Hi
Another noob question.
Been running two rigs whole night on both CPU & GPU, two fold on GPU has estimate points 44K+ each, plus some small CPU based.
Checked in a morning and not sure results of two GPU folds been sent back, especially based on points earned, doesn't seems like thos 80K+ was counted at all, I have 30K after two days of running.
Here is a both logs
because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
16:49:16:WU02:FS00:Trying to send results to collection server
16:49:16:WU02:FS00:Uploading 2.46MiB to 155.247.166.220
16:49:16:WU02:FS00:Connecting to 155.247.166.220:8080
16:49:22:WU02:FS00:Upload 100.00%
16:49:22:WU02:FS00:Upload complete
16:49:22:WU02:FS00:Server responded WORK_ACK (400)
16:49:22:WU02:FS00:Final credit estimate, 4825.00 points
16:49:22:WU02:FS00:Cleaning up
16:50:39:WU01:FS00:Connecting to 65.254.110.245:8080
16:50:39:WU01:FS00:Assigned to work server 128.252.203.9
16:50:39:WU01:FS00:Requesting new work unit for slot 00: READY cpu:3 from 128.252.203.9
16:50:39:WU01:FS00:Connecting to 128.252.203.9:8080
16:51:00:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
16:51:00:WU01:FS00:Connecting to 128.252.203.9:80
16:51:21:ERROR:WU01:FS00:Exception: Failed to connect to 128.252.203.9:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
******************************* Date: 2020-03-24 *******************************
16:54:53:WU01:FS00:Connecting to 65.254.110.245:8080
16:54:53:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:54:53:WU01:FS00:Connecting to 18.218.241.186:80
16:54:53:WU01:FS00:Assigned to work server 128.252.203.9
16:54:53:WU01:FS00:Requesting new work unit for slot 00: READY cpu:3 from 128.252.203.9
16:54:53:WU01:FS00:Connecting to 128.252.203.9:8080
16:55:14:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
16:55:14:WU01:FS00:Connecting to 128.252.203.9:80
16:55:35:ERROR:WU01:FS00:Exception: Failed to connect to 128.252.203.9:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:01:44:WU01:FS00:Connecting to 65.254.110.245:8080
17:01:44:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:01:44:WU01:FS00:Connecting to 18.218.241.186:80
17:01:45:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:01:45:ERROR:WU01:FS00:Exception: Could not get an assignment
17:10:27:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
17:12:50:WU01:FS00:Connecting to 65.254.110.245:8080
17:12:50:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:12:50:WU01:FS00:Connecting to 18.218.241.186:80
17:12:50:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:12:50:ERROR:WU01:FS00:Exception: Could not get an assignment
Just want to make sure everything works the way it should, results been sent back to servers and it's not for nothing and stuck somewhere in a middle.
Thanks in advance.
*********************** Log Started 2020-03-24T04:40:42Z ***********************
04:40:42:************************* Folding@home Client *************************
04:40:42: Website: https://foldingathome.org/
04:40:42: Copyright: (c) 2009-2018 foldingathome.org
04:40:42: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:40:42: Args: --open-web-control
04:40:42: Config: <none>
04:40:42:******************************** Build ********************************
04:40:42: Version: 7.5.1
04:40:42: Date: May 11 2018
04:40:42: Time: 13:06:32
04:40:42: Repository: Git
04:40:42: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
04:40:42: Branch: master
04:40:42: Compiler: Visual C++ 2008
04:40:42: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:40:42: Platform: win32 10
04:40:42: Bits: 32
04:40:42: Mode: Release
04:40:42:******************************* System ********************************
04:40:42: CPU: Intel(R) Core(TM) i5-7300HQ CPU @ 2.50GHz
04:40:42: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
04:40:42: CPUs: 4
04:40:42: Memory: 15.87GiB
04:40:42: Free Memory: 12.22GiB
04:40:42: Threads: WINDOWS_THREADS
04:40:42: OS Version: 6.2
04:40:42: Has Battery: true
04:40:42: On Battery: false
04:40:42: UTC Offset: -4
04:40:42: PID: 8984
04:40:42: CWD: D:\FAHClient
04:40:42: OS: Windows 10 Enterprise
04:40:42: OS Arch: AMD64
04:40:42: GPUs: 0
04:40:42: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:9.1
04:40:42:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:23.20
04:40:42:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:391.25
04:40:42: Win32 Service: false
04:40:42:***********************************************************************
04:40:42:<config>
04:40:42: <!-- Folding Slots -->
04:40:42:</config>
04:40:42:Connecting to assign1.foldingathome.org:8080
04:40:42:Updated GPUs.txt
04:40:42:Read GPUs.txt
04:40:42:Trying to access database...
04:40:42:Successfully acquired database lock
04:40:42:Enabled folding slot 00: PAUSED cpu:1 (not configured)
04:40:42:Enabled folding slot 01: PAUSED gpu:0:GP107M [GeForce GTX 1050 Mobile] (not configured)
04:40:45:8:127.0.0.1:New Web connection
04:41:43:Saving configuration to config.xml
04:41:43:<config>
04:41:43: <!-- Folding Slots -->
04:41:43: <slot id='0' type='CPU'/>
04:41:43: <slot id='1' type='GPU'/>
04:41:43:</config>
04:41:43:Set client configured
04:41:43:WU00:FS00:Connecting to 65.254.110.245:8080
04:41:45:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:41:45:WU00:FS00:Connecting to 18.218.241.186:80
04:41:45:WU00:FS00:Assigned to work server 13.90.152.57
04:41:45:WU00:FS00:Requesting new work unit for slot 00: READY cpu:1 from 13.90.152.57
04:41:45:WU00:FS00:Connecting to 13.90.152.57:8080
04:42:06:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
04:42:06:WU00:FS00:Connecting to 13.90.152.57:80
04:42:14:WU00:FS00:Downloading 4.96MiB
04:42:16:WU00:FS00:Download complete
04:42:16:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14333 run:0 clone:683 gen:2 core:0xa7 unit:0x000000030d5a98395e7525ed25040809
04:42:16:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
04:42:16:WU00:FS00:Connecting to cores.foldingathome.org:80
04:42:17:WU00:FS00:FahCore a7: Downloading 6.71MiB
04:42:18:WU00:FS00:FahCore a7: Download complete
04:42:18:WU00:FS00:Valid core signature
04:42:18:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
04:42:18:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
04:42:18:WU00:FS00:Starting
04:42:18:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 8984 -checkpoint 15 -np 1
04:42:18:WU00:FS00:Started FahCore on PID 1576
04:42:18:WU00:FS00:Core PID:8716
04:42:18:WU00:FS00:FahCore 0xa7 started
04:42:19:WU00:FS00:0xa7:*********************** Log Started 2020-03-24T04:42:19Z ***********************
04:42:19:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
04:42:19:WU00:FS00:0xa7: Type: 0xa7
04:42:19:WU00:FS00:0xa7: Core: Gromacs
04:42:19:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 1576 -checkpoint 15 -np 1
04:42:19:WU00:FS00:0xa7:************************************ CBang *************************************
04:42:19:WU00:FS00:0xa7: Date: Oct 26 2019
04:42:19:WU00:FS00:0xa7: Time: 01:38:25
04:42:19:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
04:42:19:WU00:FS00:0xa7: Branch: master
04:42:19:WU00:FS00:0xa7: Compiler: Visual C++ 2008
04:42:19:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:42:19:WU00:FS00:0xa7: Platform: win32 10
04:42:19:WU00:FS00:0xa7: Bits: 64
04:42:19:WU00:FS00:0xa7: Mode: Release
04:42:19:WU00:FS00:0xa7:************************************ System ************************************
04:42:19:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-7300HQ CPU @ 2.50GHz
04:42:19:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
04:42:19:WU00:FS00:0xa7: CPUs: 4
04:42:19:WU00:FS00:0xa7: Memory: 15.87GiB
04:42:19:WU00:FS00:0xa7:Free Memory: 11.38GiB
04:42:19:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
04:42:19:WU00:FS00:0xa7: OS Version: 6.2
04:42:19:WU00:FS00:0xa7:Has Battery: true
04:42:19:WU00:FS00:0xa7: On Battery: false
04:42:19:WU00:FS00:0xa7: UTC Offset: -4
04:42:19:WU00:FS00:0xa7: PID: 8716
04:42:19:WU00:FS00:0xa7: CWD: D:\FAHClient\work
04:42:19:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
04:42:19:WU00:FS00:0xa7: Version: 0.0.18
04:42:19:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:42:19:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
04:42:19:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
04:42:19:WU00:FS00:0xa7: Time: 01:52:30
04:42:19:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
04:42:19:WU00:FS00:0xa7:************************************ Build *************************************
04:42:19:WU00:FS00:0xa7: SIMD: avx_256
04:42:19:WU00:FS00:0xa7:********************************************************************************
04:42:19:WU00:FS00:0xa7:Project: 14333 (Run 0, Clone 683, Gen 2)
04:42:19:WU00:FS00:0xa7:Unit: 0x000000030d5a98395e7525ed25040809
04:42:19:WU00:FS00:0xa7:Reading tar file core.xml
04:42:19:WU00:FS00:0xa7:Reading tar file frame2.tpr
04:42:19:WU00:FS00:0xa7:Digital signatures verified
04:42:19:WU00:FS00:0xa7:Calling: mdrun -s frame2.tpr -o frame2.trr -cpt 15 -nt 1
04:42:19:WU00:FS00:0xa7:Steps: first=500000 total=250000
04:42:21:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
04:43:45:Saving configuration to config.xml
04:43:45:<config>
04:43:45: <!-- User Information -->
04:43:45: <passkey v='********************************'/>
04:43:45: <team v='240212'/>
04:43:45: <user v='Bubunya'/>
04:43:45:
04:43:45: <!-- Folding Slots -->
04:43:45: <slot id='0' type='CPU'/>
04:43:45: <slot id='1' type='GPU'/>
04:43:45:</config>
04:44:44:FS00:Shutting core down
04:44:44:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 8716
04:44:44:WU00:FS00:0xa7:Exiting, please wait. . .
04:44:45:WU01:FS01:Connecting to 65.254.110.245:8080
04:44:45:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:44:45:WU01:FS01:Connecting to 18.218.241.186:80
04:44:46:Saving configuration to config.xml
04:44:46:<config>
04:44:46: <!-- Slot Control -->
04:44:46: <power v='medium'/>
04:44:46:
04:44:46: <!-- User Information -->
04:44:46: <passkey v='********************************'/>
04:44:46: <team v='240212'/>
04:44:46: <user v='Bubunya'/>
04:44:46:
04:44:46: <!-- Folding Slots -->
04:44:46: <slot id='0' type='CPU'/>
04:44:46: <slot id='1' type='GPU'/>
04:44:46:</config>
04:44:46:WU01:FS01:Assigned to work server 128.252.203.2
04:44:46:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Mobile] from 128.252.203.2
04:44:46:WU01:FS01:Connecting to 128.252.203.2:8080
04:44:48:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:44:48:WU00:FS00:Starting
04:44:48:WARNING:WU00:FS00:Changed SMP threads from 1 to 2 this can cause some work units to fail
04:44:48:WARNING:WU00:FS00:AS lowered CPUs from 2 to 1
04:44:48:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 8984 -checkpoint 15 -np 1
04:44:48:WU00:FS00:Started FahCore on PID 6540
04:44:48:WU00:FS00:Core PID:12024
04:44:48:WU00:FS00:FahCore 0xa7 started
04:44:48:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:44:48:WU01:FS01:Connecting to 128.252.203.2:80
04:44:49:WU00:FS00:0xa7:*********************** Log Started 2020-03-24T04:44:48Z ***********************
04:44:49:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
04:44:49:WU00:FS00:0xa7: Type: 0xa7
04:44:49:WU00:FS00:0xa7: Core: Gromacs
04:44:49:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 6540 -checkpoint 15 -np 1
04:44:49:WU00:FS00:0xa7:************************************ CBang *************************************
04:44:49:WU00:FS00:0xa7: Date: Oct 26 2019
04:44:49:WU00:FS00:0xa7: Time: 01:38:25
04:44:49:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
04:44:49:WU00:FS00:0xa7: Branch: master
04:44:49:WU00:FS00:0xa7: Compiler: Visual C++ 2008
04:44:49:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:44:49:WU00:FS00:0xa7: Platform: win32 10
04:44:49:WU00:FS00:0xa7: Bits: 64
04:44:49:WU00:FS00:0xa7: Mode: Release
04:44:49:WU00:FS00:0xa7:************************************ System ************************************
04:44:49:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-7300HQ CPU @ 2.50GHz
04:44:49:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
04:44:49:WU00:FS00:0xa7: CPUs: 4
04:44:49:WU00:FS00:0xa7: Memory: 15.87GiB
04:44:49:WU00:FS00:0xa7:Free Memory: 11.40GiB
04:44:49:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
04:44:49:WU00:FS00:0xa7: OS Version: 6.2
04:44:49:WU00:FS00:0xa7:Has Battery: true
04:44:49:WU00:FS00:0xa7: On Battery: false
04:44:49:WU00:FS00:0xa7: UTC Offset: -4
04:44:49:WU00:FS00:0xa7: PID: 12024
04:44:49:WU00:FS00:0xa7: CWD: D:\FAHClient\work
04:44:49:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
04:44:49:WU00:FS00:0xa7: Version: 0.0.18
04:44:49:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:44:49:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
04:44:49:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
04:44:49:WU00:FS00:0xa7: Time: 01:52:30
04:44:49:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
04:44:49:WU00:FS00:0xa7:************************************ Build *************************************
04:44:49:WU00:FS00:0xa7: SIMD: avx_256
04:44:49:WU00:FS00:0xa7:********************************************************************************
04:44:49:WU00:FS00:0xa7:Project: 14333 (Run 0, Clone 683, Gen 2)
04:44:49:WU00:FS00:0xa7:Unit: 0x000000030d5a98395e7525ed25040809
04:44:49:WU00:FS00:0xa7:Digital signatures verified
04:44:49:WU00:FS00:0xa7:Calling: mdrun -s frame2.tpr -o frame2.trr -cpi state.cpt -cpt 15 -nt 1
04:44:49:WU00:FS00:0xa7:Steps: first=500000 total=250000
04:44:50:WU00:FS00:0xa7:Completed 872 out of 250000 steps (0%)
04:44:51:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.2:80: No connection could be made because the target machine actively refused it.
04:44:51:WU01:FS01:Connecting to 65.254.110.245:8080
04:44:51:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:44:51:WU01:FS01:Connecting to 18.218.241.186:80
04:44:52:WU01:FS01:Assigned to work server 128.252.203.2
04:44:52:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Mobile] from 128.252.203.2
04:44:52:WU01:FS01:Connecting to 128.252.203.2:8080
04:44:54:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
04:44:54:WU01:FS01:Connecting to 128.252.203.2:80
04:44:57:ERROR:WU01:FS01:Exception: Failed to connect to 128.252.203.2:80: No connection could be made because the target machine actively refused it.
04:45:51:WU01:FS01:Connecting to 65.254.110.245:8080
04:45:51:WU01:FS01:Assigned to work server 40.114.52.201
04:45:52:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Mobile] from 40.114.52.201
04:45:52:WU01:FS01:Connecting to 40.114.52.201:8080
04:46:48:WU01:FS01:Downloading 29.75MiB
04:46:54:WU01:FS01:Download 22.27%
04:47:00:WU01:FS01:Download 34.87%
04:47:06:WU01:FS01:Download 49.36%
04:47:12:WU01:FS01:Download 68.27%
04:47:18:WU01:FS01:Download 88.65%
04:47:23:WU01:FS01:Download complete
04:47:23:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11777 run:0 clone:12733 gen:0 core:0x22 unit:0x00000002287234c95e7432a450fc9843
04:47:23:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
04:47:23:WU01:FS01:Connecting to cores.foldingathome.org:80
04:47:24:WU01:FS01:FahCore 22: Downloading 4.04MiB
04:47:25:WU01:FS01:FahCore 22: Download complete
04:47:25:WU01:FS01:Valid core signature
04:47:25:WU01:FS01:Unpacked 13.49MiB to cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe
04:47:25:WU01:FS01:Starting
04:47:25:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 8984 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
04:47:25:WU01:FS01:Started FahCore on PID 7668
04:47:25:WU01:FS01:Core PID:3600
04:47:25:WU01:FS01:FahCore 0x22 started
04:47:25:WU01:FS01:0x22:*********************** Log Started 2020-03-24T04:47:25Z ***********************
04:47:25:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
04:47:25:WU01:FS01:0x22: Type: 0x22
04:47:25:WU01:FS01:0x22: Core: Core22
04:47:25:WU01:FS01:0x22: Website: https://foldingathome.org/
04:47:25:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
04:47:25:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
04:47:25:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
04:47:25:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 7668 -checkpoint 15
04:47:25:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
04:47:25:WU01:FS01:0x22: 0 -gpu 0
04:47:25:WU01:FS01:0x22: Config: <none>
04:47:25:WU01:FS01:0x22:************************************ Build *************************************
04:47:25:WU01:FS01:0x22: Version: 0.0.2
04:47:25:WU01:FS01:0x22: Date: Dec 6 2019
04:47:25:WU01:FS01:0x22: Time: 21:30:31
04:47:25:WU01:FS01:0x22: Repository: Git
04:47:25:WU01:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
04:47:25:WU01:FS01:0x22: Branch: HEAD
04:47:25:WU01:FS01:0x22: Compiler: Visual C++ 2008
04:47:25:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:47:25:WU01:FS01:0x22: Platform: win32 10
04:47:25:WU01:FS01:0x22: Bits: 64
04:47:25:WU01:FS01:0x22: Mode: Release
04:47:25:WU01:FS01:0x22:************************************ System ************************************
04:47:25:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i5-7300HQ CPU @ 2.50GHz
04:47:25:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
04:47:25:WU01:FS01:0x22: CPUs: 4
04:47:25:WU01:FS01:0x22: Memory: 15.87GiB
04:47:25:WU01:FS01:0x22:Free Memory: 11.31GiB
04:47:25:WU01:FS01:0x22: Threads: WINDOWS_THREADS
04:47:25:WU01:FS01:0x22: OS Version: 6.2
04:47:25:WU01:FS01:0x22:Has Battery: true
04:47:25:WU01:FS01:0x22: On Battery: false
04:47:25:WU01:FS01:0x22: UTC Offset: -4
04:47:25:WU01:FS01:0x22: PID: 3600
04:47:25:WU01:FS01:0x22: CWD: D:\FAHClient\work
04:47:25:WU01:FS01:0x22: OS: Windows 10 Pro
04:47:25:WU01:FS01:0x22: OS Arch: AMD64
04:47:25:WU01:FS01:0x22:********************************************************************************
04:47:25:WU01:FS01:0x22:Project: 11777 (Run 0, Clone 12733, Gen 0)
04:47:25:WU01:FS01:0x22:Unit: 0x00000002287234c95e7432a450fc9843
04:47:25:WU01:FS01:0x22:Reading tar file core.xml
04:47:25:WU01:FS01:0x22:Reading tar file integrator.xml
04:47:25:WU01:FS01:0x22:Reading tar file state.xml
04:47:26:WU01:FS01:0x22:Reading tar file system.xml
04:47:26:WU01:FS01:0x22:Digital signatures verified
04:47:26:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
04:47:26:WU01:FS01:0x22:Version 0.0.2
04:47:41:WU01:FS01:0x22:Completed 0 out of 2000000 steps (0%)
04:47:41:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
04:49:23:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
04:49:51:FS00:Shutting core down
04:49:52:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 12024
04:49:52:WU00:FS00:0xa7:Exiting, please wait. . .
04:49:54:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:49:54:WU00:FS00:Starting
04:49:54:WARNING:WU00:FS00:Changed SMP threads from 2 to 3 this can cause some work units to fail
04:49:54:WARNING:WU00:FS00:AS lowered CPUs from 3 to 1
04:49:54:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 8984 -checkpoint 15 -np 1
04:49:54:WU00:FS00:Started FahCore on PID 7860
04:49:54:WU00:FS00:Core PID:8028
04:49:54:WU00:FS00:FahCore 0xa7 started
04:49:55:WU00:FS00:0xa7:*********************** Log Started 2020-03-24T04:49:54Z ***********************
04:49:55:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
04:49:55:WU00:FS00:0xa7: Type: 0xa7
04:49:55:WU00:FS00:0xa7: Core: Gromacs
04:49:55:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 705 -lifeline 7860 -checkpoint 15 -np 1
04:49:55:WU00:FS00:0xa7:************************************ CBang *************************************
04:49:55:WU00:FS00:0xa7: Date: Oct 26 2019
04:49:55:WU00:FS00:0xa7: Time: 01:38:25
04:49:55:WU00:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
04:49:55:WU00:FS00:0xa7: Branch: master
04:49:55:WU00:FS00:0xa7: Compiler: Visual C++ 2008
04:49:55:WU00:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
04:49:55:WU00:FS00:0xa7: Platform: win32 10
04:49:55:WU00:FS00:0xa7: Bits: 64
04:49:55:WU00:FS00:0xa7: Mode: Release
04:49:55:WU00:FS00:0xa7:************************************ System ************************************
04:49:55:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-7300HQ CPU @ 2.50GHz
04:49:55:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
04:49:55:WU00:FS00:0xa7: CPUs: 4
04:49:55:WU00:FS00:0xa7: Memory: 15.87GiB
04:49:55:WU00:FS00:0xa7:Free Memory: 10.95GiB
04:49:55:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
04:49:55:WU00:FS00:0xa7: OS Version: 6.2
04:49:55:WU00:FS00:0xa7:Has Battery: true
04:49:55:WU00:FS00:0xa7: On Battery: false
04:49:55:WU00:FS00:0xa7: UTC Offset: -4
04:49:55:WU00:FS00:0xa7: PID: 8028
04:49:55:WU00:FS00:0xa7: CWD: D:\FAHClient\work
04:49:55:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
04:49:55:WU00:FS00:0xa7: Version: 0.0.18
04:49:55:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:49:55:WU00:FS00:0xa7: Copyright: 2019 foldingathome.org
04:49:55:WU00:FS00:0xa7: Homepage: https://foldingathome.org/
04:49:55:WU00:FS00:0xa7: Time: 01:52:30
04:49:55:WU00:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
04:49:55:WU00:FS00:0xa7:************************************ Build *************************************
04:49:55:WU00:FS00:0xa7: SIMD: avx_256
04:49:55:WU00:FS00:0xa7:********************************************************************************
04:49:55:WU00:FS00:0xa7:Project: 14333 (Run 0, Clone 683, Gen 2)
04:49:55:WU00:FS00:0xa7:Unit: 0x000000030d5a98395e7525ed25040809
04:49:55:WU00:FS00:0xa7:Digital signatures verified
04:49:55:WU00:FS00:0xa7:Calling: mdrun -s frame2.tpr -o frame2.trr -cpi state.cpt -cpt 15 -nt 1
04:49:55:WU00:FS00:0xa7:Steps: first=500000 total=250000
04:49:56:WU00:FS00:0xa7:Completed 2672 out of 250000 steps (1%)
04:50:52:Saving configuration to config.xml
04:50:52:<config>
04:50:52: <!-- Slot Control -->
04:50:52: <power v='full'/>
04:50:52:
04:50:52: <!-- User Information -->
04:50:52: <passkey v='********************************'/>
04:50:52: <team v='240212'/>
04:50:52: <user v='Bubunya'/>
04:50:52:
04:50:52: <!-- Folding Slots -->
04:50:52: <slot id='0' type='CPU'/>
04:50:52: <slot id='1' type='GPU'/>
04:50:52:</config>
04:51:37:WU01:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
04:55:33:WU01:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
04:56:49:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
04:59:33:WU01:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
05:03:29:WU01:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
05:04:42:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
05:07:25:WU01:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
05:11:25:WU01:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
05:12:39:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
05:15:21:WU01:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
05:19:20:WU01:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
05:20:37:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
05:23:17:WU01:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
05:27:13:WU01:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
05:28:44:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
05:31:13:WU01:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
05:35:09:WU01:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
05:36:57:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
05:39:09:WU01:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
05:43:05:WU01:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
05:45:05:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
05:47:02:WU01:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
05:51:01:WU01:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
05:53:11:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
05:54:58:WU01:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
05:58:57:WU01:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
06:01:15:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
06:02:54:WU01:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
06:06:50:WU01:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
06:09:26:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
06:10:50:WU01:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
06:14:46:WU01:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
06:17:41:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
06:18:46:WU01:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
06:22:42:WU01:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
06:25:57:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
06:26:39:WU01:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
06:30:38:WU01:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
06:34:02:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
06:34:35:WU01:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
06:38:34:WU01:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
06:42:04:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
06:42:31:WU01:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
06:46:28:WU01:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
06:50:09:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
06:50:27:WU01:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
06:54:24:WU01:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
06:58:14:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
06:58:23:WU01:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
07:02:20:WU01:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
07:06:16:WU01:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
07:06:23:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
07:10:16:WU01:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
07:14:12:WU01:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
07:14:30:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
07:18:12:WU01:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
07:22:09:WU01:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
07:22:41:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
07:26:05:WU01:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
07:30:05:WU01:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
07:30:50:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
07:34:02:WU01:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
07:38:01:WU01:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
07:39:03:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
07:41:58:WU01:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
07:45:54:WU01:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
07:47:16:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
07:49:54:WU01:FS01:0x22:Completed 920000 out of 2000000 steps (46%)
07:53:50:WU01:FS01:0x22:Completed 940000 out of 2000000 steps (47%)
07:55:26:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
07:57:49:WU01:FS01:0x22:Completed 960000 out of 2000000 steps (48%)
08:01:46:WU01:FS01:0x22:Completed 980000 out of 2000000 steps (49%)
08:03:31:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
08:05:43:WU01:FS01:0x22:Completed 1000000 out of 2000000 steps (50%)
08:09:42:WU01:FS01:0x22:Completed 1020000 out of 2000000 steps (51%)
08:11:38:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
08:13:38:WU01:FS01:0x22:Completed 1040000 out of 2000000 steps (52%)
08:17:38:WU01:FS01:0x22:Completed 1060000 out of 2000000 steps (53%)
08:19:41:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
08:21:34:WU01:FS01:0x22:Completed 1080000 out of 2000000 steps (54%)
08:25:30:WU01:FS01:0x22:Completed 1100000 out of 2000000 steps (55%)
08:27:44:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
08:29:30:WU01:FS01:0x22:Completed 1120000 out of 2000000 steps (56%)
08:33:26:WU01:FS01:0x22:Completed 1140000 out of 2000000 steps (57%)
08:35:43:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
08:37:25:WU01:FS01:0x22:Completed 1160000 out of 2000000 steps (58%)
08:41:22:WU01:FS01:0x22:Completed 1180000 out of 2000000 steps (59%)
08:43:49:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
08:45:18:WU01:FS01:0x22:Completed 1200000 out of 2000000 steps (60%)
08:49:17:WU01:FS01:0x22:Completed 1220000 out of 2000000 steps (61%)
08:51:46:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
08:53:14:WU01:FS01:0x22:Completed 1240000 out of 2000000 steps (62%)
08:57:13:WU01:FS01:0x22:Completed 1260000 out of 2000000 steps (63%)
08:59:35:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
09:01:10:WU01:FS01:0x22:Completed 1280000 out of 2000000 steps (64%)
09:05:06:WU01:FS01:0x22:Completed 1300000 out of 2000000 steps (65%)
09:07:28:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
09:09:05:WU01:FS01:0x22:Completed 1320000 out of 2000000 steps (66%)
09:13:02:WU01:FS01:0x22:Completed 1340000 out of 2000000 steps (67%)
09:15:16:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
09:17:01:WU01:FS01:0x22:Completed 1360000 out of 2000000 steps (68%)
09:20:57:WU01:FS01:0x22:Completed 1380000 out of 2000000 steps (69%)
09:23:06:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
09:24:53:WU01:FS01:0x22:Completed 1400000 out of 2000000 steps (70%)
09:28:53:WU01:FS01:0x22:Completed 1420000 out of 2000000 steps (71%)
09:30:55:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
09:32:49:WU01:FS01:0x22:Completed 1440000 out of 2000000 steps (72%)
09:36:48:WU01:FS01:0x22:Completed 1460000 out of 2000000 steps (73%)
09:38:43:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
09:40:45:WU01:FS01:0x22:Completed 1480000 out of 2000000 steps (74%)
09:44:41:WU01:FS01:0x22:Completed 1500000 out of 2000000 steps (75%)
09:46:36:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
09:48:40:WU01:FS01:0x22:Completed 1520000 out of 2000000 steps (76%)
09:52:36:WU01:FS01:0x22:Completed 1540000 out of 2000000 steps (77%)
09:54:27:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
09:56:35:WU01:FS01:0x22:Completed 1560000 out of 2000000 steps (78%)
10:00:32:WU01:FS01:0x22:Completed 1580000 out of 2000000 steps (79%)
10:02:17:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
10:04:28:WU01:FS01:0x22:Completed 1600000 out of 2000000 steps (80%)
10:08:27:WU01:FS01:0x22:Completed 1620000 out of 2000000 steps (81%)
10:10:02:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
10:12:23:WU01:FS01:0x22:Completed 1640000 out of 2000000 steps (82%)
10:16:22:WU01:FS01:0x22:Completed 1660000 out of 2000000 steps (83%)
10:17:41:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
10:20:18:WU01:FS01:0x22:Completed 1680000 out of 2000000 steps (84%)
10:24:14:WU01:FS01:0x22:Completed 1700000 out of 2000000 steps (85%)
10:25:24:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
10:28:13:WU01:FS01:0x22:Completed 1720000 out of 2000000 steps (86%)
10:32:10:WU01:FS01:0x22:Completed 1740000 out of 2000000 steps (87%)
10:33:12:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
10:36:08:WU01:FS01:0x22:Completed 1760000 out of 2000000 steps (88%)
10:40:04:WU01:FS01:0x22:Completed 1780000 out of 2000000 steps (89%)
10:40:54:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
10:44:01:WU01:FS01:0x22:Completed 1800000 out of 2000000 steps (90%)
10:48:00:WU01:FS01:0x22:Completed 1820000 out of 2000000 steps (91%)
10:48:39:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
10:51:56:WU01:FS01:0x22:Completed 1840000 out of 2000000 steps (92%)
10:55:55:WU01:FS01:0x22:Completed 1860000 out of 2000000 steps (93%)
10:56:27:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
10:59:51:WU01:FS01:0x22:Completed 1880000 out of 2000000 steps (94%)
11:03:47:WU01:FS01:0x22:Completed 1900000 out of 2000000 steps (95%)
11:04:14:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
11:07:46:WU01:FS01:0x22:Completed 1920000 out of 2000000 steps (96%)
11:11:42:WU01:FS01:0x22:Completed 1940000 out of 2000000 steps (97%)
11:12:01:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
11:15:41:WU01:FS01:0x22:Completed 1960000 out of 2000000 steps (98%)
11:19:37:WU01:FS01:0x22:Completed 1980000 out of 2000000 steps (99%)
11:19:38:WU02:FS01:Connecting to 65.254.110.245:8080
11:19:38:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:19:38:WU02:FS01:Connecting to 18.218.241.186:80
11:19:39:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:19:39:ERROR:WU02:FS01:Exception: Could not get an assignment
11:19:39:WU02:FS01:Connecting to 65.254.110.245:8080
11:19:39:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:19:39:WU02:FS01:Connecting to 18.218.241.186:80
11:19:47:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
11:20:39:WU02:FS01:Connecting to 65.254.110.245:8080
11:20:39:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:20:39:WU02:FS01:Connecting to 18.218.241.186:80
11:20:39:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:20:39:ERROR:WU02:FS01:Exception: Could not get an assignment
11:22:16:WU02:FS01:Connecting to 65.254.110.245:8080
11:22:17:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:22:17:WU02:FS01:Connecting to 18.218.241.186:80
11:22:17:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:22:17:ERROR:WU02:FS01:Exception: Could not get an assignment
11:23:33:WU01:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
11:23:36:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
11:23:36:WU01:FS01:0x22:Saving result file checkpointState.xml
11:23:36:WU01:FS01:0x22:Saving result file checkpt.crc
11:23:36:WU01:FS01:0x22:Saving result file positions.xtc
11:23:36:WU01:FS01:0x22:Saving result file science.log
11:23:36:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
11:23:37:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:23:37:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11777 run:0 clone:12733 gen:0 core:0x22 unit:0x00000002287234c95e7432a450fc9843
11:23:37:WU01:FS01:Uploading 23.07MiB to 40.114.52.201
11:23:37:WU01:FS01:Connecting to 40.114.52.201:8080
11:23:58:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
11:23:58:WU01:FS01:Connecting to 40.114.52.201:80
11:24:19:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
11:24:19:WU01:FS01:Trying to send results to collection server
11:24:19:WU01:FS01:Uploading 23.07MiB to 37.187.12.48
11:24:19:WU01:FS01:Connecting to 37.187.12.48:8080
11:24:25:WU01:FS01:Upload 24.12%
11:24:31:WU01:FS01:Upload 60.97%
11:24:37:WU01:FS01:Upload 98.09%
11:24:38:WU01:FS01:Upload complete
11:24:38:WU01:FS01:Server responded WORK_ACK (400)
11:24:38:WU01:FS01:Final credit estimate, 44321.00 points
11:24:38:WU01:FS01:Cleaning up
11:24:53:WU02:FS01:Connecting to 65.254.110.245:8080
11:24:54:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:24:54:WU02:FS01:Connecting to 18.218.241.186:80
11:24:54:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:24:54:ERROR:WU02:FS01:Exception: Could not get an assignment
11:27:07:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
11:29:08:WU02:FS01:Connecting to 65.254.110.245:8080
11:29:08:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:29:08:WU02:FS01:Connecting to 18.218.241.186:80
11:29:09:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:29:09:ERROR:WU02:FS01:Exception: Could not get an assignment
11:33:55:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
11:35:59:WU02:FS01:Connecting to 65.254.110.245:8080
11:35:59:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:35:59:WU02:FS01:Connecting to 18.218.241.186:80
11:36:00:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:36:00:ERROR:WU02:FS01:Exception: Could not get an assignment
11:40:42:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
11:47:04:WU02:FS01:Connecting to 65.254.110.245:8080
11:47:05:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:47:05:WU02:FS01:Connecting to 18.218.241.186:80
11:47:05:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:47:05:ERROR:WU02:FS01:Exception: Could not get an assignment
11:47:30:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
11:54:19:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
12:01:07:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
12:05:01:WU02:FS01:Connecting to 65.254.110.245:8080
12:05:02:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
12:05:02:WU02:FS01:Connecting to 18.218.241.186:80
12:05:02:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
12:05:02:ERROR:WU02:FS01:Exception: Could not get an assignment
12:07:56:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
12:14:43:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
12:21:31:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
12:28:18:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
12:34:03:WU02:FS01:Connecting to 65.254.110.245:8080
12:34:04:WU02:FS01:Assigned to work server 128.252.203.2
12:34:04:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Mobile] from 128.252.203.2
12:34:04:WU02:FS01:Connecting to 128.252.203.2:8080
12:34:25:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
12:34:25:WU02:FS01:Connecting to 128.252.203.2:80
12:34:46:ERROR:WU02:FS01:Exception: Failed to connect to 128.252.203.2:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
12:35:06:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
12:41:54:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
12:48:42:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
12:55:30:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
13:02:18:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
13:09:07:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
13:15:54:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
13:21:02:WU02:FS01:Connecting to 65.254.110.245:8080
13:21:03:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:21:03:WU02:FS01:Connecting to 18.218.241.186:80
13:21:03:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:21:03:ERROR:WU02:FS01:Exception: Could not get an assignment
13:22:43:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
13:29:30:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
13:36:18:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
13:43:05:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
13:49:52:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
13:56:40:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
14:03:27:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
14:10:15:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
14:17:01:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
14:23:50:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
14:30:37:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
14:37:03:WU02:FS01:Connecting to 65.254.110.245:8080
14:37:05:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:37:05:WU02:FS01:Connecting to 18.218.241.186:80
14:37:06:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:37:06:ERROR:WU02:FS01:Exception: Could not get an assignment
14:37:26:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
14:44:13:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
14:51:02:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
14:57:48:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
15:04:35:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
15:11:22:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
15:18:09:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
15:24:57:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
15:31:45:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
15:38:33:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
15:45:20:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
15:52:09:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
15:58:55:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
16:05:43:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
16:09:41:75:127.0.0.1:New Web connection
16:12:31:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
16:19:22:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
16:26:15:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
16:33:06:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
16:39:59:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
16:40:03:WU02:FS01:Connecting to 65.254.110.245:8080
16:40:03:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:40:03:WU02:FS01:Connecting to 18.218.241.186:80
16:40:03:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:40:03:ERROR:WU02:FS01:Exception: Could not get an assignment
16:46:49:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
16:53:44:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
16:53:45:WU01:FS00:Connecting to 65.254.110.245:8080
16:53:45:WU01:FS00:Assigned to work server 155.247.164.214
16:53:45:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:3 from 155.247.164.214
16:53:45:WU01:FS00:Connecting to 155.247.164.214:8080
16:53:47:WU01:FS00:Downloading 1.53MiB
16:53:47:WU01:FS00:Download complete
16:53:47:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14328 run:9 clone:649 gen:16 core:0xa7 unit:0x000000149bf7a4d65e6d0ba57cafcc82
17:00:44:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
17:00:47:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
17:00:47:WU00:FS00:0xa7:Saving result file frame2.trr
17:00:47:WU00:FS00:0xa7:Saving result file md.log
17:00:47:WU00:FS00:0xa7:Saving result file science.log
17:00:47:WU00:FS00:0xa7:Saving result file traj_comp.xtc
17:00:47:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
17:00:47:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:00:47:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14333 run:0 clone:683 gen:2 core:0xa7 unit:0x000000030d5a98395e7525ed25040809
17:00:47:WU00:FS00:Uploading 8.95MiB to 13.90.152.57
17:00:47:WU00:FS00:Connecting to 13.90.152.57:8080
17:00:48:WU01:FS00:Starting
17:00:48:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" D:\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 705 -lifeline 8984 -checkpoint 15 -np 3
17:00:48:WU01:FS00:Started FahCore on PID 4112
17:00:48:WU01:FS00:Core PID:2544
17:00:48:WU01:FS00:FahCore 0xa7 started
17:00:48:WU01:FS00:0xa7:*********************** Log Started 2020-03-24T17:00:48Z ***********************
17:00:48:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:00:48:WU01:FS00:0xa7: Type: 0xa7
17:00:48:WU01:FS00:0xa7: Core: Gromacs
17:00:48:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 705 -lifeline 4112 -checkpoint 15 -np 3
17:00:48:WU01:FS00:0xa7:************************************ CBang *************************************
17:00:48:WU01:FS00:0xa7: Date: Oct 26 2019
17:00:48:WU01:FS00:0xa7: Time: 01:38:25
17:00:48:WU01:FS00:0xa7: Revision: c46a1a011a24143739ac7218c5a435f66777f62f
17:00:48:WU01:FS00:0xa7: Branch: master
17:00:48:WU01:FS00:0xa7: Compiler: Visual C++ 2008
17:00:48:WU01:FS00:0xa7: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:00:48:WU01:FS00:0xa7: Platform: win32 10
17:00:48:WU01:FS00:0xa7: Bits: 64
17:00:48:WU01:FS00:0xa7: Mode: Release
17:00:48:WU01:FS00:0xa7:************************************ System ************************************
17:00:48:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i5-7300HQ CPU @ 2.50GHz
17:00:48:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
17:00:48:WU01:FS00:0xa7: CPUs: 4
17:00:48:WU01:FS00:0xa7: Memory: 15.87GiB
17:00:48:WU01:FS00:0xa7:Free Memory: 11.41GiB
17:00:48:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
17:00:48:WU01:FS00:0xa7: OS Version: 6.2
17:00:48:WU01:FS00:0xa7:Has Battery: true
17:00:48:WU01:FS00:0xa7: On Battery: false
17:00:48:WU01:FS00:0xa7: UTC Offset: -4
17:00:48:WU01:FS00:0xa7: PID: 2544
17:00:48:WU01:FS00:0xa7: CWD: D:\FAHClient\work
17:00:48:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
17:00:48:WU01:FS00:0xa7: Version: 0.0.18
17:00:48:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:00:48:WU01:FS00:0xa7: Copyright: 2019 foldingathome.org
17:00:48:WU01:FS00:0xa7: Homepage: https://foldingathome.org/
17:00:48:WU01:FS00:0xa7: Time: 01:52:30
17:00:48:WU01:FS00:0xa7: Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
17:00:48:WU01:FS00:0xa7:************************************ Build *************************************
17:00:48:WU01:FS00:0xa7: SIMD: avx_256
17:00:48:WU01:FS00:0xa7:********************************************************************************
17:00:48:WU01:FS00:0xa7:Project: 14328 (Run 9, Clone 649, Gen 16)
17:00:48:WU01:FS00:0xa7:Unit: 0x000000149bf7a4d65e6d0ba57cafcc82
17:00:48:WU01:FS00:0xa7:Reading tar file core.xml
17:00:48:WU01:FS00:0xa7:Reading tar file frame16.tpr
17:00:48:WU01:FS00:0xa7:Digital signatures verified
17:00:48:WU01:FS00:0xa7:Calling: mdrun -s frame16.tpr -o frame16.trr -cpt 15 -nt 3
17:00:48:WU01:FS00:0xa7:Steps: first=4000000 total=250000
17:00:50:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
17:00:53:WU00:FS00:Upload 70.57%
17:00:55:WU00:FS00:Upload complete
17:00:55:WU00:FS00:Server responded WORK_ACK (400)
17:00:55:WU00:FS00:Final credit estimate, 2114.00 points
17:00:55:WU00:FS00:Cleaning up
17:02:18:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
17:03:45:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
17:05:12:WU01:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
17:06:30:WU01:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
17:07:48:WU01:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
11777 run:0 clone:12733 gen:0 was returned for 9405 points.
You need to complete 10 units and maintain an 80% success rate before you start to get bonus points. The client doesn't know if you have qualified for the bonus and just acts like you have when giving you the final credit estimate.
Rel25917 wrote:11777 run:0 clone:12733 gen:0 was returned for 9405 points.
Don't care THAT much about bonus, was worried if everything is ok and upload was successful on both machines.
