Randomly getting base credit (9405) on COVID-19 projects
MrFrizzy
Post by MrFrizzy »
I've logged three separate occasions where I have received base credit for 3 different projects when I have completed them within an hour or two of being assigned. All three of these projects I have had other successful runs on with the proper points awarded so it isn't something that is repeating.
Is there something on my end I can do about this, or is it something with the servers getting hammered lately?
March 18th - 11743 (Run 0, Clone 2319, Gen 4)
15:55:01:WU00:FS01:Connecting to 18.218.241.186:80
15:55:02:WU00:FS01:Assigned to work server 140.163.4.241
15:55:02:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 140.163.4.241
15:55:02:WU00:FS01:Connecting to 140.163.4.241:8080
15:55:37:WU01:FS01:Upload 1.06%
15:55:43:WU01:FS01:Upload 14.25%
15:55:49:WU01:FS01:Upload 42.22%
15:55:55:WU01:FS01:Upload 74.93%
15:55:58:WU00:FS01:Downloading 4.52MiB
15:56:05:WU00:FS01:Download 22.14%
15:56:10:WU01:FS01:Upload complete
15:56:10:WU01:FS01:Server responded WORK_ACK (400)
15:56:10:WU01:FS01:Cleaning up
15:56:11:WU00:FS01:Download 66.42%
15:56:17:WU00:FS01:Download 94.09%
15:56:17:WU00:FS01:Download complete
15:56:17:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11743 run:0 clone:2319 gen:4 core:0x22 unit:0x0000000a8ca304f15e67e43c1a0b3209
15:56:17:WU00:FS01:Starting
15:56:17:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\tfriz\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/beta/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 2136 -checkpoint 5 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
15:56:17:WU00:FS01:Started FahCore on PID 9556
15:56:17:WU00:FS01:Core PID:13408
15:56:17:WU00:FS01:FahCore 0x22 started
15:56:17:WU00:FS01:0x22:*********************** Log Started 2020-03-18T15:56:17Z ***********************
15:56:17:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:56:17:WU00:FS01:0x22:       Type: 0x22
15:56:17:WU00:FS01:0x22:       Core: Core22
15:56:17:WU00:FS01:0x22:    Website: https://foldingathome.org/
15:56:17:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
15:56:17:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:56:17:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
15:56:17:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 9556 -checkpoint 5
15:56:17:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
15:56:17:WU00:FS01:0x22:     Config: <none>
15:56:17:WU00:FS01:0x22:************************************ Build *************************************
15:56:17:WU00:FS01:0x22:    Version: 0.0.2
15:56:17:WU00:FS01:0x22:       Date: Dec 6 2019
15:56:17:WU00:FS01:0x22:       Time: 21:30:31
15:56:17:WU00:FS01:0x22: Repository: Git
15:56:17:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
15:56:17:WU00:FS01:0x22:     Branch: HEAD
15:56:17:WU00:FS01:0x22:   Compiler: Visual C++ 2008
15:56:17:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:56:17:WU00:FS01:0x22:   Platform: win32 10
15:56:17:WU00:FS01:0x22:       Bits: 64
15:56:17:WU00:FS01:0x22:       Mode: Release
15:56:17:WU00:FS01:0x22:************************************ System ************************************
15:56:17:WU00:FS01:0x22:        CPU: AMD Ryzen 5 3600 6-Core Processor
15:56:17:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
15:56:17:WU00:FS01:0x22:       CPUs: 12
15:56:17:WU00:FS01:0x22:     Memory: 15.95GiB
15:56:17:WU00:FS01:0x22:Free Memory: 9.17GiB
15:56:17:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
15:56:17:WU00:FS01:0x22: OS Version: 6.2
15:56:17:WU00:FS01:0x22:Has Battery: false
15:56:17:WU00:FS01:0x22: On Battery: false
15:56:17:WU00:FS01:0x22: UTC Offset: -5
15:56:17:WU00:FS01:0x22:        PID: 13408
15:56:17:WU00:FS01:0x22:        CWD: C:\Users\tfriz\AppData\Roaming\FAHClient\work
15:56:17:WU00:FS01:0x22:         OS: Windows 10 Pro
15:56:17:WU00:FS01:0x22:    OS Arch: AMD64
15:56:17:WU00:FS01:0x22:********************************************************************************
15:56:17:WU00:FS01:0x22:Project: 11743 (Run 0, Clone 2319, Gen 4)
15:56:17:WU00:FS01:0x22:Unit: 0x0000000a8ca304f15e67e43c1a0b3209
15:56:17:WU00:FS01:0x22:Reading tar file core.xml
15:56:17:WU00:FS01:0x22:Reading tar file integrator.xml
15:56:17:WU00:FS01:0x22:Reading tar file state.xml
15:56:18:WU00:FS01:0x22:Reading tar file system.xml
15:56:18:WU00:FS01:0x22:Digital signatures verified
15:56:18:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:56:18:WU00:FS01:0x22:Version 0.0.2
15:56:41:WU00:FS01:0x22:Completed 0 out of 2000000 steps (0%)
15:56:41:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:57:52:WU00:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
15:59:02:WU00:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
16:00:14:WU00:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
16:01:23:WU00:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
16:02:33:WU00:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
16:03:45:WU00:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
16:04:55:WU00:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
16:06:07:WU00:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
16:07:17:WU00:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
16:08:27:WU00:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
16:09:39:WU00:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
16:10:49:WU00:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
16:12:01:WU00:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
16:13:11:WU00:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
16:14:21:WU00:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
16:15:33:WU00:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
16:16:43:WU00:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
16:17:55:WU00:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
16:19:05:WU00:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
16:20:15:WU00:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
16:21:27:WU00:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
16:22:37:WU00:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
16:23:48:WU00:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
16:24:58:WU00:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
16:26:08:WU00:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
16:27:20:WU00:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
16:28:30:WU00:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
16:29:42:WU00:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
16:30:52:WU00:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
16:32:02:WU00:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
16:33:14:WU00:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
16:34:24:WU00:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
16:35:36:WU00:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
16:36:46:WU00:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
16:37:57:WU00:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
16:39:09:WU00:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
16:40:19:WU00:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
16:41:31:WU00:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
16:42:41:WU00:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
16:43:51:WU00:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
16:45:03:WU00:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
16:46:13:WU00:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
16:47:25:WU00:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
16:48:36:WU00:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
16:49:46:WU00:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
16:50:58:WU00:FS01:0x22:Completed 920000 out of 2000000 steps (46%)
16:52:09:WU00:FS01:0x22:Completed 940000 out of 2000000 steps (47%)
16:53:21:WU00:FS01:0x22:Completed 960000 out of 2000000 steps (48%)
16:54:31:WU00:FS01:0x22:Completed 980000 out of 2000000 steps (49%)
16:55:41:WU00:FS01:0x22:Completed 1000000 out of 2000000 steps (50%)
16:56:53:WU00:FS01:0x22:Completed 1020000 out of 2000000 steps (51%)
16:58:03:WU00:FS01:0x22:Completed 1040000 out of 2000000 steps (52%)
16:59:15:WU00:FS01:0x22:Completed 1060000 out of 2000000 steps (53%)
17:00:24:WU00:FS01:0x22:Completed 1080000 out of 2000000 steps (54%)
17:01:34:WU00:FS01:0x22:Completed 1100000 out of 2000000 steps (55%)
17:02:46:WU00:FS01:0x22:Completed 1120000 out of 2000000 steps (56%)
17:03:56:WU00:FS01:0x22:Completed 1140000 out of 2000000 steps (57%)
17:05:07:WU00:FS01:0x22:Completed 1160000 out of 2000000 steps (58%)
17:06:17:WU00:FS01:0x22:Completed 1180000 out of 2000000 steps (59%)
17:07:27:WU00:FS01:0x22:Completed 1200000 out of 2000000 steps (60%)
17:08:39:WU00:FS01:0x22:Completed 1220000 out of 2000000 steps (61%)
17:09:49:WU00:FS01:0x22:Completed 1240000 out of 2000000 steps (62%)
17:11:01:WU00:FS01:0x22:Completed 1260000 out of 2000000 steps (63%)
17:12:11:WU00:FS01:0x22:Completed 1280000 out of 2000000 steps (64%)
17:13:22:WU00:FS01:0x22:Completed 1300000 out of 2000000 steps (65%)
17:14:34:WU00:FS01:0x22:Completed 1320000 out of 2000000 steps (66%)
17:15:44:WU00:FS01:0x22:Completed 1340000 out of 2000000 steps (67%)
17:16:56:WU00:FS01:0x22:Completed 1360000 out of 2000000 steps (68%)
17:18:06:WU00:FS01:0x22:Completed 1380000 out of 2000000 steps (69%)
17:19:17:WU00:FS01:0x22:Completed 1400000 out of 2000000 steps (70%)
17:20:29:WU00:FS01:0x22:Completed 1420000 out of 2000000 steps (71%)
17:21:39:WU00:FS01:0x22:Completed 1440000 out of 2000000 steps (72%)
17:22:51:WU00:FS01:0x22:Completed 1460000 out of 2000000 steps (73%)
17:24:02:WU00:FS01:0x22:Completed 1480000 out of 2000000 steps (74%)
17:25:12:WU00:FS01:0x22:Completed 1500000 out of 2000000 steps (75%)
17:26:24:WU00:FS01:0x22:Completed 1520000 out of 2000000 steps (76%)
17:27:34:WU00:FS01:0x22:Completed 1540000 out of 2000000 steps (77%)
17:28:46:WU00:FS01:0x22:Completed 1560000 out of 2000000 steps (78%)
17:29:57:WU00:FS01:0x22:Completed 1580000 out of 2000000 steps (79%)
17:31:07:WU00:FS01:0x22:Completed 1600000 out of 2000000 steps (80%)
17:32:20:WU00:FS01:0x22:Completed 1620000 out of 2000000 steps (81%)
17:33:30:WU00:FS01:0x22:Completed 1640000 out of 2000000 steps (82%)
17:34:42:WU00:FS01:0x22:Completed 1660000 out of 2000000 steps (83%)
17:35:53:WU00:FS01:0x22:Completed 1680000 out of 2000000 steps (84%)
17:37:03:WU00:FS01:0x22:Completed 1700000 out of 2000000 steps (85%)
17:38:15:WU00:FS01:0x22:Completed 1720000 out of 2000000 steps (86%)
17:39:25:WU00:FS01:0x22:Completed 1740000 out of 2000000 steps (87%)
17:40:37:WU00:FS01:0x22:Completed 1760000 out of 2000000 steps (88%)
17:41:47:WU00:FS01:0x22:Completed 1780000 out of 2000000 steps (89%)
17:42:58:WU00:FS01:0x22:Completed 1800000 out of 2000000 steps (90%)
17:44:10:WU00:FS01:0x22:Completed 1820000 out of 2000000 steps (91%)
17:45:20:WU00:FS01:0x22:Completed 1840000 out of 2000000 steps (92%)
17:46:32:WU00:FS01:0x22:Completed 1860000 out of 2000000 steps (93%)
17:47:42:WU00:FS01:0x22:Completed 1880000 out of 2000000 steps (94%)
17:48:52:WU00:FS01:0x22:Completed 1900000 out of 2000000 steps (95%)
17:50:05:WU00:FS01:0x22:Completed 1920000 out of 2000000 steps (96%)
17:51:15:WU00:FS01:0x22:Completed 1940000 out of 2000000 steps (97%)
17:52:27:WU00:FS01:0x22:Completed 1960000 out of 2000000 steps (98%)
17:52:28:WU01:FS01:Connecting to 65.254.110.245:8080
17:52:28:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:52:28:WU01:FS01:Connecting to 18.218.241.186:80
17:52:28:WU01:FS01:Assigned to work server 128.252.203.2
17:52:28:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 128.252.203.2
17:52:28:WU01:FS01:Connecting to 128.252.203.2:8080
17:52:40:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
17:52:41:WU01:FS01:Connecting to 65.254.110.245:8080
17:52:41:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:52:41:WU01:FS01:Connecting to 18.218.241.186:80
17:52:41:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:52:41:ERROR:WU01:FS01:Exception: Could not get an assignment
17:53:37:WU00:FS01:0x22:Completed 1980000 out of 2000000 steps (99%)
17:53:41:WU01:FS01:Connecting to 65.254.110.245:8080
17:53:41:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:53:41:WU01:FS01:Connecting to 18.218.241.186:80
17:53:41:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:53:41:ERROR:WU01:FS01:Exception: Could not get an assignment
17:54:48:WU00:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
17:54:49:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
17:54:49:WU00:FS01:0x22:Saving result file checkpointState.xml
17:54:50:WU00:FS01:0x22:Saving result file checkpt.crc
17:54:50:WU00:FS01:0x22:Saving result file positions.xtc
17:54:51:WU00:FS01:0x22:Saving result file science.log
17:54:51:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
17:54:52:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:54:52:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11743 run:0 clone:2319 gen:4 core:0x22 unit:0x0000000a8ca304f15e67e43c1a0b3209
17:54:52:WU00:FS01:Uploading 12.57MiB to 140.163.4.241
17:54:52:WU00:FS01:Connecting to 140.163.4.241:8080
17:55:13:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
17:55:13:WU00:FS01:Connecting to 140.163.4.241:80
17:55:18:WU01:FS01:Connecting to 65.254.110.245:8080
17:55:18:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:55:18:WU01:FS01:Connecting to 18.218.241.186:80
17:55:18:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:55:18:ERROR:WU01:FS01:Exception: Could not get an assignment
17:55:34:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.241:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:55:34:WU00:FS01:Trying to send results to collection server
17:55:34:WU00:FS01:Uploading 12.57MiB to 140.163.4.231
17:55:34:WU00:FS01:Connecting to 140.163.4.231:8080
17:55:55:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
17:55:55:WU00:FS01:Connecting to 140.163.4.231:80
17:56:16:ERROR:WU00:FS01:Exception: Failed to connect to 140.163.4.231:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:56:16:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11743 run:0 clone:2319 gen:4 core:0x22 unit:0x0000000a8ca304f15e67e43c1a0b3209
17:56:16:WU00:FS01:Uploading 12.57MiB to 140.163.4.241
17:56:16:WU00:FS01:Connecting to 140.163.4.241:8080
17:56:37:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
17:56:37:WU00:FS01:Connecting to 140.163.4.241:80
17:56:58:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 140.163.4.241:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:56:58:WU00:FS01:Trying to send results to collection server
17:56:58:WU00:FS01:Uploading 12.57MiB to 140.163.4.231
17:56:58:WU00:FS01:Connecting to 140.163.4.231:8080
17:57:19:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
17:57:19:WU00:FS01:Connecting to 140.163.4.231:80
17:57:34:WU00:FS01:Upload 0.50%
17:57:40:WU00:FS01:Upload 34.32%
17:57:46:WU00:FS01:Upload 100.00%
17:57:48:WU00:FS01:Upload complete
17:57:49:WU00:FS01:Server responded WORK_ACK (400)
17:57:49:WU00:FS01:Final credit estimate, 9405.00 points
17:57:49:WU00:FS01:Cleaning up
March 23rd - 11778 (Run 0, Clone 9000, Gen 1)
01:36:32:WU01:FS01:Connecting to 40.114.52.201:80
01:36:37:WU00:FS01:Upload 86.53%
01:37:06:WU01:FS01:Downloading 29.59MiB
01:37:12:WU01:FS01:Download 12.04%
01:37:13:WU00:FS01:Upload complete
01:37:13:WU00:FS01:Server responded WORK_ACK (400)
01:37:13:WU00:FS01:Final credit estimate, 119302.00 points
01:37:13:WU00:FS01:Cleaning up
01:37:18:WU01:FS01:Download 38.02%
01:37:24:WU01:FS01:Download 56.39%
01:37:31:WU01:FS01:Download 73.29%
01:37:35:WU01:FS01:Download complete
01:37:35:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11778 run:0 clone:9000 gen:1 core:0x22 unit:0x00000004287234c95e743246798042f9
01:37:35:WU01:FS01:Starting
01:37:35:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\tfriz\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/beta/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 14804 -checkpoint 5 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
01:37:35:WU01:FS01:Started FahCore on PID 12068
01:37:35:WU01:FS01:Core PID:380
01:37:35:WU01:FS01:FahCore 0x22 started
01:37:36:WU01:FS01:0x22:*********************** Log Started 2020-03-24T01:37:35Z ***********************
01:37:36:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
01:37:36:WU01:FS01:0x22:       Type: 0x22
01:37:36:WU01:FS01:0x22:       Core: Core22
01:37:36:WU01:FS01:0x22:    Website: https://foldingathome.org/
01:37:36:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
01:37:36:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
01:37:36:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
01:37:36:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 12068 -checkpoint 5
01:37:36:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
01:37:36:WU01:FS01:0x22:     Config: <none>
01:37:36:WU01:FS01:0x22:************************************ Build *************************************
01:37:36:WU01:FS01:0x22:    Version: 0.0.2
01:37:36:WU01:FS01:0x22:       Date: Dec 6 2019
01:37:36:WU01:FS01:0x22:       Time: 21:30:31
01:37:36:WU01:FS01:0x22: Repository: Git
01:37:36:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
01:37:36:WU01:FS01:0x22:     Branch: HEAD
01:37:36:WU01:FS01:0x22:   Compiler: Visual C++ 2008
01:37:36:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:37:36:WU01:FS01:0x22:   Platform: win32 10
01:37:36:WU01:FS01:0x22:       Bits: 64
01:37:36:WU01:FS01:0x22:       Mode: Release
01:37:36:WU01:FS01:0x22:************************************ System ************************************
01:37:36:WU01:FS01:0x22:        CPU: AMD Ryzen 5 3600 6-Core Processor
01:37:36:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
01:37:36:WU01:FS01:0x22:       CPUs: 12
01:37:36:WU01:FS01:0x22:     Memory: 15.95GiB
01:37:36:WU01:FS01:0x22:Free Memory: 8.67GiB
01:37:36:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
01:37:36:WU01:FS01:0x22: OS Version: 6.2
01:37:36:WU01:FS01:0x22:Has Battery: false
01:37:36:WU01:FS01:0x22: On Battery: false
01:37:36:WU01:FS01:0x22: UTC Offset: -5
01:37:36:WU01:FS01:0x22:        PID: 380
01:37:36:WU01:FS01:0x22:        CWD: C:\Users\tfriz\AppData\Roaming\FAHClient\work
01:37:36:WU01:FS01:0x22:         OS: Windows 10 Pro
01:37:36:WU01:FS01:0x22:    OS Arch: AMD64
01:37:36:WU01:FS01:0x22:********************************************************************************
01:37:36:WU01:FS01:0x22:Project: 11778 (Run 0, Clone 9000, Gen 1)
01:37:36:WU01:FS01:0x22:Unit: 0x00000004287234c95e743246798042f9
01:37:36:WU01:FS01:0x22:Reading tar file core.xml
01:37:36:WU01:FS01:0x22:Reading tar file integrator.xml
01:37:36:WU01:FS01:0x22:Reading tar file state.xml
01:37:36:WU01:FS01:0x22:Reading tar file system.xml
01:37:36:WU01:FS01:0x22:Digital signatures verified
01:37:36:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
01:37:36:WU01:FS01:0x22:Version 0.0.2
01:37:59:WU01:FS01:0x22:Completed 0 out of 2000000 steps (0%)
01:37:59:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
01:39:02:WU01:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
01:40:03:WU01:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
01:41:07:WU01:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
01:42:10:WU01:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
01:43:12:WU01:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
01:44:16:WU01:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
01:45:21:WU01:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
01:46:26:WU01:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
01:47:30:WU01:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
01:48:35:WU01:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
01:49:37:WU01:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
01:50:38:WU01:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
01:51:42:WU01:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
01:52:44:WU01:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
01:53:45:WU01:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
01:54:48:WU01:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
01:55:51:WU01:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
01:56:55:WU01:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
01:57:57:WU01:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
01:59:01:WU01:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
02:00:07:WU01:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
02:01:10:WU01:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
02:02:15:WU01:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
02:03:18:WU01:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
02:04:21:WU01:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
02:05:25:WU01:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
02:06:26:WU01:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
02:07:30:WU01:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
02:08:33:WU01:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
02:09:36:WU01:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
02:10:41:WU01:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
02:11:44:WU01:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
02:12:49:WU01:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
02:13:52:WU01:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
02:14:56:WU01:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
02:16:00:WU01:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
02:17:03:WU01:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
02:18:08:WU01:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
02:19:12:WU01:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
02:20:16:WU01:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
02:21:21:WU01:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
02:22:25:WU01:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
02:23:30:WU01:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
02:24:32:WU01:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
02:25:35:WU01:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
02:26:40:WU01:FS01:0x22:Completed 920000 out of 2000000 steps (46%)
02:27:43:WU01:FS01:0x22:Completed 940000 out of 2000000 steps (47%)
02:28:48:WU01:FS01:0x22:Completed 960000 out of 2000000 steps (48%)
02:29:52:WU01:FS01:0x22:Completed 980000 out of 2000000 steps (49%)
02:30:55:WU01:FS01:0x22:Completed 1000000 out of 2000000 steps (50%)
02:32:00:WU01:FS01:0x22:Completed 1020000 out of 2000000 steps (51%)
02:33:02:WU01:FS01:0x22:Completed 1040000 out of 2000000 steps (52%)
02:34:06:WU01:FS01:0x22:Completed 1060000 out of 2000000 steps (53%)
02:35:09:WU01:FS01:0x22:Completed 1080000 out of 2000000 steps (54%)
02:36:13:WU01:FS01:0x22:Completed 1100000 out of 2000000 steps (55%)
02:37:18:WU01:FS01:0x22:Completed 1120000 out of 2000000 steps (56%)
02:38:22:WU01:FS01:0x22:Completed 1140000 out of 2000000 steps (57%)
02:39:27:WU01:FS01:0x22:Completed 1160000 out of 2000000 steps (58%)
02:40:31:WU01:FS01:0x22:Completed 1180000 out of 2000000 steps (59%)
02:41:35:WU01:FS01:0x22:Completed 1200000 out of 2000000 steps (60%)
02:42:41:WU01:FS01:0x22:Completed 1220000 out of 2000000 steps (61%)
02:43:44:WU01:FS01:0x22:Completed 1240000 out of 2000000 steps (62%)
02:44:49:WU01:FS01:0x22:Completed 1260000 out of 2000000 steps (63%)
02:45:52:WU01:FS01:0x22:Completed 1280000 out of 2000000 steps (64%)
02:46:57:WU01:FS01:0x22:Completed 1300000 out of 2000000 steps (65%)
02:48:02:WU01:FS01:0x22:Completed 1320000 out of 2000000 steps (66%)
02:49:06:WU01:FS01:0x22:Completed 1340000 out of 2000000 steps (67%)
02:50:13:WU01:FS01:0x22:Completed 1360000 out of 2000000 steps (68%)
02:51:18:WU01:FS01:0x22:Completed 1380000 out of 2000000 steps (69%)
02:52:23:WU01:FS01:0x22:Completed 1400000 out of 2000000 steps (70%)
02:53:28:WU01:FS01:0x22:Completed 1420000 out of 2000000 steps (71%)
02:54:33:WU01:FS01:0x22:Completed 1440000 out of 2000000 steps (72%)
02:55:37:WU01:FS01:0x22:Completed 1460000 out of 2000000 steps (73%)
02:56:41:WU01:FS01:0x22:Completed 1480000 out of 2000000 steps (74%)
02:57:44:WU01:FS01:0x22:Completed 1500000 out of 2000000 steps (75%)
02:58:49:WU01:FS01:0x22:Completed 1520000 out of 2000000 steps (76%)
02:59:52:WU01:FS01:0x22:Completed 1540000 out of 2000000 steps (77%)
03:00:56:WU01:FS01:0x22:Completed 1560000 out of 2000000 steps (78%)
03:02:00:WU01:FS01:0x22:Completed 1580000 out of 2000000 steps (79%)
03:03:04:WU01:FS01:0x22:Completed 1600000 out of 2000000 steps (80%)
03:04:09:WU01:FS01:0x22:Completed 1620000 out of 2000000 steps (81%)
03:05:10:WU01:FS01:0x22:Completed 1640000 out of 2000000 steps (82%)
03:06:13:WU01:FS01:0x22:Completed 1660000 out of 2000000 steps (83%)
03:07:14:WU01:FS01:0x22:Completed 1680000 out of 2000000 steps (84%)
03:08:14:WU01:FS01:0x22:Completed 1700000 out of 2000000 steps (85%)
03:09:16:WU01:FS01:0x22:Completed 1720000 out of 2000000 steps (86%)
03:10:16:WU01:FS01:0x22:Completed 1740000 out of 2000000 steps (87%)
03:11:18:WU01:FS01:0x22:Completed 1760000 out of 2000000 steps (88%)
03:12:18:WU01:FS01:0x22:Completed 1780000 out of 2000000 steps (89%)
03:13:18:WU01:FS01:0x22:Completed 1800000 out of 2000000 steps (90%)
03:14:19:WU01:FS01:0x22:Completed 1820000 out of 2000000 steps (91%)
03:15:20:WU01:FS01:0x22:Completed 1840000 out of 2000000 steps (92%)
03:16:22:WU01:FS01:0x22:Completed 1860000 out of 2000000 steps (93%)
03:17:22:WU01:FS01:0x22:Completed 1880000 out of 2000000 steps (94%)
03:18:23:WU01:FS01:0x22:Completed 1900000 out of 2000000 steps (95%)
03:19:25:WU01:FS01:0x22:Completed 1920000 out of 2000000 steps (96%)
03:20:25:WU01:FS01:0x22:Completed 1940000 out of 2000000 steps (97%)
03:21:29:WU01:FS01:0x22:Completed 1960000 out of 2000000 steps (98%)
03:21:30:WU00:FS01:Connecting to 65.254.110.245:8080
03:21:30:WU00:FS01:Assigned to work server 140.163.4.231
03:21:30:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 140.163.4.231
03:21:30:WU00:FS01:Connecting to 140.163.4.231:8080
03:22:32:WU01:FS01:0x22:Completed 1980000 out of 2000000 steps (99%)
03:23:36:WU01:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
03:23:37:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
03:23:37:WU01:FS01:0x22:Saving result file checkpointState.xml
03:23:38:WU01:FS01:0x22:Saving result file checkpt.crc
03:23:38:WU01:FS01:0x22:Saving result file positions.xtc
03:23:38:WU01:FS01:0x22:Saving result file science.log
03:23:38:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
03:23:38:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:23:38:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11778 run:0 clone:9000 gen:1 core:0x22 unit:0x00000004287234c95e743246798042f9
03:23:38:WU01:FS01:Uploading 23.04MiB to 40.114.52.201
03:23:38:WU01:FS01:Connecting to 40.114.52.201:8080
03:23:40:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
03:23:40:WU01:FS01:Connecting to 40.114.52.201:80
03:23:43:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: No connection could be made because the target machine actively refused it.
03:23:43:WU01:FS01:Trying to send results to collection server
03:23:43:WU01:FS01:Uploading 23.04MiB to 13.82.98.119
03:23:43:WU01:FS01:Connecting to 13.82.98.119:8080
03:23:43:WU00:FS01:Downloading 7.92MiB
03:23:49:WU01:FS01:Upload 13.02%
03:23:49:WU00:FS01:Download 15.77%
03:23:55:WU01:FS01:Upload 29.02%
03:23:57:WU00:FS01:Download 23.66%
03:24:01:WU01:FS01:Upload 42.58%
03:24:03:WU00:FS01:Download 35.49%
03:24:07:WU01:FS01:Upload 70.52%
03:24:12:WU00:FS01:Download 71.77%
03:24:13:WU01:FS01:Upload 92.22%
03:24:14:WU00:FS01:Download complete
03:24:15:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11751 run:0 clone:5743 gen:11 core:0x22 unit:0x000000138ca304e75e6bbb4bbdae5361
03:24:15:WU00:FS01:Starting
03:24:15:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\tfriz\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/beta/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 14804 -checkpoint 5 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
03:24:15:WU00:FS01:Started FahCore on PID 16060
03:24:15:WU00:FS01:Core PID:8188
03:24:15:WU00:FS01:FahCore 0x22 started
03:24:15:WU00:FS01:0x22:*********************** Log Started 2020-03-24T03:24:15Z ***********************
03:24:15:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
03:24:15:WU00:FS01:0x22:       Type: 0x22
03:24:15:WU00:FS01:0x22:       Core: Core22
03:24:15:WU00:FS01:0x22:    Website: https://foldingathome.org/
03:24:15:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
03:24:15:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
03:24:15:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
03:24:15:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 16060 -checkpoint 5
03:24:15:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
03:24:15:WU00:FS01:0x22:     Config: <none>
03:24:15:WU00:FS01:0x22:************************************ Build *************************************
03:24:15:WU00:FS01:0x22:    Version: 0.0.2
03:24:15:WU00:FS01:0x22:       Date: Dec 6 2019
03:24:15:WU00:FS01:0x22:       Time: 21:30:31
03:24:15:WU00:FS01:0x22: Repository: Git
03:24:15:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
03:24:15:WU00:FS01:0x22:     Branch: HEAD
03:24:15:WU00:FS01:0x22:   Compiler: Visual C++ 2008
03:24:15:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:24:15:WU00:FS01:0x22:   Platform: win32 10
03:24:15:WU00:FS01:0x22:       Bits: 64
03:24:15:WU00:FS01:0x22:       Mode: Release
03:24:15:WU00:FS01:0x22:************************************ System ************************************
03:24:15:WU00:FS01:0x22:        CPU: AMD Ryzen 5 3600 6-Core Processor
03:24:15:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
03:24:15:WU00:FS01:0x22:       CPUs: 12
03:24:15:WU00:FS01:0x22:     Memory: 15.95GiB
03:24:15:WU00:FS01:0x22:Free Memory: 8.78GiB
03:24:15:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
03:24:15:WU00:FS01:0x22: OS Version: 6.2
03:24:15:WU00:FS01:0x22:Has Battery: false
03:24:15:WU00:FS01:0x22: On Battery: false
03:24:15:WU00:FS01:0x22: UTC Offset: -5
03:24:15:WU00:FS01:0x22:        PID: 8188
03:24:15:WU00:FS01:0x22:        CWD: C:\Users\tfriz\AppData\Roaming\FAHClient\work
03:24:15:WU00:FS01:0x22:         OS: Windows 10 Pro
03:24:15:WU00:FS01:0x22:    OS Arch: AMD64
03:24:15:WU00:FS01:0x22:********************************************************************************
03:24:15:WU00:FS01:0x22:Project: 11751 (Run 0, Clone 5743, Gen 11)
03:24:15:WU00:FS01:0x22:Unit: 0x000000138ca304e75e6bbb4bbdae5361
03:24:15:WU00:FS01:0x22:Reading tar file core.xml
03:24:15:WU00:FS01:0x22:Reading tar file integrator.xml
03:24:15:WU00:FS01:0x22:Reading tar file state.xml
03:24:16:WU00:FS01:0x22:Reading tar file system.xml
03:24:16:WU01:FS01:Upload complete
03:24:16:WU01:FS01:Server responded WORK_ACK (400)
03:24:16:WU01:FS01:Final credit estimate, 9405.00 points
03:24:16:WU01:FS01:Cleaning up
Third one will be in the next message as it doesn't fit in this one.
S1: AMD R5 3600 & Sapphire RX 5700 XT Reference @2.1GHz under water
S2: Intel Xeon E5-2620v3 & MSI GTX 1650
RX 5700 XT Project & PPD Tracking Spreadsheet
MrFrizzy
Re: Randomly getting base credit (9405) on COVID-19 projects
Post by MrFrizzy »
March 24th - 11777 (Run 0, Clone 9775, Gen 1)
19:20:30:WU01:FS01:Connecting to 65.254.110.245:8080
19:20:31:WU01:FS01:Assigned to work server 40.114.52.201
19:20:31:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 40.114.52.201
19:20:31:WU01:FS01:Connecting to 40.114.52.201:8080
19:20:48:WU00:FS00:0xa7:Completed 47500 out of 125000 steps (38%)
19:21:37:WU00:FS00:0xa7:Completed 48750 out of 125000 steps (39%)
19:22:18:WU01:FS01:Downloading 29.70MiB
19:22:25:WU00:FS00:0xa7:Completed 50000 out of 125000 steps (40%)
19:22:27:WU01:FS01:Download 4.00%
19:22:33:WU01:FS01:Download 16.63%
19:22:39:WU01:FS01:Download 28.41%
19:22:49:WU01:FS01:Download 40.62%
19:22:55:WU01:FS01:Download 49.88%
19:23:01:WU01:FS01:Download 59.98%
19:23:08:WU01:FS01:Download 67.13%
19:23:14:WU01:FS01:Download 81.24%
19:23:14:WU00:FS00:0xa7:Completed 51250 out of 125000 steps (41%)
19:23:20:WU01:FS01:Download 91.76%
19:23:23:WU01:FS01:Download complete
19:23:23:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11777 run:0 clone:9775 gen:1 core:0x22 unit:0x00000007287234c95e7432cb47f52048
19:23:24:WU01:FS01:Starting
19:23:24:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\tfriz\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/beta/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 16832 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:23:24:WU01:FS01:Started FahCore on PID 16404
19:23:24:WU01:FS01:Core PID:11840
19:23:24:WU01:FS01:FahCore 0x22 started
19:23:24:WU01:FS01:0x22:*********************** Log Started 2020-03-24T19:23:24Z ***********************
19:23:24:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
19:23:24:WU01:FS01:0x22:       Type: 0x22
19:23:24:WU01:FS01:0x22:       Core: Core22
19:23:24:WU01:FS01:0x22:    Website: https://foldingathome.org/
19:23:24:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
19:23:24:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
19:23:24:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
19:23:24:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 16404 -checkpoint 15
19:23:24:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
19:23:24:WU01:FS01:0x22:     Config: <none>
19:23:24:WU01:FS01:0x22:************************************ Build *************************************
19:23:24:WU01:FS01:0x22:    Version: 0.0.2
19:23:24:WU01:FS01:0x22:       Date: Dec 6 2019
19:23:24:WU01:FS01:0x22:       Time: 21:30:31
19:23:24:WU01:FS01:0x22: Repository: Git
19:23:24:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
19:23:24:WU01:FS01:0x22:     Branch: HEAD
19:23:24:WU01:FS01:0x22:   Compiler: Visual C++ 2008
19:23:24:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:23:24:WU01:FS01:0x22:   Platform: win32 10
19:23:24:WU01:FS01:0x22:       Bits: 64
19:23:24:WU01:FS01:0x22:       Mode: Release
19:23:24:WU01:FS01:0x22:************************************ System ************************************
19:23:24:WU01:FS01:0x22:        CPU: AMD Ryzen 5 3600 6-Core Processor
19:23:24:WU01:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
19:23:24:WU01:FS01:0x22:       CPUs: 12
19:23:24:WU01:FS01:0x22:     Memory: 15.95GiB
19:23:24:WU01:FS01:0x22:Free Memory: 8.76GiB
19:23:24:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
19:23:24:WU01:FS01:0x22: OS Version: 6.2
19:23:24:WU01:FS01:0x22:Has Battery: false
19:23:24:WU01:FS01:0x22: On Battery: false
19:23:24:WU01:FS01:0x22: UTC Offset: -5
19:23:24:WU01:FS01:0x22:        PID: 11840
19:23:24:WU01:FS01:0x22:        CWD: C:\Users\tfriz\AppData\Roaming\FAHClient\work
19:23:24:WU01:FS01:0x22:         OS: Windows 10 Pro
19:23:24:WU01:FS01:0x22:    OS Arch: AMD64
19:23:24:WU01:FS01:0x22:********************************************************************************
19:23:24:WU01:FS01:0x22:Project: 11777 (Run 0, Clone 9775, Gen 1)
19:23:24:WU01:FS01:0x22:Unit: 0x00000007287234c95e7432cb47f52048
19:23:24:WU01:FS01:0x22:Reading tar file core.xml
19:23:24:WU01:FS01:0x22:Reading tar file integrator.xml
19:23:24:WU01:FS01:0x22:Reading tar file state.xml
19:23:24:WU01:FS01:0x22:Reading tar file system.xml
19:23:24:WU01:FS01:0x22:Digital signatures verified
19:23:24:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
19:23:24:WU01:FS01:0x22:Version 0.0.2
19:23:55:WU01:FS01:0x22:Completed 0 out of 2000000 steps (0%)
19:23:55:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:24:03:WU00:FS00:0xa7:Completed 52500 out of 125000 steps (42%)
19:24:52:WU00:FS00:0xa7:Completed 53750 out of 125000 steps (43%)
19:24:56:WU01:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
19:25:41:WU00:FS00:0xa7:Completed 55000 out of 125000 steps (44%)
19:25:57:WU01:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
19:26:30:WU00:FS00:0xa7:Completed 56250 out of 125000 steps (45%)
19:26:59:WU01:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
19:27:19:WU00:FS00:0xa7:Completed 57500 out of 125000 steps (46%)
19:27:59:WU01:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
19:28:08:WU00:FS00:0xa7:Completed 58750 out of 125000 steps (47%)
19:28:57:WU00:FS00:0xa7:Completed 60000 out of 125000 steps (48%)
19:29:00:WU01:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
19:29:46:WU00:FS00:0xa7:Completed 61250 out of 125000 steps (49%)
19:30:02:WU01:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
19:30:35:WU00:FS00:0xa7:Completed 62500 out of 125000 steps (50%)
19:31:02:WU01:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
19:31:24:WU00:FS00:0xa7:Completed 63750 out of 125000 steps (51%)
19:32:05:WU01:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
19:32:14:WU00:FS00:0xa7:Completed 65000 out of 125000 steps (52%)
19:32:19:Removing old file 'configs/config-20200324-164159.xml'
19:32:19:Saving configuration to config.xml
19:32:19:<config>
19:32:19:  <!-- Folding Slot Configuration -->
19:32:19:  <client-type v='beta'/>
19:32:19:
19:32:19:  <!-- Network -->
19:32:19:  <proxy v=':8080'/>
19:32:19:
19:32:19:  <!-- Slot Control -->
19:32:19:  <pause-on-start v='true'/>
19:32:19:  <power v='FULL'/>
19:32:19:
19:32:19:  <!-- User Information -->
19:32:19:  <passkey v='********************************'/>
19:32:19:  <team v='223518'/>
19:32:19:  <user v='MrFrizzy'/>
19:32:19:
19:32:19:  <!-- Folding Slots -->
19:32:19:  <slot id='1' type='GPU'>
19:32:19:    <core-priority v='low'/>
19:32:19:    <next-unit-percentage v='98'/>
19:32:19:  </slot>
19:32:19:  <slot id='0' type='CPU'>
19:32:19:    <cpus v='6'/>
19:32:19:  </slot>
19:32:19:</config>
19:32:19:FS00:Shutting core down
19:32:19:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 16836
19:32:19:WU00:FS00:0xa7:Exiting, please wait. . .
19:32:21:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
19:32:21:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:32:22:WU00:FS00:Starting
19:32:22:WARNING:WU00:FS00:Changed SMP threads from 8 to 6 this can cause some work units to fail
19:32:22:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\tfriz\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 16832 -checkpoint 15 -np 6
19:32:22:WU00:FS00:Started FahCore on PID 16388
19:32:22:WU00:FS00:Core PID:15572
19:32:22:WU00:FS00:FahCore 0xa7 started
19:32:22:WU00:FS00:0xa7:*********************** Log Started 2020-03-24T19:32:22Z ***********************
19:32:22:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
19:32:22:WU00:FS00:0xa7:       Type: 0xa7
19:32:22:WU00:FS00:0xa7:       Core: Gromacs
19:32:22:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 16388 -checkpoint 15 -np
19:32:22:WU00:FS00:0xa7:             6
19:32:22:WU00:FS00:0xa7:************************************ CBang *************************************
19:32:22:WU00:FS00:0xa7:       Date: Oct 26 2019
19:32:22:WU00:FS00:0xa7:       Time: 01:38:25
19:32:22:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
19:32:22:WU00:FS00:0xa7:     Branch: master
19:32:22:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
19:32:22:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
19:32:22:WU00:FS00:0xa7:   Platform: win32 10
19:32:22:WU00:FS00:0xa7:       Bits: 64
19:32:22:WU00:FS00:0xa7:       Mode: Release
19:32:22:WU00:FS00:0xa7:************************************ System ************************************
19:32:22:WU00:FS00:0xa7:        CPU: AMD Ryzen 5 3600 6-Core Processor
19:32:22:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
19:32:22:WU00:FS00:0xa7:       CPUs: 12
19:32:22:WU00:FS00:0xa7:     Memory: 15.95GiB
19:32:22:WU00:FS00:0xa7:Free Memory: 9.18GiB
19:32:22:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
19:32:22:WU00:FS00:0xa7: OS Version: 6.2
19:32:22:WU00:FS00:0xa7:Has Battery: false
19:32:22:WU00:FS00:0xa7: On Battery: false
19:32:22:WU00:FS00:0xa7: UTC Offset: -5
19:32:22:WU00:FS00:0xa7:        PID: 15572
19:32:22:WU00:FS00:0xa7:        CWD: C:\Users\tfriz\AppData\Roaming\FAHClient\work
19:32:22:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
19:32:22:WU00:FS00:0xa7:    Version: 0.0.18
19:32:22:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:32:22:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
19:32:22:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
19:32:22:WU00:FS00:0xa7:       Time: 01:52:30
19:32:22:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
19:32:22:WU00:FS00:0xa7:************************************ Build *************************************
19:32:22:WU00:FS00:0xa7:       SIMD: avx_256
19:32:22:WU00:FS00:0xa7:********************************************************************************
19:32:22:WU00:FS00:0xa7:Project: 13872 (Run 0, Clone 91, Gen 0)
19:32:22:WU00:FS00:0xa7:Unit: 0x000000000d5262775e77c9f82f4b82eb
19:32:22:WU00:FS00:0xa7:Digital signatures verified
19:32:22:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -x frame0.xtc -e frame0.edr -cpi state.cpt -cpt 15 -nt 6
19:32:22:WU00:FS00:0xa7:Steps: first=0 total=125000
19:32:23:WU00:FS00:0xa7:Completed 65152 out of 125000 steps (52%)
19:33:00:Removing old file 'configs/config-20200324-164212.xml'
19:33:00:Saving configuration to config.xml
19:33:00:<config>
19:33:00:  <!-- Folding Slot Configuration -->
19:33:00:  <client-type v='beta'/>
19:33:00:
19:33:00:  <!-- Network -->
19:33:00:  <proxy v=':8080'/>
19:33:00:
19:33:00:  <!-- Slot Control -->
19:33:00:  <pause-on-start v='true'/>
19:33:00:  <power v='FULL'/>
19:33:00:
19:33:00:  <!-- User Information -->
19:33:00:  <passkey v='********************************'/>
19:33:00:  <team v='223518'/>
19:33:00:  <user v='MrFrizzy'/>
19:33:00:
19:33:00:  <!-- Folding Slots -->
19:33:00:  <slot id='1' type='GPU'>
19:33:00:    <core-priority v='low'/>
19:33:00:    <next-unit-percentage v='98'/>
19:33:00:  </slot>
19:33:00:  <slot id='0' type='CPU'>
19:33:00:    <cpus v='6'/>
19:33:00:  </slot>
19:33:00:</config>
19:33:04:WU01:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
19:33:16:WU00:FS00:0xa7:Completed 66250 out of 125000 steps (53%)
19:34:03:WU01:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
19:34:16:WU00:FS00:0xa7:Completed 67500 out of 125000 steps (54%)
19:35:03:WU01:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
19:35:16:WU00:FS00:0xa7:Completed 68750 out of 125000 steps (55%)
19:36:02:WU01:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
19:36:17:WU00:FS00:0xa7:Completed 70000 out of 125000 steps (56%)
19:37:03:WU01:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
19:37:17:WU00:FS00:0xa7:Completed 71250 out of 125000 steps (57%)
19:38:02:WU01:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
19:38:17:WU00:FS00:0xa7:Completed 72500 out of 125000 steps (58%)
19:39:01:WU01:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
19:39:18:WU00:FS00:0xa7:Completed 73750 out of 125000 steps (59%)
19:40:02:WU01:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
19:40:18:WU00:FS00:0xa7:Completed 75000 out of 125000 steps (60%)
19:41:01:WU01:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
19:41:18:WU00:FS00:0xa7:Completed 76250 out of 125000 steps (61%)
19:42:02:WU01:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
19:42:19:WU00:FS00:0xa7:Completed 77500 out of 125000 steps (62%)
19:43:00:WU01:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
19:43:19:WU00:FS00:0xa7:Completed 78750 out of 125000 steps (63%)
19:44:00:WU01:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
19:44:19:WU00:FS00:0xa7:Completed 80000 out of 125000 steps (64%)
19:45:01:WU01:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
19:45:20:WU00:FS00:0xa7:Completed 81250 out of 125000 steps (65%)
19:46:00:WU01:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
19:46:20:WU00:FS00:0xa7:Completed 82500 out of 125000 steps (66%)
19:47:01:WU01:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
19:47:20:WU00:FS00:0xa7:Completed 83750 out of 125000 steps (67%)
19:48:00:WU01:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
19:48:21:WU00:FS00:0xa7:Completed 85000 out of 125000 steps (68%)
19:48:59:WU01:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
19:49:21:WU00:FS00:0xa7:Completed 86250 out of 125000 steps (69%)
19:50:01:WU01:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
19:50:21:WU00:FS00:0xa7:Completed 87500 out of 125000 steps (70%)
19:51:00:WU01:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
19:51:21:WU00:FS00:0xa7:Completed 88750 out of 125000 steps (71%)
19:52:01:WU01:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
19:52:22:WU00:FS00:0xa7:Completed 90000 out of 125000 steps (72%)
19:53:00:WU01:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
19:53:22:WU00:FS00:0xa7:Completed 91250 out of 125000 steps (73%)
19:54:00:WU01:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
19:54:22:WU00:FS00:0xa7:Completed 92500 out of 125000 steps (74%)
19:55:01:WU01:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
19:55:23:WU00:FS00:0xa7:Completed 93750 out of 125000 steps (75%)
19:56:00:WU01:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
19:56:23:WU00:FS00:0xa7:Completed 95000 out of 125000 steps (76%)
19:57:00:WU01:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
19:57:23:WU00:FS00:0xa7:Completed 96250 out of 125000 steps (77%)
19:58:00:WU01:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
19:58:23:WU00:FS00:0xa7:Completed 97500 out of 125000 steps (78%)
19:58:59:WU01:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
19:59:24:WU00:FS00:0xa7:Completed 98750 out of 125000 steps (79%)
20:00:00:WU01:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
20:00:24:WU00:FS00:0xa7:Completed 100000 out of 125000 steps (80%)
20:00:59:WU01:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
20:01:24:WU00:FS00:0xa7:Completed 101250 out of 125000 steps (81%)
20:02:00:WU01:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
20:02:25:WU00:FS00:0xa7:Completed 102500 out of 125000 steps (82%)
20:02:59:WU01:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
20:03:25:WU00:FS00:0xa7:Completed 103750 out of 125000 steps (83%)
20:03:58:WU01:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
20:04:25:WU00:FS00:0xa7:Completed 105000 out of 125000 steps (84%)
20:04:59:WU01:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
20:05:25:WU00:FS00:0xa7:Completed 106250 out of 125000 steps (85%)
20:05:58:WU01:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
20:06:25:WU00:FS00:0xa7:Completed 107500 out of 125000 steps (86%)
20:06:59:WU01:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
20:07:25:WU00:FS00:0xa7:Completed 108750 out of 125000 steps (87%)
20:07:58:WU01:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
20:08:26:WU00:FS00:0xa7:Completed 110000 out of 125000 steps (88%)
20:08:56:WU01:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
20:09:26:WU00:FS00:0xa7:Completed 111250 out of 125000 steps (89%)
20:09:57:WU01:FS01:0x22:Completed 920000 out of 2000000 steps (46%)
20:10:27:WU00:FS00:0xa7:Completed 112500 out of 125000 steps (90%)
20:10:56:WU01:FS01:0x22:Completed 940000 out of 2000000 steps (47%)
20:11:28:WU00:FS00:0xa7:Completed 113750 out of 125000 steps (91%)
20:11:56:WU01:FS01:0x22:Completed 960000 out of 2000000 steps (48%)
20:12:27:WU00:FS00:0xa7:Completed 115000 out of 125000 steps (92%)
20:12:55:WU01:FS01:0x22:Completed 980000 out of 2000000 steps (49%)
20:13:27:WU00:FS00:0xa7:Completed 116250 out of 125000 steps (93%)
20:13:54:WU01:FS01:0x22:Completed 1000000 out of 2000000 steps (50%)
20:14:28:WU00:FS00:0xa7:Completed 117500 out of 125000 steps (94%)
20:14:54:WU01:FS01:0x22:Completed 1020000 out of 2000000 steps (51%)
20:15:28:WU00:FS00:0xa7:Completed 118750 out of 125000 steps (95%)
20:15:53:WU01:FS01:0x22:Completed 1040000 out of 2000000 steps (52%)
20:16:29:WU00:FS00:0xa7:Completed 120000 out of 125000 steps (96%)
20:16:54:WU01:FS01:0x22:Completed 1060000 out of 2000000 steps (53%)
20:17:31:WU00:FS00:0xa7:Completed 121250 out of 125000 steps (97%)
20:17:52:WU01:FS01:0x22:Completed 1080000 out of 2000000 steps (54%)
20:18:31:WU00:FS00:0xa7:Completed 122500 out of 125000 steps (98%)
20:18:51:WU01:FS01:0x22:Completed 1100000 out of 2000000 steps (55%)
20:19:32:WU00:FS00:0xa7:Completed 123750 out of 125000 steps (99%)
20:19:33:WU02:FS00:Connecting to 65.254.110.245:8080
20:19:33:WU02:FS00:Assigned to work server 37.187.12.48
20:19:33:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:6 from 37.187.12.48
20:19:33:WU02:FS00:Connecting to 37.187.12.48:8080
20:19:33:WU02:FS00:Downloading 7.99MiB
20:19:35:WU02:FS00:Download complete
20:19:35:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:14344 run:0 clone:31 gen:16 core:0xa7 unit:0x0000001025bb0c305e702bbd0e1ea6a4
20:19:51:WU01:FS01:0x22:Completed 1120000 out of 2000000 steps (56%)
20:20:33:WU00:FS00:0xa7:Completed 125000 out of 125000 steps (100%)
20:20:35:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
20:20:35:WU00:FS00:0xa7:Saving result file frame0.edr
20:20:35:WU00:FS00:0xa7:Saving result file frame0.trr
20:20:35:WU00:FS00:0xa7:Saving result file frame0.xtc
20:20:35:WU00:FS00:0xa7:Saving result file md.log
20:20:35:WU00:FS00:0xa7:Saving result file science.log
20:20:35:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
20:20:36:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:20:36:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13872 run:0 clone:91 gen:0 core:0xa7 unit:0x000000000d5262775e77c9f82f4b82eb
20:20:36:WU00:FS00:Uploading 9.38MiB to 13.82.98.119
20:20:36:WU00:FS00:Connecting to 13.82.98.119:8080
20:20:36:WU02:FS00:Starting
20:20:36:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\tfriz\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 705 -lifeline 16832 -checkpoint 15 -np 6
20:20:36:WU02:FS00:Started FahCore on PID 6760
20:20:36:WU02:FS00:Core PID:3272
20:20:36:WU02:FS00:FahCore 0xa7 started
20:20:36:WU02:FS00:0xa7:*********************** Log Started 2020-03-24T20:20:36Z ***********************
20:20:36:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:20:36:WU02:FS00:0xa7:       Type: 0xa7
20:20:36:WU02:FS00:0xa7:       Core: Gromacs
20:20:36:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 705 -lifeline 6760 -checkpoint 15 -np 6
20:20:36:WU02:FS00:0xa7:************************************ CBang *************************************
20:20:36:WU02:FS00:0xa7:       Date: Oct 26 2019
20:20:36:WU02:FS00:0xa7:       Time: 01:38:25
20:20:36:WU02:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
20:20:36:WU02:FS00:0xa7:     Branch: master
20:20:36:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
20:20:36:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:20:36:WU02:FS00:0xa7:   Platform: win32 10
20:20:36:WU02:FS00:0xa7:       Bits: 64
20:20:36:WU02:FS00:0xa7:       Mode: Release
20:20:36:WU02:FS00:0xa7:************************************ System ************************************
20:20:36:WU02:FS00:0xa7:        CPU: AMD Ryzen 5 3600 6-Core Processor
20:20:36:WU02:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
20:20:36:WU02:FS00:0xa7:       CPUs: 12
20:20:36:WU02:FS00:0xa7:     Memory: 15.95GiB
20:20:36:WU02:FS00:0xa7:Free Memory: 9.37GiB
20:20:36:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
20:20:36:WU02:FS00:0xa7: OS Version: 6.2
20:20:36:WU02:FS00:0xa7:Has Battery: false
20:20:36:WU02:FS00:0xa7: On Battery: false
20:20:36:WU02:FS00:0xa7: UTC Offset: -5
20:20:36:WU02:FS00:0xa7:        PID: 3272
20:20:36:WU02:FS00:0xa7:        CWD: C:\Users\tfriz\AppData\Roaming\FAHClient\work
20:20:36:WU02:FS00:0xa7:******************************** Build - libFAH ********************************
20:20:36:WU02:FS00:0xa7:    Version: 0.0.18
20:20:36:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:20:36:WU02:FS00:0xa7:  Copyright: 2019 foldingathome.org
20:20:36:WU02:FS00:0xa7:   Homepage: https://foldingathome.org/
20:20:36:WU02:FS00:0xa7:       Time: 01:52:30
20:20:36:WU02:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
20:20:36:WU02:FS00:0xa7:************************************ Build *************************************
20:20:36:WU02:FS00:0xa7:       SIMD: avx_256
20:20:36:WU02:FS00:0xa7:********************************************************************************
20:20:36:WU02:FS00:0xa7:Project: 14344 (Run 0, Clone 31, Gen 16)
20:20:36:WU02:FS00:0xa7:Unit: 0x0000001025bb0c305e702bbd0e1ea6a4
20:20:36:WU02:FS00:0xa7:Reading tar file core.xml
20:20:36:WU02:FS00:0xa7:Reading tar file frame16.tpr
20:20:36:WU02:FS00:0xa7:Digital signatures verified
20:20:36:WU02:FS00:0xa7:Calling: mdrun -s frame16.tpr -o frame16.trr -cpt 15 -nt 6
20:20:36:WU02:FS00:0xa7:Steps: first=4000000 total=250000
20:20:38:WU02:FS00:0xa7:Completed 1 out of 250000 steps (0%)
20:20:42:WU00:FS00:Upload 71.93%
20:20:45:WU00:FS00:Upload complete
20:20:45:WU00:FS00:Server responded WORK_ACK (400)
20:20:45:WU00:FS00:Final credit estimate, 7255.00 points
20:20:45:WU00:FS00:Cleaning up
20:20:50:WU01:FS01:0x22:Completed 1140000 out of 2000000 steps (57%)
20:21:51:WU01:FS01:0x22:Completed 1160000 out of 2000000 steps (58%)
20:22:11:WU02:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
20:22:49:WU01:FS01:0x22:Completed 1180000 out of 2000000 steps (59%)
20:23:45:WU02:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
20:23:48:WU01:FS01:0x22:Completed 1200000 out of 2000000 steps (60%)
20:24:48:WU01:FS01:0x22:Completed 1220000 out of 2000000 steps (61%)
20:25:18:WU02:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
20:25:47:WU01:FS01:0x22:Completed 1240000 out of 2000000 steps (62%)
20:26:47:WU01:FS01:0x22:Completed 1260000 out of 2000000 steps (63%)
20:26:52:WU02:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
20:27:46:WU01:FS01:0x22:Completed 1280000 out of 2000000 steps (64%)
20:28:26:WU02:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
20:28:44:WU01:FS01:0x22:Completed 1300000 out of 2000000 steps (65%)
20:29:45:WU01:FS01:0x22:Completed 1320000 out of 2000000 steps (66%)
20:29:59:WU02:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
20:30:43:WU01:FS01:0x22:Completed 1340000 out of 2000000 steps (67%)
20:31:32:WU02:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
20:31:44:WU01:FS01:0x22:Completed 1360000 out of 2000000 steps (68%)
20:32:42:WU01:FS01:0x22:Completed 1380000 out of 2000000 steps (69%)
20:33:05:WU02:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
20:33:41:WU01:FS01:0x22:Completed 1400000 out of 2000000 steps (70%)
20:34:39:WU02:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
20:34:41:WU01:FS01:0x22:Completed 1420000 out of 2000000 steps (71%)
20:35:40:WU01:FS01:0x22:Completed 1440000 out of 2000000 steps (72%)
20:36:13:WU02:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
20:36:40:WU01:FS01:0x22:Completed 1460000 out of 2000000 steps (73%)
20:37:39:WU01:FS01:0x22:Completed 1480000 out of 2000000 steps (74%)
20:37:47:WU02:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
20:38:37:WU01:FS01:0x22:Completed 1500000 out of 2000000 steps (75%)
20:39:20:WU02:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
20:39:38:WU01:FS01:0x22:Completed 1520000 out of 2000000 steps (76%)
20:40:36:WU01:FS01:0x22:Completed 1540000 out of 2000000 steps (77%)
20:40:53:WU02:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
20:41:37:WU01:FS01:0x22:Completed 1560000 out of 2000000 steps (78%)
20:42:27:WU02:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
20:42:35:WU01:FS01:0x22:Completed 1580000 out of 2000000 steps (79%)
20:43:34:WU01:FS01:0x22:Completed 1600000 out of 2000000 steps (80%)
20:44:01:WU02:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
20:44:34:WU01:FS01:0x22:Completed 1620000 out of 2000000 steps (81%)
20:45:33:WU01:FS01:0x22:Completed 1640000 out of 2000000 steps (82%)
20:45:34:WU02:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
20:46:33:WU01:FS01:0x22:Completed 1660000 out of 2000000 steps (83%)
20:47:07:WU02:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
20:47:31:WU01:FS01:0x22:Completed 1680000 out of 2000000 steps (84%)
20:48:30:WU01:FS01:0x22:Completed 1700000 out of 2000000 steps (85%)
20:48:40:WU02:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
20:49:30:WU01:FS01:0x22:Completed 1720000 out of 2000000 steps (86%)
20:50:14:WU02:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
20:50:29:WU01:FS01:0x22:Completed 1740000 out of 2000000 steps (87%)
20:51:29:WU01:FS01:0x22:Completed 1760000 out of 2000000 steps (88%)
20:51:48:WU02:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
20:52:28:WU01:FS01:0x22:Completed 1780000 out of 2000000 steps (89%)
20:53:21:WU02:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
20:53:27:WU01:FS01:0x22:Completed 1800000 out of 2000000 steps (90%)
20:54:27:WU01:FS01:0x22:Completed 1820000 out of 2000000 steps (91%)
20:54:54:WU02:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
20:55:26:WU01:FS01:0x22:Completed 1840000 out of 2000000 steps (92%)
20:56:27:WU02:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
20:56:27:WU01:FS01:0x22:Completed 1860000 out of 2000000 steps (93%)
20:57:27:WU01:FS01:0x22:Completed 1880000 out of 2000000 steps (94%)
20:58:00:WU02:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
20:58:27:WU01:FS01:0x22:Completed 1900000 out of 2000000 steps (95%)
20:59:28:WU01:FS01:0x22:Completed 1920000 out of 2000000 steps (96%)
20:59:33:WU02:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
21:00:27:WU01:FS01:0x22:Completed 1940000 out of 2000000 steps (97%)
21:01:05:WU02:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
21:01:28:WU01:FS01:0x22:Completed 1960000 out of 2000000 steps (98%)
21:01:29:WU00:FS01:Connecting to 65.254.110.245:8080
21:01:29:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:01:29:WU00:FS01:Connecting to 18.218.241.186:80
21:01:30:WU00:FS01:Assigned to work server 155.247.164.213
21:01:30:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] from 155.247.164.213
21:01:30:WU00:FS01:Connecting to 155.247.164.213:8080
21:01:34:WU00:FS01:Downloading 4.52MiB
21:01:34:WU00:FS01:Download complete
21:01:35:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11755 run:0 clone:467 gen:14 core:0x22 unit:0x000000159bf7a4d55e6d76e0bae8a8c4
21:02:28:WU01:FS01:0x22:Completed 1980000 out of 2000000 steps (99%)
21:02:38:WU02:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
21:03:27:WU01:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
21:03:29:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
21:03:29:WU01:FS01:0x22:Saving result file checkpointState.xml
21:03:29:WU01:FS01:0x22:Saving result file checkpt.crc
21:03:29:WU01:FS01:0x22:Saving result file positions.xtc
21:03:29:WU01:FS01:0x22:Saving result file science.log
21:03:29:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
21:03:30:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:03:30:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11777 run:0 clone:9775 gen:1 core:0x22 unit:0x00000007287234c95e7432cb47f52048
21:03:30:WU01:FS01:Uploading 23.06MiB to 40.114.52.201
21:03:30:WU01:FS01:Connecting to 40.114.52.201:8080
21:03:30:WU00:FS01:Starting
21:03:30:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\tfriz\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/beta/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 16832 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
21:03:30:WU00:FS01:Started FahCore on PID 10068
21:03:30:WU00:FS01:Core PID:17064
21:03:30:WU00:FS01:FahCore 0x22 started
21:03:30:WU00:FS01:0x22:*********************** Log Started 2020-03-24T21:03:30Z ***********************
21:03:30:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
21:03:30:WU00:FS01:0x22:       Type: 0x22
21:03:30:WU00:FS01:0x22:       Core: Core22
21:03:30:WU00:FS01:0x22:    Website: https://foldingathome.org/
21:03:30:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
21:03:30:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
21:03:30:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
21:03:30:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 10068 -checkpoint 15
21:03:30:WU00:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
21:03:30:WU00:FS01:0x22:     Config: <none>
21:03:30:WU00:FS01:0x22:************************************ Build *************************************
21:03:30:WU00:FS01:0x22:    Version: 0.0.2
21:03:30:WU00:FS01:0x22:       Date: Dec 6 2019
21:03:30:WU00:FS01:0x22:       Time: 21:30:31
21:03:30:WU00:FS01:0x22: Repository: Git
21:03:30:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
21:03:30:WU00:FS01:0x22:     Branch: HEAD
21:03:30:WU00:FS01:0x22:   Compiler: Visual C++ 2008
21:03:30:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
21:03:30:WU00:FS01:0x22:   Platform: win32 10
21:03:30:WU00:FS01:0x22:       Bits: 64
21:03:30:WU00:FS01:0x22:       Mode: Release
21:03:30:WU00:FS01:0x22:************************************ System ************************************
21:03:30:WU00:FS01:0x22:        CPU: AMD Ryzen 5 3600 6-Core Processor
21:03:30:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
21:03:30:WU00:FS01:0x22:       CPUs: 12
21:03:30:WU00:FS01:0x22:     Memory: 15.95GiB
21:03:30:WU00:FS01:0x22:Free Memory: 8.88GiB
21:03:30:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
21:03:30:WU00:FS01:0x22: OS Version: 6.2
21:03:30:WU00:FS01:0x22:Has Battery: false
21:03:30:WU00:FS01:0x22: On Battery: false
21:03:30:WU00:FS01:0x22: UTC Offset: -5
21:03:30:WU00:FS01:0x22:        PID: 17064
21:03:30:WU00:FS01:0x22:        CWD: C:\Users\tfriz\AppData\Roaming\FAHClient\work
21:03:30:WU00:FS01:0x22:         OS: Windows 10 Pro
21:03:30:WU00:FS01:0x22:    OS Arch: AMD64
21:03:30:WU00:FS01:0x22:********************************************************************************
21:03:30:WU00:FS01:0x22:Project: 11755 (Run 0, Clone 467, Gen 14)
21:03:30:WU00:FS01:0x22:Unit: 0x000000159bf7a4d55e6d76e0bae8a8c4
21:03:30:WU00:FS01:0x22:Reading tar file core.xml
21:03:30:WU00:FS01:0x22:Reading tar file integrator.xml
21:03:30:WU00:FS01:0x22:Reading tar file state.xml
21:03:31:WU00:FS01:0x22:Reading tar file system.xml
21:03:31:WU00:FS01:0x22:Digital signatures verified
21:03:31:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
21:03:31:WU00:FS01:0x22:Version 0.0.2
21:03:51:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
21:03:51:WU01:FS01:Connecting to 40.114.52.201:80
21:03:59:WU00:FS01:0x22:Completed 0 out of 2000000 steps (0%)
21:03:59:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
21:04:11:WU02:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
21:04:12:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
21:04:12:WU01:FS01:Trying to send results to collection server
21:04:12:WU01:FS01:Uploading 23.06MiB to 155.247.164.214
21:04:12:WU01:FS01:Connecting to 155.247.164.214:8080
21:04:19:WU01:FS01:Upload 3.79%
21:04:25:WU01:FS01:Upload 21.41%
21:04:31:WU01:FS01:Upload 56.36%
21:04:37:WU01:FS01:Upload 91.86%
21:04:39:WU01:FS01:Upload complete
21:04:39:WU01:FS01:Server responded WORK_ACK (400)
21:04:39:WU01:FS01:Final credit estimate, 9405.00 points
21:04:39:WU01:FS01:Cleaning up
I have a recollection of a post a few days ago that a report was in for WU's returned to one of the new servers not properly awarding QRB. I think it was this server, but am not sure. In the large number of recent posts I can't find the post right now The F@h team is aware of this and looking into it. It may take a while, but they should be putting in credits for the missing QRB.
What's your FAH UserName ?
First WU you listed is credited to Anonymous (only base credit), second WU is not found and the thirds one is credited with base credit, but an error status. That's strange ...
MrFrizzy
Post by MrFrizzy »
toTOW wrote:What's your FAH UserName ?
Same as it is here, MrFrizzy.
Is there anything more out of the logs you would like me to provide? Sounds like some weird stuff is happening!
You're not the first one who reported such issues, so I'll try to find someone who can have a deeper look at it ...
KjartanD
Post by KjartanD »
toTOW wrote:You're not the first one who reported such issues, so I'll try to find someone who can have a deeper look at it ...
Has anyting been found out about this? i am also just sometimes getting base credit for 11778 WU, 9405 points.
08:46:11:WU03:FS02:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:11778 run:0 clone:16449 gen:0 core:0x22 unit:0x00000003287234c95e7749587d9a0344
08:46:11:WU03:FS02:Starting
08:46:11:WU03:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\snudd\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 03 -suffix 01 -version 705 -lifeline 13896 -checkpoint 3 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu 1
08:46:11:WU03:FS02:Started FahCore on PID 2716
08:46:11:WU03:FS02:Core PID:5236
08:46:11:WU03:FS02:FahCore 0x22 started
08:46:12:WU03:FS02:0x22:*********************** Log Started 2020-03-28T08:46:11Z ***********************
08:46:12:WU03:FS02:0x22:*************************** Core22 Folding@home Core ***************************
08:46:12:WU03:FS02:0x22:       Type: 0x22
08:46:12:WU03:FS02:0x22:       Core: Core22
08:46:12:WU03:FS02:0x22:    Website: https://foldingathome.org/
08:46:12:WU03:FS02:0x22:  Copyright: (c) 2009-2018 foldingathome.org
08:46:12:WU03:FS02:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
08:46:12:WU03:FS02:0x22:             <rafal.wiewiora@choderalab.org>
08:46:12:WU03:FS02:0x22:       Args: -dir 03 -suffix 01 -version 705 -lifeline 2716 -checkpoint 3
08:46:12:WU03:FS02:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device
08:46:12:WU03:FS02:0x22:             1 -gpu 1
08:46:12:WU03:FS02:0x22:     Config: <none>
08:46:12:WU03:FS02:0x22:************************************ Build *************************************
08:46:12:WU03:FS02:0x22:    Version: 0.0.2
08:46:12:WU03:FS02:0x22:       Date: Dec 6 2019
08:46:12:WU03:FS02:0x22:       Time: 21:30:31
08:46:12:WU03:FS02:0x22: Repository: Git
08:46:12:WU03:FS02:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
08:46:12:WU03:FS02:0x22:     Branch: HEAD
08:46:12:WU03:FS02:0x22:   Compiler: Visual C++ 2008
08:46:12:WU03:FS02:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:46:12:WU03:FS02:0x22:   Platform: win32 10
08:46:12:WU03:FS02:0x22:       Bits: 64
08:46:12:WU03:FS02:0x22:       Mode: Release
08:46:12:WU03:FS02:0x22:************************************ System ************************************
08:46:12:WU03:FS02:0x22:        CPU: AMD Ryzen 9 3900X 12-Core Processor
08:46:12:WU03:FS02:0x22:     CPU ID: AuthenticAMD Family 23 Model 113 Stepping 0
08:46:12:WU03:FS02:0x22:       CPUs: 24
08:46:12:WU03:FS02:0x22:     Memory: 31.95GiB
08:46:12:WU03:FS02:0x22:Free Memory: 25.42GiB
08:46:12:WU03:FS02:0x22:    Threads: WINDOWS_THREADS
08:46:12:WU03:FS02:0x22: OS Version: 6.2
08:46:12:WU03:FS02:0x22:Has Battery: false
08:46:12:WU03:FS02:0x22: On Battery: false
08:46:12:WU03:FS02:0x22: UTC Offset: 0
08:46:12:WU03:FS02:0x22:        PID: 5236
08:46:12:WU03:FS02:0x22:        CWD: C:\Users\snudd\AppData\Roaming\FAHClient\work
08:46:12:WU03:FS02:0x22:         OS: Windows 10 Pro
08:46:12:WU03:FS02:0x22:    OS Arch: AMD64
08:46:12:WU03:FS02:0x22:********************************************************************************
08:46:12:WU03:FS02:0x22:Project: 11778 (Run 0, Clone 16449, Gen 0)
08:46:12:WU03:FS02:0x22:Unit: 0x00000003287234c95e7749587d9a0344
08:46:12:WU03:FS02:0x22:Reading tar file core.xml
08:46:12:WU03:FS02:0x22:Reading tar file integrator.xml
08:46:12:WU03:FS02:0x22:Reading tar file state.xml
08:46:12:WU03:FS02:0x22:Reading tar file system.xml
08:46:12:WU03:FS02:0x22:Digital signatures verified
08:46:12:WU03:FS02:0x22:Folding@home GPU Core22 Folding@home Core
08:46:12:WU03:FS02:0x22:Version 0.0.2
08:46:17:WU03:FS02:0x22:Completed 0 out of 2000000 steps (0%)
08:46:17:WU03:FS02:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
08:47:36:WU03:FS02:0x22:Completed 20000 out of 2000000 steps (1%)
08:48:55:WU03:FS02:0x22:Completed 40000 out of 2000000 steps (2%)
08:50:16:WU03:FS02:0x22:Completed 60000 out of 2000000 steps (3%)
08:51:36:WU03:FS02:0x22:Completed 80000 out of 2000000 steps (4%)
08:52:55:WU03:FS02:0x22:Completed 100000 out of 2000000 steps (5%)
08:54:17:WU03:FS02:0x22:Completed 120000 out of 2000000 steps (6%)
08:55:36:WU03:FS02:0x22:Completed 140000 out of 2000000 steps (7%)
08:56:58:WU03:FS02:0x22:Completed 160000 out of 2000000 steps (8%)
08:58:18:WU03:FS02:0x22:Completed 180000 out of 2000000 steps (9%)
08:59:37:WU03:FS02:0x22:Completed 200000 out of 2000000 steps (10%)
09:00:59:WU03:FS02:0x22:Completed 220000 out of 2000000 steps (11%)
09:02:18:WU03:FS02:0x22:Completed 240000 out of 2000000 steps (12%)
09:03:40:WU03:FS02:0x22:Completed 260000 out of 2000000 steps (13%)
09:05:00:WU03:FS02:0x22:Completed 280000 out of 2000000 steps (14%)
09:06:19:WU03:FS02:0x22:Completed 300000 out of 2000000 steps (15%)
09:07:41:WU03:FS02:0x22:Completed 320000 out of 2000000 steps (16%)
09:09:00:WU03:FS02:0x22:Completed 340000 out of 2000000 steps (17%)
09:10:22:WU03:FS02:0x22:Completed 360000 out of 2000000 steps (18%)
09:11:42:WU03:FS02:0x22:Completed 380000 out of 2000000 steps (19%)
09:13:01:WU03:FS02:0x22:Completed 400000 out of 2000000 steps (20%)
09:14:23:WU03:FS02:0x22:Completed 420000 out of 2000000 steps (21%)
09:15:43:WU03:FS02:0x22:Completed 440000 out of 2000000 steps (22%)
09:17:04:WU03:FS02:0x22:Completed 460000 out of 2000000 steps (23%)
09:18:24:WU03:FS02:0x22:Completed 480000 out of 2000000 steps (24%)
09:19:44:WU03:FS02:0x22:Completed 500000 out of 2000000 steps (25%)
09:21:05:WU03:FS02:0x22:Completed 520000 out of 2000000 steps (26%)
09:22:25:WU03:FS02:0x22:Completed 540000 out of 2000000 steps (27%)
09:23:46:WU03:FS02:0x22:Completed 560000 out of 2000000 steps (28%)
09:25:06:WU03:FS02:0x22:Completed 580000 out of 2000000 steps (29%)
09:26:26:WU03:FS02:0x22:Completed 600000 out of 2000000 steps (30%)
09:27:47:WU03:FS02:0x22:Completed 620000 out of 2000000 steps (31%)
09:29:07:WU03:FS02:0x22:Completed 640000 out of 2000000 steps (32%)
09:30:28:WU03:FS02:0x22:Completed 660000 out of 2000000 steps (33%)
09:31:48:WU03:FS02:0x22:Completed 680000 out of 2000000 steps (34%)
09:33:08:WU03:FS02:0x22:Completed 700000 out of 2000000 steps (35%)
09:34:29:WU03:FS02:0x22:Completed 720000 out of 2000000 steps (36%)
09:35:49:WU03:FS02:0x22:Completed 740000 out of 2000000 steps (37%)
09:37:11:WU03:FS02:0x22:Completed 760000 out of 2000000 steps (38%)
09:38:30:WU03:FS02:0x22:Completed 780000 out of 2000000 steps (39%)
09:39:50:WU03:FS02:0x22:Completed 800000 out of 2000000 steps (40%)
09:41:11:WU03:FS02:0x22:Completed 820000 out of 2000000 steps (41%)
09:42:31:WU03:FS02:0x22:Completed 840000 out of 2000000 steps (42%)
09:43:53:WU03:FS02:0x22:Completed 860000 out of 2000000 steps (43%)
09:45:12:WU03:FS02:0x22:Completed 880000 out of 2000000 steps (44%)
09:46:32:WU03:FS02:0x22:Completed 900000 out of 2000000 steps (45%)
09:47:54:WU03:FS02:0x22:Completed 920000 out of 2000000 steps (46%)
09:49:13:WU03:FS02:0x22:Completed 940000 out of 2000000 steps (47%)
09:50:35:WU03:FS02:0x22:Completed 960000 out of 2000000 steps (48%)
09:51:55:WU03:FS02:0x22:Completed 980000 out of 2000000 steps (49%)
09:53:14:WU03:FS02:0x22:Completed 1000000 out of 2000000 steps (50%)
09:54:36:WU03:FS02:0x22:Completed 1020000 out of 2000000 steps (51%)
09:55:56:WU03:FS02:0x22:Completed 1040000 out of 2000000 steps (52%)
09:57:17:WU03:FS02:0x22:Completed 1060000 out of 2000000 steps (53%)
09:58:37:WU03:FS02:0x22:Completed 1080000 out of 2000000 steps (54%)
09:59:56:WU03:FS02:0x22:Completed 1100000 out of 2000000 steps (55%)
10:01:18:WU03:FS02:0x22:Completed 1120000 out of 2000000 steps (56%)
10:02:37:WU03:FS02:0x22:Completed 1140000 out of 2000000 steps (57%)
10:03:59:WU03:FS02:0x22:Completed 1160000 out of 2000000 steps (58%)
10:05:19:WU03:FS02:0x22:Completed 1180000 out of 2000000 steps (59%)
10:06:38:WU03:FS02:0x22:Completed 1200000 out of 2000000 steps (60%)
10:08:00:WU03:FS02:0x22:Completed 1220000 out of 2000000 steps (61%)
10:09:20:WU03:FS02:0x22:Completed 1240000 out of 2000000 steps (62%)
10:10:41:WU03:FS02:0x22:Completed 1260000 out of 2000000 steps (63%)
10:12:01:WU03:FS02:0x22:Completed 1280000 out of 2000000 steps (64%)
10:13:22:WU03:FS02:0x22:Completed 1300000 out of 2000000 steps (65%)
10:14:43:WU03:FS02:0x22:Completed 1320000 out of 2000000 steps (66%)
10:16:03:WU03:FS02:0x22:Completed 1340000 out of 2000000 steps (67%)
10:17:24:WU03:FS02:0x22:Completed 1360000 out of 2000000 steps (68%)
10:18:44:WU03:FS02:0x22:Completed 1380000 out of 2000000 steps (69%)
10:20:04:WU03:FS02:0x22:Completed 1400000 out of 2000000 steps (70%)
10:21:26:WU03:FS02:0x22:Completed 1420000 out of 2000000 steps (71%)
10:22:45:WU03:FS02:0x22:Completed 1440000 out of 2000000 steps (72%)
10:24:07:WU03:FS02:0x22:Completed 1460000 out of 2000000 steps (73%)
10:25:26:WU03:FS02:0x22:Completed 1480000 out of 2000000 steps (74%)
10:26:46:WU03:FS02:0x22:Completed 1500000 out of 2000000 steps (75%)
10:28:08:WU03:FS02:0x22:Completed 1520000 out of 2000000 steps (76%)
10:29:27:WU03:FS02:0x22:Completed 1540000 out of 2000000 steps (77%)
10:30:49:WU03:FS02:0x22:Completed 1560000 out of 2000000 steps (78%)
10:32:08:WU03:FS02:0x22:Completed 1580000 out of 2000000 steps (79%)
10:33:28:WU03:FS02:0x22:Completed 1600000 out of 2000000 steps (80%)
10:34:50:WU03:FS02:0x22:Completed 1620000 out of 2000000 steps (81%)
10:36:09:WU03:FS02:0x22:Completed 1640000 out of 2000000 steps (82%)
10:37:31:WU03:FS02:0x22:Completed 1660000 out of 2000000 steps (83%)
10:38:50:WU03:FS02:0x22:Completed 1680000 out of 2000000 steps (84%)
10:40:10:WU03:FS02:0x22:Completed 1700000 out of 2000000 steps (85%)
10:41:32:WU03:FS02:0x22:Completed 1720000 out of 2000000 steps (86%)
10:42:51:WU03:FS02:0x22:Completed 1740000 out of 2000000 steps (87%)
10:44:13:WU03:FS02:0x22:Completed 1760000 out of 2000000 steps (88%)
10:45:32:WU03:FS02:0x22:Completed 1780000 out of 2000000 steps (89%)
10:46:51:WU03:FS02:0x22:Completed 1800000 out of 2000000 steps (90%)
10:48:12:WU03:FS02:0x22:Completed 1820000 out of 2000000 steps (91%)
10:49:32:WU03:FS02:0x22:Completed 1840000 out of 2000000 steps (92%)
10:50:53:WU03:FS02:0x22:Completed 1860000 out of 2000000 steps (93%)
10:52:12:WU03:FS02:0x22:Completed 1880000 out of 2000000 steps (94%)
10:53:31:WU03:FS02:0x22:Completed 1900000 out of 2000000 steps (95%)
10:54:52:WU03:FS02:0x22:Completed 1920000 out of 2000000 steps (96%)
10:56:12:WU03:FS02:0x22:Completed 1940000 out of 2000000 steps (97%)
10:57:33:WU03:FS02:0x22:Completed 1960000 out of 2000000 steps (98%)
10:58:52:WU03:FS02:0x22:Completed 1980000 out of 2000000 steps (99%)
10:58:53:WU01:FS02:Connecting to 65.254.110.245:8080
10:58:53:WARNING:WU01:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:58:53:WU01:FS02:Connecting to 18.218.241.186:80
10:58:54:WARNING:WU01:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:58:54:ERROR:WU01:FS02:Exception: Could not get an assignment
10:58:54:WU01:FS02:Connecting to 65.254.110.245:8080
10:58:55:WARNING:WU01:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:58:55:WU01:FS02:Connecting to 18.218.241.186:80
10:58:55:WARNING:WU01:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:58:55:ERROR:WU01:FS02:Exception: Could not get an assignment
10:59:54:WU01:FS02:Connecting to 65.254.110.245:8080
10:59:55:WARNING:WU01:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:59:55:WU01:FS02:Connecting to 18.218.241.186:80
10:59:55:WARNING:WU01:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:59:55:ERROR:WU01:FS02:Exception: Could not get an assignment
11:00:11:WU03:FS02:0x22:Completed 2000000 out of 2000000 steps (100%)
11:00:13:WU03:FS02:0x22:Saving result file ..\logfile_01.txt
11:00:13:WU03:FS02:0x22:Saving result file checkpointState.xml
11:00:13:WU03:FS02:0x22:Saving result file checkpt.crc
11:00:13:WU03:FS02:0x22:Saving result file positions.xtc
11:00:13:WU03:FS02:0x22:Saving result file science.log
11:00:13:WU03:FS02:0x22:Folding@home Core Shutdown: FINISHED_UNIT
11:00:14:WU03:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:00:14:WU03:FS02:Sending unit results: id:03 state:SEND error:NO_ERROR project:11778 run:0 clone:16449 gen:0 core:0x22 unit:0x00000003287234c95e7749587d9a0344
11:00:14:WU03:FS02:Uploading 23.05MiB to 40.114.52.201
11:00:14:WU03:FS02:Connecting to 40.114.52.201:8080
11:00:21:WU03:FS02:Upload 0.27%
11:01:31:WU01:FS02:Connecting to 65.254.110.245:8080
11:01:32:WARNING:WU01:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:01:32:WU01:FS02:Connecting to 18.218.241.186:80
11:01:32:WARNING:WU01:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:01:32:ERROR:WU01:FS02:Exception: Could not get an assignment
11:01:33:WU03:FS02:Upload 0.54%
11:01:33:WARNING:WU03:FS02:Exception: Failed to send results to work server: Transfer failed
11:01:33:WU03:FS02:Trying to send results to collection server
11:01:33:WU03:FS02:Uploading 23.05MiB to 128.252.203.9
11:01:33:WU03:FS02:Connecting to 128.252.203.9:8080
11:01:39:WU03:FS02:Upload 11.12%
11:01:47:WU03:FS02:Upload 17.63%
11:01:53:WU03:FS02:Upload 24.68%
11:02:01:WU03:FS02:Upload 38.51%
11:02:08:WU03:FS02:Upload 53.70%
11:02:14:WU03:FS02:Upload 79.46%
11:02:20:WU03:FS02:Upload 92.21%
11:02:23:WU03:FS02:Upload complete
11:02:23:WU03:FS02:Server responded WORK_ACK (400)
11:02:23:WU03:FS02:Final credit estimate, 9405.00 points
11:02:23:WU03:FS02:Cleaning up
11:04:08:WU01:FS02:Connecting t
PedroDuarte
Hardware configuration: Server:
CPU: Xeon Silver 4208 @ 2.1Ghz
GPU0 : P2000
GPU1 : P2000
Laptop Windows:
CPU : i5-8365U @ 1.9 Ghz
Raspberry pi 3b: other projects
Post by PedroDuarte »
Having the same issue multiples my project i'm doing i receive only the base credit or just like this one i receive nothing at all.
Project: 11777 (Run 0, Clone 21599, Gen 0) - No credits received but on logs says +9k to receive.
14:42:18:WU00:FS00:Connecting to 65.254.110.245:8080
14:42:19:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:42:19:WU00:FS00:Connecting to 18.218.241.186:80
14:42:20:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:42:20:ERROR:WU00:FS00:Exception: Could not get an assignment
14:42:20:WU00:FS00:Connecting to 65.254.110.245:8080
14:42:22:WU00:FS00:Assigned to work server 40.114.52.201
14:42:22:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GP106GL [Quadro P2000] [MED-XN71]  3935 from 40.114.52.201
14:42:22:WU00:FS00:Connecting to 40.114.52.201:8080
14:44:31:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
14:44:31:WU00:FS00:Connecting to 40.114.52.201:80
14:45:02:WU00:FS00:Downloading 29.75MiB
14:45:08:WU00:FS00:Download 15.54%
14:45:14:WU00:FS00:Download 23.74%
14:45:20:WU00:FS00:Download 40.33%
14:45:26:WU00:FS00:Download 54.83%
14:45:32:WU00:FS00:Download 65.96%
14:45:40:WU00:FS00:Download 79.82%
14:45:46:WU00:FS00:Download 94.32%
14:45:48:WU00:FS00:Download complete
14:45:49:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11777 run:0 clone:21599 gen:0 core:0x22 unit:0x00000003287234c95e774a2a35fe5f94
14:45:49:WU00:FS00:Starting
14:45:49:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 705 -lifeline 2579 -checkpoint 3 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
14:45:49:WU00:FS00:Started FahCore on PID 4281
14:45:49:WU00:FS00:Core PID:4285
14:45:49:WU00:FS00:FahCore 0x22 started
14:45:49:WU00:FS00:0x22:*********************** Log Started 2020-03-28T14:45:49Z ***********************
14:45:49:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
14:45:49:WU00:FS00:0x22:       Type: 0x22
14:45:49:WU00:FS00:0x22:       Core: Core22
14:45:49:WU00:FS00:0x22:    Website: https://foldingathome.org/
14:45:49:WU00:FS00:0x22:  Copyright: (c) 2009-2018 foldingathome.org
14:45:49:WU00:FS00:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
14:45:49:WU00:FS00:0x22:             <rafal.wiewiora@choderalab.org>
14:45:49:WU00:FS00:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 4281 -checkpoint 3
14:45:49:WU00:FS00:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
14:45:49:WU00:FS00:0x22:             0 -gpu 0
14:45:49:WU00:FS00:0x22:     Config: <none>
14:45:49:WU00:FS00:0x22:************************************ Build *************************************
14:45:49:WU00:FS00:0x22:    Version: 0.0.2
14:45:49:WU00:FS00:0x22:       Date: Dec 6 2019
14:45:49:WU00:FS00:0x22:       Time: 21:20:17
14:45:49:WU00:FS00:0x22: Repository: Git
14:45:49:WU00:FS00:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
14:45:49:WU00:FS00:0x22:     Branch: core22
14:45:49:WU00:FS00:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
14:45:49:WU00:FS00:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
14:45:49:WU00:FS00:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
14:45:49:WU00:FS00:0x22:       Bits: 64
14:45:49:WU00:FS00:0x22:       Mode: Release
14:45:49:WU00:FS00:0x22:************************************ System ************************************
14:45:49:WU00:FS00:0x22:        CPU: Intel(R) Xeon(R) Silver 4208 CPU @ 2.10GHz
14:45:49:WU00:FS00:0x22:     CPU ID: GenuineIntel Family 6 Model 85 Stepping 7
14:45:49:WU00:FS00:0x22:       CPUs: 6
14:45:49:WU00:FS00:0x22:     Memory: 7.79GiB
14:45:49:WU00:FS00:0x22:Free Memory: 5.94GiB
14:45:49:WU00:FS00:0x22:    Threads: POSIX_THREADS
14:45:49:WU00:FS00:0x22: OS Version: 4.15
14:45:49:WU00:FS00:0x22:Has Battery: false
14:45:49:WU00:FS00:0x22: On Battery: false
14:45:49:WU00:FS00:0x22: UTC Offset: 0
14:45:49:WU00:FS00:0x22:        PID: 4285
14:45:49:WU00:FS00:0x22:        CWD: /var/lib/fahclient/work
14:45:49:WU00:FS00:0x22:         OS: Linux 4.15.0-91-generic x86_64
14:45:49:WU00:FS00:0x22:    OS Arch: AMD64
14:45:49:WU00:FS00:0x22:********************************************************************************
14:45:49:WU00:FS00:0x22:Project: 11777 (Run 0, Clone 21599, Gen 0)
14:45:49:WU00:FS00:0x22:Unit: 0x00000003287234c95e774a2a35fe5f94
14:45:49:WU00:FS00:0x22:Reading tar file core.xml
14:45:49:WU00:FS00:0x22:Reading tar file integrator.xml
14:45:49:WU00:FS00:0x22:Reading tar file state.xml
14:45:49:WU00:FS00:0x22:Reading tar file system.xml
14:45:49:WU00:FS00:0x22:Digital signatures verified
14:45:49:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
14:45:49:WU00:FS00:0x22:Version 0.0.2
14:46:02:WU00:FS00:0x22:Completed 0 out of 2000000 steps (0%)
14:46:02:WU00:FS00:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
14:48:32:WU00:FS00:0x22:Completed 20000 out of 2000000 steps (1%)
14:51:01:WU00:FS00:0x22:Completed 40000 out of 2000000 steps (2%)
14:53:33:WU00:FS00:0x22:Completed 60000 out of 2000000 steps (3%)
14:56:02:WU00:FS00:0x22:Completed 80000 out of 2000000 steps (4%)
14:58:32:WU00:FS00:0x22:Completed 100000 out of 2000000 steps (5%)
15:01:06:WU00:FS00:0x22:Completed 120000 out of 2000000 steps (6%)
15:03:36:WU00:FS00:0x22:Completed 140000 out of 2000000 steps (7%)
15:06:08:WU00:FS00:0x22:Completed 160000 out of 2000000 steps (8%)
15:08:38:WU00:FS00:0x22:Completed 180000 out of 2000000 steps (9%)
15:11:08:WU00:FS00:0x22:Completed 200000 out of 2000000 steps (10%)
15:13:41:WU00:FS00:0x22:Completed 220000 out of 2000000 steps (11%)
15:16:11:WU00:FS00:0x22:Completed 240000 out of 2000000 steps (12%)
15:18:45:WU00:FS00:0x22:Completed 260000 out of 2000000 steps (13%)
15:21:15:WU00:FS00:0x22:Completed 280000 out of 2000000 steps (14%)
15:23:45:WU00:FS00:0x22:Completed 300000 out of 2000000 steps (15%)
15:26:17:WU00:FS00:0x22:Completed 320000 out of 2000000 steps (16%)
15:28:47:WU00:FS00:0x22:Completed 340000 out of 2000000 steps (17%)
15:31:21:WU00:FS00:0x22:Completed 360000 out of 2000000 steps (18%)
15:33:51:WU00:FS00:0x22:Completed 380000 out of 2000000 steps (19%)
15:36:21:WU00:FS00:0x22:Completed 400000 out of 2000000 steps (20%)
15:38:54:WU00:FS00:0x22:Completed 420000 out of 2000000 steps (21%)
15:41:24:WU00:FS00:0x22:Completed 440000 out of 2000000 steps (22%)
15:43:57:WU00:FS00:0x22:Completed 460000 out of 2000000 steps (23%)
15:46:27:WU00:FS00:0x22:Completed 480000 out of 2000000 steps (24%)
15:48:57:WU00:FS00:0x22:Completed 500000 out of 2000000 steps (25%)
15:51:30:WU00:FS00:0x22:Completed 520000 out of 2000000 steps (26%)
15:54:00:WU00:FS00:0x22:Completed 540000 out of 2000000 steps (27%)
15:56:33:WU00:FS00:0x22:Completed 560000 out of 2000000 steps (28%)
15:59:03:WU00:FS00:0x22:Completed 580000 out of 2000000 steps (29%)
16:01:33:WU00:FS00:0x22:Completed 600000 out of 2000000 steps (30%)
16:04:06:WU00:FS00:0x22:Completed 620000 out of 2000000 steps (31%)
16:06:35:WU00:FS00:0x22:Completed 640000 out of 2000000 steps (32%)
16:09:08:WU00:FS00:0x22:Completed 660000 out of 2000000 steps (33%)
16:11:38:WU00:FS00:0x22:Completed 680000 out of 2000000 steps (34%)
16:14:08:WU00:FS00:0x22:Completed 700000 out of 2000000 steps (35%)
16:16:42:WU00:FS00:0x22:Completed 720000 out of 2000000 steps (36%)
16:19:12:WU00:FS00:0x22:Completed 740000 out of 2000000 steps (37%)
16:21:45:WU00:FS00:0x22:Completed 760000 out of 2000000 steps (38%)
16:24:15:WU00:FS00:0x22:Completed 780000 out of 2000000 steps (39%)
16:26:46:WU00:FS00:0x22:Completed 800000 out of 2000000 steps (40%)
16:29:19:WU00:FS00:0x22:Completed 820000 out of 2000000 steps (41%)
16:31:49:WU00:FS00:0x22:Completed 840000 out of 2000000 steps (42%)
16:34:21:WU00:FS00:0x22:Completed 860000 out of 2000000 steps (43%)
16:36:51:WU00:FS00:0x22:Completed 880000 out of 2000000 steps (44%)
16:39:22:WU00:FS00:0x22:Completed 900000 out of 2000000 steps (45%)
16:41:54:WU00:FS00:0x22:Completed 920000 out of 2000000 steps (46%)
16:44:24:WU00:FS00:0x22:Completed 940000 out of 2000000 steps (47%)
16:46:57:WU00:FS00:0x22:Completed 960000 out of 2000000 steps (48%)
16:49:27:WU00:FS00:0x22:Completed 980000 out of 2000000 steps (49%)
16:51:58:WU00:FS00:0x22:Completed 1000000 out of 2000000 steps (50%)
16:54:30:WU00:FS00:0x22:Completed 1020000 out of 2000000 steps (51%)
16:57:01:WU00:FS00:0x22:Completed 1040000 out of 2000000 steps (52%)
16:59:34:WU00:FS00:0x22:Completed 1060000 out of 2000000 steps (53%)
17:02:04:WU00:FS00:0x22:Completed 1080000 out of 2000000 steps (54%)
17:04:34:WU00:FS00:0x22:Completed 1100000 out of 2000000 steps (55%)
17:07:07:WU00:FS00:0x22:Completed 1120000 out of 2000000 steps (56%)
17:09:37:WU00:FS00:0x22:Completed 1140000 out of 2000000 steps (57%)
17:12:10:WU00:FS00:0x22:Completed 1160000 out of 2000000 steps (58%)
17:14:40:WU00:FS00:0x22:Completed 1180000 out of 2000000 steps (59%)
17:17:11:WU00:FS00:0x22:Completed 1200000 out of 2000000 steps (60%)
17:19:44:WU00:FS00:0x22:Completed 1220000 out of 2000000 steps (61%)
17:22:15:WU00:FS00:0x22:Completed 1240000 out of 2000000 steps (62%)
17:24:48:WU00:FS00:0x22:Completed 1260000 out of 2000000 steps (63%)
17:27:18:WU00:FS00:0x22:Completed 1280000 out of 2000000 steps (64%)
17:29:48:WU00:FS00:0x22:Completed 1300000 out of 2000000 steps (65%)
17:32:22:WU00:FS00:0x22:Completed 1320000 out of 2000000 steps (66%)
17:34:52:WU00:FS00:0x22:Completed 1340000 out of 2000000 steps (67%)
17:37:26:WU00:FS00:0x22:Completed 1360000 out of 2000000 steps (68%)
17:39:56:WU00:FS00:0x22:Completed 1380000 out of 2000000 steps (69%)
17:42:26:WU00:FS00:0x22:Completed 1400000 out of 2000000 steps (70%)
17:45:00:WU00:FS00:0x22:Completed 1420000 out of 2000000 steps (71%)
17:47:30:WU00:FS00:0x22:Completed 1440000 out of 2000000 steps (72%)
17:50:03:WU00:FS00:0x22:Completed 1460000 out of 2000000 steps (73%)
17:52:33:WU00:FS00:0x22:Completed 1480000 out of 2000000 steps (74%)
17:55:03:WU00:FS00:0x22:Completed 1500000 out of 2000000 steps (75%)
17:57:37:WU00:FS00:0x22:Completed 1520000 out of 2000000 steps (76%)
18:00:07:WU00:FS00:0x22:Completed 1540000 out of 2000000 steps (77%)
18:02:41:WU00:FS00:0x22:Completed 1560000 out of 2000000 steps (78%)
18:05:11:WU00:FS00:0x22:Completed 1580000 out of 2000000 steps (79%)
18:07:41:WU00:FS00:0x22:Completed 1600000 out of 2000000 steps (80%)
18:10:13:WU00:FS00:0x22:Completed 1620000 out of 2000000 steps (81%)
18:12:43:WU00:FS00:0x22:Completed 1640000 out of 2000000 steps (82%)
18:15:17:WU00:FS00:0x22:Completed 1660000 out of 2000000 steps (83%)
18:17:47:WU00:FS00:0x22:Completed 1680000 out of 2000000 steps (84%)
18:20:18:WU00:FS00:0x22:Completed 1700000 out of 2000000 steps (85%)
18:22:51:WU00:FS00:0x22:Completed 1720000 out of 2000000 steps (86%)
18:25:21:WU00:FS00:0x22:Completed 1740000 out of 2000000 steps (87%)
18:27:55:WU00:FS00:0x22:Completed 1760000 out of 2000000 steps (88%)
18:30:25:WU00:FS00:0x22:Completed 1780000 out of 2000000 steps (89%)
18:32:55:WU00:FS00:0x22:Completed 1800000 out of 2000000 steps (90%)
18:35:29:WU00:FS00:0x22:Completed 1820000 out of 2000000 steps (91%)
18:37:59:WU00:FS00:0x22:Completed 1840000 out of 2000000 steps (92%)
18:40:31:WU00:FS00:0x22:Completed 1860000 out of 2000000 steps (93%)
18:43:02:WU00:FS00:0x22:Completed 1880000 out of 2000000 steps (94%)
18:45:32:WU00:FS00:0x22:Completed 1900000 out of 2000000 steps (95%)
18:48:06:WU00:FS00:0x22:Completed 1920000 out of 2000000 steps (96%)
18:50:37:WU00:FS00:0x22:Completed 1940000 out of 2000000 steps (97%)
18:53:10:WU00:FS00:0x22:Completed 1960000 out of 2000000 steps (98%)
18:55:41:WU00:FS00:0x22:Completed 1980000 out of 2000000 steps (99%)
18:55:42:WU01:FS00:Connecting to 65.254.110.245:8080
18:55:42:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:55:42:WU01:FS00:Connecting to 18.218.241.186:80
18:55:43:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:55:43:ERROR:WU01:FS00:Exception: Could not get an assignment
18:55:43:WU01:FS00:Connecting to 65.254.110.245:8080
18:55:44:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:55:44:WU01:FS00:Connecting to 18.218.241.186:80
18:55:44:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:55:44:ERROR:WU01:FS00:Exception: Could not get an assignment
18:56:43:WU01:FS00:Connecting to 65.254.110.245:8080
18:56:44:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:56:44:WU01:FS00:Connecting to 18.218.241.186:80
18:56:44:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:56:44:ERROR:WU01:FS00:Exception: Could not get an assignment
18:58:11:WU00:FS00:0x22:Completed 2000000 out of 2000000 steps (100%)
18:58:15:WU00:FS00:0x22:Saving result file ../logfile_01.txt
18:58:15:WU00:FS00:0x22:Saving result file checkpointState.xml
18:58:15:WU00:FS00:0x22:Saving result file checkpt.crc
18:58:15:WU00:FS00:0x22:Saving result file positions.xtc
18:58:15:WU00:FS00:0x22:Saving result file science.log
18:58:15:WU00:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
18:58:15:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:58:15:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:11777 run:0 clone:21599 gen:0 core:0x22 unit:0x00000003287234c95e774a2a35fe5f94
18:58:15:WU00:FS00:Uploading 23.08MiB to 40.114.52.201
18:58:15:WU00:FS00:Connecting to 40.114.52.201:8080
18:58:20:WU01:FS00:Connecting to 65.254.110.245:8080
18:58:21:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:58:21:WU01:FS00:Connecting to 18.218.241.186:80
18:58:21:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:58:21:ERROR:WU01:FS00:Exception: Could not get an assignment
18:58:31:WU00:FS00:Upload 0.27%
18:58:50:WU00:FS00:Upload 0.54%
18:58:50:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
18:58:50:WU00:FS00:Trying to send results to collection server
18:58:50:WU00:FS00:Uploading 23.08MiB to 128.252.203.10
18:58:50:WU00:FS00:Connecting to 128.252.203.10:8080
18:59:22:WU00:FS00:Upload 0.27%
19:00:12:WU00:FS00:Upload 1.63%
19:00:18:WU00:FS00:Upload 21.67%
19:00:24:WU00:FS00:Upload 60.13%
19:00:30:WU00:FS00:Upload 96.15%
19:00:32:WU00:FS00:Upload complete
19:00:32:WU00:FS00:Server responded WORK_ACK (400)
19:00:32:WU00:FS00:Final credit estimate, 9405.00 points
19:00:32:WU00:FS00:Cleaning up
19:00:58:WU01:FS00:Connecting to 65.254.110.245:8080
19:00:58:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
I understand the servers are super busy and that is creating multiples issues as no credit WU, base or random credits for WU, server dumping WU, etc ...
Is any way the community be able to solve this? Can i help on a sort of way?
Re: Randomly getting base credit (9405) on COVID-19 projects
Thanks for the report. Apparently when the results were uploaded, they didn't go directly to the Work Server and were redirected to the Collection Server. Due to the overwhelming number of FAH Clients running, our servers' bandwidth has been saturated. Credit records for work that are being cached on the CS have been queued up and have not been able to be transferred into the stream of credit reports going to the database. It may be a while before you see your credit, but I've been assured that they'll show up eventually.
:roll: I'm not sure which will happen first: The points will appear in the official results or we'll find a cure for COVAID19 and the FAH surge will dissipate. :P
Post by Neil-B »
tbh I'd be happy if it were the later :)
grimery
Post by grimery »
This is happening to me too for some jobs that are worth 90K+.
Latest happened about 20 minutes ago from time of this posting.
  • Project: 11777
    Server uploaded to: 13.90.152.57
    Points awarded: 9405
02:38:32:WU03:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
02:38:36:WU03:FS01:0x22:Saving result file ..\logfile_01.txt
02:38:36:WU03:FS01:0x22:Saving result file checkpointState.xml
02:38:36:WU03:FS01:0x22:Saving result file checkpt.crc
02:38:36:WU03:FS01:0x22:Saving result file positions.xtc
02:38:36:WU03:FS01:0x22:Saving result file science.log
02:38:36:WU03:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
02:38:36:WU03:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:38:36:WU03:FS01:Sending unit results: id:03 state:SEND error:NO_ERROR project:11777 run:0 clone:21165 gen:2 core:0x22 unit:0x00000007287234c95e774a32889655d9
02:38:36:WU03:FS01:Uploading 23.06MiB to 40.114.52.201
02:38:36:WU03:FS01:Connecting to 40.114.52.201:8080
2:38:57:WARNING:WU03:FS01:WorkServer connection failed on port 8080 trying 80
02:38:57:WU03:FS01:Connecting to 40.114.52.201:80
02:39:19:WARNING:WU03:FS01:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
02:39:19:WU03:FS01:Trying to send results to collection server
02:39:19:WU03:FS01:Uploading 23.06MiB to 13.90.152.57
02:39:19:WU03:FS01:Connecting to 13.90.152.57:8080
02:39:32:WU03:FS01:Upload 0.81%
02:39:38:WU03:FS01:Upload 3.79%
02:39:44:WU03:FS01:Upload 8.67%
02:39:50:WU03:FS01:Upload 13.55%
02:39:56:WU03:FS01:Upload 16.80%
02:40:02:WU03:FS01:Upload 20.32%
02:40:08:WU03:FS01:Upload 23.31%
02:40:14:WU03:FS01:Upload 26.29%
02:40:20:WU03:FS01:Upload 29.27%
02:40:26:WU03:FS01:Upload 32.25%
02:40:32:WU03:FS01:Upload 36.31%
02:40:38:WU03:FS01:Upload 39.56%
02:40:44:WU03:FS01:Upload 42.82%
02:40:50:WU03:FS01:Upload 47.42%
02:40:56:WU03:FS01:Upload 50.68%
02:41:02:WU03:FS01:Upload 54.20%
02:41:08:WU03:FS01:Upload 58.53%
02:41:14:WU03:FS01:Upload 61.79%
02:41:20:WU03:FS01:Upload 64.22%
02:41:26:WU03:FS01:Upload 69.37%
02:41:32:WU03:FS01:Upload 72.63%
02:41:38:WU03:FS01:Upload 77.77%
02:41:44:WU03:FS01:Upload 82.92%
02:41:50:WU03:FS01:Upload 87.80%
02:41:56:WU03:FS01:Upload 92.14%
02:42:02:WU03:FS01:Upload 95.66%
02:42:08:WU03:FS01:Upload 96.20%
02:42:14:WU03:FS01:Upload 98.91%
02:42:21:WU03:FS01:Upload complete
02:42:21:WU03:FS01:Server responded WORK_ACK (400)
02:42:21:WU03:FS01:Final credit estimate, 9405.00 points
02:42:21:WU03:FS01:Cleaning up
According to https://apps.foldingathome.org/wu#proje ... 1165&gen=2 you have NOT received credit for that WU yet.
Per my earlier post, at this time FAH is not able to process the credits promptly.
alxbelu
Post by alxbelu »
bruce wrote:According to https://apps.foldingathome.org/wu#proje ... 1165&gen=2 you have NOT received credit for that WU yet.
So the CS needs to get a QRB value from the WS to report to the donor client? I.e. I get that there might be a delay before credits are awarded/listed on the web, but does it also affect the final credit estimate in the client logs?
I haven't checked through all my logs, but during the night I have one instance of 11777 (0,4415,15) uploading to CS 155.247.166.220 that got a final credit estimate of 9405 (base credit):
22:21:58:WU00:FS01:Assigned to work server 40.114.52.201
22:21:58:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:TU106M [GeForce RTX 2060 Mobile] from 40.114.52.201
22:21:58:WU00:FS01:Connecting to 40.114.52.201:8080
22:22:34:WU00:FS01:Downloading 29.70MiB
22:22:40:WU00:FS01:Download 16.63%
22:22:46:WU00:FS01:Download 38.30%
22:22:53:WU00:FS01:Download 46.51%
22:22:59:WU00:FS01:Download 62.72%
22:23:05:WU00:FS01:Download 77.66%
22:23:11:WU00:FS01:Download 95.13%
22:23:12:WU00:FS01:Download complete
22:23:12:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11777 run:0 clone:4415 gen:15 core:0x22 unit:0x00000018287234c95e73c4304d22baa3
22:23:12:WU00:FS01:Starting
22:23:12:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\aluks\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 1716 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
22:23:12:WU00:FS01:Started FahCore on PID 10832
22:23:12:WU00:FS01:Core PID:20320
22:23:12:WU00:FS01:FahCore 0x22 started
22:23:13:WU00:FS01:0x22:*********************** Log Started 2020-03-28T22:23:12Z ***********************
22:23:13:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
22:23:13:WU00:FS01:0x22:       Type: 0x22
22:23:13:WU00:FS01:0x22:       Core: Core22
22:23:13:WU00:FS01:0x22:    Website: https://foldingathome.org/
22:23:13:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
22:23:13:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
22:23:13:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
22:23:13:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 10832 -checkpoint 15
22:23:13:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
22:23:13:WU00:FS01:0x22:             0 -gpu 0
22:23:13:WU00:FS01:0x22:     Config: <none>
22:23:13:WU00:FS01:0x22:************************************ Build *************************************
22:23:13:WU00:FS01:0x22:    Version: 0.0.2
22:23:13:WU00:FS01:0x22:       Date: Dec 6 2019
22:23:13:WU00:FS01:0x22:       Time: 21:30:31
22:23:13:WU00:FS01:0x22: Repository: Git
22:23:13:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
22:23:13:WU00:FS01:0x22:     Branch: HEAD
22:23:13:WU00:FS01:0x22:   Compiler: Visual C++ 2008
22:23:13:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:23:13:WU00:FS01:0x22:   Platform: win32 10
22:23:13:WU00:FS01:0x22:       Bits: 64
22:23:13:WU00:FS01:0x22:       Mode: Release
22:23:13:WU00:FS01:0x22:************************************ System ************************************
22:23:13:WU00:FS01:0x22:        CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
22:23:13:WU00:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
22:23:13:WU00:FS01:0x22:       CPUs: 12
22:23:13:WU00:FS01:0x22:     Memory: 15.85GiB
22:23:13:WU00:FS01:0x22:Free Memory: 8.44GiB
22:23:13:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
22:23:13:WU00:FS01:0x22: OS Version: 6.2
22:23:13:WU00:FS01:0x22:Has Battery: true
22:23:13:WU00:FS01:0x22: On Battery: false
22:23:13:WU00:FS01:0x22: UTC Offset: 1
22:23:13:WU00:FS01:0x22:        PID: 20320
22:23:13:WU00:FS01:0x22:        CWD: C:\Users\aluks\AppData\Roaming\FAHClient\work
22:23:13:WU00:FS01:0x22:         OS: Windows 10 Home
22:23:13:WU00:FS01:0x22:    OS Arch: AMD64
22:23:13:WU00:FS01:0x22:********************************************************************************
22:23:13:WU00:FS01:0x22:Project: 11777 (Run 0, Clone 4415, Gen 15)
22:23:13:WU00:FS01:0x22:Unit: 0x00000018287234c95e73c4304d22baa3
22:23:13:WU00:FS01:0x22:Reading tar file core.xml
22:23:13:WU00:FS01:0x22:Reading tar file integrator.xml
22:23:13:WU00:FS01:0x22:Reading tar file state.xml
22:23:13:WU00:FS01:0x22:Reading tar file system.xml
22:23:13:WU00:FS01:0x22:Digital signatures verified
22:23:13:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
22:23:13:WU00:FS01:0x22:Version 0.0.2
22:23:28:WU00:FS01:0x22:Completed 0 out of 2000000 steps (0%)
22:23:28:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
22:24:56:WU00:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
22:26:24:WU00:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
22:28:08:WU00:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
22:29:59:WU00:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
22:31:26:WU00:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
22:32:57:WU00:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
22:34:29:WU00:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
22:36:01:WU00:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
22:37:30:WU00:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
22:39:00:WU00:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
22:40:33:WU00:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
22:42:00:WU00:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
22:43:32:WU00:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
22:45:00:WU00:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
22:46:29:WU00:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
22:48:03:WU00:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
22:49:33:WU00:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
22:51:05:WU00:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
22:52:35:WU00:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
22:54:03:WU00:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
22:55:35:WU00:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
22:57:04:WU00:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
22:58:36:WU00:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
23:00:04:WU00:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
23:01:33:WU00:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
23:03:05:WU00:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
23:04:33:WU00:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
23:06:04:WU00:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
23:07:32:WU00:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
23:08:59:WU00:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
23:10:31:WU00:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
23:12:00:WU00:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
23:13:30:WU00:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
23:14:58:WU00:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
23:16:25:WU00:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
23:17:56:WU00:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
23:19:25:WU00:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
23:20:56:WU00:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
23:22:23:WU00:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
23:23:49:WU00:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
23:25:18:WU00:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
23:26:45:WU00:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
23:28:14:WU00:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
23:29:40:WU00:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
23:31:06:WU00:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
23:32:35:WU00:FS01:0x22:Completed 920000 out of 2000000 steps (46%)
23:34:01:WU00:FS01:0x22:Completed 940000 out of 2000000 steps (47%)
23:35:30:WU00:FS01:0x22:Completed 960000 out of 2000000 steps (48%)
23:36:56:WU00:FS01:0x22:Completed 980000 out of 2000000 steps (49%)
23:38:22:WU00:FS01:0x22:Completed 1000000 out of 2000000 steps (50%)
23:39:51:WU00:FS01:0x22:Completed 1020000 out of 2000000 steps (51%)
23:41:16:WU00:FS01:0x22:Completed 1040000 out of 2000000 steps (52%)
23:42:45:WU00:FS01:0x22:Completed 1060000 out of 2000000 steps (53%)
23:44:11:WU00:FS01:0x22:Completed 1080000 out of 2000000 steps (54%)
23:45:37:WU00:FS01:0x22:Completed 1100000 out of 2000000 steps (55%)
23:47:06:WU00:FS01:0x22:Completed 1120000 out of 2000000 steps (56%)
23:48:32:WU00:FS01:0x22:Completed 1140000 out of 2000000 steps (57%)
23:50:01:WU00:FS01:0x22:Completed 1160000 out of 2000000 steps (58%)
23:51:27:WU00:FS01:0x22:Completed 1180000 out of 2000000 steps (59%)
23:52:52:WU00:FS01:0x22:Completed 1200000 out of 2000000 steps (60%)
23:54:21:WU00:FS01:0x22:Completed 1220000 out of 2000000 steps (61%)
23:55:47:WU00:FS01:0x22:Completed 1240000 out of 2000000 steps (62%)
23:57:16:WU00:FS01:0x22:Completed 1260000 out of 2000000 steps (63%)
23:58:42:WU00:FS01:0x22:Completed 1280000 out of 2000000 steps (64%)
00:00:08:WU00:FS01:0x22:Completed 1300000 out of 2000000 steps (65%)
00:01:36:WU00:FS01:0x22:Completed 1320000 out of 2000000 steps (66%)
00:03:00:WU00:FS01:0x22:Completed 1340000 out of 2000000 steps (67%)
00:04:28:WU00:FS01:0x22:Completed 1360000 out of 2000000 steps (68%)
00:05:54:WU00:FS01:0x22:Completed 1380000 out of 2000000 steps (69%)
00:07:19:WU00:FS01:0x22:Completed 1400000 out of 2000000 steps (70%)
00:08:48:WU00:FS01:0x22:Completed 1420000 out of 2000000 steps (71%)
00:10:14:WU00:FS01:0x22:Completed 1440000 out of 2000000 steps (72%)
00:11:42:WU00:FS01:0x22:Completed 1460000 out of 2000000 steps (73%)
00:13:08:WU00:FS01:0x22:Completed 1480000 out of 2000000 steps (74%)
00:14:33:WU00:FS01:0x22:Completed 1500000 out of 2000000 steps (75%)
00:16:02:WU00:FS01:0x22:Completed 1520000 out of 2000000 steps (76%)
00:17:27:WU00:FS01:0x22:Completed 1540000 out of 2000000 steps (77%)
00:18:56:WU00:FS01:0x22:Completed 1560000 out of 2000000 steps (78%)
00:20:21:WU00:FS01:0x22:Completed 1580000 out of 2000000 steps (79%)
00:21:47:WU00:FS01:0x22:Completed 1600000 out of 2000000 steps (80%)
00:23:15:WU00:FS01:0x22:Completed 1620000 out of 2000000 steps (81%)
00:24:41:WU00:FS01:0x22:Completed 1640000 out of 2000000 steps (82%)
00:26:10:WU00:FS01:0x22:Completed 1660000 out of 2000000 steps (83%)
00:27:35:WU00:FS01:0x22:Completed 1680000 out of 2000000 steps (84%)
00:29:01:WU00:FS01:0x22:Completed 1700000 out of 2000000 steps (85%)
00:30:29:WU00:FS01:0x22:Completed 1720000 out of 2000000 steps (86%)
00:31:55:WU00:FS01:0x22:Completed 1740000 out of 2000000 steps (87%)
00:33:23:WU00:FS01:0x22:Completed 1760000 out of 2000000 steps (88%)
00:34:49:WU00:FS01:0x22:Completed 1780000 out of 2000000 steps (89%)
00:36:14:WU00:FS01:0x22:Completed 1800000 out of 2000000 steps (90%)
00:37:42:WU00:FS01:0x22:Completed 1820000 out of 2000000 steps (91%)
00:39:08:WU00:FS01:0x22:Completed 1840000 out of 2000000 steps (92%)
00:40:36:WU00:FS01:0x22:Completed 1860000 out of 2000000 steps (93%)
00:42:02:WU00:FS01:0x22:Completed 1880000 out of 2000000 steps (94%)
00:43:27:WU00:FS01:0x22:Completed 1900000 out of 2000000 steps (95%)
00:44:56:WU00:FS01:0x22:Completed 1920000 out of 2000000 steps (96%)
00:46:21:WU00:FS01:0x22:Completed 1940000 out of 2000000 steps (97%)
00:47:50:WU00:FS01:0x22:Completed 1960000 out of 2000000 steps (98%)
00:49:15:WU00:FS01:0x22:Completed 1980000 out of 2000000 steps (99%)
00:50:41:WU00:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
00:50:44:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
00:50:44:WU00:FS01:0x22:Saving result file checkpointState.xml
00:50:44:WU00:FS01:0x22:Saving result file checkpt.crc
00:50:44:WU00:FS01:0x22:Saving result file positions.xtc
00:50:44:WU00:FS01:0x22:Saving result file science.log
00:50:45:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
00:50:45:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:50:45:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11777 run:0 clone:4415 gen:15 core:0x22 unit:0x00000018287234c95e73c4304d22baa3
00:50:45:WU00:FS01:Uploading 23.06MiB to 40.114.52.201
00:50:45:WU00:FS01:Connecting to 40.114.52.201:8080
00:50:58:WU00:FS01:Upload 0.81%
00:51:06:WU00:FS01:Upload 2.44%
00:51:12:WU00:FS01:Upload 3.52%
00:51:18:WU00:FS01:Upload 5.42%
00:51:26:WU00:FS01:Upload 6.23%
00:51:34:WU00:FS01:Upload 7.32%
00:51:40:WU00:FS01:Upload 8.40%
00:51:46:WU00:FS01:Upload 9.76%
00:51:52:WU00:FS01:Upload 10.30%
00:52:20:WU00:FS01:Upload 11.11%
00:52:20:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
00:52:20:WU00:FS01:Trying to send results to collection server
00:52:20:WU00:FS01:Uploading 23.06MiB to 155.247.166.220
00:52:20:WU00:FS01:Connecting to 155.247.166.220:8080
00:52:26:WU00:FS01:Upload 1.63%
00:52:33:WU00:FS01:Upload 2.98%
00:52:40:WU00:FS01:Upload 4.61%
00:52:46:WU00:FS01:Upload 6.23%
00:52:53:WU00:FS01:Upload 7.05%
00:52:59:WU00:FS01:Upload 8.13%
00:53:05:WU00:FS01:Upload 9.76%
00:53:12:WU00:FS01:Upload 11.38%
00:53:18:WU00:FS01:Upload 13.01%
00:53:24:WU00:FS01:Upload 14.36%
00:53:30:WU00:FS01:Upload 15.72%
00:53:36:WU00:FS01:Upload 18.70%
00:53:42:WU00:FS01:Upload 21.95%
00:53:48:WU00:FS01:Upload 24.93%
00:53:54:WU00:FS01:Upload 27.91%
00:54:00:WU00:FS01:Upload 31.43%
00:54:06:WU00:FS01:Upload 34.41%
00:54:12:WU00:FS01:Upload 37.40%
00:54:18:WU00:FS01:Upload 40.38%
00:54:24:WU00:FS01:Upload 43.09%
00:54:30:WU00:FS01:Upload 45.52%
00:54:36:WU00:FS01:Upload 47.69%
00:54:42:WU00:FS01:Upload 49.32%
00:54:48:WU00:FS01:Upload 52.03%
00:54:54:WU00:FS01:Upload 54.20%
00:55:01:WU00:FS01:Upload 55.82%
00:55:07:WU00:FS01:Upload 57.45%
00:55:13:WU00:FS01:Upload 59.34%
00:55:19:WU00:FS01:Upload 61.24%
00:55:25:WU00:FS01:Upload 63.14%
00:55:31:WU00:FS01:Upload 67.20%
00:55:37:WU00:FS01:Upload 72.89%
00:55:43:WU00:FS01:Upload 77.50%
00:55:49:WU00:FS01:Upload 85.09%
00:55:55:WU00:FS01:Upload 88.61%
00:56:01:WU00:FS01:Upload 93.22%
00:56:07:WU00:FS01:Upload 99.72%
00:56:07:WU00:FS01:Upload complete
00:56:07:WU00:FS01:Server responded WORK_ACK (400)
00:56:07:WU00:FS01:Final credit estimate, 9405.00 points
00:56:07:WU00:FS01:Cleaning up
Official F@H Twitter (frequently updated): https://twitter.com/foldingathome
Official F@H Facebook: https://www.facebook.com/Foldinghome-136059519794607/
(I'm not affiliated with the F@H Team, just promoting these channels for official updates)
The estimate in the client is just based on the WU download and upload times recorded there, not from any value sent from the WS or CS. On the server side the QRB is calculated from the time the WU was assigned and downloaded in their records to the time received on either the WS our CS. If a setting is not correct, then either might credit only the base points.
Part of the current holdup is that stats reports are sent after the WU is sent from the CS to the WS. With the high network traffic that is getting delayed. The developer has said he would be putting out a server update to have the CS send the stats report directly, that would speed up stats for WUs sent to a CS.
The WU you linked has not yet shown up in the stats database, so that estimate in your log should be based on the settings on the client. Check to see if the passkey is entered.
alxbelu
Post by alxbelu »
Joe_H wrote:The estimate in the client is just based on the WU download and upload times recorded there, not from any value sent from the WS or CS.
Then the issue is not likely with my client but with the CS, as you'll note that the other logs in this thread are also seeing incorrect final credit estimates.
Joe_H wrote: If a setting is not correct, then either might credit only the base points.
I've submitted 161 WUs from this particular client, in most cases QRB has been correctly calculated; I can only find one other WU that seems to only have gotten base credit on March 19th, interestingly also not showing up in the stats, and seemingly reassigned after the timeout: 11744 (0,597,7).
The WU immediately before and the WU immediately after this latest base credit WU (11777) calculated correctly. I have not changed the passkey (which was configured since the beginning). This last particular night I guess Europe did switch to DST, but that was after (at 01:00am GMT) the WORK_ACK response at 00:56am GMT.
Here's the next WU the client got, which was correctly awarded the QRB:
02:50:41:WU02:FS01:Connecting to 65.254.110.245:8080
02:50:41:WU02:FS01:Assigned to work server 128.252.203.10
02:50:41:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:TU106M [GeForce RTX 2060 Mobile] from 128.252.203.10
02:50:41:WU02:FS01:Connecting to 128.252.203.10:8080
02:51:29:WU00:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
02:52:05:WU02:FS01:Downloading 50.74MiB
02:52:11:WU02:FS01:Download 11.33%
02:52:17:WU02:FS01:Download 22.79%
02:52:23:WU02:FS01:Download 32.27%
02:52:29:WU02:FS01:Download 43.11%
02:52:35:WU02:FS01:Download 54.57%
02:52:41:WU02:FS01:Download 62.33%
02:52:47:WU02:FS01:Download 68.37%
02:52:53:WU02:FS01:Download 75.51%
02:52:59:WU02:FS01:Download 81.55%
02:53:05:WU02:FS01:Download 87.09%
02:53:11:WU02:FS01:Download 91.77%
02:53:17:WU02:FS01:Download 98.42%
02:53:18:WU02:FS01:Download complete
02:53:18:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11762 run:0 clone:5946 gen:8 core:0x22 unit:0x0000001480fccb0a5e7113e693593f31
02:53:18:WU02:FS01:Starting
02:53:18:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\aluks\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 1716 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
02:53:18:WU02:FS01:Started FahCore on PID 16084
02:53:18:WU02:FS01:Core PID:10268
02:53:18:WU02:FS01:FahCore 0x22 started
02:53:19:WU02:FS01:0x22:*********************** Log Started 2020-03-29T02:53:18Z ***********************
02:53:19:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
02:53:19:WU02:FS01:0x22:       Type: 0x22
02:53:19:WU02:FS01:0x22:       Core: Core22
02:53:19:WU02:FS01:0x22:    Website: https://foldingathome.org/
02:53:19:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
02:53:19:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
02:53:19:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
02:53:19:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 16084 -checkpoint 15
02:53:19:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
02:53:19:WU02:FS01:0x22:             0 -gpu 0
02:53:19:WU02:FS01:0x22:     Config: <none>
02:53:19:WU02:FS01:0x22:************************************ Build *************************************
02:53:19:WU02:FS01:0x22:    Version: 0.0.2
02:53:19:WU02:FS01:0x22:       Date: Dec 6 2019
02:53:19:WU02:FS01:0x22:       Time: 21:30:31
02:53:19:WU02:FS01:0x22: Repository: Git
02:53:19:WU02:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
02:53:19:WU02:FS01:0x22:     Branch: HEAD
02:53:19:WU02:FS01:0x22:   Compiler: Visual C++ 2008
02:53:19:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
02:53:19:WU02:FS01:0x22:   Platform: win32 10
02:53:19:WU02:FS01:0x22:       Bits: 64
02:53:19:WU02:FS01:0x22:       Mode: Release
02:53:19:WU02:FS01:0x22:************************************ System ************************************
02:53:19:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
02:53:19:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
02:53:19:WU02:FS01:0x22:       CPUs: 12
02:53:19:WU02:FS01:0x22:     Memory: 15.85GiB
02:53:19:WU02:FS01:0x22:Free Memory: 8.60GiB
02:53:19:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
02:53:19:WU02:FS01:0x22: OS Version: 6.2
02:53:19:WU02:FS01:0x22:Has Battery: true
02:53:19:WU02:FS01:0x22: On Battery: false
02:53:19:WU02:FS01:0x22: UTC Offset: 2
02:53:19:WU02:FS01:0x22:        PID: 10268
02:53:19:WU02:FS01:0x22:        CWD: C:\Users\aluks\AppData\Roaming\FAHClient\work
02:53:19:WU02:FS01:0x22:         OS: Windows 10 Home
02:53:19:WU02:FS01:0x22:    OS Arch: AMD64
02:53:19:WU02:FS01:0x22:********************************************************************************
02:53:19:WU02:FS01:0x22:Project: 11762 (Run 0, Clone 5946, Gen 8)
02:53:19:WU02:FS01:0x22:Unit: 0x0000001480fccb0a5e7113e693593f31
02:53:19:WU02:FS01:0x22:Reading tar file core.xml
02:53:19:WU02:FS01:0x22:Reading tar file integrator.xml
02:53:19:WU02:FS01:0x22:Reading tar file state.xml
02:53:19:WU02:FS01:0x22:Reading tar file system.xml
02:53:19:WU02:FS01:0x22:Digital signatures verified
02:53:19:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
02:53:19:WU02:FS01:0x22:Version 0.0.2
02:53:39:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
<snip>
04:59:54:WU02:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
04:59:59:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
04:59:59:WU02:FS01:0x22:Saving result file checkpointState.xml
04:59:59:WU02:FS01:0x22:Saving result file checkpt.crc
04:59:59:WU02:FS01:0x22:Saving result file positions.xtc
05:00:00:WU02:FS01:0x22:Saving result file science.log
05:00:00:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
05:00:00:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:00:00:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11762 run:0 clone:5946 gen:8 core:0x22 unit:0x0000001480fccb0a5e7113e693593f31
05:00:00:WU02:FS01:Uploading 33.02MiB to 128.252.203.10
05:00:00:WU02:FS01:Connecting to 128.252.203.10:8080
05:00:21:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
05:00:21:WU02:FS01:Connecting to 128.252.203.10:80
05:00:42:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
05:00:42:WU02:FS01:Trying to send results to collection server
05:00:42:WU02:FS01:Uploading 33.02MiB to 13.90.152.57
05:00:42:WU02:FS01:Connecting to 13.90.152.57:8080
05:00:48:WU02:FS01:Upload 2.84%
05:00:54:WU02:FS01:Upload 6.44%
05:01:01:WU02:FS01:Upload 9.27%
05:01:07:WU02:FS01:Upload 13.44%
05:01:13:WU02:FS01:Upload 17.79%
05:01:19:WU02:FS01:Upload 22.33%
05:01:25:WU02:FS01:Upload 27.63%
05:01:31:WU02:FS01:Upload 33.50%
05:01:39:WU02:FS01:Upload 37.47%
05:01:45:WU02:FS01:Upload 42.58%
05:01:51:WU02:FS01:Upload 47.88%
05:01:57:WU02:FS01:Upload 52.05%
05:02:03:WU02:FS01:Upload 55.83%
05:02:09:WU02:FS01:Upload 58.86%
05:02:15:WU02:FS01:Upload 62.65%
05:02:21:WU02:FS01:Upload 66.81%
05:02:27:WU02:FS01:Upload 71.16%
05:02:33:WU02:FS01:Upload 74.95%
05:02:39:WU02:FS01:Upload 79.11%
05:02:45:WU02:FS01:Upload 82.33%
05:02:51:WU02:FS01:Upload 84.41%
05:02:57:WU02:FS01:Upload 87.25%
05:03:03:WU02:FS01:Upload 90.85%
05:03:09:WU02:FS01:Upload 93.69%
05:03:16:WU02:FS01:Upload 95.58%
05:03:25:WU02:FS01:Upload 96.90%
05:03:32:WU02:FS01:Upload 98.80%
05:03:38:WU02:FS01:Upload 99.93%
05:03:43:WU02:FS01:Upload complete
05:03:43:WU02:FS01:Server responded WORK_ACK (400)
05:03:43:WU02:FS01:Final credit estimate, 62077.00 points
March 19th 11744 (0,597,7)
05:31:18:WU02:FS01:Downloading 7.85MiB
05:31:27:WU02:FS01:Download 6.37%
05:31:37:WU02:FS01:Download 19.91%
05:31:43:WU02:FS01:Download 41.40%
05:31:49:WU02:FS01:Download 76.44%
05:31:54:WU02:FS01:Download complete
05:31:55:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11744 run:0 clone:597 gen:7 core:0x22 unit:0x0000000c8ca304f15e67e5bbf0c1f621
05:31:55:WU02:FS01:Starting
05:31:55:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\aluks\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 11980 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
05:31:55:WU02:FS01:Started FahCore on PID 7608
05:31:55:WU02:FS01:Core PID:19356
05:31:55:WU02:FS01:FahCore 0x22 started
05:31:55:WU02:FS01:0x22:*********************** Log Started 2020-03-19T05:31:55Z ***********************
05:31:55:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
05:31:55:WU02:FS01:0x22:       Type: 0x22
05:31:55:WU02:FS01:0x22:       Core: Core22
05:31:55:WU02:FS01:0x22:    Website: https://foldingathome.org/
05:31:55:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
05:31:55:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
05:31:55:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
05:31:55:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 7608 -checkpoint 15
05:31:55:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
05:31:55:WU02:FS01:0x22:             0 -gpu 0
05:31:55:WU02:FS01:0x22:     Config: <none>
05:31:55:WU02:FS01:0x22:************************************ Build *************************************
05:31:55:WU02:FS01:0x22:    Version: 0.0.2
05:31:55:WU02:FS01:0x22:       Date: Dec 6 2019
05:31:55:WU02:FS01:0x22:       Time: 21:30:31
05:31:55:WU02:FS01:0x22: Repository: Git
05:31:55:WU02:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
05:31:55:WU02:FS01:0x22:     Branch: HEAD
05:31:55:WU02:FS01:0x22:   Compiler: Visual C++ 2008
05:31:55:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:31:55:WU02:FS01:0x22:   Platform: win32 10
05:31:55:WU02:FS01:0x22:       Bits: 64
05:31:55:WU02:FS01:0x22:       Mode: Release
05:31:55:WU02:FS01:0x22:************************************ System ************************************
05:31:55:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
05:31:55:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
05:31:55:WU02:FS01:0x22:       CPUs: 12
05:31:55:WU02:FS01:0x22:     Memory: 15.85GiB
05:31:55:WU02:FS01:0x22:Free Memory: 9.30GiB
05:31:55:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
05:31:55:WU02:FS01:0x22: OS Version: 6.2
05:31:55:WU02:FS01:0x22:Has Battery: true
05:31:55:WU02:FS01:0x22: On Battery: false
05:31:55:WU02:FS01:0x22: UTC Offset: 1
05:31:55:WU02:FS01:0x22:        PID: 19356
05:31:55:WU02:FS01:0x22:        CWD: C:\Users\aluks\AppData\Roaming\FAHClient\work
05:31:55:WU02:FS01:0x22:         OS: Windows 10 Home
05:31:55:WU02:FS01:0x22:    OS Arch: AMD64
05:31:55:WU02:FS01:0x22:********************************************************************************
05:31:55:WU02:FS01:0x22:Project: 11744 (Run 0, Clone 597, Gen 7)
05:31:55:WU02:FS01:0x22:Unit: 0x0000000c8ca304f15e67e5bbf0c1f621
05:31:55:WU02:FS01:0x22:Reading tar file core.xml
05:31:55:WU02:FS01:0x22:Reading tar file integrator.xml
05:31:55:WU02:FS01:0x22:Reading tar file state.xml
05:31:57:WU02:FS01:0x22:Reading tar file system.xml
05:31:57:WU02:FS01:0x22:Digital signatures verified
05:31:57:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
05:31:57:WU02:FS01:0x22:Version 0.0.2
05:32:13:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
05:32:13:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
05:33:25:WU02:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
<snip>
07:34:59:WU02:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
07:35:05:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
07:35:05:WU02:FS01:0x22:Saving result file checkpointState.xml
07:35:09:WU02:FS01:0x22:Saving result file checkpt.crc
07:35:09:WU02:FS01:0x22:Saving result file positions.xtc
07:35:12:WU02:FS01:0x22:Saving result file science.log
07:35:12:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
07:35:13:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
07:35:13:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11744 run:0 clone:597 gen:7 core:0x22 unit:0x0000000c8ca304f15e67e5bbf0c1f621
07:35:13:WU02:FS01:Uploading 14.51MiB to 140.163.4.241
07:35:13:WU02:FS01:Connecting to 140.163.4.241:8080
07:35:33:WU02:FS01:Upload 0.86%
07:35:33:WARNING:WU02:FS01:Exception: Failed to send results to work server: Transfer failed
07:35:33:WU02:FS01:Trying to send results to collection server
07:35:33:WU02:FS01:Uploading 14.51MiB to 140.163.4.231
07:35:33:WU02:FS01:Connecting to 140.163.4.231:8080
07:35:47:WU02:FS01:Upload 0.86%
07:36:48:WU02:FS01:Upload 1.29%
07:36:54:WU02:FS01:Upload 94.76%
07:37:02:WU02:FS01:Upload complete
07:37:02:WU02:FS01:Server responded WORK_ACK (400)
07:37:02:WU02:FS01:Final credit estimate, 7608.00 points
07:37:02:WU02:FS01:Cleaning up
I guess in my two cases, the upload to the WS started, but then timed-out/failed. In any case, this does not seem to be an issue with delayed CS reporting of WU credits, if the CS does not depend on e.g. the WS for QRB values.
edit: Just to be clear, I don't think this is a priority per se, as long as the WUs are correctly received (which according to the WU pages, seems a bit concerning). This just happens to be the only "issue" I'm experiencing now beyond the general lack of WU/server responsiveness.
