Unable to process on NVIDIA GeForce GTX 750 Ti
jetchko.jekov
Post by jetchko.jekov »
Can someone explain what is happening here and why can't I use my NVIDIA GPU for folding?
Ever after installing F@H I am unable to run any WU on this GPU and in the logs, I see this (many times over):
15:59:32:WU02:FS01:Assigned to work server 140.163.4.231
15:59:32:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM107 [GeForce GTX 750 Ti] 1306 from 140.163.4.231
15:59:32:WU02:FS01:Connecting to 140.163.4.231:8080
16:00:57:WU02:FS01:Downloading 7.92MiB
16:01:03:WU02:FS01:Download 40.24%
16:01:10:WU02:FS01:Download 88.37%
16:01:11:WU02:FS01:Download complete
16:01:11:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11751 run:0 clone:1562 gen:8 core:0x22 unit:0x000000138ca304e75e6a80415b0431b2
16:01:11:WU02:FS01:Starting
16:01:11:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 02 -suffix 01 -version 705 -lifeline 1305 -checkpoint 30 -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
16:01:11:WU02:FS01:Started FahCore on PID 33310
16:01:11:WU02:FS01:Core PID:33314
16:01:11:WU02:FS01:FahCore 0x22 started
16:01:11:WU02:FS01:0x22:*********************** Log Started 2020-03-25T16:01:11Z ***********************
16:01:11:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
16:01:11:WU02:FS01:0x22:       Type: 0x22
16:01:11:WU02:FS01:0x22:       Core: Core22
16:01:11:WU02:FS01:0x22:    Website: https://foldingathome.org/
16:01:11:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
16:01:11:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
16:01:11:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
16:01:11:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 33310 -checkpoint 30
16:01:11:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-device 0 -cuda-device 0 -gpu 0
16:01:11:WU02:FS01:0x22:     Config: <none>
16:01:11:WU02:FS01:0x22:************************************ Build *************************************
16:01:11:WU02:FS01:0x22:    Version: 0.0.2
16:01:11:WU02:FS01:0x22:       Date: Dec 6 2019
16:01:11:WU02:FS01:0x22:       Time: 21:20:17
16:01:11:WU02:FS01:0x22: Repository: Git
16:01:11:WU02:FS01:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
16:01:11:WU02:FS01:0x22:     Branch: core22
16:01:11:WU02:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
16:01:11:WU02:FS01:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
16:01:11:WU02:FS01:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
16:01:11:WU02:FS01:0x22:       Bits: 64
16:01:11:WU02:FS01:0x22:       Mode: Release
16:01:11:WU02:FS01:0x22:************************************ System ************************************
16:01:11:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
16:01:11:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
16:01:11:WU02:FS01:0x22:       CPUs: 8
16:01:11:WU02:FS01:0x22:     Memory: 15.57GiB
16:01:11:WU02:FS01:0x22:Free Memory: 7.46GiB
16:01:11:WU02:FS01:0x22:    Threads: POSIX_THREADS
16:01:11:WU02:FS01:0x22: OS Version: 5.5
16:01:11:WU02:FS01:0x22:Has Battery: false
16:01:11:WU02:FS01:0x22: On Battery: false
16:01:11:WU02:FS01:0x22: UTC Offset: 1
16:01:11:WU02:FS01:0x22:        PID: 33314
16:01:11:WU02:FS01:0x22:        CWD: /var/lib/fahclient/work
16:01:11:WU02:FS01:0x22:         OS: Linux 5.5.10-200.fc31.x86_64 x86_64
16:01:11:WU02:FS01:0x22:    OS Arch: AMD64
16:01:11:WU02:FS01:0x22:********************************************************************************
16:01:11:WU02:FS01:0x22:Project: 11751 (Run 0, Clone 1562, Gen 8)
16:01:11:WU02:FS01:0x22:Unit: 0x000000138ca304e75e6a80415b0431b2
16:01:11:WU02:FS01:0x22:Reading tar file core.xml
16:01:11:WU02:FS01:0x22:Reading tar file integrator.xml
16:01:11:WU02:FS01:0x22:Reading tar file state.xml
16:01:13:WU02:FS01:0x22:Reading tar file system.xml
16:01:13:WU02:FS01:0x22:Digital signatures verified
16:01:13:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
16:01:13:WU02:FS01:0x22:Version 0.0.2
16:01:13:WU02:FS01:0x22:ERROR:126: Bad platformId size.
16:01:13:WU02:FS01:0x22:Saving result file ../logfile_01.txt
16:01:13:WU02:FS01:0x22:Saving result file science.log
16:01:13:WU02:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
16:01:13:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
16:01:13:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11751 run:0 clone:1562 gen:8 core:0x22 unit:0x000000138ca304e75e6a80415b0431b2
16:01:13:WU02:FS01:Uploading 2.38KiB to 140.163.4.231
snapshot
Re: Unable to process on NVIDIA GeForce GTX 750 Ti
Post by snapshot »
This is the failure line and I'd guess it's a GPU driver problem, mis-reporting what your GPU is. Hopefully, someone more knowledgeable about Linux will be along shortly.
jonault
Post by jonault »
Which video drivers are you using? AIUI, you have to be using the closed source drivers from the vendor, not the open source ones.
jetchko.jekov
Oh, sorry I cross-posted it here by mistake.
Anyway, thanks. I managed to fix my problem.
Jertzuu
Hardware configuration: Ryzen 5 2600 @ 4,1GHz
G.Skill Trident Z RGB 3200mHz CL14 32Gb
Asus Prime X470-PRO
Zotac AMP! Extreme 1080 Ti
Samsung Evo 970 250Gb NVMe M.2
Samsung Evo 860 500Gb SSD
WD Black 1Tb 7200RPM HDD
Post by Jertzuu »
jetchko.jekov wrote:Oh, sorry I cross-posted it here by mistake.
What was the fix?
