Screen Flicker with Nvidia GeForce GTX 1080
jonault
Re: Screen Flicker with Nvidia GeForce GTX 1080
Post by jonault »
I used to run dual monitors while folding on a 1070Ti without issue, so your 1080 should be able to handle it. What temperature is your card running at?
Darth_Peter_dualxeon
Hardware configuration: EVGA SR-2 motherboard
2x Xeon x5670 CPU
64 GB ECC DDR3
Nvidia RTX 2070
Post by Darth_Peter_dualxeon »
Lagging of the graphical user interface is normal (slow scrolling in a web browser for example) while GPU is folding. (at least this is what i saw in Linux, on dual monitors)
Flickering of screen is not normal at all.
What operating system? What connection of monitor, and what settings?
