GPU is not working at full power
Hello, my GPU while it is folding uses no more the 15% load. I don't know if this is normal. If it's not normal, please tell me how to fix this. I have a NVIDIA GeForce GTX 1050 Ti if that helps.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
Re: GPU is not working at full power
Hi and welcome to the forum.
That seems abnormal. How are you seeing 15%? Windows or Linux? Is your CPU fully used?
davidcoton
How are you checking the power? Try GPUZ if you can. Some monitors do not understand compute usage and exclude it from their report.
@Jesse_v I am using NZXT Cam for monitoring, my OS is Windows, and yes my CPU is fully loaded.
@davidcoton Can you familiarize with GPUZ, I don't know what that is.
nvm, i just downloaded GPUZ and it says that my GPU is at full load! @davidcoton thanks for the suggestion
