Project: 14329 (Run 0, Clone 4470, Gen 17)
jankal
Post by jankal »
Error happening at the 88% mark.
Excerpt from my log:
*********************** Log Started 2020-03-23T14:32:35Z ***********************
14:32:35:************************* Folding@home Client *************************
14:32:35:        Website: https://foldingathome.org/
14:32:35:      Copyright: (c) 2009-2018 foldingathome.org
14:32:35:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:32:35:           Args: --open-web-control
14:32:35:         Config: C:\Users\alexa\AppData\Roaming\FAHClient\config.xml
14:32:35:******************************** Build ********************************
14:32:35:        Version: 7.5.1
14:32:35:           Date: May 11 2018
14:32:35:           Time: 13:06:32
14:32:35:     Repository: Git
14:32:35:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
14:32:35:         Branch: master
14:32:35:       Compiler: Visual C++ 2008
14:32:35:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:32:35:       Platform: win32 10
14:32:35:           Bits: 32
14:32:35:           Mode: Release
14:32:35:******************************* System ********************************
14:32:35:            CPU: Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz
14:32:35:         CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
14:32:35:           CPUs: 8
14:32:35:         Memory: 15.86GiB
14:32:35:    Free Memory: 3.95GiB
14:32:35:        Threads: WINDOWS_THREADS
14:32:35:     OS Version: 6.2
14:32:35:    Has Battery: true
14:32:35:     On Battery: true
14:32:35:     UTC Offset: 1
14:32:35:            PID: 27020
14:32:35:            CWD: C:\Users\alexa\AppData\Roaming\FAHClient
14:32:35:             OS: Windows 10 Enterprise
14:32:35:        OS Arch: AMD64
14:32:35:           GPUs: 0
14:32:35:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': Das
14:32:35:                 angegebene Modul wurde nicht gefunden.
14:32:35:
14:32:35:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:25.20
14:32:35:  Win32 Service: false
14:32:35:***********************************************************************
14:32:35:<config>
14:32:35:  <!-- Folding Slot Configuration -->
14:32:35:  <client-type v='advanced'/>
14:32:35:
14:32:35:  <!-- Network -->
14:32:35:  <proxy v=':8080'/>
14:32:35:
14:32:35:  <!-- Slot Control -->
14:32:35:  <pause-on-battery v='false'/>
14:32:35:  <power v='FULL'/>
14:32:35:
14:32:35:  <!-- User Information -->
14:32:35:  <passkey v='********************************'/>
14:32:35:  <team v='247327'/>
14:32:35:  <user v='jankal'/>
14:32:35:
14:32:35:  <!-- Work Unit Control -->
14:32:35:  <next-unit-percentage v='95'/>
14:32:35:
14:32:35:  <!-- Folding Slots -->
14:32:35:  <slot id='0' type='CPU'/>
14:32:35:</config>
14:32:35:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\alexa\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 27020 -checkpoint 15 -np 8
14:32:35:WU00:FS00:Started FahCore on PID 41884
14:32:35:WU00:FS00:Core PID:41308
14:32:35:WU00:FS00:FahCore 0xa7 started
14:32:36:WU00:FS00:0xa7:*********************** Log Started 2020-03-23T14:32:35Z ***********************
14:32:36:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
14:32:36:WU00:FS00:0xa7:       Type: 0xa7
14:32:36:WU00:FS00:0xa7:       Core: Gromacs
14:32:36:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 41884 -checkpoint 15 -np
14:32:36:WU00:FS00:0xa7:             8
14:32:36:WU00:FS00:0xa7:************************************ CBang *************************************
14:32:36:WU00:FS00:0xa7:       Date: Oct 26 2019
14:32:36:WU00:FS00:0xa7:       Time: 01:38:25
14:32:36:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
14:32:36:WU00:FS00:0xa7:     Branch: master
14:32:36:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
14:32:36:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
14:32:36:WU00:FS00:0xa7:   Platform: win32 10
14:32:36:WU00:FS00:0xa7:       Bits: 64
14:32:36:WU00:FS00:0xa7:       Mode: Release
14:32:36:WU00:FS00:0xa7:************************************ System ************************************
14:32:36:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz
14:32:36:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 142 Stepping 10
14:32:36:WU00:FS00:0xa7:       CPUs: 8
14:32:36:WU00:FS00:0xa7:     Memory: 15.86GiB
14:32:36:WU00:FS00:0xa7:Free Memory: 3.94GiB
14:32:36:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
14:32:36:WU00:FS00:0xa7: OS Version: 6.2
14:32:36:WU00:FS00:0xa7:Has Battery: true
14:32:36:WU00:FS00:0xa7: On Battery: true
14:32:36:WU00:FS00:0xa7: UTC Offset: 1
14:32:36:WU00:FS00:0xa7:        PID: 41308
14:32:36:WU00:FS00:0xa7:        CWD: C:\Users\alexa\AppData\Roaming\FAHClient\work
14:32:36:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
14:32:36:WU00:FS00:0xa7:    Version: 0.0.18
14:32:36:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:32:36:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
14:32:36:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
14:32:36:WU00:FS00:0xa7:       Time: 01:52:30
14:32:36:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
14:32:36:WU00:FS00:0xa7:************************************ Build *************************************
14:32:36:WU00:FS00:0xa7:       SIMD: avx_256
14:32:36:WU00:FS00:0xa7:********************************************************************************
14:32:36:WU00:FS00:0xa7:Project: 14329 (Run 0, Clone 4470, Gen 17)
14:32:36:WU00:FS00:0xa7:Unit: 0x000000159bf7a4d65e6c6ac81e63071d
14:32:36:WU00:FS00:0xa7:Digital signatures verified
14:32:36:WU00:FS00:0xa7:Calling: mdrun -s frame17.tpr -o frame17.trr -cpi state.cpt -cpt 15 -nt 8
14:32:36:WU00:FS00:0xa7:Steps: first=4250000 total=250000
16:27:27:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
16:27:30:WU00:FS00:0xa7:ERROR:
16:27:30:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
16:27:30:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
16:27:30:WU00:FS00:0xa7:ERROR:Source code file: C:\build\fah\core-a7-avx-release\windows-10-64bit-core-a7-avx-release\gromacs-core\build\gromacs\src\gromacs\mdlib\pme.c, line: 754
16:27:30:WU00:FS00:0xa7:ERROR:Fatal error:
16:27:30:WU00:FS00:0xa7:ERROR:4 particles communicated to PME rank 6 are more than 2/3 times the cut-off out of the domain decomposition cell of their charge group in dimension x.
16:27:30:WU00:FS00:0xa7:ERROR:This usually means that your system is not well equilibrated.
16:27:30:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
16:27:30:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
Re: Project: 14329 (Run 0, Clone 4470, Gen 17)
It looks like you ended up turning that WU in successfully. Did it restart at a prior checkpoint after the error?
Hi jankal (team 247327), Your WU (P14329 R0 C4470 G17) was added to the stats database on Invalid Date for 1954.8 points of credit.
jankal
Post by jankal »
Yes, it restarted at 80 % when I already submitted the report (only closed Windows error prompt after turning in the error because I was worried to lose any logs).
