Connection issues
MobileGamesMotion
Hardware configuration: Windows 7, Intel i7-6600U CPU on a laptop
Connection issues
Post by MobileGamesMotion »
I tried to use http://fahmm.net/faq.html, and I had to quit and re-open fahclient. Now it continually says Connecting Inactive. Is it having trouble connecting to the overloaded servers?
here is my log but it was made before I restarted
*********************** Log Started 2020-03-25T02:10:42Z ***********************
02:10:42:************************* Folding@home Client *************************
02:10:42:        Website: https://foldingathome.org/
02:10:42:      Copyright: (c) 2009-2018 foldingathome.org
02:10:42:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:10:42:           Args:
02:10:42:         Config: C:\Users\Jing Li\AppData\Roaming\FAHClient\config.xml
02:10:42:******************************** Build ********************************
02:10:42:        Version: 7.5.1
02:10:42:           Date: May 11 2018
02:10:42:           Time: 13:06:32
02:10:42:     Repository: Git
02:10:42:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
02:10:42:         Branch: master
02:10:42:       Compiler: Visual C++ 2008
02:10:42:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:10:42:       Platform: win32 10
02:10:42:           Bits: 32
02:10:42:           Mode: Release
02:10:42:******************************* System ********************************
02:10:42:            CPU: Intel(R) Core(TM) i7-6600U CPU @ 2.60GHz
02:10:42:         CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
02:10:42:           CPUs: 4
02:10:42:         Memory: 7.88GiB
02:10:42:    Free Memory: 3.42GiB
02:10:42:        Threads: WINDOWS_THREADS
02:10:42:     OS Version: 6.1
02:10:42:    Has Battery: true
02:10:42:     On Battery: false
02:10:42:     UTC Offset: -6
02:10:42:            PID: 15096
02:10:42:            CWD: C:\Users\Jing Li\AppData\Roaming\FAHClient
02:10:42:             OS: Windows 7 Professional
02:10:42:        OS Arch: AMD64
02:10:42:           GPUs: 0
02:10:42:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
02:10:42:                 specified module could not be found.
02:10:42:
02:10:42:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.0 Driver:21.20
02:10:42:  Win32 Service: false
02:10:42:***********************************************************************
02:10:42:<config>
02:10:42:  <!-- Folding Core -->
02:10:42:  <checkpoint v='10'/>
02:10:42:
02:10:42:  <!-- HTTP Server -->
02:10:42:  <allow v='192.168.0.0-192.168.0.225'/>
02:10:42:
02:10:42:  <!-- Network -->
02:10:42:  <proxy v=':8080'/>
02:10:42:
02:10:42:  <!-- Remote Command Server -->
02:10:42:  <command-allow-no-pass v='192.168.0.0-192.168.0.225'/>
02:10:42:  <command-port v='36329'/>
02:10:42:  <password v='*****'/>
02:10:42:
02:10:42:  <!-- Slot Control -->
02:10:42:  <power v='full'/>
02:10:42:
02:10:42:  <!-- User Information -->
02:10:42:  <passkey v='********************************'/>
02:10:42:  <team v='223518'/>
02:10:42:  <user v='MobileGamesMotionYT'/>
02:10:42:
02:10:42:  <!-- Folding Slots -->
02:10:42:  <slot id='0' type='CPU'>
02:10:42:    <next-unit-percentage v='95'/>
02:10:42:  </slot>
02:10:42:</config>
02:10:42:Trying to access database...
02:10:42:Successfully acquired database lock
02:10:42:Enabled folding slot 00: READY cpu:4
02:10:42:WU00:FS00:Starting
02:10:42:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\Jing Li\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe" -dir 00 -suffix 01 -version 705 -lifeline 15096 -checkpoint 10 -np 4
02:10:42:WU00:FS00:Started FahCore on PID 14756
02:10:42:WU00:FS00:Core PID:3732
02:10:42:WU00:FS00:FahCore 0xa7 started
02:10:43:WU00:FS00:0xa7:*********************** Log Started 2020-03-25T02:10:42Z ***********************
02:10:43:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:10:43:WU00:FS00:0xa7:       Type: 0xa7
02:10:43:WU00:FS00:0xa7:       Core: Gromacs
02:10:43:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 14756 -checkpoint 10 -np
02:10:43:WU00:FS00:0xa7:             4
02:10:43:WU00:FS00:0xa7:************************************ CBang *************************************
02:10:43:WU00:FS00:0xa7:       Date: Oct 26 2019
02:10:43:WU00:FS00:0xa7:       Time: 01:38:25
02:10:43:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
02:10:43:WU00:FS00:0xa7:     Branch: master
02:10:43:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
02:10:43:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:10:43:WU00:FS00:0xa7:   Platform: win32 10
02:10:43:WU00:FS00:0xa7:       Bits: 64
02:10:43:WU00:FS00:0xa7:       Mode: Release
02:10:43:WU00:FS00:0xa7:************************************ System ************************************
02:10:43:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-6600U CPU @ 2.60GHz
02:10:43:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
02:10:43:WU00:FS00:0xa7:       CPUs: 4
02:10:43:WU00:FS00:0xa7:     Memory: 7.88GiB
02:10:43:WU00:FS00:0xa7:Free Memory: 3.39GiB
02:10:43:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
02:10:43:WU00:FS00:0xa7: OS Version: 6.1
02:10:43:WU00:FS00:0xa7:Has Battery: true
02:10:43:WU00:FS00:0xa7: On Battery: false
02:10:43:WU00:FS00:0xa7: UTC Offset: -6
02:10:43:WU00:FS00:0xa7:        PID: 3732
02:10:43:WU00:FS00:0xa7:        CWD: C:\Users\Jing Li\AppData\Roaming\FAHClient\work
02:10:43:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
02:10:43:WU00:FS00:0xa7:    Version: 0.0.18
02:10:43:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:10:43:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
02:10:43:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
02:10:43:WU00:FS00:0xa7:       Time: 01:52:30
02:10:43:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
02:10:43:WU00:FS00:0xa7:************************************ Build *************************************
02:10:43:WU00:FS00:0xa7:       SIMD: avx_256
02:10:43:WU00:FS00:0xa7:********************************************************************************
02:10:43:WU00:FS00:0xa7:Project: 14307 (Run 2, Clone 956, Gen 31)
02:10:43:WU00:FS00:0xa7:Unit: 0x000000239bf7a4d55e66c59151aeb5cd
02:10:43:WU00:FS00:0xa7:Digital signatures verified
02:10:43:WU00:FS00:0xa7:Calling: mdrun -s frame31.tpr -o frame31.trr -cpi state.cpt -cpt 10 -nt 4
02:10:43:WU00:FS00:0xa7:Steps: first=15500000 total=500000
02:10:43:WU00:FS00:0xa7:Completed 86832 out of 500000 steps (17%)
02:11:45:WU00:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
02:13:23:WU00:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
02:15:03:WU00:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
02:16:34:WU00:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
02:18:19:WU00:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
02:20:18:WU00:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
02:22:15:WU00:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
02:24:37:WU00:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
02:26:20:WU00:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
#StayAtHome #AlertNotAnxious #FoldForCOVID :) :idea: :egeek:
Basic help stuff:viewtopic.php?f=61&t=26036 | Find Your Stats:https://stats.foldingathome.org/donors
https://folding.extremeoverclocking.com/
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Re: Connection issues
Post by Jesse_V »
Put 127.0.0.1 back into the HTTP Server section. It should also be a whiltelisted IP address so that the Web Control or FAHControl programs can connect to the FAHClient on the same computer.
Did you change the port intentionally, the default port is 36330, and the log shows it set to 36329.
MobileGamesMotion
No, I didn't touch the port when I was setting up FAHMM and I made sure it was 36330
I rechecked my log and here is what I got
*********************** Log Started 2020-03-25T15:13:16Z ***********************
15:13:16:************************* Folding@home Client *************************
15:13:16:        Website: https://foldingathome.org/
15:13:16:      Copyright: (c) 2009-2018 foldingathome.org
15:13:16:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:13:16:           Args:
15:13:16:         Config: C:\Users\Jing Li\AppData\Roaming\FAHClient\config.xml
15:13:16:******************************** Build ********************************
15:13:16:        Version: 7.5.1
15:13:16:           Date: May 11 2018
15:13:16:           Time: 13:06:32
15:13:16:     Repository: Git
15:13:16:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
15:13:16:         Branch: master
15:13:16:       Compiler: Visual C++ 2008
15:13:16:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:13:16:       Platform: win32 10
15:13:16:           Bits: 32
15:13:16:           Mode: Release
15:13:16:******************************* System ********************************
15:13:16:            CPU: Intel(R) Core(TM) i7-6600U CPU @ 2.60GHz
15:13:16:         CPU ID: GenuineIntel Family 6 Model 78 Stepping 3
15:13:16:           CPUs: 4
15:13:16:         Memory: 7.88GiB
15:13:16:    Free Memory: 2.89GiB
15:13:16:        Threads: WINDOWS_THREADS
15:13:16:     OS Version: 6.1
15:13:16:    Has Battery: true
15:13:16:     On Battery: false
15:13:16:     UTC Offset: -6
15:13:16:            PID: 10444
15:13:16:            CWD: C:\Users\Jing Li\AppData\Roaming\FAHClient
15:13:16:             OS: Windows 7 Professional
15:13:16:        OS Arch: AMD64
15:13:16:           GPUs: 0
15:13:16:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
15:13:16:                 specified module could not be found.
15:13:16:
15:13:16:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.0 Driver:21.20
15:13:16:  Win32 Service: false
15:13:16:***********************************************************************
15:13:16:<config>
15:13:16:  <!-- Folding Core -->
15:13:16:  <checkpoint v='10'/>
15:13:16:
15:13:16:  <!-- HTTP Server -->
15:13:16:  <allow v='192.168.0.0-192.168.0.225'/>
15:13:16:
15:13:16:  <!-- Network -->
15:13:16:  <proxy v=':8080'/>
15:13:16:
15:13:16:  <!-- Remote Command Server -->
15:13:16:  <command-allow-no-pass v='192.168.0.0-192.168.0.225'/>
15:13:16:  <command-port v='36329'/>
15:13:16:  <password v='*****'/>
15:13:16:
15:13:16:  <!-- Slot Control -->
15:13:16:  <power v='full'/>
15:13:16:
15:13:16:  <!-- User Information -->
15:13:16:  <passkey v='********************************'/>
15:13:16:  <team v='223518'/>
15:13:16:  <user v='MobileGamesMotionYT'/>
15:13:16:
15:13:16:  <!-- Folding Slots -->
15:13:16:  <slot id='0' type='CPU'>
15:13:16:    <next-unit-percentage v='95'/>
15:13:16:  </slot>
15:13:16:</config>
15:13:16:Trying to access database...
15:13:16:Successfully acquired database lock
15:13:16:Enabled folding slot 00: READY cpu:4
15:13:17:WU00:FS00:Connecting to 65.254.110.245:8080
15:13:18:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:13:18:WU00:FS00:Connecting to 18.218.241.186:80
15:13:19:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:13:19:ERROR:WU00:FS00:Exception: Could not get an assignment
15:13:19:WU00:FS00:Connecting to 65.254.110.245:8080
15:13:19:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:13:19:WU00:FS00:Connecting to 18.218.241.186:80
15:13:20:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:13:20:ERROR:WU00:FS00:Exception: Could not get an assignment
Can you tel me how to change it back as in advanced control, in configure it says the port is 36330? I did check config.xml and the port is 36329, but it opens in a web browser. Wait, would it work if I opened it with notepad++?
MobileGamesMotion
Now it says updating. Its been 30 mins and it is still updating
You may need to reboot to restart the client process and have it reread the config.xml file. Notepad++ should be okay as long as it save the files in the same format including line endings. Used too many different editors to remember which cause problems by changing the format on a save, the file might look right by sight, but not be readable by the software.
As for changing the port number, it is possible to do it accidentally. It is set in a small window with up/down arrows to change the number, so you could have accidentally clicked the down one.
MobileGamesMotion
Sorry for not getting back! I did some research and did use notepad++ to fix the port and HTML address, and deleted config.xml, which solved the problem and it started folding. But man have I been having problems since joining F@H. Probably because I'm really young and really curious about stuff? :lol: :ewink:
