02:56:10:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
02:56:10:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 85 Stepping 7
02:56:10:WU01:FS00:0xa7:       CPUs: 20
02:56:10:WU01:FS00:0xa7:     Memory: 15.71GiB
02:56:10:WU01:FS00:0xa7:Free Memory: 6.30GiB
02:56:10:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
02:56:10:WU01:FS00:0xa7: OS Version: 6.2
02:56:10:WU01:FS00:0xa7:Has Battery: false
02:56:10:WU01:FS00:0xa7: On Battery: false
02:56:10:WU01:FS00:0xa7: UTC Offset: -7
02:56:10:WU01:FS00:0xa7:        PID: 17540
02:56:10:WU01:FS00:0xa7:        CWD: C:\Users\KevinNorman\AppData\Roaming\FAHClient\work
02:56:10:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
02:56:10:WU01:FS00:0xa7:    Version: 0.0.18
02:56:10:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:56:10:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
02:56:10:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
02:56:10:WU01:FS00:0xa7:       Time: 01:52:30
02:56:10:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
02:56:10:WU01:FS00:0xa7:************************************ Build *************************************
02:56:10:WU01:FS00:0xa7:       SIMD: avx_256
02:56:10:WU01:FS00:0xa7:********************************************************************************
02:56:10:WU01:FS00:0xa7:Project: 14303 (Run 7, Clone 637, Gen 24)
02:56:10:WU01:FS00:0xa7:Unit: 0x0000001b9bf7a4d55e66cb9c34db9fe3
02:56:10:WU01:FS00:0xa7:Reading tar file core.xml
02:56:10:WU01:FS00:0xa7:Reading tar file frame24.tpr
02:56:10:WU01:FS00:0xa7:Digital signatures verified
02:56:10:WU01:FS00:0xa7:Calling: mdrun -s frame24.tpr -o frame24.trr -cpt 15 -nt 18
02:56:10:WU01:FS00:0xa7:Steps: first=12000000 total=500000
02:56:11:WU01:FS00:0xa7:Completed 1 out of 500000 steps (0%)
02:56:26:WU01:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
02:56:41:WU01:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
02:56:57:WU01:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
02:57:04:WU03:FS02:Connecting to 65.254.110.245:8080
02:57:05:WARNING:WU03:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
02:57:05:WU03:FS02:Connecting to 18.218.241.186:80
02:57:05:WARNING:WU03:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
02:57:05:ERROR:WU03:FS02:Exception: Could not get an assignment
02:57:12:WU01:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
02:57:27:WU01:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
02:57:43:WU01:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
02:57:58:WU01:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
02:58:13:WU01:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
02:58:28:WU01:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
02:58:43:WU01:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
02:58:59:WU01:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
02:59:14:WU01:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
02:59:29:WU01:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
02:59:45:WU01:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
03:00:00:WU01:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
03:00:12:WU02:FS01:Connecting to 65.254.110.245:8080
03:00:12:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:00:12:WU02:FS01:Connecting to 18.218.241.186:80
03:00:12:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:00:12:ERROR:WU02:FS01:Exception: Could not get an assignment
03:00:15:WU01:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
03:00:30:WU01:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
03:00:46:WU01:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
03:01:01:WU01:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
03:01:16:WU01:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
03:01:32:WU01:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
03:01:47:WU01:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
03:02:02:WU01:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
03:02:17:WU01:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
03:02:32:WU01:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
03:02:48:WU01:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
03:03:03:WU01:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
03:03:18:WU01:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
03:03:34:WU01:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
03:03:49:WU01:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
03:04:04:WU01:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
03:04:19:WU01:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
03:04:35:WU01:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
03:04:50:WU01:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
03:05:05:WU01:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
03:05:21:WU01:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
03:05:36:WU01:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
03:05:51:WU01:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
03:06:06:WU01:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
03:06:22:WU01:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
03:06:37:WU01:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
03:06:52:WU01:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
03:07:07:WU01:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
03:07:23:WU01:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
03:07:38:WU01:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
03:07:53:WU01:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
03:08:09:WU01:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
03:08:24:WU01:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
03:08:39:WU01:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
03:08:54:WU01:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
03:09:10:WU01:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
03:09:25:WU01:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
03:09:40:WU01:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
03:09:56:WU01:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
03:10:11:WU01:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
03:10:26:WU01:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
03:10:41:WU01:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
03:10:57:WU01:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
03:11:12:WU01:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
03:11:27:WU01:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
03:11:42:WU01:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
03:11:58:WU01:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
03:12:13:WU01:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
03:12:28:WU01:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
03:12:44:WU01:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
03:12:59:WU01:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
03:13:14:WU01:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
03:13:29:WU01:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
03:13:44:WU01:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
03:14:00:WU01:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
03:14:15:WU01:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
03:14:31:WU01:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
03:14:46:WU01:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
03:15:01:WU01:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
03:15:16:WU01:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
03:15:31:WU01:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
03:15:47:WU01:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
03:16:02:WU01:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
03:16:17:WU01:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
03:16:32:WU01:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
03:16:48:WU01:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
03:17:03:WU01:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
03:17:18:WU01:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
03:17:33:WU01:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
03:17:49:WU01:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
03:18:04:WU01:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
03:18:19:WU01:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
03:18:35:WU01:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
03:18:50:WU01:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
03:19:05:WU01:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
03:19:20:WU01:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
03:19:36:WU01:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
03:19:51:WU01:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
03:20:06:WU01:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
03:20:21:WU01:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
03:20:37:WU01:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
03:20:52:WU01:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
03:21:07:WU01:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
03:21:23:WU01:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
03:21:23:WU00:FS00:Connecting to 65.254.110.245:8080
03:21:23:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:21:23:WU00:FS00:Connecting to 18.218.241.186:80
03:21:23:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:21:23:ERROR:WU00:FS00:Exception: Could not get an assignment
03:21:24:WU00:FS00:Connecting to 65.254.110.245:8080
03:21:24:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:21:24:WU00:FS00:Connecting to 18.218.241.186:80
03:21:24:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:21:24:ERROR:WU00:FS00:Exception: Could not get an assignment
03:21:38:WU01:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
03:21:39:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
03:21:39:WU01:FS00:0xa7:Saving result file frame24.trr
03:21:39:WU01:FS00:0xa7:Saving result file md.log
03:21:39:WU01:FS00:0xa7:Saving result file pullf.xvg
03:21:39:WU01:FS00:0xa7:Saving result file pullx.xvg
03:21:39:WU01:FS00:0xa7:Saving result file science.log
03:21:39:WU01:FS00:0xa7:Saving result file traj_comp.xtc
03:21:39:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
03:21:39:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:21:39:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14303 run:7 clone:637 gen:24 core:0xa7 unit:0x0000001b9bf7a4d55e66cb9c34db9fe3
03:21:39:WU01:FS00:Uploading 3.20MiB to 155.247.164.213
03:21:39:WU01:FS00:Connecting to 155.247.164.213:8080
03:21:44:WU01:FS00:Upload complete
03:21:44:WU01:FS00:Server responded WORK_ACK (400)
03:21:44:WU01:FS00:Final credit estimate, 3305.00 points
03:21:44:WU01:FS00:Cleaning up
03:22:24:WU00:FS00:Connecting to 65.254.110.245:8080
03:22:24:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:22:24:WU00:FS00:Connecting to 18.218.241.186:80
03:22:24:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:22:24:ERROR:WU00:FS00:Exception: Could not get an assignment
03:24:01:WU00:FS00:Connecting to 65.254.110.245:8080
03:24:01:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:24:01:WU00:FS00:Connecting to 18.218.241.186:80
03:24:02:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:24:02:ERROR:WU00:FS00:Exception: Could not get an assignment
03:26:38:WU00:FS00:Connecting to 65.254.110.245:8080
03:26:38:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:26:38:WU00:FS00:Connecting to 18.218.241.186:80
03:26:39:WU00:FS00:Assigned to work server 155.247.164.214
03:26:39:WU00:FS00:Requesting new work unit for slot 00: READY cpu:18 from 155.247.164.214
03:26:39:WU00:FS00:Connecting to 155.247.164.214:8080
03:26:39:WU00:FS00:Downloading 2.83MiB
03:26:40:WU00:FS00:Download complete
03:26:40:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14363 run:389 clone:1 gen:30 core:0xa7 unit:0x000000209bf7a4d65e7c864e96185b69
03:26:40:WU00:FS00:Starting
03:26:40:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\KevinNorman\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 15344 -checkpoint 15 -np 18
03:26:40:WU00:FS00:Started FahCore on PID 20224
03:26:40:WU00:FS00:Core PID:18196
03:26:40:WU00:FS00:FahCore 0xa7 started
03:26:41:WU00:FS00:0xa7:*********************** Log Started 2020-04-07T03:26:40Z ***********************
03:26:41:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:26:41:WU00:FS00:0xa7:       Type: 0xa7
03:26:41:WU00:FS00:0xa7:       Core: Gromacs
03:26:41:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 20224 -checkpoint 15 -np
03:26:41:WU00:FS00:0xa7:             18
03:26:41:WU00:FS00:0xa7:************************************ CBang *************************************
03:26:41:WU00:FS00:0xa7:       Date: Oct 26 2019
03:26:41:WU00:FS00:0xa7:       Time: 01:38:25
03:26:41:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:26:41:WU00:FS00:0xa7:     Branch: master
03:26:41:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
03:26:41:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:26:41:WU00:FS00:0xa7:   Platform: win32 10
03:26:41:WU00:FS00:0xa7:       Bits: 64
03:26:41:WU00:FS00:0xa7:       Mode: Release
03:26:41:WU00:FS00:0xa7:************************************ System ************************************
03:26:41:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
03:26:41:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 85 Stepping 7
03:26:41:WU00:FS00:0xa7:       CPUs: 20
03:26:41:WU00:FS00:0xa7:     Memory: 15.71GiB
03:26:41:WU00:FS00:0xa7:Free Memory: 6.28GiB
03:26:41:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
03:26:41:WU00:FS00:0xa7: OS Version: 6.2
03:26:41:WU00:FS00:0xa7:Has Battery: false
03:26:41:WU00:FS00:0xa7: On Battery: false
03:26:41:WU00:FS00:0xa7: UTC Offset: -7
03:26:41:WU00:FS00:0xa7:        PID: 18196
03:26:41:WU00:FS00:0xa7:        CWD: C:\Users\KevinNorman\AppData\Roaming\FAHClient\work
03:26:41:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
03:26:41:WU00:FS00:0xa7:    Version: 0.0.18
03:26:41:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:26:41:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
03:26:41:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
03:26:41:WU00:FS00:0xa7:       Time: 01:52:30
03:26:41:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:26:41:WU00:FS00:0xa7:************************************ Build *************************************
03:26:41:WU00:FS00:0xa7:       SIMD: avx_256
03:26:41:WU00:FS00:0xa7:********************************************************************************
03:26:41:WU00:FS00:0xa7:Project: 14363 (Run 389, Clone 1, Gen 30)
03:26:41:WU00:FS00:0xa7:Unit: 0x000000209bf7a4d65e7c864e96185b69
03:26:41:WU00:FS00:0xa7:Reading tar file core.xml
03:26:41:WU00:FS00:0xa7:Reading tar file frame30.tpr
03:26:41:WU00:FS00:0xa7:Digital signatures verified
03:26:41:WU00:FS00:0xa7:Calling: mdrun -s frame30.tpr -o frame30.trr -cpt 15 -nt 18
03:26:41:WU00:FS00:0xa7:Steps: first=0 total=250000
03:26:41:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
03:27:19:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
03:27:29:FS00:Shutting core down
03:27:29:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 18196
03:27:29:WU00:FS00:0xa7:Exiting, please wait. . .
03:27:30:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
03:27:30:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
03:27:58:WU00:FS00:Starting
03:27:58:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\KevinNorman\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 15344 -checkpoint 15 -np 18
03:27:58:WU00:FS00:Started FahCore on PID 1664
03:27:58:WU00:FS00:Core PID:18196
03:27:58:WU00:FS00:FahCore 0xa7 started
03:27:58:WU00:FS00:0xa7:*********************** Log Started 2020-04-07T03:27:58Z ***********************
03:27:58:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
03:27:58:WU00:FS00:0xa7:       Type: 0xa7
03:27:58:WU00:FS00:0xa7:       Core: Gromacs
03:27:58:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 1664 -checkpoint 15 -np
03:27:58:WU00:FS00:0xa7:             18
03:27:58:WU00:FS00:0xa7:************************************ CBang *************************************
03:27:58:WU00:FS00:0xa7:       Date: Oct 26 2019
03:27:58:WU00:FS00:0xa7:       Time: 01:38:25
03:27:58:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
03:27:58:WU00:FS00:0xa7:     Branch: master
03:27:58:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
03:27:58:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:27:58:WU00:FS00:0xa7:   Platform: win32 10
03:27:58:WU00:FS00:0xa7:       Bits: 64
03:27:58:WU00:FS00:0xa7:       Mode: Release
03:27:58:WU00:FS00:0xa7:************************************ System ************************************
03:27:58:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
03:27:58:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 85 Stepping 7
03:27:58:WU00:FS00:0xa7:       CPUs: 20
03:27:58:WU00:FS00:0xa7:     Memory: 15.71GiB
03:27:58:WU00:FS00:0xa7:Free Memory: 6.13GiB
03:27:58:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
03:27:58:WU00:FS00:0xa7: OS Version: 6.2
03:27:58:WU00:FS00:0xa7:Has Battery: false
03:27:58:WU00:FS00:0xa7: On Battery: false
03:27:58:WU00:FS00:0xa7: UTC Offset: -7
03:27:58:WU00:FS00:0xa7:        PID: 18196
03:27:58:WU00:FS00:0xa7:        CWD: C:\Users\KevinNorman\AppData\Roaming\FAHClient\work
03:27:58:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
03:27:58:WU00:FS00:0xa7:    Version: 0.0.18
03:27:58:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:27:58:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
03:27:58:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
03:27:58:WU00:FS00:0xa7:       Time: 01:52:30
03:27:58:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
03:27:58:WU00:FS00:0xa7:************************************ Build *************************************
03:27:58:WU00:FS00:0xa7:       SIMD: avx_256
03:27:58:WU00:FS00:0xa7:********************************************************************************
03:27:58:WU00:FS00:0xa7:Project: 14363 (Run 389, Clone 1, Gen 30)
03:27:58:WU00:FS00:0xa7:Unit: 0x000000209bf7a4d65e7c864e96185b69
03:27:58:WU00:FS00:0xa7:Digital signatures verified
03:27:58:WU00:FS00:0xa7:Calling: mdrun -s frame30.tpr -o frame30.trr -cpi state.cpt -cpt 15 -nt 18
03:27:58:WU00:FS00:0xa7:Steps: first=0 total=250000
03:27:59:WU00:FS00:0xa7:Completed 3186 out of 250000 steps (1%)
03:28:04:WU03:FS02:Connecting to 65.254.110.245:8080
03:28:04:WARNING:WU03:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:28:04:WU03:FS02:Connecting to 18.218.241.186:80
03:28:04:WARNING:WU03:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:28:04:ERROR:WU03:FS02:Exception: Could not get an assignment
03:28:23:Removing old file 'configs/config-20200327-045039.xml'
03:28:23:Saving configuration to config.xml
03:28:23:<config>
03:28:23:  <!-- Folding Core -->
03:28:23:  <core-priority v='low'/>
03:28:23:
03:28:23:  <!-- Network -->
03:28:23:  <proxy v=':8080'/>
03:28:23:
03:28:23:  <!-- Slot Control -->
03:28:23:  <pause-on-battery v='false'/>
03:28:23:  <power v='full'/>
03:28:23:
03:28:23:  <!-- User Information -->
03:28:23:  <user v='Kevonator12'/>
03:28:23:
03:28:23:  <!-- Folding Slots -->
03:28:23:  <slot id='0' type='CPU'/>
03:28:23:  <slot id='1' type='GPU'>
03:28:23:    <cuda-index v='0'/>
03:28:23:    <opencl-index v='0'/>
03:28:23:  </slot>
03:28:23:  <slot id='2' type='GPU'/>
03:28:23:</config>
03:28:26:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
03:29:03:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
03:29:40:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
03:29:41:WU03:FS02:Connecting to 65.254.110.245:8080
03:29:41:WARNING:WU03:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:29:41:WU03:FS02:Connecting to 18.218.241.186:80
03:29:41:WARNING:WU03:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:29:41:ERROR:WU03:FS02:Exception: Could not get an assignment
03:30:18:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
03:30:55:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
03:31:32:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
Here are my observations from your log file:
1) The client isn't configured for a passkey. Using of a passkey isn't compulsory but it does allow you to get bonus points once you qualify for it: https://apps.foldingathome.org/getpasskey
2) You have 03:28:23: <pause-on-battery v='false'/> which is slightly weird as I presume that you have a desktop, not a laptop.
3) If your GPUs are working fine, great. However, if not, then this is what I expected the configuration to look like based on this image of yours https://imgur.com/pIeL8VE :
    <cuda-index v='0'/>
  </slot>
    <cuda-index v='1'/>
    <opencl-index v=1'/>
  </slot>
Kevonator11
PantherX,
Thanks for all the help it's working as expected at this time.
1. I created the passkey. I also have 5 computers at home i have added to a team (1124) I invented but not sure if there is a proper method for making a team.
2. The "<pause-on-battery v='false'/>" issue might have been me un-checking the feature to pause on battery, which was enabled by default, even though it's a desktop.
3. All hardware is brand new. It's working with both GPU's. I removed all the slots. And added the GPU's first as 0,1, and the indexing as specified above. Then the CPU default as -1. It seems to be working great on both GPU's at this time. Although still only utilizing 45-50% of the GPU during "copy" operations. Considering these GPU's can perform about 1Teraflop each i would think it wouldn't be unreasonable to let it run at 60-65% without running into thermal issues.
4. Hope to have my RAM upgrade working again with new RAM this week. This might be my only performance limiting factor perhaps it's limiting the GPU's copy operations? Or would that be a RAM limitation of the GPU's themselves?
Once again thanks!
K
PS. I really enjoy being part of the project to fight COVID-19 and in the future other projects. I have read a recent article that over 400,000 new users have joined the effort including some supercomputers, and bitcoin miners creating the worlds largest/fastest supercomputer.
For you point 1., Team 1124 already exists but there's no informations about it : https://stats.foldingathome.org/team/1124
If you want to choose a team, you can start from here : https://stats.foldingathome.org/teams (top 100 displayed) or by searching on that page if a team with the keyword you like exists.
If you want to start your own team, this is where your should go : https://apps.foldingathome.org/team
Kevonator11 wrote:...3. All hardware is brand new. It's working with both GPU's. I removed all the slots. And added the GPU's first as 0,1, and the indexing as specified above. Then the CPU default as -1. It seems to be working great on both GPU's at this time. Although still only utilizing 45-50% of the GPU during "copy" operations. Considering these GPU's can perform about 1Teraflop each i would think it wouldn't be unreasonable to let it run at 60-65% without running into thermal issues.
4. Hope to have my RAM upgrade working again with new RAM this week. This might be my only performance limiting factor perhaps it's limiting the GPU's copy operations? Or would that be a RAM limitation of the GPU's themselves?...
Glad to hear that your GPUs and CPU are folding without issues :)
I am guessing that you're using Task Manager to view the GPU utilization? If yes, then the Task Manager is only showing part of the picture. Folding uses CUDA cores which is one component of the GPU, it will not use Video Encoding/Decoding, etc. Have a look at this thread to see how 40% GPU usage is actually ~97% CUDA utilization: viewtopic.php?f=101&t=33810
You can use other tools to monitor GPU utilization such as GPU-Z: https://www.techpowerup.com/download/techpowerup-gpu-z/
Do note that your RAM limitation will not impact your GPU performance. RAM will impact overall system stability if it is defective or unstable.
Kevonator11
PantherX,
Thanks for all the input. I have noticed since my last post the CUDA cores on both GPUs are @ almost 99%.
I have the new RAM installed with 32GB total system seems very stable even with full CPU utilization during folding. Although it wasn't unstable before it just was getting close to maxing out the RAM while i was working.
Thanks again,
K
