Low performance using CUDA on 1070ti
SNK
Post by SNK »
Hi guys.
I started folding recently and have ~100k PPD on my Geforce1070 Ti which seems to me really low (comparing to /viewtopic.php?f=38&t=31426)
I am unsure whether it is Nvidia driver problems but it seems that my GPU is detected properly see log:
******************************* System ********************************
            CPU: Intel(R) Core(TM) i5-7640X CPU @ 4.00GHz
         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
           CPUs: 4
         Memory: 15.91GiB
    Free Memory: 9.03GiB
        Threads: WINDOWS_THREADS
     OS Version: 6.2
    Has Battery: false
     On Battery: false
     UTC Offset: 1
            PID: 5584
            CWD: C:\Users\FH\AppData\Roaming\FAHClient
             OS: Windows 10 Enterprise
        OS Arch: AMD64
           GPUs: 1
          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1070 Ti] 8186
  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.74
  Win32 Service: false
Enabled folding slot 01: READY gpu:0:GP104 [GeForce GTX 1070 Ti] 8186
WU01:FS01:Starting
WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\S\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 5584 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
It seems that there is ~44% usage in Windows task manager.
My GPU is plugged in PCIe x8 3.0 could that be issue for such low score?
Adding CUDA-Z report of performance as
CUDA-Z Report
Performance Information
Memory Copy
	Host Pinned to Device: 6065.73 MiB/s
	Host Pageable to Device: 4429.99 MiB/s
	Device to Host Pinned: 6181.77 MiB/s
	Device to Host Pageable: 4578.14 MiB/s
	Device to Device: 96.2367 GiB/s
GPU Core Performance
	Single-precision Float: 8960.42 Gflop/s
	Double-precision Float: 283.274 Gflop/s
	64-bit Integer: 451.001 Giop/s
	32-bit Integer: 2691.89 Giop/s
	24-bit Integer: 2222.44 Giop/s
Re: Low performance using CUDA on 1070ti
Using Task Manager you need to change one of the performance windows under GPU to see the F@h utilization. Click on the down arrow and change the type to CUDA or if that is not an available option, one of the Compute options. You might need to try more than one of the Compute 0,1,2 options. The utilization should be in the 90+% range.
As for the PPD you are seeing, do you have a passkey set in the client? That will make a big difference as the bonus points are based on how quick a WU is returned. Your 1070ti is much faster than a 1050 for example.
To see GPU utilization I prefer GPU-Z's sensor screen
jonault
Post by jonault »
My 1070Ti, when it's folding, gets around 700K PPD with the QRB. That's in a x8 PCIe 3.0 slot, so that isn't an issue.
SNK
Post by SNK »
Thanks for answers.
New suggested resource monitor methods seems fine (Utilization is ~98% in GPU-Z)
I didn't know that passkey can have such big impact. I don't have passkey as I didn't receive it when I asked for it (I tried several times and also different e-mail addresses)
EDIT:
I just found on forum that currently you have problems with high load on PassKeys retrieval. That makes sense. Will wait and try again later.
SNK
Post by SNK »
Just to let you know I now get ~850k PPD with QRB after registration. So it seems that was the issue. Thanks.
