I was sloppy setting up my workstations and now wish to standardize my Team Name and Team Number across all stations.
I unknowingly assigned my Team Number to a value already in use.
What does do to my accumulated stats if I update my identity?
Team Name Number Change
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
Re: Team Name Number Change
Hi and welcome to the forum!
F@h can't move stats from one team to the other so the older points will stay on the other team. Once you change the team number in the software, your points will go to your team from that point on. I'd also recommend that you get a passkey to help you get bonus points too.
henrik.oppermann
After changing my team number in the client, my stats page (the one that opens after clicking on the user name in the client) shows only the last stats for the old team before the change.
When I click on the total score link in the stats page I get a certification-jpg showing the correct total amounts of WUs I have done. So it still counts my work now for the new team, but it doesn't show the correct score and WU numbers on the stats page. It doesn't show the new team either.
Any ideas on this? Thank you!
