Can't fold, stuck on Failed reading core package header
Amitb01FUB
Post by Amitb01FUB »
I keep getting these errors-
22:40:48:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
22:40:48:WU00:FS00:Connecting to cores.foldingathome.org:80
22:40:49:ERROR:WU00:FS00:Exception: Failed reading core package header.
22:41:48:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
22:41:48:WU00:FS00:Connecting to cores.foldingathome.org:80
22:41:49:ERROR:WU00:FS00:Exception: Failed reading core package header.
22:43:26:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
22:43:26:WU00:FS00:Connecting to cores.foldingathome.org:80
22:43:26:ERROR:WU00:FS00:Exception: Failed reading core package header.
22:46:03:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
22:46:03:WU00:FS00:Connecting to cores.foldingathome.org:80
22:46:03:ERROR:WU00:FS00:Exception: Failed reading core package header.
22:50:17:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
22:50:17:WU00:FS00:Connecting to cores.foldingathome.org:80
22:50:18:ERROR:WU00:FS00:Exception: Failed reading core package header.
22:57:09:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
22:57:09:WU00:FS00:Connecting to cores.foldingathome.org:80
22:57:09:ERROR:WU00:FS00:Exception: Failed reading core package header.
I'm getting similar errors on my GPU as well-
22:44:07:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
22:44:07:WU01:FS01:Connecting to cores.foldingathome.org:80
22:44:07:ERROR:WU01:FS01:Exception: Failed reading core package header.
22:45:07:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
22:45:07:WU01:FS01:Connecting to cores.foldingathome.org:80
22:45:08:ERROR:WU01:FS01:Exception: Failed reading core package header.
22:46:44:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
22:46:44:WU01:FS01:Connecting to cores.foldingathome.org:80
22:46:45:ERROR:WU01:FS01:Exception: Failed reading core package header.
22:49:22:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
22:49:22:WU01:FS01:Connecting to cores.foldingathome.org:80
22:49:22:ERROR:WU01:FS01:Exception: Failed reading core package header.
22:53:36:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
22:53:36:WU01:FS01:Connecting to cores.foldingathome.org:80
22:53:36:ERROR:WU01:FS01:Exception: Failed reading core package header.
23:00:27:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
23:00:27:WU01:FS01:Connecting to cores.foldingathome.org:80
23:00:28:ERROR:WU01:FS01:Exception: Failed reading core package header.
Here's my system info
22:40:42:******************************* System ********************************
22:40:42:            CPU: Intel(R) Core(TM) i5-8600K CPU @ 3.60GHz
22:40:42:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
22:40:42:           CPUs: 6
22:40:42:         Memory: 15.94GiB
22:40:42:    Free Memory: 10.01GiB
22:40:42:        Threads: WINDOWS_THREADS
22:40:42:     OS Version: 6.2
22:40:42:    Has Battery: false
22:40:42:     On Battery: false
22:40:42:     UTC Offset: 2
22:40:42:            PID: 20356
22:40:42:            CWD: C:\Users\bokob\AppData\Roaming\FAHClient
22:40:42:             OS: Windows 10 Home
22:40:42:        OS Arch: AMD64
22:40:42:           GPUs: 1
22:40:42:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070 Ti] 8186
22:40:42:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:11.0
22:40:42:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:445.75
22:40:42:  Win32 Service: false
22:40:42:***********************************************************************
I already tried making a firewall exception and all of my drivers are up to date, I have no idea what the problem might be
Re: Can't fold, stuck on Failed reading core package header
Open one of the links (http://cores.foldingathome.org/v7/win/64bit/Core_22.fah) in your browser. Does it ask permission to save the downloaded file? Does it successfully download the file? (You can't use that file, so delete it.)
Now ask yourself why FAHClient can't do the same thing? It's not a server problem, it's a local security problem. Temporarily disable your security software and tell me if it works or not. Your exception is not working.
Amitb01FUB
bruce wrote:Open one of the links (http://cores.foldingathome.org/v7/win/64bit/Core_22.fah) in your browser. Does it ask permission to save the downloaded file? Does it successfully download the file? (You can't use that file, so delete it.)
I can download the file through the browser no problem,
I turned off my firewall and restarted the f@h client and I'm still getting "Failed reading core package header" on both slots
Some ISPs (or countries) use transparent firewall/proxy to protect their users (or citizens). It may cause issues with FAH because these systems are usually set to allow only "known browsers". Although FAH Client act as a browser, it is not a "known browser".
Are you sure that you're not in this situation ?
Amitb01FUB
toTOW wrote:Some ISPs (or countries) use transparent firewall/proxy to protect their users (or citizens). It may cause issues with FAH because these systems are usually set to allow only "known browsers". Although FAH Client act as a browser, it is not a "known browser".
I'm not aware of any ISP firewall (how do I even check that?), but lets's say there is one, what could one do to bypass it? I guess some proxy service?
If you're in a country that restricts internet access (or political speech) you don't. but the proxy might work. If the problem is local to your machine, answer my questions above.
If you're on your employer's internet service (or a university connection) be careful, too.
Amitb01FUB
bruce wrote:If you're in a country that restricts internet access (or political speech) you don't. but the proxy might work. If the problem is local to your machine, answer my questions above.
Well my country (Israel) doesn't restrict internet access in any way, and I am on my home network.
As I already said in a previous answer, I can download the file through the browser with no problem,
and I turned off my firewall and restarted the f@h client and still got "Failed reading core package header" on both slots
Amitb01FUB
I forwarded ports 80 and 8080 but that didn't help either
There is definitely something interfering with your FAH transfers. :(
It could be interesting to use Wireshark to see how the packets returned look like.
You might want to try a public proxy (but good luck finding one that work reliably) or a VPN ...
Amitb01FUB
toTOW wrote:There is definitely something interfering with your FAH transfers. :(
I have WireShark running but I don't know what packets belong to F@H, I'll try a vpn to see if that works but they usually mess up my internet speed so it's not a long term solution
Amitb01FUB
I bought ExpressVPN and connected to the UK server, still getting "Failed reading core package header",
Any suggestions?
NathanOldfield
Post by NathanOldfield »
I am having exactly the same problem.
Amitb01FUB
NathanOldfield wrote:I am having exactly the same problem.
Are you also using the 7.5.1 client? Maybe it's a problem with the client itself, at this point I can't see anything else that could be the problem
If a VPN doesn't help, the issue is localised on your system. Do you have some security software suite (Norton, Kaspersky, BitDefender, ...) that could interfere with your network connections ?
Amitb01FUB
toTOW wrote:If a VPN doesn't help, the issue is localised on your system. Do you have some security software suite (Norton, Kaspersky, BitDefender, ...) that could interfere with your network connections ?
nothing except the the windows defender, which turning off doesn't help
