Client not working
- Hardware configuration: Windows 7, Intel i7-6600U CPU on a laptop
Client not working
The web client says "Your browser was unable to connect to a Folding@home client running on your computer.". The FAH icon isn't in the bottom right taskbar, and I tried to run fah client but it said it couldn't connect. Also, I think viewtopic.php?f=106&t=33286 is related to this problem. Please check that one too.
#StayAtHome #AlertNotAnxious #FoldForCOVID
Basic help stuff:viewtopic.php?f=61&t=26036 | Find Your Stats:https://stats.foldingathome.org/donors
https://folding.extremeoverclocking.com/
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
Re: Client not working
Can you open the program called "Folding@home" in your Start Menu?
It worked! But now it says "Ready" and doesn't do anything. This happened last time and I know it will stay like that for a while. Maybe it has to do with the fact that it is using CPU as default? Also, can you help me with viewtopic.php?f=20&t=33288&p=317856#p317856?
Thanks for your time!
Cheers!
PS. My client says the id for CPU in slots is 0.
Cheers!
