Any work units for Ryzen vega 8 moble GPU?
ptavares
Post by ptavares »
Greetings,
I'm a new folder and have managed to assemble, what I think, is a solid, purpose-built machine running on Fedora 31. While this machine has been making effective use of the CPU (Ryzen 2200G) and nVidia GPUs (RTX 2060s) to complete WUs, I've noticed that my iGPU has yet to be allocated a WU. Is it just that there really are no WUs slated for this type of GPU or could there perhaps be something amiss?
Here is a recent startup log:
*********************** Log Started 2020-03-24T15:57:36Z ***********************
15:57:36:************************* Folding@home Client *************************
15:57:36:        Website: https://foldingathome.org/
15:57:36:      Copyright: (c) 2009-2018 foldingathome.org
15:57:36:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:57:36:           Args: /etc/fahclient/config.xml
15:57:36:                 --pid-file=/run/fahclient/FAHClient.pid
15:57:36:         Config: /etc/fahclient/config.xml
15:57:36:******************************** Build ********************************
15:57:36:        Version: 7.5.1
15:57:36:           Date: May 12 2018
15:57:36:           Time: 22:51:07
15:57:36:     Repository: Git
15:57:36:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
15:57:36:         Branch: master
15:57:36:       Compiler: GNU 4.4.7 20120313 (Red Hat 4.4.7-18)
15:57:36:        Options: -std=gnu++98 -O3 -funroll-loops
15:57:36:       Platform: linux2 4.14.0-3-amd64
15:57:36:           Bits: 64
15:57:36:           Mode: Release
15:57:36:******************************* System ********************************
15:57:36:            CPU: AMD Ryzen 3 2200G with Radeon Vega Graphics
15:57:36:         CPU ID: AuthenticAMD Family 23 Model 17 Stepping 0
15:57:36:           CPUs: 4
15:57:36:         Memory: 5.81GiB
15:57:36:    Free Memory: 2.42GiB
15:57:36:        Threads: POSIX_THREADS
15:57:36:     OS Version: 5.5
15:57:36:    Has Battery: false
15:57:36:     On Battery: false
15:57:36:     UTC Offset: -5
15:57:36:            PID: 22279
15:57:36:            CWD: /var/lib/fahclient
15:57:36:             OS: Linux 5.5.10-200.fc31.x86_64 x86_64
15:57:36:        OS Arch: AMD64
15:57:36:           GPUs: 3
15:57:36:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU106-200A [GeForce RTX 2060]
15:57:36:          GPU 1: Bus:6 Slot:0 Func:0 NVIDIA:7 TU106 [Geforce RTX 2060]
15:57:36:          GPU 2: Bus:8 Slot:0 Func:0 AMD:5 Raven [Ryzen vega 8 moble]
15:57:36:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
15:57:36:  CUDA Device 1: Platform:0 Device:1 Bus:6 Slot:0 Compute:7.5 Driver:10.2
15:57:36:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:1.1 Driver:19.2
15:57:36:OpenCL Device 1: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:440.64
15:57:36:OpenCL Device 2: Platform:1 Device:1 Bus:6 Slot:0 Compute:1.2 Driver:440.64
15:57:36:***********************************************************************
15:57:36:<config>
15:57:36:  <!-- HTTP Server -->
15:57:36:  <allow v='127.0.0.1 192.168.1.0/24'/>
15:57:36:
15:57:36:  <!-- Network -->
15:57:36:  <proxy v=':8080'/>
15:57:36:
15:57:36:  <!-- Remote Command Server -->
15:57:36:  <command-allow-no-pass v='127.0.0.1 192.168.1.0/24'/>
15:57:36:
15:57:36:  <!-- Slot Control -->
15:57:36:  <power v='full'/>
15:57:36:
15:57:36:  <!-- User Information -->
15:57:36:  <passkey v='********************************'/>
15:57:36:  <team v='11812'/>
15:57:36:  <user v='ptavares'/>
15:57:36:
15:57:36:  <!-- Folding Slots -->
15:57:36:  <slot id='0' type='CPU'/>
15:57:36:  <slot id='1' type='GPU'>
15:57:36:    <opencl-index v='0'/>
15:57:36:  </slot>
15:57:36:  <slot id='2' type='GPU'/>
15:57:36:  <slot id='3' type='GPU'/>
15:57:36:</config>
15:57:36:Trying to access database...
15:57:36:Successfully acquired database lock
15:57:36:Enabled folding slot 00: READY cpu:1
15:57:36:Enabled folding slot 01: READY gpu:0:TU106-200A [GeForce RTX 2060]
15:57:36:Enabled folding slot 02: READY gpu:1:TU106 [Geforce RTX 2060]
15:57:36:Enabled folding slot 03: READY gpu:2:Raven [Ryzen vega 8 moble]
15:57:36:WU01:FS00:Starting
15:57:36:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 705 -lifeline 22279 -checkpoint 15 -np 1
15:57:36:WU01:FS00:Started FahCore on PID 22315
15:57:36:WU01:FS00:Core PID:22319
15:57:36:WU01:FS00:FahCore 0xa7 started
15:57:36:WU03:FS02:Starting
15:57:36:WU03:FS02:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 03 -suffix 01 -version 705 -lifeline 22279 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 1 -cuda-device 1 -gpu 1
15:57:36:WU03:FS02:Started FahCore on PID 22323
15:57:36:WU03:FS02:Core PID:22327
15:57:36:WU03:FS02:FahCore 0x22 started
15:57:37:WU00:FS01:Starting
15:57:37:WU00:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/cores.foldingathome.org/v7/lin/64bit/Core_22.fah/FahCore_22 -dir 00 -suffix 01 -version 705 -lifeline 22279 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device 0 -gpu 0
15:57:37:WU00:FS01:Started FahCore on PID 22345
15:57:37:WU00:FS01:Core PID:22349
15:57:37:WU00:FS01:FahCore 0x22 started
15:57:37:WU01:FS00:0xa7:*********************** Log Started 2020-03-24T15:57:36Z ***********************
15:57:37:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
15:57:37:WU01:FS00:0xa7:       Type: 0xa7
15:57:37:WU01:FS00:0xa7:       Core: Gromacs
15:57:37:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 22315 -checkpoint 15 -np
15:57:37:WU01:FS00:0xa7:             1
15:57:37:WU01:FS00:0xa7:************************************ CBang *************************************
15:57:37:WU01:FS00:0xa7:       Date: Nov 5 2019
15:57:37:WU01:FS00:0xa7:       Time: 06:06:57
15:57:37:WU01:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
15:57:37:WU01:FS00:0xa7:     Branch: master
15:57:37:WU01:FS00:0xa7:   Compiler: GNU 8.3.0
15:57:37:WU01:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
15:57:37:WU01:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
15:57:37:WU01:FS00:0xa7:       Bits: 64
15:57:37:WU01:FS00:0xa7:       Mode: Release
15:57:37:WU01:FS00:0xa7:************************************ System ************************************
15:57:37:WU01:FS00:0xa7:        CPU: AMD Ryzen 3 2200G with Radeon Vega Graphics
15:57:37:WU01:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 17 Stepping 0
15:57:37:WU01:FS00:0xa7:       CPUs: 4
15:57:37:WU01:FS00:0xa7:     Memory: 5.81GiB
15:57:37:WU01:FS00:0xa7:Free Memory: 2.35GiB
15:57:37:WU01:FS00:0xa7:    Threads: POSIX_THREADS
15:57:37:WU01:FS00:0xa7: OS Version: 5.5
15:57:37:WU01:FS00:0xa7:Has Battery: false
15:57:37:WU01:FS00:0xa7: On Battery: false
15:57:37:WU01:FS00:0xa7: UTC Offset: -5
15:57:37:WU01:FS00:0xa7:        PID: 22319
15:57:37:WU01:FS00:0xa7:        CWD: /var/lib/fahclient/work
15:57:37:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
15:57:37:WU01:FS00:0xa7:    Version: 0.0.18
15:57:37:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:57:37:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
15:57:37:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
15:57:37:WU01:FS00:0xa7:       Time: 06:13:26
15:57:37:WU01:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
15:57:37:WU01:FS00:0xa7:************************************ Build *************************************
15:57:37:WU01:FS00:0xa7:       SIMD: avx_256
15:57:37:WU01:FS00:0xa7:********************************************************************************
15:57:37:WU01:FS00:0xa7:Project: 13860 (Run 0, Clone 1023, Gen 10)
15:57:37:WU01:FS00:0xa7:Unit: 0x0000000b0d5a98395e72df88e72e259b
15:57:37:WU01:FS00:0xa7:Digital signatures verified
15:57:37:WU01:FS00:0xa7:Calling: mdrun -s frame10.tpr -o frame10.trr -x frame10.xtc -e frame10.edr -cpi state.cpt -cpt 15 -nt 1
15:57:37:WU01:FS00:0xa7:Steps: first=1250000 total=125000
15:57:37:WU03:FS02:0x22:*********************** Log Started 2020-03-24T15:57:36Z ***********************
15:57:37:WU03:FS02:0x22:*************************** Core22 Folding@home Core ***************************
15:57:37:WU03:FS02:0x22:       Type: 0x22
15:57:37:WU03:FS02:0x22:       Core: Core22
15:57:37:WU03:FS02:0x22:    Website: https://foldingathome.org/
15:57:37:WU03:FS02:0x22:  Copyright: (c) 2009-2018 foldingathome.org
15:57:37:WU03:FS02:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:57:37:WU03:FS02:0x22:             <rafal.wiewiora@choderalab.org>
15:57:37:WU03:FS02:0x22:       Args: -dir 03 -suffix 01 -version 705 -lifeline 22323 -checkpoint 15
15:57:37:WU03:FS02:0x22:             -gpu-vendor nvidia -opencl-platform 1 -opencl-device 1 -cuda-device
15:57:37:WU03:FS02:0x22:             1 -gpu 1
15:57:37:WU03:FS02:0x22:     Config: <none>
15:57:37:WU03:FS02:0x22:************************************ Build *************************************
15:57:37:WU03:FS02:0x22:    Version: 0.0.2
15:57:37:WU03:FS02:0x22:       Date: Dec 6 2019
15:57:37:WU03:FS02:0x22:       Time: 21:20:17
15:57:37:WU03:FS02:0x22: Repository: Git
15:57:37:WU03:FS02:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
15:57:37:WU03:FS02:0x22:     Branch: core22
15:57:37:WU03:FS02:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
15:57:37:WU03:FS02:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
15:57:37:WU03:FS02:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
15:57:37:WU03:FS02:0x22:       Bits: 64
15:57:37:WU03:FS02:0x22:       Mode: Release
15:57:37:WU03:FS02:0x22:************************************ System ************************************
15:57:37:WU03:FS02:0x22:        CPU: AMD Ryzen 3 2200G with Radeon Vega Graphics
15:57:37:WU03:FS02:0x22:     CPU ID: AuthenticAMD Family 23 Model 17 Stepping 0
15:57:37:WU03:FS02:0x22:       CPUs: 4
15:57:37:WU03:FS02:0x22:     Memory: 5.81GiB
15:57:37:WU03:FS02:0x22:Free Memory: 2.34GiB
15:57:37:WU03:FS02:0x22:    Threads: POSIX_THREADS
15:57:37:WU03:FS02:0x22: OS Version: 5.5
15:57:37:WU03:FS02:0x22:Has Battery: false
15:57:37:WU03:FS02:0x22: On Battery: false
15:57:37:WU03:FS02:0x22: UTC Offset: -5
15:57:37:WU03:FS02:0x22:        PID: 22327
15:57:37:WU03:FS02:0x22:        CWD: /var/lib/fahclient/work
15:57:37:WU03:FS02:0x22:         OS: Linux 5.5.10-200.fc31.x86_64 x86_64
15:57:37:WU03:FS02:0x22:    OS Arch: AMD64
15:57:37:WU03:FS02:0x22:********************************************************************************
15:57:37:WU03:FS02:0x22:Project: 11761 (Run 0, Clone 4191, Gen 9)
15:57:37:WU03:FS02:0x22:Unit: 0x0000001180fccb0a5e6d7d62fdcd8a10
15:57:37:WU03:FS02:0x22:Digital signatures verified
15:57:37:WU03:FS02:0x22:Folding@home GPU Core22 Folding@home Core
15:57:37:WU03:FS02:0x22:Version 0.0.2
15:57:37:WU03:FS02:0x22:  Found a checkpoint file
15:57:37:WU00:FS01:0x22:*********************** Log Started 2020-03-24T15:57:37Z ***********************
15:57:37:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
15:57:37:WU00:FS01:0x22:       Type: 0x22
15:57:37:WU00:FS01:0x22:       Core: Core22
15:57:37:WU00:FS01:0x22:    Website: https://foldingathome.org/
15:57:37:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
15:57:37:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:57:37:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
15:57:37:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 22345 -checkpoint 15
15:57:37:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 1 -opencl-device 0 -cuda-device
15:57:37:WU00:FS01:0x22:             0 -gpu 0
15:57:37:WU00:FS01:0x22:     Config: <none>
15:57:37:WU00:FS01:0x22:************************************ Build *************************************
15:57:37:WU00:FS01:0x22:    Version: 0.0.2
15:57:37:WU00:FS01:0x22:       Date: Dec 6 2019
15:57:37:WU00:FS01:0x22:       Time: 21:20:17
15:57:37:WU00:FS01:0x22: Repository: Git
15:57:37:WU00:FS01:0x22:   Revision: f87d92b58abdf7e6bf2e173cfbc4dc3e837c7042
15:57:37:WU00:FS01:0x22:     Branch: core22
15:57:37:WU00:FS01:0x22:   Compiler: GNU 4.8.2 20140120 (Red Hat 4.8.2-15)
15:57:37:WU00:FS01:0x22:    Options: -std=gnu++98 -O3 -funroll-loops
15:57:37:WU00:FS01:0x22:   Platform: linux2 4.9.87-linuxkit-aufs
15:57:37:WU00:FS01:0x22:       Bits: 64
15:57:37:WU00:FS01:0x22:       Mode: Release
15:57:37:WU00:FS01:0x22:************************************ System ************************************
15:57:37:WU00:FS01:0x22:        CPU: AMD Ryzen 3 2200G with Radeon Vega Graphics
15:57:37:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 17 Stepping 0
15:57:37:WU00:FS01:0x22:       CPUs: 4
15:57:37:WU00:FS01:0x22:     Memory: 5.81GiB
15:57:37:WU00:FS01:0x22:Free Memory: 2.20GiB
15:57:37:WU00:FS01:0x22:    Threads: POSIX_THREADS
15:57:37:WU00:FS01:0x22: OS Version: 5.5
15:57:37:WU00:FS01:0x22:Has Battery: false
15:57:37:WU00:FS01:0x22: On Battery: false
15:57:37:WU00:FS01:0x22: UTC Offset: -5
15:57:37:WU00:FS01:0x22:        PID: 22349
15:57:37:WU00:FS01:0x22:        CWD: /var/lib/fahclient/work
15:57:37:WU00:FS01:0x22:         OS: Linux 5.5.10-200.fc31.x86_64 x86_64
15:57:37:WU00:FS01:0x22:    OS Arch: AMD64
15:57:37:WU00:FS01:0x22:********************************************************************************
15:57:37:WU00:FS01:0x22:Project: 11762 (Run 0, Clone 9014, Gen 9)
15:57:37:WU00:FS01:0x22:Unit: 0x0000000f80fccb0a5e7113c4fb0a80e9
15:57:37:WU00:FS01:0x22:Digital signatures verified
15:57:37:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
15:57:37:WU00:FS01:0x22:Version 0.0.2
15:57:37:WU00:FS01:0x22:  Found a checkpoint file
15:57:37:WU01:FS00:0xa7:Completed 2422 out of 125000 steps (1%)
15:57:41:WU03:FS02:0x22:Completed 1350000 out of 2000000 steps (67%)
15:57:41:WU03:FS02:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:57:44:WU00:FS01:0x22:Completed 800000 out of 1000000 steps (80%)
15:57:44:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
15:57:48:WU02:FS03:Connecting to 65.254.110.245:8080
15:57:51:WU01:FS00:0xa7:Completed 2500 out of 125000 steps (2%)
15:57:52:WARNING:WU02:FS03:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:57:52:WU02:FS03:Connecting to 18.218.241.186:80
15:57:52:WARNING:WU02:FS03:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:57:52:ERROR:WU02:FS03:Exception: Could not get an assignment
15:57:53:WU02:FS03:Connecting to 65.254.110.245:8080
15:57:53:WARNING:WU02:FS03:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:57:53:WU02:FS03:Connecting to 18.218.241.186:80
15:57:54:WARNING:WU02:FS03:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
Any insight here would be greatly appreciated!
Re: Any work units for Ryzen vega 8 moble GPU?
Welcome to Folding@Home!
The two Nvidia cards both show the right Compute and Driver.
The AMD card is not showing that you have OpenCL installed for it
AMD supports Compute 2.0 and the driver is much higher.
I am not a Linux users, but I know you need the AMD proprietary Driver, and you need to install OpenCL separately.
https://einsteinathome.org/content/quic ... lar-distro
ptavares
Post by ptavares »
Thanks Jimbo. After investigating your link, also looking at viewtopic.php?f=81&t=33353&p=318278&hil ... ux#p318278, and doing a bit of stracing on the FAHClient, I was able to come up with a clean installation of just the AMD OpenCL drivers (leverages the open amdgpu driver that ships with the Linux kernel) on my Fedora 31 machine.
For anyone else looking to fold with a Fedora Linux machine and an AMD GPU here are the steps:
  1. Download the latest AMD driver from https://www.amd.com/en/support for your card. I happened to go with version 19.50 for RHEL/CentOS 8.1 as this is the closest to match to Fedora 31 that was available.
  2. Untar the archive:
    tar -xvf amdgpu-pro-*-rhel-8.tar.xz
  3. Install, using rpm with --nodeps to force the install without un-needed dependencies, just the bare minimum packages needed:
    rpm -i --nodeps ./amdgpu-pro-*/RPMS/x86_64/opencl-orca-amdgpu-pro-icd*.rpm ./amdgpu-pro-*/RPMS/x86_64/libgl-amdgpu-pro*.rpm ./amdgpu-pro-*/RPMS/x86_64/opencl-amdgpu-pro-icd*.rpm ./amdgpu-pro-*/RPMS/noarch/libgl-amdgpu-pro-appprofiles*.rpm
  4. Restart your machine and you should be in business
Here is my updated startup log for reference:
*********************** Log Started 2020-03-26T12:47:54Z ***********************
12:47:54:************************* Folding@home Client *************************
12:47:54:        Website: https://foldingathome.org/
12:47:54:      Copyright: (c) 2009-2018 foldingathome.org
12:47:54:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:47:54:           Args: /etc/fahclient/config.xml
12:47:54:                 --pid-file=/run/fahclient/FAHClient.pid
12:47:54:         Config: /etc/fahclient/config.xml
12:47:54:******************************** Build ********************************
12:47:54:        Version: 7.5.1
12:47:54:           Date: May 12 2018
12:47:54:           Time: 22:51:07
12:47:54:     Repository: Git
12:47:54:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
12:47:54:         Branch: master
12:47:54:       Compiler: GNU 4.4.7 20120313 (Red Hat 4.4.7-18)
12:47:54:        Options: -std=gnu++98 -O3 -funroll-loops
12:47:54:       Platform: linux2 4.14.0-3-amd64
12:47:54:           Bits: 64
12:47:54:           Mode: Release
12:47:54:******************************* System ********************************
12:47:54:            CPU: AMD Ryzen 3 2200G with Radeon Vega Graphics
12:47:54:         CPU ID: AuthenticAMD Family 23 Model 17 Stepping 0
12:47:54:           CPUs: 4
12:47:54:         Memory: 5.80GiB
12:47:54:    Free Memory: 3.30GiB
12:47:54:        Threads: POSIX_THREADS
12:47:54:     OS Version: 5.5
12:47:54:    Has Battery: false
12:47:54:     On Battery: false
12:47:54:     UTC Offset: -5
12:47:54:            PID: 7678
12:47:54:            CWD: /var/lib/fahclient
12:47:54:             OS: Linux 5.5.10-200.fc31.x86_64 x86_64
12:47:54:        OS Arch: AMD64
12:47:54:           GPUs: 3
12:47:54:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 TU106-200A [GeForce RTX 2060]
12:47:54:          GPU 1: Bus:6 Slot:0 Func:0 NVIDIA:7 TU106 [Geforce RTX 2060]
12:47:54:          GPU 2: Bus:8 Slot:0 Func:0 AMD:5 Raven [Ryzen vega 8 moble]
12:47:54:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:10.2
12:47:54:  CUDA Device 1: Platform:0 Device:1 Bus:6 Slot:0 Compute:7.5 Driver:10.2
12:47:54:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:440.64
12:47:54:OpenCL Device 1: Platform:0 Device:1 Bus:6 Slot:0 Compute:1.2 Driver:440.64
12:47:54:OpenCL Device 3: Platform:2 Device:0 Bus:8 Slot:0 Compute:2.0 Driver:3004.6
12:47:54:***********************************************************************
12:47:54:<config>
12:47:54:  <!-- HTTP Server -->
12:47:54:  <allow v='127.0.0.1 192.168.1.0/24'/>
12:47:54:
12:47:54:  <!-- Network -->
12:47:54:  <proxy v=':8080'/>
12:47:54:
12:47:54:  <!-- Remote Command Server -->
12:47:54:  <command-allow-no-pass v='127.0.0.1 192.168.1.0/24'/>
12:47:54:
12:47:54:  <!-- Slot Control -->
12:47:54:  <power v='full'/>
12:47:54:
12:47:54:  <!-- User Information -->
12:47:54:  <passkey v='********************************'/>
12:47:54:  <team v='11812'/>
12:47:54:  <user v='ptavares'/>
12:47:54:
12:47:54:  <!-- Folding Slots -->
12:47:54:  <slot id='0' type='CPU'/>
12:47:54:  <slot id='1' type='GPU'>
12:47:54:    <opencl-index v='0'/>
12:47:54:  </slot>
12:47:54:  <slot id='2' type='GPU'/>
12:47:54:  <slot id='3' type='GPU'/>
12:47:54:</config>
12:47:54:Trying to access database...
12:47:54:Successfully acquired database lock
12:47:54:Enabled folding slot 00: READY cpu:1
12:47:54:Enabled folding slot 01: READY gpu:0:TU106-200A [GeForce RTX 2060]
12:47:54:Enabled folding slot 02: READY gpu:1:TU106 [Geforce RTX 2060]
12:47:54:Enabled folding slot 03: READY gpu:2:Raven [Ryzen vega 8 moble]
And a screenshot for proof:
Now I just need to figure out how to get this iGPU folding faster. I know it's not as powerful as a dGPU but surely it can complete a WU in way less that 24 hours. Anyone using this same APU have any metrics for comparison?
Thanks again!
dmk1000
Post by dmk1000 »
Ryzen 5 2400G, stock cooler, no overclock.
02 Running [19.20%] 14 hours 10 mins 44122 11759 ( 0, 9028, 24)
From Log:
19:11:31:WU02:FS01:0x22:Completed 0 out of 1000000 steps (0%)
21:03:32:WU02:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
22:43:26:WU02:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
I make that ~18.25 hrs toal for this WU.
BobWilliams757
Ryzen 2400G APU
16 GB DDR4-3200
MSI GTX 1660 Super Gaming X
Post by BobWilliams757 »
Another stock 2400G build here.
Most of my work units have been in the 8-12 hour range.
My Points per day hovers in the high 16,000's to the low 17,000's
I'm running the onboard graphics only, no dedicated GPU and not running CPU
I would suspect that with multiple GPU's running that more memory resources are being used to feed the dedicated GPU's. Two faster discreet cards are going to use resources over one on board card that's not a powerhouse.
But I could be wrong.....
Fold them if you get them!
sam6861
Post by sam6861 »
My Ryzen 2400g have Vega 11 that takes about 8-10 hours, at a locked 1240 Mhz manually set on my motherboard BIOS settings.
Vega 8 may take 1.55 times longer from less compute units (8 / 11) and slower clock speed (1100 / 1240), if it wasn't limited by memory bandwidth, power limit, temperature limit.
Using Dual channel DDR4? Dual channel using 2 or 4 sticks of equal size DDR4 will double the speed of memory bandwidth, which will speed up Vega integrated graphics. I am using DDR4-3200 3.5v 32 GB (8 GB x4), dual channel, slowed down to 2933 MT/s due to Ryzen 2400g memory controller specs and to avoid random errors or crashes.
