Failed to Send WU 11776
Kenidrunkenwolf
Post by Kenidrunkenwolf »
My computer has been attempting to send the completed WU 11776, however I continually get a exemption that it failed to connect.
12:54:22:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:54:43:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
12:54:43:ERROR:WU01:FS01:Exception: Transfer failed
12:55:04:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:55:26:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
12:55:26:ERROR:WU01:FS01:Exception: Transfer failed
12:56:05:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
12:56:24:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
12:56:24:ERROR:WU01:FS01:Exception: Transfer failed
12:57:48:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
12:57:49:ERROR:WU01:FS01:Exception: Transfer failed
13:00:19:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
13:35:05:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
13:35:06:ERROR:WU01:FS01:Exception: Transfer failed
13:35:27:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
******************************* Date: 2020-03-24 *******************************
14:27:02:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
14:27:02:ERROR:WU01:FS01:Exception: Transfer failed
14:27:05:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
14:27:07:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: No connection could be made because the target machine actively refused it.
14:27:08:ERROR:WU01:FS01:Exception: Transfer failed
It appears that the file is 49.92MiB if that helps. It transfered about 70.61% of the file.
davidcoton
Re: Failed to Send WU 11776
Post by davidcoton »
That is a "normal" set of errors resulting from server overload. The team are aware and are trying to ramp up to cope with the 20x increase in F@H clients.
Kebast
Post by Kebast »
I've had this one fail 13 times now...
00:27:10:WU02:FS00:0x22:Completed 1000000 out of 1000000 steps (100%)
00:27:17:WU02:FS00:0x22:Saving result file ../logfile_01.txt
00:27:17:WU02:FS00:0x22:Saving result file checkpointState.xml
00:27:17:WU02:FS00:0x22:Saving result file checkpt.crc
00:27:17:WU02:FS00:0x22:Saving result file positions.xtc
00:27:17:WU02:FS00:0x22:Saving result file science.log
00:27:17:WU02:FS00:0x22:Folding@home Core Shutdown: FINISHED_UNIT
00:27:18:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:27:18:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:11776 run:0 clone:15663 gen:3 core:0x22 unit:0x00000006287234c95e774beee348abe7
00:27:18:WU02:FS00:Uploading 49.92MiB to 40.114.52.201
00:27:18:WU02:FS00:Connecting to 40.114.52.201:8080
00:29:27:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
00:29:27:WU02:FS00:Connecting to 40.114.52.201:80
00:31:38:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: Connection timed out
00:31:38:WU02:FS00:Trying to send results to collection server
00:31:38:WU02:FS00:Uploading 49.92MiB to 155.247.166.220
00:31:38:WU02:FS00:Connecting to 155.247.166.220:8080
00:31:38:ERROR:WU02:FS00:Exception: Transfer failed
00:31:39:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:11776 run:0 clone:15663 gen:3 core:0x22 unit:0x00000006287234c95e774beee348abe7
00:31:39:WU02:FS00:Uploading 49.92MiB to 40.114.52.201
00:31:39:WU02:FS00:Connecting to 40.114.52.201:8080
00:33:49:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
00:33:49:WU02:FS00:Connecting to 40.114.52.201:80
00:36:00:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: Connection timed out
00:36:00:WU02:FS00:Trying to send results to collection server
00:36:00:WU02:FS00:Uploading 49.92MiB to 155.247.166.220
00:36:00:WU02:FS00:Connecting to 155.247.166.220:8080
00:36:01:ERROR:WU02:FS00:Exception: Transfer failed
00:36:01:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:11776 run:0 clone:15663 gen:3 core:0x22 unit:0x00000006287234c95e774beee348abe7
00:36:01:WU02:FS00:Uploading 49.92MiB to 40.114.52.201
00:36:01:WU02:FS00:Connecting to 40.114.52.201:8080
00:38:11:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
00:38:11:WU02:FS00:Connecting to 40.114.52.201:80
00:40:22:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: Connection timed out
00:40:22:WU02:FS00:Trying to send results to collection server
00:40:22:WU02:FS00:Uploading 49.92MiB to 155.247.166.220
00:40:22:WU02:FS00:Connecting to 155.247.166.220:8080
00:40:23:ERROR:WU02:FS00:Exception: Transfer failed
00:40:23:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:11776 run:0 clone:15663 gen:3 core:0x22 unit:0x00000006287234c95e774beee348abe7
00:40:23:WU02:FS00:Uploading 49.92MiB to 40.114.52.201
00:40:23:WU02:FS00:Connecting to 40.114.52.201:8080
02:41:02:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:11776 run:0 clone:15663 gen:3 core:0x22 unit:0x00000006287234c95e774beee348abe7
02:41:02:WU02:FS00:Uploading 49.92MiB to 40.114.52.201
02:41:02:WU02:FS00:Connecting to 40.114.52.201:8080
02:43:11:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
02:43:11:WU02:FS00:Connecting to 40.114.52.201:80
02:45:22:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: Connection timed out
02:45:22:WU02:FS00:Trying to send results to collection server
02:45:22:WU02:FS00:Uploading 49.92MiB to 155.247.166.220
02:45:22:WU02:FS00:Connecting to 155.247.166.220:8080
02:45:23:ERROR:WU02:FS00:Exception: Transfer failed
03:57:03:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:11776 run:0 clone:15663 gen:3 core:0x22 unit:0x00000006287234c95e774beee348abe7
03:57:03:WU02:FS00:Uploading 49.92MiB to 40.114.52.201
03:57:03:WU02:FS00:Connecting to 40.114.52.201:8080
03:59:12:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
03:59:12:WU02:FS00:Connecting to 40.114.52.201:80
04:01:23:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: Connection timed out
04:01:23:WU02:FS00:Trying to send results to collection server
04:01:23:WU02:FS00:Uploading 49.92MiB to 155.247.166.220
04:01:23:WU02:FS00:Connecting to 155.247.166.220:8080
04:01:23:ERROR:WU02:FS00:Exception: Transfer failed
******************************* Date: 2020-03-25 *******************************
06:00:02:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:11776 run:0 clone:15663 gen:3 core:0x22 unit:0x00000006287234c95e774beee348abe7
06:00:02:WU02:FS00:Uploading 49.92MiB to 40.114.52.201
06:00:02:WU02:FS00:Connecting to 40.114.52.201:8080
06:02:13:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
06:02:13:WU02:FS00:Connecting to 40.114.52.201:80
06:02:14:WU02:FS00:Upload 0.13%
06:02:45:WU02:FS00:Upload 0.25%
06:02:45:WARNING:WU02:FS00:Exception: Failed to send results to work server: Transfer failed
06:02:45:WU02:FS00:Trying to send results to collection server
06:02:45:WU02:FS00:Uploading 49.92MiB to 155.247.166.220
06:02:45:WU02:FS00:Connecting to 155.247.166.220:8080
06:02:45:ERROR:WU02:FS00:Exception: Transfer failed
09:19:03:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:11776 run:0 clone:15663 gen:3 core:0x22 unit:0x00000006287234c95e774beee348abe7
09:19:03:WU02:FS00:Uploading 49.92MiB to 40.114.52.201
09:19:03:WU02:FS00:Connecting to 40.114.52.201:8080
09:21:13:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
09:21:13:WU02:FS00:Connecting to 40.114.52.201:80
09:23:24:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: Connection timed out
09:23:24:WU02:FS00:Trying to send results to collection server
09:23:24:WU02:FS00:Uploading 49.92MiB to 155.247.166.220
09:23:24:WU02:FS00:Connecting to 155.247.166.220:8080
09:23:24:ERROR:WU02:FS00:Exception: Transfer failed
12:17:36:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:11776 run:0 clone:15663 gen:3 core:0x22 unit:0x00000006287234c95e774beee348abe7
12:17:36:WU02:FS00:Uploading 49.92MiB to 40.114.52.201
12:17:36:WU02:FS00:Connecting to 40.114.52.201:8080
Ryzen 5900x 12T - RTX 4070 TI
Jertzuu
Hardware configuration: Ryzen 5 2600 @ 4,1GHz
G.Skill Trident Z RGB 3200mHz CL14 32Gb
Asus Prime X470-PRO
Zotac AMP! Extreme 1080 Ti
Samsung Evo 970 250Gb NVMe M.2
Samsung Evo 860 500Gb SSD
WD Black 1Tb 7200RPM HDD
Post by Jertzuu »
Just got this...
08:34:06:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11776 run:0 clone:37789 gen:1 core:0x22 unit:0x00000001287234c95e793105fde5aafb
08:34:06:WU00:FS01:Starting
08:34:07:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\jeret\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 15620 -checkpoint 10 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
08:34:07:WU00:FS01:Started FahCore on PID 3412
08:34:07:WU00:FS01:Core PID:9840
08:34:07:WU00:FS01:FahCore 0x22 started
08:34:07:WU00:FS01:0x22:*********************** Log Started 2020-03-28T08:34:07Z ***********************
08:34:07:WU00:FS01:0x22:*************************** Core22 Folding@home Core ***************************
08:34:07:WU00:FS01:0x22:       Type: 0x22
08:34:07:WU00:FS01:0x22:       Core: Core22
08:34:07:WU00:FS01:0x22:    Website: https://foldingathome.org/
08:34:07:WU00:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
08:34:07:WU00:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
08:34:07:WU00:FS01:0x22:             <rafal.wiewiora@choderalab.org>
08:34:07:WU00:FS01:0x22:       Args: -dir 00 -suffix 01 -version 705 -lifeline 3412 -checkpoint 10
08:34:07:WU00:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
08:34:07:WU00:FS01:0x22:             0 -gpu 0
08:34:07:WU00:FS01:0x22:     Config: <none>
08:34:07:WU00:FS01:0x22:************************************ Build *************************************
08:34:07:WU00:FS01:0x22:    Version: 0.0.2
08:34:07:WU00:FS01:0x22:       Date: Dec 6 2019
08:34:07:WU00:FS01:0x22:       Time: 21:30:31
08:34:07:WU00:FS01:0x22: Repository: Git
08:34:07:WU00:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
08:34:07:WU00:FS01:0x22:     Branch: HEAD
08:34:07:WU00:FS01:0x22:   Compiler: Visual C++ 2008
08:34:07:WU00:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:34:07:WU00:FS01:0x22:   Platform: win32 10
08:34:07:WU00:FS01:0x22:       Bits: 64
08:34:07:WU00:FS01:0x22:       Mode: Release
08:34:07:WU00:FS01:0x22:************************************ System ************************************
08:34:07:WU00:FS01:0x22:        CPU: AMD Ryzen 5 2600 Six-Core Processor
08:34:07:WU00:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
08:34:07:WU00:FS01:0x22:       CPUs: 12
08:34:07:WU00:FS01:0x22:     Memory: 31.92GiB
08:34:07:WU00:FS01:0x22:Free Memory: 27.99GiB
08:34:07:WU00:FS01:0x22:    Threads: WINDOWS_THREADS
08:34:07:WU00:FS01:0x22: OS Version: 6.2
08:34:07:WU00:FS01:0x22:Has Battery: false
08:34:07:WU00:FS01:0x22: On Battery: false
08:34:07:WU00:FS01:0x22: UTC Offset: 2
08:34:07:WU00:FS01:0x22:        PID: 9840
08:34:07:WU00:FS01:0x22:        CWD: C:\Users\jeret\AppData\Roaming\FAHClient\work
08:34:07:WU00:FS01:0x22:         OS: Windows 10 Pro
08:34:07:WU00:FS01:0x22:    OS Arch: AMD64
08:34:07:WU00:FS01:0x22:********************************************************************************
08:34:07:WU00:FS01:0x22:Project: 11776 (Run 0, Clone 37789, Gen 1)
08:34:07:WU00:FS01:0x22:Unit: 0x00000001287234c95e793105fde5aafb
08:34:07:WU00:FS01:0x22:Reading tar file core.xml
08:34:07:WU00:FS01:0x22:Reading tar file integrator.xml
08:34:07:WU00:FS01:0x22:Reading tar file state.xml
08:34:08:WU00:FS01:0x22:Reading tar file system.xml
08:34:09:WU00:FS01:0x22:Digital signatures verified
08:34:09:WU00:FS01:0x22:Folding@home GPU Core22 Folding@home Core
08:34:09:WU00:FS01:0x22:Version 0.0.2
08:34:23:WU00:FS01:0x22:Completed 0 out of 1000000 steps (0%)
08:34:23:WU00:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
08:34:24:WU00:FS01:0x22:ERROR:exception: clWaitForEvents
08:34:24:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
08:34:24:WU00:FS01:0x22:Saving result file checkpt.crc
08:34:24:WU00:FS01:0x22:Saving result file science.log
08:34:24:WU00:FS01:0x22:Folding@home Core Shutdown: BAD_WORK_UNIT
08:34:24:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
08:34:24:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:11776 run:0 clone:37789 gen:1 core:0x22 unit:0x00000001287234c95e793105fde5aafb
08:34:24:WU00:FS01:Uploading 10.00KiB to 40.114.52.201
davidcoton
@Kebast -- that log extract does not show whether the last attempt succeeded or not. You could try Pause and then Fold to encourage the upload to retry if it is still stuck.
@Jurtzuu -- something glitched in that WU. It's difficult to know what, whether it was hardware, software, or data. You should just get a new WU, if that runs normally there is no need to take any further action.
Jertzuu
Asus Prime X470-PRO
Post by Jertzuu »
davidcoton wrote:@Jertzuu -- something glitched in that WU. It's difficult to know what, whether it was hardware, software, or data. You should just get a new WU, if that runs normally there is no need to take any further action.
The only problem is the fact that I my system hasn't been able to finish any GPU projects for the last 5 days. My first GPU projects did finish succesfully, but now I get the same BAD_WORK_UNIT and (114 = 0x72) errors all the time. I have tried every solution I could find, like lowering GPU clocks, lowering the power limit, reinstall drivers and change GPU openCL value from -1 to 1. Really running out of ideas and own knowledge here...
*Edit* Reinstalled the client and made sure all previous data was deleted from my PC. So far so good, and seems to be working fine so far
