CUDA/OpenCL fail (Not Detected) - Linux Mint / GT730
D0nkey
Post by D0nkey »
Hi all,
I'm trying to get FAH up & running but it's failing to use my GPU, I suspect it's because I don't have the NVidia drivers (they caused massive problems for me) so I'm using the "nouveau" drivers. I think I got CUDA/OpenCL installed OK per the instructions elsewhere on this forum but now I'm stuck - can anyone help?
System is Linux Mint 18 64-Bit, GPU is NVidia GF108 / GeForce GT730 - full diagnostics below.
This is (yet another) of those CUDA: Not detected: cuInit() returned 100 / OpenCL: Not detected: clGetPlatformIDs() returned -1001 problems :(
FAH Info/Config
******************************** Build ********************************
    Version: 7.5.1
       Date: May 11 2018
       Time: 19:59:04
 Repository: Git
   Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
     Branch: master
   Compiler: GNU 6.3.0 20170516
    Options: -std=gnu++98 -O3 -funroll-loops
   Platform: linux2 4.14.0-3-amd64
       Bits: 64
       Mode: Release
******************************* System ********************************
        CPU: Intel(R) Xeon(R) CPU X5660 @ 2.80GHz
     CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
       CPUs: 24
     Memory: 47.16GiB
Free Memory: 35.56GiB
    Threads: POSIX_THREADS
 OS Version: 4.4
Has Battery: false
 On Battery: false
 UTC Offset: 0
        PID: 9594
        CWD: /var/lib/fahclient
         OS: Linux 4.4.0-150-generic x86_64
    OS Arch: AMD64
       GPUs: 1
      GPU 0: Bus:2 Slot:0 Func:0 NVIDIA:2 GF108 [GeForce GT 730]
<config>
  <!-- Client Control -->
  <client-threads v='6'/>
  <cycle-rate v='4'/>
  <cycles v='-1'/>
  <data-directory v='.'/>
  <disable-sleep-when-active v='true'/>
  <exec-directory v='/usr/bin'/>
  <exit-when-done v='false'/>
  <fold-anon v='true'/>
  <idle-seconds v='300'/>
  <open-web-control v='false'/>
  <!-- Configuration -->
  <config-rotate v='true'/>
  <config-rotate-dir v='configs'/>
  <config-rotate-max v='16'/>
  <!-- Debugging -->
  <assignment-servers>
    assign1.foldingathome.org:8080 assign2.foldingathome.org:80
  </assignment-servers>
  <auth-as v='true'/>
  <capture-directory v='capture'/>
  <capture-on-error v='false'/>
  <capture-packets v='false'/>
  <capture-requests v='false'/>
  <capture-responses v='false'/>
  <capture-sockets v='false'/>
  <core-exec v='FahCore_$type'/>
  <core-wrapper-exec v='FAHCoreWrapper'/>
  <debug-sockets v='false'/>
  <exception-locations v='true'/>
  <stack-traces v='false'/>
  <!-- Error Handling -->
  <max-slot-errors v='10'/>
  <max-unit-errors v='5'/>
  <!-- Folding Core -->
  <checkpoint v='15'/>
  <core-dir v='cores'/>
  <core-priority v='idle'/>
  <cpu-affinity v='false'/>
  <cpu-usage v='100'/>
  <gpu-usage v='100'/>
  <no-assembly v='false'/>
  <cause v='ANY'/>
  <client-subtype v='LINUX'/>
  <client-type v='normal'/>
  <cpu-species v='X86_PENTIUM_II'/>
  <cpu-type v='AMD64'/>
  <cpus v='-1'/>
  <disable-viz v='false'/>
  <gpu v='true'/>
  <max-packet-size v='normal'/>
  <os-species v='UNKNOWN'/>
  <os-type v='LINUX'/>
  <project-key v='0'/>
  <smp v='true'/>
  <!-- GUI -->
  <gui-enabled v='true'/>
  <!-- HTTP Server -->
  <allow v='127.0.0.1'/>
  <connection-timeout v='60'/>
  <deny v='0/0'/>
  <http-addresses v='0:7396'/>
  <https-addresses v=''/>
  <max-connect-time v='900'/>
  <max-connections v='800'/>
  <max-request-length v='52428800'/>
  <min-connect-time v='300'/>
  <!-- Logging -->
  <log v='log.txt'/>
  <log-color v='true'/>
  <log-crlf v='false'/>
  <log-date v='false'/>
  <log-date-periodically v='21600'/>
  <log-domain v='false'/>
  <log-header v='true'/>
  <log-level v='true'/>
  <log-no-info-header v='true'/>
  <log-redirect v='false'/>
  <log-rotate v='true'/>
  <log-rotate-dir v='logs'/>
  <log-rotate-max v='16'/>
  <log-short-level v='false'/>
  <log-simple-domains v='true'/>
  <log-thread-id v='false'/>
  <log-thread-prefix v='true'/>
  <log-time v='true'/>
  <log-to-screen v='true'/>
  <log-truncate v='false'/>
  <verbosity v='4'/>
  <!-- Network -->
  <proxy v=':8080'/>
  <proxy-enable v='false'/>
  <proxy-pass v=''/>
  <proxy-user v=''/>
  <!-- Process Control -->
  <child v='true'/>
  <daemon v='true'/>
  <fork v='false'/>
  <pid v='false'/>
  <pid-file v='/var/run/fahclient.pid'/>
  <respawn v='false'/>
  <service v='false'/>
  <!-- Remote Command Server -->
  <command-address v='0.0.0.0'/>
  <command-allow-no-pass v='127.0.0.1'/>
  <command-deny-no-pass v='0/0'/>
  <command-enable v='true'/>
  <command-port v='36330'/>
  <!-- Slot Control -->
  <idle v='false'/>
  <max-shutdown-wait v='60'/>
  <pause-on-battery v='true'/>
  <pause-on-start v='false'/>
  <paused v='false'/>
  <power v='medium'/>
  <!-- User Information -->
  <machine-id v='0'/>
  <passkey v='********************************'/>
  <team v='*****'/>
  <user v='*****'/>
  <!-- Web Server -->
  <web-allow v='127.0.0.1'/>
  <web-deny v='0/0'/>
  <web-enable v='true'/>
  <!-- Web Server Sessions -->
  <session-cookie v='sid'/>
  <session-lifetime v='86400'/>
  <session-timeout v='3600'/>
  <!-- Work Unit Control -->
  <dump-after-deadline v='true'/>
  <max-queue v='16'/>
  <max-units v='0'/>
  <next-unit-percentage v='99'/>
  <stall-detection-enabled v='false'/>
  <stall-percent v='5'/>
  <stall-timeout v='1800'/>
  <!-- Folding Slots -->
  <slot id='0' type='CPU'/>
</config>
LSHW Output for GFX
       *-pci:1
             description: PCI bridge
             product: 5520/5500/X58 I/O Hub PCI Express Root Port 3
             vendor: Intel Corporation
             physical id: 3
             bus info: pci@0000:00:03.0
             version: 13
             width: 32 bits
             clock: 33MHz
             capabilities: pci msi pciexpress pm normal_decode bus_master cap_list
             configuration: driver=pcieport
             resources: irq:16 ioport:d000(size=4096) memory:f6000000-f7efffff ioport:e8000000(size=167772160)
           *-display
                description: VGA compatible controller
                product: GF108 [GeForce GT 730]
                vendor: NVIDIA Corporation
                physical id: 0
                bus info: pci@0000:02:00.0
                version: a1
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
                configuration: driver=nouveau latency=0
                resources: irq:28 memory:f6000000-f6ffffff memory:e8000000-efffffff memory:f0000000-f1ffffff ioport:dc80(size=128) memory:f7e00000-f7e7ffff
           *-multimedia
                description: Audio device
                product: GF108 High Definition Audio Controller
                physical id: 0.1
                bus info: pci@0000:02:00.1
                version: a1
                width: 32 bits
                clock: 33MHz
                capabilities: pm msi pciexpress bus_master cap_list
                configuration: driver=snd_hda_intel latency=0
                resources: irq:30 memory:f7dfc000-f7dfffff
Re: CUDA/OpenCL fail (Not Detected) - Linux Mint / GT730
The F@h software does not work with the nouveau or Mesa drivers, just the proprietary drivers from nVIdia or AMD. Some have followed developments in the open source drives. but while they have improved, they still run into errors with the OpenCL used by the GPU folding core.
stevenevents
Post by stevenevents »
I'm running a GT720, with the proprietary drivers, on Mint 18.3.
OS Arch: AMD64
21:59:17:           GPUs: 1
21:59:17:          GPU 0: Bus:0 Slot:1 Func:0 AMD:5 xxxx [Radeon R7]
21:59:17:  CUDA Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:3.5 Driver:9.0
21:59:17:OpenCL Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:1.2 Driver:384.130
Nvidia-opencl-icd-### is in the repository. I also had to install ocl-icd-opencl-dev, and then reboot.
As a new forum member, I can't post a link to the second package. Search for it, and you'll find it on the official linuxmintcom domain.
