Need help with utilizing more resources.
Alienhead
Post by Alienhead »
I am new. I have one GPU running and one that looks to have been assigned but no work being done. My CPU is sitting "Ready" as well. I want this machine to be fully utilized. Do I just need to wait for the work to come or do I need to change a setting?
Here is my log file.
Am I seeing some network issues in there?
*********************** Log Started 2020-03-23T18:30:09Z ***********************
18:30:09:************************* Folding@home Client *************************
18:30:09:        Website: https://foldingathome.org/
18:30:09:      Copyright: (c) 2009-2018 foldingathome.org
18:30:09:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:30:09:           Args: --open-web-control
18:30:09:         Config: <none>
18:30:09:******************************** Build ********************************
18:30:09:        Version: 7.5.1
18:30:09:           Date: May 11 2018
18:30:09:           Time: 13:06:32
18:30:09:     Repository: Git
18:30:09:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
18:30:09:         Branch: master
18:30:09:       Compiler: Visual C++ 2008
18:30:09:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:30:09:       Platform: win32 10
18:30:09:           Bits: 32
18:30:09:           Mode: Release
18:30:09:******************************* System ********************************
18:30:09:            CPU: Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz
18:30:09:         CPU ID: GenuineIntel Family 6 Model 79 Stepping 1
18:30:09:           CPUs: 20
18:30:09:         Memory: 63.84GiB
18:30:09:    Free Memory: 58.77GiB
18:30:09:        Threads: WINDOWS_THREADS
18:30:09:     OS Version: 6.2
18:30:09:    Has Battery: false
18:30:09:     On Battery: false
18:30:09:     UTC Offset: -6
18:30:09:            PID: 9944
18:30:09:            CWD: C:\Users\James\AppData\Roaming\FAHClient
18:30:09:             OS: Windows 10 Enterprise
18:30:09:        OS Arch: AMD64
18:30:09:           GPUs: 0
18:30:09:  CUDA Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:6.1 Driver:10.2
18:30:09:  CUDA Device 1: Platform:0 Device:1 Bus:3 Slot:0 Compute:6.1 Driver:10.2
18:30:09:OpenCL Device 0: Platform:0 Device:0 Bus:2 Slot:0 Compute:1.2 Driver:442.74
18:30:09:OpenCL Device 1: Platform:0 Device:1 Bus:3 Slot:0 Compute:1.2 Driver:442.74
18:30:09:  Win32 Service: false
18:30:09:***********************************************************************
18:30:09:<config>
18:30:09:  <!-- Folding Slots -->
18:30:09:</config>
18:30:09:Connecting to assign1.foldingathome.org:8080
18:30:10:Updated GPUs.txt
18:30:10:Read GPUs.txt
18:30:10:Trying to access database...
18:30:10:Successfully acquired database lock
18:30:10:Enabled folding slot 00: PAUSED cpu:17 (not configured)
18:30:10:Enabled folding slot 01: PAUSED gpu:0:GP102 [TITAN X] 6144 (not configured)
18:30:10:Enabled folding slot 02: PAUSED gpu:1:GP102 [TITAN X] 6144 (not configured)
18:30:13:8:127.0.0.1:New Web connection
18:30:51:Set client configured
18:30:52:WU00:FS00:Connecting to 65.254.110.245:8080
18:30:52:WU01:FS01:Connecting to 65.254.110.245:8080
18:30:52:WU02:FS02:Connecting to 65.254.110.245:8080
18:30:52:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:30:52:WU00:FS00:Connecting to 18.218.241.186:80
18:30:52:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:30:52:WU01:FS01:Connecting to 18.218.241.186:80
18:30:52:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:30:52:WU02:FS02:Connecting to 18.218.241.186:80
18:30:53:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:30:53:ERROR:WU01:FS01:Exception: Could not get an assignment
18:30:53:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:30:53:ERROR:WU00:FS00:Exception: Could not get an assignment
18:30:53:WU01:FS01:Connecting to 65.254.110.245:8080
18:30:53:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:30:53:ERROR:WU02:FS02:Exception: Could not get an assignment
18:30:53:WU00:FS00:Connecting to 65.254.110.245:8080
18:30:53:WU02:FS02:Connecting to 65.254.110.245:8080
18:30:53:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:30:53:WU01:FS01:Connecting to 18.218.241.186:80
18:30:53:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:30:53:WU00:FS00:Connecting to 18.218.241.186:80
18:30:53:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:30:53:WU02:FS02:Connecting to 18.218.241.186:80
18:30:54:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:30:54:ERROR:WU00:FS00:Exception: Could not get an assignment
18:30:54:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:30:54:ERROR:WU02:FS02:Exception: Could not get an assignment
18:31:11:Saving configuration to config.xml
18:31:11:<config>
18:31:11:  <!-- User Information -->
18:31:11:  <team v='1'/>
18:31:11:  <user v='alienhead'/>
18:31:11:
18:31:11:  <!-- Folding Slots -->
18:31:11:  <slot id='0' type='CPU'/>
18:31:11:  <slot id='1' type='GPU'/>
18:31:11:  <slot id='2' type='GPU'/>
18:31:11:</config>
18:31:53:WU01:FS01:Connecting to 65.254.110.245:8080
18:31:53:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:31:53:WU01:FS01:Connecting to 18.218.241.186:80
18:31:53:WU00:FS00:Connecting to 65.254.110.245:8080
18:31:53:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:31:53:ERROR:WU01:FS01:Exception: Could not get an assignment
18:31:53:WU02:FS02:Connecting to 65.254.110.245:8080
18:31:53:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:31:53:WU00:FS00:Connecting to 18.218.241.186:80
18:31:53:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:31:53:WU02:FS02:Connecting to 18.218.241.186:80
18:31:53:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:31:53:ERROR:WU00:FS00:Exception: Could not get an assignment
18:31:54:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:31:54:ERROR:WU02:FS02:Exception: Could not get an assignment
18:33:30:WU01:FS01:Connecting to 65.254.110.245:8080
18:33:30:WU01:FS01:Assigned to work server 13.90.152.57
18:33:30:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP102 [TITAN X] 6144 from 13.90.152.57
18:33:30:WU01:FS01:Connecting to 13.90.152.57:8080
18:33:30:WU00:FS00:Connecting to 65.254.110.245:8080
18:33:30:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:33:30:WU00:FS00:Connecting to 18.218.241.186:80
18:33:31:WU02:FS02:Connecting to 65.254.110.245:8080
18:33:31:WU00:FS00:Assigned to work server 40.114.52.201
18:33:31:WU00:FS00:Requesting new work unit for slot 00: READY cpu:17 from 40.114.52.201
18:33:31:WU00:FS00:Connecting to 40.114.52.201:8080
18:33:31:WU02:FS02:Assigned to work server 40.114.52.201
18:33:31:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:GP102 [TITAN X] 6144 from 40.114.52.201
18:33:31:WU02:FS02:Connecting to 40.114.52.201:8080
18:33:52:WARNING:WU02:FS02:WorkServer connection failed on port 8080 trying 80
18:33:52:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
18:33:52:WU02:FS02:Connecting to 40.114.52.201:80
18:33:52:WU00:FS00:Connecting to 40.114.52.201:80
18:34:08:WU01:FS01:Downloading 51.19MiB
18:34:13:ERROR:WU02:FS02:Exception: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:34:13:ERROR:WU00:FS00:Exception: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:34:14:WU01:FS01:Download 33.33%
18:34:20:WU01:FS01:Download 75.33%
18:34:24:WU01:FS01:Download complete
18:34:24:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11780 run:0 clone:6917 gen:11 core:0x22 unit:0x0000000e0d5a98395e75893d6154a303
18:34:24:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
18:34:24:WU01:FS01:Connecting to cores.foldingathome.org:80
18:34:24:WU01:FS01:FahCore 22: Downloading 4.04MiB
18:34:28:WU01:FS01:FahCore 22: Download complete
18:34:29:WU01:FS01:Valid core signature
18:34:29:WU01:FS01:Unpacked 13.49MiB to cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe
18:34:29:WU01:FS01:Starting
18:34:29:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\James\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 9944 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device 1 -gpu 1
18:34:29:WU01:FS01:Started FahCore on PID 15596
18:34:33:WU01:FS01:Core PID:13512
18:34:33:WU01:FS01:FahCore 0x22 started
18:34:34:WU01:FS01:0x22:*********************** Log Started 2020-03-23T18:34:33Z ***********************
18:34:34:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:34:34:WU01:FS01:0x22:       Type: 0x22
18:34:34:WU01:FS01:0x22:       Core: Core22
18:34:34:WU01:FS01:0x22:    Website: https://foldingathome.org/
18:34:34:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
18:34:34:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
18:34:34:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
18:34:34:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 15596 -checkpoint 15
18:34:34:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 1 -cuda-device
18:34:34:WU01:FS01:0x22:             1 -gpu 1
18:34:34:WU01:FS01:0x22:     Config: <none>
18:34:34:WU01:FS01:0x22:************************************ Build *************************************
18:34:34:WU01:FS01:0x22:    Version: 0.0.2
18:34:34:WU01:FS01:0x22:       Date: Dec 6 2019
18:34:34:WU01:FS01:0x22:       Time: 21:30:31
18:34:34:WU01:FS01:0x22: Repository: Git
18:34:34:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
18:34:34:WU01:FS01:0x22:     Branch: HEAD
18:34:34:WU01:FS01:0x22:   Compiler: Visual C++ 2008
18:34:34:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:34:34:WU01:FS01:0x22:   Platform: win32 10
18:34:34:WU01:FS01:0x22:       Bits: 64
18:34:34:WU01:FS01:0x22:       Mode: Release
18:34:34:WU01:FS01:0x22:************************************ System ************************************
18:34:34:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz
18:34:34:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 79 Stepping 1
18:34:34:WU01:FS01:0x22:       CPUs: 20
18:34:34:WU01:FS01:0x22:     Memory: 63.84GiB
18:34:34:WU01:FS01:0x22:Free Memory: 58.39GiB
18:34:34:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
18:34:34:WU01:FS01:0x22: OS Version: 6.2
18:34:34:WU01:FS01:0x22:Has Battery: false
18:34:34:WU01:FS01:0x22: On Battery: false
18:34:34:WU01:FS01:0x22: UTC Offset: -6
18:34:34:WU01:FS01:0x22:        PID: 13512
18:34:34:WU01:FS01:0x22:        CWD: C:\Users\James\AppData\Roaming\FAHClient\work
18:34:34:WU01:FS01:0x22:         OS: Windows 10 Pro
18:34:34:WU01:FS01:0x22:    OS Arch: AMD64
18:34:34:WU01:FS01:0x22:********************************************************************************
18:34:34:WU01:FS01:0x22:Project: 11780 (Run 0, Clone 6917, Gen 11)
18:34:34:WU01:FS01:0x22:Unit: 0x0000000e0d5a98395e75893d6154a303
18:34:34:WU01:FS01:0x22:Reading tar file core.xml
18:34:34:WU01:FS01:0x22:Reading tar file integrator.xml
18:34:34:WU01:FS01:0x22:Reading tar file state.xml
18:34:34:WU01:FS01:0x22:Reading tar file system.xml
18:34:34:WU01:FS01:0x22:Digital signatures verified
18:34:34:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:34:34:WU01:FS01:0x22:Version 0.0.2
18:34:51:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
18:34:51:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:35:38:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
18:35:57:WU00:FS00:Connecting to 65.254.110.245:8080
18:35:58:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:35:58:WU00:FS00:Connecting to 18.218.241.186:80
18:35:58:WU02:FS02:Connecting to 65.254.110.245:8080
18:35:58:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:35:58:ERROR:WU00:FS00:Exception: Could not get an assignment
18:35:58:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:35:58:WU02:FS02:Connecting to 18.218.241.186:80
18:35:58:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:35:58:ERROR:WU02:FS02:Exception: Could not get an assignment
18:36:16:Saving configuration to config.xml
18:36:16:<config>
18:36:16:  <!-- Slot Control -->
18:36:16:  <power v='FULL'/>
18:36:16:
18:36:16:  <!-- User Information -->
18:36:16:  <team v='1'/>
18:36:16:  <user v='alienhead'/>
18:36:16:
18:36:16:  <!-- Folding Slots -->
18:36:16:  <slot id='0' type='CPU'/>
18:36:16:  <slot id='1' type='GPU'/>
18:36:16:  <slot id='2' type='GPU'/>
18:36:16:</config>
18:36:27:WU01:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
18:37:19:WU01:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
18:37:34:WU00:FS00:Connecting to 65.254.110.245:8080
18:37:35:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:37:35:WU00:FS00:Connecting to 18.218.241.186:80
18:37:35:WU02:FS02:Connecting to 65.254.110.245:8080
18:37:35:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:37:35:ERROR:WU00:FS00:Exception: Could not get an assignment
18:37:35:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:37:35:WU02:FS02:Connecting to 18.218.241.186:80
18:37:35:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:37:35:ERROR:WU02:FS02:Exception: Could not get an assignment
18:38:10:WU01:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
18:39:03:WU01:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
18:39:59:WU01:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
18:40:12:WU00:FS00:Connecting to 65.254.110.245:8080
18:40:12:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:40:12:WU00:FS00:Connecting to 18.218.241.186:80
18:40:12:WU02:FS02:Connecting to 65.254.110.245:8080
18:40:12:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:40:12:ERROR:WU00:FS00:Exception: Could not get an assignment
18:40:12:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:40:12:WU02:FS02:Connecting to 18.218.241.186:80
18:40:13:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:40:13:ERROR:WU02:FS02:Exception: Could not get an assignment
18:40:52:WU01:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
18:41:46:WU01:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
18:42:40:WU01:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
18:43:34:WU01:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
18:44:26:WU00:FS00:Connecting to 65.254.110.245:8080
18:44:26:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:44:26:WU00:FS00:Connecting to 18.218.241.186:80
18:44:26:WU02:FS02:Connecting to 65.254.110.245:8080
18:44:26:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:44:26:ERROR:WU00:FS00:Exception: Could not get an assignment
18:44:27:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:44:27:WU02:FS02:Connecting to 18.218.241.186:80
18:44:27:WU02:FS02:Assigned to work server 40.114.52.201
18:44:27:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:GP102 [TITAN X] 6144 from 40.114.52.201
18:44:27:WU02:FS02:Connecting to 40.114.52.201:8080
18:44:30:WU01:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
18:44:49:ERROR:WU02:FS02:Exception: 10002: Received short response, expected 512 bytes, got 0
18:45:24:WU01:FS01:0x22:Completed 120000 out of 1000000 steps (12%)
18:46:17:WU01:FS01:0x22:Completed 130000 out of 1000000 steps (13%)
18:47:11:WU01:FS01:0x22:Completed 140000 out of 1000000 steps (14%)
18:48:05:WU01:FS01:0x22:Completed 150000 out of 1000000 steps (15%)
18:49:01:WU01:FS01:0x22:Completed 160000 out of 1000000 steps (16%)
18:49:55:WU01:FS01:0x22:Completed 170000 out of 1000000 steps (17%)
18:50:49:WU01:FS01:0x22:Completed 180000 out of 1000000 steps (18%)
18:51:17:WU00:FS00:Connecting to 65.254.110.245:8080
18:51:17:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:51:17:WU00:FS00:Connecting to 18.218.241.186:80
18:51:18:WU02:FS02:Connecting to 65.254.110.245:8080
18:51:18:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:51:18:ERROR:WU00:FS00:Exception: Could not get an assignment
18:51:18:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:51:18:WU02:FS02:Connecting to 18.218.241.186:80
18:51:18:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:51:18:ERROR:WU02:FS02:Exception: Could not get an assignment
18:51:43:WU01:FS01:0x22:Completed 190000 out of 1000000 steps (19%)
18:52:36:WU01:FS01:0x22:Completed 200000 out of 1000000 steps (20%)
18:53:32:WU01:FS01:0x22:Completed 210000 out of 1000000 steps (21%)
18:54:26:WU01:FS01:0x22:Completed 220000 out of 1000000 steps (22%)
18:55:20:WU01:FS01:0x22:Completed 230000 out of 1000000 steps (23%)
18:55:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:55:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:56:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:56:14:WU01:FS01:0x22:Completed 240000 out of 1000000 steps (24%)
18:56:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:56:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:56:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:57:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:57:08:WU01:FS01:0x22:Completed 250000 out of 1000000 steps (25%)
18:57:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:57:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:57:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:58:05:WU01:FS01:0x22:Completed 260000 out of 1000000 steps (26%)
18:58:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:58:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:58:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:58:58:WU01:FS01:0x22:Completed 270000 out of 1000000 steps (27%)
18:59:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:59:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:59:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:59:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:59:52:WU01:FS01:0x22:Completed 280000 out of 1000000 steps (28%)
19:00:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:00:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:00:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:00:46:WU01:FS01:0x22:Completed 290000 out of 1000000 steps (29%)
19:00:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:01:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:01:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:01:39:WU01:FS01:0x22:Completed 300000 out of 1000000 steps (30%)
19:01:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:01:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
19:02:23:WU00:FS00:Connecting to 65.254.110.245:8080
19:02:23:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:02:23:WU00:FS00:Connecting to 18.218.241.186:80
19:02:23:WU02:FS02:Connecting to 65.254.110.245:8080
19:02:23:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:02:23:ERROR:WU00:FS00:Exception: Could not get an assignment
19:02:23:WARNING:WU02:FS02:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:02:23:WU02:FS02:Connecting to 18.218.241.186:80
19:02:24:WARNING:WU02:FS02:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:02:24:ERROR:WU02:FS02:Exception: Could not get an assignment
19:02:36:WU01:FS01:0x22:Completed 310000 out of 1000000 steps (31%)
19:03:31:WU01:FS01:0x22:Completed 320000 out of 1000000 steps (32%)
19:04:25:WU01:FS01:0x22:Completed 330000 out of 1000000 steps (33%)
19:05:19:WU01:FS01:0x22:Completed 340000 out of 1000000 steps (34%)
19:06:13:WU01:FS01:0x22:Completed 350000 out of 1000000 steps (35%)
19:07:10:WU01:FS01:0x22:Completed 360000 out of 1000000 steps (36%)
19:08:04:WU01:FS01:0x22:Completed 370000 out of 1000000 steps (37%)
19:08:58:WU01:FS01:0x22:Completed 380000 out of 1000000 steps (38%)
19:09:52:WU01:FS01:0x22:Completed 390000 out of 1000000 steps (39%)
19:10:45:WU01:FS01:0x22:Completed 400000 out of 1000000 steps (40%)
19:11:42:WU01:FS01:0x22:Completed 410000 out of 1000000 steps (41%)
19:12:37:WU01:FS01:0x22:Completed 420000 out of 1000000 steps (42%)
19:13:31:WU01:FS01:0x22:Completed 430000 out of 1000000 steps (43%)
19:14:25:WU01:FS01:0x22:Completed 440000 out of 1000000 steps (44%)
Re: Need help with utilizing more resources.
(not configured) bothers me. Reboot and look to see if it changes.
The FAHClient program needs permission to operate like a browser, downloading files from the internet.
our servers have been ovwhelmed by the number of folks who want to help. We're frantically adding servers and working on saturation problems but the number of folks want to help keeps growing faster than we can grow our resources. Thus a properly configure machine may not be able to get work promptly.
Alienhead
Post by Alienhead »
Looks like the reset fixed the Not Configured issue.
After restart it started a WU on the processor. The other are ready.
WOW you set that thing on FULL POWER and my GPU went strait up to 80c. I took the side panel off for better cooling. Its what I get for using a two slot SLI on blower style GPUs. But at that speed it cuts through the WU's
