Bob049
Posts: 3 Joined: Mon Mar 23, 2020 4:28 pm
Post
by Bob049 » Mon Mar 23, 2020 4:56 pm
Hi
I'm receiving the above message when starting the Fah client. The body of the error is "The procedure entry point fatBinaryCtl could not be located in the dynamic link library C:\Windows\SysWOW64\qcopencl.dll.
This seems to cause the client to halt, and means that if it occurs when the client is running unattended (I think it is generated when a new WU starts). When I clear the message the client seems to run ok until the error is generated again.
The time lapse between new web connection and checkpoint file found is from starting the client to me clearing the error.
Any help would be appreciated
Kind regards
Robin
*********************** Log Started 2020-03-23T16:50:50Z ***********************
16:50:50:************************* Folding@home Client *************************
16:50:50: Website: https://foldingathome.org/
16:50:50: Copyright: (c) 2009-2018 foldingathome.org
16:50:50: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:50:50: Args: --open-web-control
16:50:50: Config: C:\Users\Robin\AppData\Roaming\FAHClient\config.xml
16:50:50:******************************** Build ********************************
16:50:50: Version: 7.5.1
16:50:50: Date: May 11 2018
16:50:50: Time: 13:06:32
16:50:50: Repository: Git
16:50:50: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
16:50:50: Branch: master
16:50:50: Compiler: Visual C++ 2008
16:50:50: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:50:50: Platform: win32 10
16:50:50: Bits: 32
16:50:50: Mode: Release
16:50:50:******************************* System ********************************
16:50:50: CPU: Intel(R) Core(TM) i9-7940X CPU @ 3.10GHz
16:50:50: CPU ID: GenuineIntel Family 6 Model 85 Stepping 4
16:50:50: CPUs: 28
16:50:50: Memory: 63.68GiB
16:50:50: Free Memory: 55.61GiB
16:50:50: Threads: WINDOWS_THREADS
16:50:50: OS Version: 6.2
16:50:50: Has Battery: false
16:50:50: On Battery: false
16:50:50: UTC Offset: 0
16:50:50: PID: 15224
16:50:50: CWD: C:\Users\Robin\AppData\Roaming\FAHClient
16:50:50: OS: Windows 10 Enterprise
16:50:50: OS Arch: AMD64
16:50:50: GPUs: 1
16:50:50: GPU 0: Bus:23 Slot:0 Func:0 NVIDIA:8 TU102 [GeForce RTX 2080 Ti Rev.
16:50:50: A] M 13448
16:50:50: CUDA Device 0: Platform:0 Device:0 Bus:23 Slot:0 Compute:7.5 Driver:10.2
16:50:50:OpenCL Device 0: Platform:0 Device:0 Bus:23 Slot:0 Compute:1.2 Driver:442.74
16:50:50: Win32 Service: false
16:50:50:***********************************************************************
16:50:51:<config>
16:50:51: <!-- Folding Core -->
16:50:51: <checkpoint v='3'/>
16:50:51:
16:50:51: <!-- Network -->
16:50:51: <proxy v=':8080'/>
16:50:51:
16:50:51: <!-- Slot Control -->
16:50:51: <pause-on-battery v='false'/>
16:50:51: <power v='full'/>
16:50:51:
16:50:51: <!-- User Information -->
16:50:51: <passkey v='********************************'/>
16:50:51: <user v='Spood'/>
16:50:51:
16:50:51: <!-- Folding Slots -->
16:50:51: <slot id='0' type='GPU'/>
16:50:51:</config>
16:50:51:Trying to access database...
16:50:51:Successfully acquired database lock
16:50:51:Enabled folding slot 00: READY gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448
16:50:51:WU00:FS00:Starting
16:50:51:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Robin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 00 -suffix 01 -version 705 -lifeline 15224 -checkpoint 3 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
16:50:51:WU00:FS00:Started FahCore on PID 23200
16:50:51:WU00:FS00:Core PID:23596
16:50:51:WU00:FS00:FahCore 0x22 started
16:50:52:WU00:FS00:0x22:*********************** Log Started 2020-03-23T16:50:52Z ***********************
16:50:52:WU00:FS00:0x22:*************************** Core22 Folding@home Core ***************************
16:50:52:WU00:FS00:0x22: Type: 0x22
16:50:52:WU00:FS00:0x22: Core: Core22
16:50:52:WU00:FS00:0x22: Website: https://foldingathome.org/
16:50:52:WU00:FS00:0x22: Copyright: (c) 2009-2018 foldingathome.org
16:50:52:WU00:FS00:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
16:50:52:WU00:FS00:0x22: <rafal.wiewiora@choderalab.org>
16:50:52:WU00:FS00:0x22: Args: -dir 00 -suffix 01 -version 705 -lifeline 23200 -checkpoint 3
16:50:52:WU00:FS00:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
16:50:52:WU00:FS00:0x22: 0 -gpu 0
16:50:52:WU00:FS00:0x22: Config: <none>
16:50:52:WU00:FS00:0x22:************************************ Build *************************************
16:50:52:WU00:FS00:0x22: Version: 0.0.2
16:50:52:WU00:FS00:0x22: Date: Dec 6 2019
16:50:53:WU00:FS00:0x22: Time: 21:30:31
16:50:53:WU00:FS00:0x22: Repository: Git
16:50:53:WU00:FS00:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
16:50:53:WU00:FS00:0x22: Branch: HEAD
16:50:53:WU00:FS00:0x22: Compiler: Visual C++ 2008
16:50:53:WU00:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:50:53:WU00:FS00:0x22: Platform: win32 10
16:50:53:WU00:FS00:0x22: Bits: 64
16:50:53:WU00:FS00:0x22: Mode: Release
16:50:53:WU00:FS00:0x22:************************************ System ************************************
16:50:53:WU00:FS00:0x22: CPU: Intel(R) Core(TM) i9-7940X CPU @ 3.10GHz
16:50:53:WU00:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 85 Stepping 4
16:50:53:WU00:FS00:0x22: CPUs: 28
16:50:53:WU00:FS00:0x22: Memory: 63.68GiB
16:50:53:WU00:FS00:0x22:Free Memory: 55.59GiB
16:50:53:WU00:FS00:0x22: Threads: WINDOWS_THREADS
16:50:53:WU00:FS00:0x22: OS Version: 6.2
16:50:53:WU00:FS00:0x22:Has Battery: false
16:50:53:WU00:FS00:0x22: On Battery: false
16:50:53:WU00:FS00:0x22: UTC Offset: 0
16:50:53:WU00:FS00:0x22: PID: 23596
16:50:53:WU00:FS00:0x22: CWD: C:\Users\Robin\AppData\Roaming\FAHClient\work
16:50:53:WU00:FS00:0x22: OS: Windows 10 Pro
16:50:53:WU00:FS00:0x22: OS Arch: AMD64
16:50:53:WU00:FS00:0x22:********************************************************************************
16:50:53:WU00:FS00:0x22:Project: 11759 (Run 0, Clone 5406, Gen 16)
16:50:53:WU00:FS00:0x22:Unit: 0x0000001b80fccb0a5e6e8676abb39303
16:50:53:WU00:FS00:0x22:Digital signatures verified
16:50:53:WU00:FS00:0x22:Folding@home GPU Core22 Folding@home Core
16:50:53:WU00:FS00:0x22:Version 0.0.2
16:50:55:16:127.0.0.1:New Web connection
16:54:08:WU00:FS00:0x22: Found a checkpoint file
16:54:21:WU00:FS00:0x22:Completed 50000 out of 1000000 steps (5%)
16:54:21:WU00:FS00:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
Posts: 8185 Joined: Tue Apr 21, 2009 4:41 pm
Hardware configuration: Mac Studio M1 Max 32 GB smp6 Mac Hack i7-7700K 48 GB smp4
Post
by Joe_H » Mon Mar 23, 2020 9:25 pm
There are couple of other reports of this error message, a cause has not yet been identified. Thank you for the report, perhaps together they can help find the reason for the error so it can be fixed.
Bob049
Post
by Bob049 » Tue Mar 24, 2020 8:07 am
Sorry, I didn't finish a sentence in my OP. .....and means that if it occurs when the client is running unattended that the client doesn't start a job. I'm not sure if the error has any other impact.
Post
by Joe_H » Tue Mar 24, 2020 3:08 pm
Does the client attempt to download new work, or just stop after finishing? In the first case if the client does not get work right away, that would probably be connected with the servers getting more requests than they can currently fulfill. For the second could you post a log section that shows this?
Bob049
Post
by Bob049 » Tue Mar 24, 2020 6:11 pm
The client downloads new work, but when the folding starts and the error message is popped it stops. You can see this in the log extract below.
In summary
15:19:52 A work unit is completed
15:20:30 A new download is started
15:22:14 The WU is started (error message pops, but not registered in log)
16:08:30 I realise the error has popped and clear it. The folding actually starts
Robin
15:18:53:ERROR:WU01:FS00:Exception: Could not get an assignment
15:19:18:WU00:FS00:Upload 0.94%
15:19:24:WU00:FS00:Upload 16.48%
15:19:30:WU00:FS00:Upload 38.21%
15:19:36:WU00:FS00:Upload 56.75%
15:19:42:WU00:FS00:Upload 74.17%
15:19:48:WU00:FS00:Upload 89.16%
15:19:52:WU00:FS00:Upload complete
15:19:52:WU00:FS00:Server responded WORK_ACK (400)
15:19:52:WU00:FS00:Final credit estimate, 77269.00 points
15:19:52:WU00:FS00:Cleaning up
15:20:29:WU01:FS00:Connecting to 65.254.110.245:8080
15:20:30:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:20:30:WU01:FS00:Connecting to 18.218.241.186:80
15:20:30:WU01:FS00:Assigned to work server 140.163.4.231
15:20:30:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 from 140.163.4.231
15:20:30:WU01:FS00:Connecting to 140.163.4.231:8080
15:21:51:WU01:FS00:Downloading 4.52MiB
15:21:57:WU01:FS00:Download 5.54%
15:22:04:WU01:FS00:Download 26.30%
15:22:09:WU01:FS00:Download complete
15:22:09:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11749 run:0 clone:4512 gen:9 core:0x22 unit:0x000000158ca304e75e6a80151550a678
15:22:09:WU01:FS00:Starting
15:22:09:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Robin\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 15812 -checkpoint 3 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
15:22:09:WU01:FS00:Started FahCore on PID 13256
15:22:10:WU01:FS00:Core PID:15680
15:22:10:WU01:FS00:FahCore 0x22 started
15:22:10:WU01:FS00:0x22:*********************** Log Started 2020-03-24T15:22:10Z ***********************
15:22:10:WU01:FS00:0x22:*************************** Core22 Folding@home Core ***************************
15:22:10:WU01:FS00:0x22: Type: 0x22
15:22:10:WU01:FS00:0x22: Core: Core22
15:22:10:WU01:FS00:0x22: Website: https://foldingathome.org/
15:22:10:WU01:FS00:0x22: Copyright: (c) 2009-2018 foldingathome.org
15:22:10:WU01:FS00:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
15:22:10:WU01:FS00:0x22: <rafal.wiewiora@choderalab.org>
15:22:10:WU01:FS00:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 13256 -checkpoint 3
15:22:10:WU01:FS00:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
15:22:10:WU01:FS00:0x22: 0 -gpu 0
15:22:10:WU01:FS00:0x22: Config: <none>
15:22:10:WU01:FS00:0x22:************************************ Build *************************************
15:22:10:WU01:FS00:0x22: Version: 0.0.2
15:22:10:WU01:FS00:0x22: Date: Dec 6 2019
15:22:10:WU01:FS00:0x22: Time: 21:30:31
15:22:10:WU01:FS00:0x22: Repository: Git
15:22:10:WU01:FS00:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
15:22:10:WU01:FS00:0x22: Branch: HEAD
15:22:10:WU01:FS00:0x22: Compiler: Visual C++ 2008
15:22:10:WU01:FS00:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
15:22:10:WU01:FS00:0x22: Platform: win32 10
15:22:10:WU01:FS00:0x22: Bits: 64
15:22:10:WU01:FS00:0x22: Mode: Release
15:22:10:WU01:FS00:0x22:************************************ System ************************************
15:22:11:WU01:FS00:0x22: CPU: Intel(R) Core(TM) i9-7940X CPU @ 3.10GHz
15:22:11:WU01:FS00:0x22: CPU ID: GenuineIntel Family 6 Model 85 Stepping 4
15:22:11:WU01:FS00:0x22: CPUs: 28
15:22:11:WU01:FS00:0x22: Memory: 63.68GiB
15:22:11:WU01:FS00:0x22:Free Memory: 54.06GiB
15:22:11:WU01:FS00:0x22: Threads: WINDOWS_THREADS
15:22:11:WU01:FS00:0x22: OS Version: 6.2
15:22:11:WU01:FS00:0x22:Has Battery: false
15:22:11:WU01:FS00:0x22: On Battery: false
15:22:11:WU01:FS00:0x22: UTC Offset: 0
15:22:11:WU01:FS00:0x22: PID: 15680
15:22:11:WU01:FS00:0x22: CWD: C:\Users\Robin\AppData\Roaming\FAHClient\work
15:22:11:WU01:FS00:0x22: OS: Windows 10 Pro
15:22:11:WU01:FS00:0x22: OS Arch: AMD64
15:22:11:WU01:FS00:0x22:********************************************************************************
15:22:11:WU01:FS00:0x22:Project: 11749 (Run 0, Clone 4512, Gen 9)
15:22:11:WU01:FS00:0x22:Unit: 0x000000158ca304e75e6a80151550a678
15:22:11:WU01:FS00:0x22:Reading tar file core.xml
15:22:11:WU01:FS00:0x22:Reading tar file integrator.xml
15:22:11:WU01:FS00:0x22:Reading tar file state.xml
15:22:12:WU01:FS00:0x22:Reading tar file system.xml
15:22:14:WU01:FS00:0x22:Digital signatures verified
15:22:14:WU01:FS00:0x22:Folding@home GPU Core22 Folding@home Core
15:22:14:WU01:FS00:0x22:Version 0.0.2
16:08:30:WU01:FS00:0x22:Completed 0 out of 2000000 steps (0%)
16:08:30:WU01:FS00:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:09:08:WU01:FS00:0x22:Completed 20000 out of 2000000 steps (1%)
16:09:51:WU01:FS00:0x22:Completed 40000 out of 2000000 steps (2%)
Posts: 20822 Joined: Thu Nov 29, 2007 10:13 pm
Post
by bruce » Tue Mar 24, 2020 6:30 pm
I have not seen many reports associated with fatBinaryCtl . There's some discussion about it on nvidia.com so my guess it's associated with their OpenCL/CUDA drivers. I don't have any definitive information yet.
VagyokC4
Posts: 1 Joined: Thu May 21, 2020 6:41 pm
Post
by VagyokC4 » Thu May 21, 2020 6:43 pm
FahCore_22.exe - Entry Point Not Found
The procedure entry point fatBinaryCtl could not be located in the dynamic link library C:\WINDOWS\System32\nvopencl.dll.
OK
Is there a fix for this?
Post
by bruce » Fri May 22, 2020 3:51 am
The only fix that we know about is to run OpenCL 1.2. We've only seen this error on hardware and drivers that support OpenCL 1.1.
Are you able to run some projects an not ohers or do they all fail?
