how can i configure power slider?
mandus
Post by mandus »
hello,
my setup is
CPU: 12 threads
GPU1
GPU2
i want to configure the slider so that it works like this,
Low:
CPU: 4 threads
GPU1: disabled/idle
GPU2: working
Medium:
CPU: 8 threads
GPU1: disabled / idle
GPU2: working
Full:
CPU: 10 threads
GPU1: working
GPU2: working
is such configuration possible?
thanks
Re: how can i configure power slider?
You can't change how each position of the slider configure the client.
If you want to personalize your settings and have full control of what you're doing, set slider to full and use Advanced Control (FAHControl) to manually set up slots (Confgure > Slots).
