unable to start folding due to no WS assignment
yash_attal
Post by yash_attal »
Cannot start folding
*********************** Log Started 2020-03-23T16:43:36Z ***********************
16:43:36:************************* Folding@home Client *************************
16:43:36:        Website: https://foldingathome.org/
16:43:36:      Copyright: (c) 2009-2018 foldingathome.org
16:43:36:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:43:36:           Args: --open-web-control
16:43:36:         Config: <none>
16:43:36:******************************** Build ********************************
16:43:36:        Version: 7.5.1
16:43:36:           Date: May 11 2018
16:43:36:           Time: 13:06:32
16:43:36:     Repository: Git
16:43:36:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
16:43:36:         Branch: master
16:43:36:       Compiler: Visual C++ 2008
16:43:36:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:43:36:       Platform: win32 10
16:43:36:           Bits: 32
16:43:36:           Mode: Release
16:43:36:******************************* System ********************************
16:43:36:            CPU: Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz
16:43:36:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
16:43:36:           CPUs: 8
16:43:36:         Memory: 7.86GiB
16:43:36:    Free Memory: 2.52GiB
16:43:36:        Threads: WINDOWS_THREADS
16:43:36:     OS Version: 6.2
16:43:36:    Has Battery: true
16:43:36:     On Battery: true
16:43:36:     UTC Offset: 5
16:43:36:            PID: 5624
16:43:36:            CWD: C:\Users\Yash\AppData\Roaming\FAHClient
16:43:36:             OS: Windows 10 Home
16:43:36:        OS Arch: AMD64
16:43:36:           GPUs: 0
16:43:36:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.1
16:43:36:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:26.20
16:43:36:OpenCL Device 2: Platform:1 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:431.70
16:43:36:  Win32 Service: false
16:43:36:***********************************************************************
16:43:36:<config>
16:43:36:  <!-- Folding Slots -->
16:43:36:</config>
16:43:36:Connecting to assign1.foldingathome.org:8080
16:43:44:Updated GPUs.txt
16:43:44:Read GPUs.txt
16:43:44:Trying to access database...
16:43:44:Successfully acquired database lock
16:43:44:Enabled folding slot 00: PAUSED cpu:3 (not configured)
16:43:44:Enabled folding slot 01: PAUSED gpu:0:GP107M [GeForce GTX 1050 Mobile] (not configured)
16:44:03:8:127.0.0.1:New Web connection
16:44:19:Set client configured
16:44:45:Saving configuration to config.xml
16:44:45:<config>
16:44:45:  <!-- Slot Control -->
16:44:45:  <power v='FULL'/>
16:44:45:
16:44:45:  <!-- Folding Slots -->
16:44:45:  <slot id='0' type='CPU'/>
16:44:45:  <slot id='1' type='GPU'/>
16:44:45:</config>
16:49:50:Saving configuration to config.xml
16:49:50:<config>
16:49:50:  <!-- Slot Control -->
16:49:50:  <power v='FULL'/>
16:49:50:
16:49:50:  <!-- User Information -->
16:49:50:  <passkey v='********************************'/>
16:49:50:  <user v='yash_attal'/>
16:49:50:
16:49:50:  <!-- Folding Slots -->
16:49:50:  <slot id='0' type='CPU'/>
16:49:50:  <slot id='1' type='GPU'/>
16:49:50:</config>
16:50:40:WU00:FS00:Connecting to 65.254.110.245:8080
16:50:40:WU01:FS01:Connecting to 65.254.110.245:8080
16:50:41:WU01:FS01:Connecting to 65.254.110.245:8080
16:50:41:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:50:41:WU00:FS00:Connecting to 18.218.241.186:80
16:50:41:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:50:41:WU01:FS01:Connecting to 18.218.241.186:80
16:50:42:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:50:42:ERROR:WU00:FS00:Exception: Could not get an assignment
16:50:42:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:50:42:ERROR:WU01:FS01:Exception: Could not get an assignment
16:50:43:WU00:FS00:Connecting to 65.254.110.245:8080
16:50:43:WU01:FS01:Connecting to 65.254.110.245:8080
16:50:43:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:50:43:WU01:FS01:Connecting to 18.218.241.186:80
16:50:43:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:50:43:WU00:FS00:Connecting to 18.218.241.186:80
16:50:44:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:50:44:ERROR:WU01:FS01:Exception: Could not get an assignment
16:50:45:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:50:45:ERROR:WU00:FS00:Exception: Could not get an assignment
16:51:27:FS00:Paused
16:51:27:FS01:Paused
16:51:29:FS00:Unpaused
16:51:29:FS01:Unpaused
16:51:43:WU00:FS00:Connecting to 65.254.110.245:8080
16:51:43:WU01:FS01:Connecting to 65.254.110.245:8080
16:51:44:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:51:44:WU00:FS00:Connecting to 18.218.241.186:80
16:51:44:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:51:44:WU01:FS01:Connecting to 18.218.241.186:80
16:51:45:WU01:FS01:Assigned to work server 40.114.52.201
16:51:45:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Mobile] from 40.114.52.201
16:51:45:WU00:FS00:Assigned to work server 155.247.164.213
16:51:45:WU01:FS01:Connecting to 40.114.52.201:8080
16:51:45:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 155.247.164.213
16:51:45:WU00:FS00:Connecting to 155.247.164.213:8080
16:51:46:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
16:52:00:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
16:53:04:WU00:FS00:Connecting to 65.254.110.245:8080
16:53:04:WU01:FS01:Connecting to 65.254.110.245:8080
16:53:04:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:53:04:WU00:FS00:Connecting to 18.218.241.186:80
16:53:04:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:53:04:WU01:FS01:Connecting to 18.218.241.186:80
16:53:05:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:53:05:ERROR:WU00:FS00:Exception: Could not get an assignment
16:53:06:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:53:06:ERROR:WU01:FS01:Exception: Could not get an assignment
16:54:41:WU00:FS00:Connecting to 65.254.110.245:8080
16:54:41:WU01:FS01:Connecting to 65.254.110.245:8080
16:54:42:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:54:42:WU00:FS00:Connecting to 18.218.241.186:80
16:54:42:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:54:42:WU01:FS01:Connecting to 18.218.241.186:80
16:54:43:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:54:43:ERROR:WU00:FS00:Exception: Could not get an assignment
16:54:43:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:54:43:ERROR:WU01:FS01:Exception: Could not get an assignment
16:57:18:WU00:FS00:Connecting to 65.254.110.245:8080
16:57:18:WU01:FS01:Connecting to 65.254.110.245:8080
16:57:19:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:57:19:WU00:FS00:Connecting to 18.218.241.186:80
16:57:19:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:57:19:WU01:FS01:Connecting to 18.218.241.186:80
16:57:20:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:57:20:ERROR:WU00:FS00:Exception: Could not get an assignment
16:57:20:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:57:20:ERROR:WU01:FS01:Exception: Could not get an assignment
17:01:32:WU00:FS00:Connecting to 65.254.110.245:8080
17:01:33:WU01:FS01:Connecting to 65.254.110.245:8080
17:01:33:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:01:33:WU00:FS00:Connecting to 18.218.241.186:80
17:01:33:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:01:33:WU01:FS01:Connecting to 18.218.241.186:80
17:01:34:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:01:34:ERROR:WU00:FS00:Exception: Could not get an assignment
17:01:34:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:01:34:ERROR:WU01:FS01:Exception: Could not get an assignment
17:02:24:FS00:Finishing
17:02:24:FS01:Finishing
17:02:36:FS00:Paused
17:02:36:FS01:Paused
17:02:42:FS00:Unpaused
17:02:42:FS01:Unpaused
17:02:42:WU00:FS00:Connecting to 65.254.110.245:8080
17:02:42:WU01:FS01:Connecting to 65.254.110.245:8080
17:02:43:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:02:43:WU00:FS00:Connecting to 18.218.241.186:80
17:02:43:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:02:43:WU01:FS01:Connecting to 18.218.241.186:80
17:02:44:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:02:44:ERROR:WU00:FS00:Exception: Could not get an assignment
17:02:44:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:02:44:ERROR:WU01:FS01:Exception: Could not get an assignment
17:02:47:FS00:Finishing
17:02:47:FS01:Finishing
17:04:19:WU00:FS00:Connecting to 65.254.110.245:8080
17:04:19:WU01:FS01:Connecting to 65.254.110.245:8080
17:04:20:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:04:20:WU00:FS00:Connecting to 18.218.241.186:80
17:04:20:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:04:20:WU01:FS01:Connecting to 18.218.241.186:80
17:04:21:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:04:21:ERROR:WU00:FS00:Exception: Could not get an assignment
17:04:21:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:04:21:ERROR:WU01:FS01:Exception: Could not get an assignment
17:06:56:WU00:FS00:Connecting to 65.254.110.245:8080
17:06:57:WU01:FS01:Connecting to 65.254.110.245:8080
17:06:57:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:06:57:WU00:FS00:Connecting to 18.218.241.186:80
17:06:57:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:06:57:WU01:FS01:Connecting to 18.218.241.186:80
17:06:58:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:06:58:ERROR:WU00:FS00:Exception: Could not get an assignment
17:06:58:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:06:58:ERROR:WU01:FS01:Exception: Could not get an assignment
17:07:07:Saving configuration to config.xml
17:07:07:<config>
17:07:07:  <!-- Slot Control -->
17:07:07:  <power v='FULL'/>
17:07:07:
17:07:07:  <!-- User Information -->
17:07:07:  <passkey v='********************************'/>
17:07:07:  <team v='224497'/>
17:07:07:  <user v='yash_attal'/>
17:07:07:
17:07:07:  <!-- Folding Slots -->
17:07:07:  <slot id='0' type='CPU'/>
17:07:07:  <slot id='1' type='GPU'/>
17:07:07:</config>
17:07:33:FS00:Paused
17:07:33:FS01:Paused
17:07:36:FS00:Unpaused
17:07:36:FS01:Unpaused
17:07:57:WU00:FS00:Connecting to 65.254.110.245:8080
17:07:57:WU01:FS01:Connecting to 65.254.110.245:8080
17:07:58:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:07:58:WU00:FS00:Connecting to 18.218.241.186:80
17:07:58:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:07:58:WU01:FS01:Connecting to 18.218.241.186:80
17:07:59:WU00:FS00:Assigned to work server 40.114.52.201
17:07:59:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 40.114.52.201
17:07:59:WU00:FS00:Connecting to 40.114.52.201:8080
17:07:59:WU01:FS01:Assigned to work server 40.114.52.201
17:07:59:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Mobile] from 40.114.52.201
17:07:59:WU01:FS01:Connecting to 40.114.52.201:8080
17:08:14:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
17:08:14:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
17:08:58:WU00:FS00:Connecting to 65.254.110.245:8080
17:08:58:WU01:FS01:Connecting to 65.254.110.245:8080
17:08:59:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:08:59:WU00:FS00:Connecting to 18.218.241.186:80
17:08:59:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:08:59:WU01:FS01:Connecting to 18.218.241.186:80
17:09:00:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:09:00:ERROR:WU00:FS00:Exception: Could not get an assignment
17:09:00:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:09:00:ERROR:WU01:FS01:Exception: Could not get an assignment
17:09:46:FS00:Paused
17:09:46:FS01:Paused
17:10:10:Saving configuration to config.xml
17:10:10:<config>
17:10:10:  <!-- Slot Control -->
17:10:10:  <power v='FULL'/>
17:10:10:
17:10:10:  <!-- User Information -->
17:10:10:  <passkey v='********************************'/>
17:10:10:  <team v='224497'/>
17:10:10:  <user v='yash_attal'/>
17:10:10:
17:10:10:  <!-- Folding Slots -->
17:10:10:  <slot id='0' type='CPU'>
17:10:10:    <paused v='true'/>
17:10:10:  </slot>
17:10:10:  <slot id='1' type='GPU'>
17:10:10:  </slot>
17:10:10:</config>
17:10:57:FS00:Unpaused
17:10:57:FS01:Unpaused
17:10:57:WU00:FS00:Connecting to 65.254.110.245:8080
17:10:57:WU01:FS01:Connecting to 65.254.110.245:8080
17:10:58:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:10:58:WU00:FS00:Connecting to 18.218.241.186:80
17:10:58:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:10:58:WU01:FS01:Connecting to 18.218.241.186:80
17:10:59:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:10:59:ERROR:WU00:FS00:Exception: Could not get an assignment
17:10:59:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:10:59:ERROR:WU01:FS01:Exception: Could not get an assignment
17:11:11:Saving configuration to config.xml
17:11:11:<config>
17:11:11:  <!-- Slot Control -->
17:11:11:  <power v='FULL'/>
17:11:11:
17:11:11:  <!-- User Information -->
17:11:11:  <passkey v='********************************'/>
17:11:11:  <team v='224497'/>
17:11:11:  <user v='yash_attal'/>
17:11:11:
17:11:11:  <!-- Folding Slots -->
17:11:11:  <slot id='0' type='CPU'/>
17:11:11:  <slot id='1' type='GPU'/>
17:11:11:</config>
17:12:34:WU00:FS00:Connecting to 65.254.110.245:8080
17:12:35:WU01:FS01:Connecting to 65.254.110.245:8080
17:12:35:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:12:35:WU00:FS00:Connecting to 18.218.241.186:80
17:12:35:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:12:35:WU01:FS01:Connecting to 18.218.241.186:80
17:12:36:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:12:36:ERROR:WU00:FS00:Exception: Could not get an assignment
17:12:36:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:12:36:ERROR:WU01:FS01:Exception: Could not get an assignment
17:12:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:13:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:13:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:13:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:13:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:14:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:14:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:14:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:14:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:15:12:WU00:FS00:Connecting to 65.254.110.245:8080
17:15:12:WU01:FS01:Connecting to 65.254.110.245:8080
17:15:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:15:12:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:15:12:WU00:FS00:Connecting to 18.218.241.186:80
17:15:12:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:15:12:WU01:FS01:Connecting to 18.218.241.186:80
17:15:13:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:15:13:ERROR:WU00:FS00:Exception: Could not get an assignment
17:15:13:WU01:FS01:Assigned to work server 40.114.52.201
17:15:13:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Mobile] from 40.114.52.201
17:15:13:WU01:FS01:Connecting to 40.114.52.201:8080
17:15:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:15:28:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
17:15:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:16:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:16:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:16:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:16:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:17:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:17:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:17:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:17:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:18:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:18:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:18:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:18:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:19:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:19:26:WU00:FS00:Connecting to 65.254.110.245:8080
17:19:26:WU01:FS01:Connecting to 65.254.110.245:8080
17:19:27:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:19:27:WU00:FS00:Connecting to 18.218.241.186:80
17:19:27:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:19:27:WU01:FS01:Connecting to 18.218.241.186:80
17:19:27:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:19:27:ERROR:WU00:FS00:Exception: Could not get an assignment
17:19:28:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:19:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:19:28:ERROR:WU01:FS01:Exception: Could not get an assignment
17:19:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:20:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:20:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:20:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:20:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:21:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:21:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:21:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:21:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:22:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:22:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:22:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:22:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:23:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:23:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
Re: unable to start folding due to no WS assignment
Post by muziqaz »
Yes, we just had another wave of massive amounts of new folders join, and servers are freaking out. 10x more requests for work.
Please be patient, F@H team is trying their best to expand server abilities and capacity :)
Thank you for your contribution
FAH Omega tester
