Hi Folks,
The GPU is churning away doing computations for the cause. But the CPUs have not done anything, what's up with that?
Thanks
Bart
						Why One But Not The Other?
				Jesse_V
 CPU: i7-6700k
 GPU: GTX 970, GTX 1080 TI
 RAM: 24 GB DDR4
Re: Why One But Not The Other?
There's been a 20x increase in F@h userbase and workunits are being consumed faster than they can be generated, which has led to the queue sometimes being empty.  I'd recommend keeping everything running and the CPU should pick up work when its available. The research labs are rapidly trying to get new projects online and more servers into place to keep up with demand, so hopefully the situation can be fixed pretty soon.
Also my cpu is a 6 core 12 thread verity. Will all of the threads be use separately or in combination for just one workunit?
Thanks
Bart
						Thanks
Bart
				Tuna_Ertemalp
- Hardware configuration: OS:Win10
 GPUs: EVGA
 CPU (cores), RAM, (GPU Core OC, Mem OC): GPU(s), Motherboard:
 * AMD Ryzen 5 3600 (6C), 32G DDR4-2400, (+0,+0): 3090 FTW3 ULTRA, Gigabyte AB350M-D3H-CF
 * Intel Core i7 5960X (8C), 32G DDR4-2400, (+0,+0): 3090 XC3 ULTRA HYBRID, ASUS X99-M WS
 * Intel Core i7 5960X (8C), 32G DDR4-2400, (+100,+200): 2x 3090 FTW3 ULTRA, ASUS X99-E WS/USB 3.1
 * Intel Core i7 970 (6C), 24G DDR3-1333, (+0,+0): 2x 3080 FTW3 ULTRA HYBRID, ASUS RAMPAGE III GENE
 * Intel Core i7 5960X (8C), 16G DDR4-2400, (+100,+0): 1080 Ti FTW3 + HYBRID KIT, ASRock X99 OC Formula/3.1
 * AMD Ryzen 7 2700X (8C), 16G DDR4-2666, (+100,+200): 3090 FTW3 ULTRA HYBRID, ASRock B450M Pro4
 * AMD Ryzen TR 1950X (16C), 32G DDR4-2133, (+100,+200): 3x 3090 XC3 ULTRA HYBRID, ASRock X399 Taichi
 * Intel Core i7 5960X (8C), 64G DDR4-2133, (+100,+0): 1080 Ti FTW3 + HYBRID KIT, 2x 1080 Ti SC2 HYBRID, MSI X99A XPOWER AC
I'm also a new user, so don't know the exact technically correct answer to your question, but all threads on all my CPUs (some up to 32) are being used at 95-100% capacity, so I don't wonder "why" or on "what" exactly they are used. As long as they are used at capacity, it is a moot point if they are churning on one WU or N WUs.
Tuna
							Tuna
Small things make quality, but quality is no small thing. (Adapted from Henry Royce talking about perfection, not quality)
8 Win10 PCs/22 slots: 8x CPUs (3xAMD+5xIntel=68C/122T), 14x NVIDIA EVGA GPUs (8x 3090, 2x 3080, 4x 1080Ti) [Details in my profile]
				Jesse_V
 CPU: i7-6700k
 RAM: 24 GB DDR4
A single workunit can use the entire CPU or part of it. The exact number of cores/threads used is set by the software and can be configured in the "Advanced Control" tool called FAHControl.BartJY wrote:Also my cpu is a 6 core 12 thread verity. Will all of the threads be use separately or in combination for just one workunit?
Thanks
Bart
A workunit, a piece of the molecular simulation under study, can be divided across many different CPU cores and processed all at once that way. So a 32-core CPU can get the workunit done 32 times faster than a 1-core CPU. As a reward for this speed, there's a non-linear point system, so your PPD (points/day) is pretty huge for running a single workunit on 32 cores instead of 32 different workunits in parallel.Tuna_Ertemalp wrote:I'm also a new user, so don't know the exact technically correct answer to your question, but all threads on all my CPUs (some up to 32) are being used at 95-100% capacity, so I don't wonder "why" or on "what" exactly they are used. As long as they are used at capacity, it is a moot point if they are churning on one WU or N WUs.
Tuna
