Remote Management (on LAN) From One Machine
rjkucia
Post by rjkucia »
(Crossposting this from New Donors, sorry if this is incorrect etiquette)
viewtopic.php?f=61&t=33246
Hi, I've installed FAH on three machines - my Macbook, my Windows desktop, and my Ubuntu server. It's running fine on all of them, but I'd like to administer them through my Macbook across my LAN.
I'm able to administer the Macbook itself through the web app and the advanced client - that's been the easy part!
I'm able to administer my server through the web client (I modified the configuration to allow my Macbook's IP). When I try to connect using the Advanced Control, the server shows up as "online", but when I click on it, it switches to "Updating", and never loads.
My desktop can currently only be set up locally. The Advanced Control on the Macbook is stuck at the "Connecting" status and doesn't change. I'm not sure how to expose the web client on Windows.
Thanks in advance!
jonault
Re: Remote Management (on LAN) From One Machine
Post by jonault »
You might find this thread helpful.
rjkucia
Post by rjkucia »
Thank you! That's what I had tried that previously, but I mistyped my IP range on my desktop; it's working now!
However, my server is still having the "Updating" issue. It's not the end of the world if I just have to use the web client for that one, but it'd be more convenient to have it all in FAHControl. Any idea where to start with that one?
