Cycling of Webclient but no processing of WU's
Hyperdoc
Post by Hyperdoc »
Hello,
I suspect this may be due to the WU lack of numbers but the web client keeps cycling through trying to access 127.0.0.1 and the offline client does not start.
Log:
*********************** Log Started 2020-03-24T01:20:29Z ***********************
01:20:29:************************* Folding@home Client *************************
01:20:29:    Website: https://foldingathome.org/
01:20:29:  Copyright: (c) 2009-2018 foldingathome.org
01:20:29:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:20:29:       Args:
01:20:29:     Config: /Library/Application Support/FAHClient/config.xml
01:20:29:******************************** Build ********************************
01:20:29:    Version: 7.5.1
01:20:29:       Date: May 11 2018
01:20:29:       Time: 12:57:01
01:20:29: Repository: Git
01:20:29:   Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
01:20:29:     Branch: master
01:20:29:   Compiler: GNU 4.2.1 Compatible Apple LLVM 7.3.0 (clang-703.0.31)
01:20:29:    Options: -std=gnu++98 -O3 -funroll-loops -mmacosx-version-min=10.6
01:20:29:             -Wno-unused-local-typedefs
01:20:29:   Platform: darwin 15.6.0
01:20:29:       Bits: 64
01:20:29:       Mode: Release
01:20:29:******************************* System ********************************
01:20:29:        CPU: Intel(R) Core(TM) i9-8950HK CPU @ 2.90GHz
01:20:29:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
01:20:29:       CPUs: 12
01:20:29:     Memory: 32.00GiB
01:20:29:Free Memory: 29.79GiB
01:20:29:    Threads: POSIX_THREADS
01:20:29: OS Version: 10.14
01:20:29:Has Battery: true
01:20:29: On Battery: false
01:20:29: UTC Offset: 11
01:20:29:        PID: 66
01:20:29:        CWD: /Library/Application Support/FAHClient
01:20:29:         OS: Darwin 18.7.0 x86_64
01:20:29:    OS Arch: AMD64
01:20:29:       GPUs: 0
01:20:29:       CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
01:20:29:             dlopen(libcuda.dylib, 1): image not found
01:20:29:     OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
01:20:29:             dlopen(libOpenCL.dylib, 1): image not found
01:20:29:***********************************************************************
01:20:29:<config>
01:20:29:  <!-- Network -->
01:20:29:  <proxy v=':8080'/>
01:20:29:
01:20:29:  <!-- Slot Control -->
01:20:29:  <power v='FULL'/>
01:20:29:
01:20:29:  <!-- User Information -->
01:20:29:  <passkey v='********************************'/>
01:20:29:  <team v='223518'/>
01:20:29:  <user v='Hawkeye'/>
01:20:29:
01:20:29:  <!-- Folding Slots -->
01:20:29:  <slot id='0' type='CPU'>
01:20:29:    <idle v='true'/>
01:20:29:  </slot>
01:20:29:</config>
01:20:29:Trying to access database...
01:20:29:Successfully acquired database lock
01:20:29:Enabled folding slot 00: PAUSED cpu:12 (waiting for idle)
01:20:29:ERROR:Failed to register for display power changes
Some odd ERRORs but wanted to check that it is a WU availability issue and not a fault in the software or hardware.
Cheers Hyperdoc.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Re: Cycling of Webclient but no processing of WU's
Post by Jesse_V »
Hi Hyperdoc and welcome to the forum!
It looks like the folding is waiting for your Mac to be idle. Can you access web control or the FAHControl tool at all?
Hyperdoc
Post by Hyperdoc »
Yes I can access the FAHcontrol but the web control keeps trying to cycle to 127.0.0.1 and I can’t stop it to stop the idle state to start things. Also it is on for several hours and doesn’t go into idle mode.
Cheers Hyperdoc
ajm
Post by ajm »
There is something in Chrome and chromium browsers that prevents Web control from functioning properly, since a recent Chrome update. Firefox is not affected.
FAQ covers the Web Control issue and has some workarounds - viewtopic.php?f=24&t=32463
