Whitelist Nvidia GT 1030
captnbp
Post by captnbp »
Hi,
Could you please add the Nvidia GT 1030 ?
Thanks ! :D
FAHClient --lspci
0x8086:0x0100:0:0:0:Intel Corporation:
0x8086:0x0101:0:1:0:Intel Corporation:
0x8086:0x0122:0:2:0:Intel Corporation:
0x8086:0x1c3a:0:22:0:Intel Corporation:
0x8086:0x1c2d:0:26:0:Intel Corporation:
0x8086:0x1c20:0:27:0:Intel Corporation:
0x8086:0x1c10:0:28:0:Intel Corporation:
0x8086:0x1c1c:0:28:6:Intel Corporation:
0x8086:0x1c1e:0:28:7:Intel Corporation:
0x8086:0x1c26:0:29:0:Intel Corporation:
0x8086:0x244e:0:30:0:Intel Corporation:
0x8086:0x1c44:0:31:0:Intel Corporation:
0x8086:0x1c02:0:31:2:Intel Corporation:
0x8086:0x1c22:0:31:3:Intel Corporation:
0x10de:0x1d01:1:0:0:NVIDIA Corporation:
0x10de:0x0fb8:1:0:1:NVIDIA Corporation:
0x10ec:0x8168:3:0:0:Realtek Semiconductor Co., Ltd.:
0x1b6f:0x7023:4:0:0:Etron Technology, Inc.:
*********************** Log Started 2020-03-24T15:42:22Z ***********************
15:42:22:************************* Folding@home Client *************************
15:42:22:      Website: https://foldingathome.org/
15:42:22:    Copyright: (c) 2009-2018 foldingathome.org
15:42:22:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:42:22:         Args: --child --lifeline 10844 /etc/fahclient/config.xml --run-as
15:42:22:               fahclient --pid-file=/var/run/fahclient.pid --daemon
15:42:22:       Config: /etc/fahclient/config.xml
15:42:22:******************************** Build ********************************
15:42:22:      Version: 7.5.1
15:42:22:         Date: May 11 2018
15:42:22:         Time: 19:59:04
15:42:22:   Repository: Git
15:42:22:     Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
15:42:22:       Branch: master
15:42:22:     Compiler: GNU 6.3.0 20170516
15:42:22:      Options: -std=gnu++98 -O3 -funroll-loops
15:42:22:     Platform: linux2 4.14.0-3-amd64
15:42:22:         Bits: 64
15:42:22:         Mode: Release
15:42:22:******************************* System ********************************
15:42:22:          CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
15:42:22:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
15:42:22:         CPUs: 8
15:42:22:       Memory: 15.56GiB
15:42:22:  Free Memory: 273.29MiB
15:42:22:      Threads: POSIX_THREADS
15:42:22:   OS Version: 5.3
15:42:22:  Has Battery: false
15:42:22:   On Battery: false
15:42:22:   UTC Offset: 1
15:42:22:          PID: 10846
15:42:22:          CWD: /var/lib/fahclient
15:42:22:           OS: Linux 5.3.0-40-generic x86_64
15:42:22:      OS Arch: AMD64
15:42:22:         GPUs: 0
15:42:22:CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:9.1
15:42:22:       OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.so':
15:42:22:               libOpenCL.so: cannot open shared object file: No such file or
15:42:22:               directory
15:42:22:***********************************************************************
15:42:53:<config>
15:42:53:  <!-- Client Control -->
15:42:53:  <fold-anon v='true'/>
15:42:53:
15:42:53:  <!-- Folding Slot Configuration -->
15:42:53:  <gpu v='false'/>
15:42:53:
15:42:53:  <!-- Network -->
15:42:53:  <proxy v=':8080'/>
15:42:53:
15:42:53:  <!-- User Information -->
15:42:53:  <team v='247478'/>
15:42:53:  <user v='captnbp'/>
15:42:53:
15:42:53:  <!-- Folding Slots -->
15:42:53:  <slot id='0' type='CPU'/>
15:42:53:</config>
Re: Whitelist Nvidia GT 1030
1d01 is already whitelisted, client needs to download updated GPUs.txt file. The configuration also need to have the gpu = false changed to true, and the FAHClient process restarted. Someone should come along and provide additional instructions, in the meantime try searching the forum for other posts on this.
Welcome to Folding@home!
I am not a Linux user, but I think I have hints
You need to use Nvidia's Graphics driver, not the generic drivers.
You also need to install the OpanCL runtime and Dev kit from Nvidia.
Best of luck!
captnbp
Post by captnbp »
Ooops my bad, I didn't check the embedded init script from the Ubuntu package. Just changed the options with --gpu=true and the GPU is now recognized.
Thanks !
