Unable to process on NVIDIA GeForce GTX 750 Ti
jetchko.jekov
Post by jetchko.jekov »
What would be the problem with my GPU?
If it is not supported why is it included in GPU.txt?
15:59:32:WU02:FS01:Assigned to work server 140.163.4.231
15:59:32:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] 1306 from 140.163.4.231
15:59:32:WU02:FS01:Connecting to 140.163.4.231:8080
16:00:57:WU02:FS01:Downloading 7.92MiB
16:01:03:WU02:FS01:Download 40.24%
16:01:10:WU02:FS01:Download 88.37%
16:01:11:WU02:FS01:Download complete
16:01:11:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11751 run:0 clone:1562 gen:8 core:0x22 unit:0x000000138ca304e75e6a80415b0431b2
16:01:11:WU02:FS01:Starting
16:01:11:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 02 -suffix 01 -version 705 -lifeline 1305 -checkpoint 30 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
16:01:11:WU02:FS01:Started FahCore on PID 33310
16:01:11:WU02:FS01:Core PID:33314
16:01:11:WU02:FS01:FahCore 0x22 started
16:01:11:WU02:FS01:0x22:*********************** Log Started 2020-03-25T16:01:11Z ***********************
16:01:11:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
16:01:11:WU02:FS01:0x22:       Type: 0x22
16:01:11:WU02:FS01:0x22:       Core: Core22
16:01:11:WU02:FS01:0x22:    Website: https://foldingathome.org/
16:01:11:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
16:01:11:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
16:01:11:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
16:01:11:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 33310 -checkpoint 30
16:01:11:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
16:01:11:WU02:FS01:0x22:     Config: <none>
16:01:11:WU02:FS01:0x22:************************************ Build *************************************
16:01:11:WU02:FS01:0x22:    Version: 0.0.2
16:01:11:WU02:FS01:0x22:       Date: Dec 6 2019
16:01:11:WU02:FS01:0x22:       Time: 21:20:17
16:01:11:WU02:FS01:0x22: Repository: Git
16:01:11:WU02:FS01:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
16:01:11:WU02:FS01:0x22:     Branch: core22
16:01:11:WU02:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
16:01:11:WU02:FS01:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
16:01:11:WU02:FS01:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
16:01:11:WU02:FS01:0x22:       Bits: 64
16:01:11:WU02:FS01:0x22:       Mode: Release
16:01:11:WU02:FS01:0x22:************************************ System ************************************
16:01:11:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
16:01:11:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
16:01:11:WU02:FS01:0x22:       CPUs: 8
16:01:11:WU02:FS01:0x22:     Memory: 15.57GiB
16:01:11:WU02:FS01:0x22:Free Memory: 7.46GiB
16:01:11:WU02:FS01:0x22:    Threads: POSIX_THREADS
16:01:11:WU02:FS01:0x22: OS Version: 5.5
16:01:11:WU02:FS01:0x22:Has Battery: false
16:01:11:WU02:FS01:0x22: On Battery: false
16:01:11:WU02:FS01:0x22: UTC Offset: 1
16:01:11:WU02:FS01:0x22:        PID: 33314
16:01:11:WU02:FS01:0x22:        CWD: /var/lib/fahclient/work
16:01:11:WU02:FS01:0x22:         OS: Linux 5.5.10-200.fc31.x86_64 x86_64
16:01:11:WU02:FS01:0x22:    OS Arch: AMD64
16:01:11:WU02:FS01:0x22:********************************************************************************
16:01:11:WU02:FS01:0x22:Project: 11751 (Run 0, Clone 1562, Gen 8)
16:01:11:WU02:FS01:0x22:Unit: 0x000000138ca304e75e6a80415b0431b2
16:01:11:WU02:FS01:0x22:Reading tar file core.xml
16:01:11:WU02:FS01:0x22:Reading tar file integrator.xml
16:01:11:WU02:FS01:0x22:Reading tar file state.xml
16:01:13:WU02:FS01:0x22:Reading tar file system.xml
16:01:13:WU02:FS01:0x22:Digital signatures verified
16:01:13:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
16:01:13:WU02:FS01:0x22:Version 0.0.2
16:01:13:WU02:FS01:0x22:ERROR:126: Bad platformId size.
16:01:13:WU02:FS01:0x22:Saving result file ../logfile_01.txt
16:01:13:WU02:FS01:0x22:Saving result file science.log
16:01:13:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
16:01:13:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
16:01:13:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11751 run:0 clone:1562 gen:8 core:0x22 unit:0x000000138ca304e75e6a80415b0431b2
16:01:13:WU02:FS01:Uploading 2.38KiB to 140.163.4.231
Re: Unable to process on NVIDIA GeForce GTX 750 Ti
Something is wrong with your OpenCL installation. Do not use Mesa or nouveau drivers, use those provided by nVidia.
jetchko.jekov
OK, thanks.
After some googling, I managed to fix my problem.
