New here, need help setting up
matthewgould1991
Post by matthewgould1991 »
Hi all,
im getting the following message and its failing to connect.
What do I do to get started?
*********************** Log Started 2020-03-24T17:19:35Z ***********************
17:19:35:************************* Folding@home Client *************************
17:19:35:        Website: https://foldingathome.org/
17:19:35:      Copyright: (c) 2009-2018 foldingathome.org
17:19:35:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:19:35:           Args: --open-web-control
17:19:35:         Config: <none>
17:19:35:******************************** Build ********************************
17:19:35:        Version: 7.5.1
17:19:35:           Date: May 11 2018
17:19:35:           Time: 13:06:32
17:19:35:     Repository: Git
17:19:35:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
17:19:35:         Branch: master
17:19:35:       Compiler: Visual C++ 2008
17:19:35:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:19:35:       Platform: win32 10
17:19:35:           Bits: 32
17:19:35:           Mode: Release
17:19:35:******************************* System ********************************
17:19:35:            CPU: Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz
17:19:35:         CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
17:19:35:           CPUs: 8
17:19:35:         Memory: 15.89GiB
17:19:35:    Free Memory: 10.00GiB
17:19:35:        Threads: WINDOWS_THREADS
17:19:35:     OS Version: 6.2
17:19:35:    Has Battery: true
17:19:35:     On Battery: false
17:19:35:     UTC Offset: 1
17:19:35:            PID: 7304
17:19:35:            CWD: C:\Users\44772\AppData\Roaming\FAHClient
17:19:35:             OS: Windows 10 Enterprise
17:19:35:        OS Arch: AMD64
17:19:35:           GPUs: 0
17:19:35:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
17:19:35:                 specified module could not be found.
17:19:35:
17:19:35:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
17:19:35:  Win32 Service: false
17:40:07:ERROR:WU00:FS00:Exception: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:44:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
Re: New here, need help setting up
Part may be just from the server overload from all of the new persons who have joined F@h. You can ignore the 10053 messages.
If you are running anti-malware or a firewall, you may need to add an exception for the client. It uses HTTP over ports 8080 and 80, and otherwise acts like a web browser for download and upload connections. The part of the client need the exception is named FAHClient.
