The Unwavering Quefile -help a noob, please
Lithe_Joint_f@h
Post by Lithe_Joint_f@h »
Hi,
I have 2 WUs complete, but the F@H app (version 5.03 for XP/Vista) fails to upload the results to wherever they should be uploaded...I have tried many times, and with different settings (even going so far as to remove and re-install the app.). No improvement is to be found. The problem is prevalent on both machines :oops:
Current setups are:
Laptop with Centrino Duo CPU, 512MB ram and 80Gig Hdd, dial-up GPRS connection via mobile phone. Win XP os
PC with Core2Quad, 2Gig Ram, 320Gig HDD, 8800GT Gfx card, same dial-up connection. Vista Ultimate 32-bit os
I would appreciate some advice, as this is very frustrating :x
Thanking you in anticipation,
LJ
ps: here is a copy of the quefile on the laptop:
01 DONE "Folding@Home" (78) 171.64.122.136:8080 June 3 18:54->June 7 22:57:09
02 DONE "Folding@Home" (82) 171.65.103.160:80 June 8 05:16->June 11 05:09:41
Re: The Unwavering Quefile -help a noob, please
Please post the FAHlog.txt file here.
Make sure USE IE and the Proxy checkbox are not checked. And let's see your fahlog.
ChelseaOilman
Post by ChelseaOilman »
Without knowing the PRCG of the WUs in question I can't investigate them.
However, in searching for your stats I see another issue that you maybe should be concerned about. You chose to use a user name with a special character in it, the @ sign.
From the client download page:
You can choose any name you like, as long as it contains only letters or numbers (to insert a space, you can use the underscore "_" character). If you choose your email address as your username, we will NOT print your full email address. Instead, just the part before the @ sign will be used in any stats listing, etc.
Hi Lithe_Joint_f (team 128409),
Your WU (P2606 R28 C6 G84) was added to the stats database on 2008-06-08 06:20:41 for 292 points of credit.
Your WU (P2170 R9 C491 G3) was added to the stats database on 2008-06-16 06:11:37 for 234 points of credit.
Notice the user name on your team stats page: http://fah-web.stanford.edu/cgi-bin/mai ... num=128409
When you click on your user name on that page, your individual stats are zero.
Lithe_Joint_f@h
Thank you for the advice. I will attempt the procedure of removing the @ and whatever follows, and revert. Meanwhile here is the Fahlog text file as requested:
--- Opening Log file [June 12 04:40:08]
# Windows Graphical Edition ###################################################
                       Folding@Home Client Version 5.03
                          http://folding.stanford.edu
Launch directory: C:\Program Files\Folding@Home
[04:40:08] - Ask before connecting: Yes
[04:40:08] - Use IE connection settings: Yes
[04:40:08] - User name: Lithe_Joint_f@h (Team 128409)
[04:40:08] - User ID: 6815B00355288775
[04:40:08] - Machine ID: 1
[04:40:08]
[04:40:08] Loaded queue successfully.
[04:40:08] Initialization complete
[04:40:08] + Benchmarking ...
[04:40:12] - Preparing to get new work unit...
[04:40:12] - Presenting message box asking to network.
[04:40:12] + Attempting to send results
[04:40:13] - Presenting message box asking to network.
[04:42:02] + Attempting to get work packet
[04:42:02] - Connecting to assignment server
[04:42:10] Error: Got status code 407 from server
[04:42:10] + Could not connect to Assignment Server
[04:43:09] Couldn't send HTTP request to server (wininet)
[04:43:09] + Could not connect to Work Server (results)
[04:43:09]     (171.64.122.136:8080)
[04:43:09] - Error: Could not transmit unit 01 (completed June 7) to work server.
[04:43:09] + Attempting to send results
[04:43:10] Couldn't send HTTP request to server (wininet)
[04:43:10] + Could not connect to Assignment Server 2
[04:43:10] + Couldn't get work instructions.
[04:43:10] - Error: Attempt #1  to get work failed, and no other work to do.
             Waiting before retry.
[04:43:21] + Attempting to get work packet
[04:43:21] - Connecting to assignment server
[04:44:09] Couldn't send HTTP request to server (wininet)
[04:44:09] + Could not connect to Work Server (results)
[04:44:09]     (171.64.122.76:8080)
[04:44:09]   Could not transmit unit 01 to Collection server; keeping in queue.
[04:44:09] + Attempting to send results
[04:44:21] Couldn't send HTTP request to server (wininet)
[04:44:21] + Could not connect to Assignment Server
[04:45:09] Couldn't send HTTP request to server (wininet)
[04:45:09] + Could not connect to Work Server (results)
[04:45:09]     (171.65.103.160:80)
[04:45:09] - Error: Could not transmit unit 02 (completed June 11) to work server.
[04:45:09] + Attempting to send results
[04:45:21] Couldn't send HTTP request to server (wininet)
[04:45:21] + Could not connect to Assignment Server 2
[04:45:21] + Couldn't get work instructions.
[04:45:21] - Error: Attempt #2  to get work failed, and no other work to do.
[04:45:35] + Attempting to get work packet
[04:45:35] - Connecting to assignment server
[04:46:09] Couldn't send HTTP request to server (wininet)
[04:46:09] + Could not connect to Work Server (results)
[04:46:09]     (171.64.122.76:80)
[04:46:09]   Could not transmit unit 02 to Collection server; keeping in queue.
[04:46:35] Couldn't send HTTP request to server (wininet)
[04:46:35] + Could not connect to Assignment Server
[04:47:35] Couldn't send HTTP request to server (wininet)
[04:47:35] + Could not connect to Assignment Server 2
[04:47:35] + Couldn't get work instructions.
[04:47:35] - Error: Attempt #3  to get work failed, and no other work to do.
[04:48:07] + Attempting to get work packet
[04:48:07] - Connecting to assignment server
[04:49:07] Couldn't send HTTP request to server (wininet)
[04:49:07] + Could not connect to Assignment Server
[04:50:07] Couldn't send HTTP request to server (wininet)
[04:50:07] + Could not connect to Assignment Server 2
[04:50:07] + Couldn't get work instructions.
[04:50:07] - Error: Attempt #4  to get work failed, and no other work to do.
[04:50:59] + Attempting to get work packet
[04:50:59] - Connecting to assignment server
[04:51:59] Couldn't send HTTP request to server (wininet)
[04:51:59] + Could not connect to Assignment Server
[04:52:59] Couldn't send HTTP request to server (wininet)
[04:52:59] + Could not connect to Assignment Server 2
[04:52:59] + Couldn't get work instructions.
[04:52:59] - Error: Attempt #5  to get work failed, and no other work to do.
[04:54:23] + Attempting to get work packet
[04:54:23] - Connecting to assignment server
[04:55:23] Couldn't send HTTP request to server (wininet)
[04:55:23] + Could not connect to Assignment Server
[04:56:23] Couldn't send HTTP request to server (wininet)
[04:56:23] + Could not connect to Assignment Server 2
[04:56:23] + Couldn't get work instructions.
[04:56:23] - Error: Attempt #6  to get work failed, and no other work to do.
[04:59:05] + Attempting to get work packet
[04:59:05] - Connecting to assignment server
[05:00:06] Couldn't send HTTP request to server (wininet)
[05:00:06] + Could not connect to Assignment Server
[05:01:06] Couldn't send HTTP request to server (wininet)
[05:01:06] + Could not connect to Assignment Server 2
[05:01:06] + Couldn't get work instructions.
[05:01:06] - Error: Attempt #7  to get work failed, and no other work to do.
[05:06:36] + Attempting to get work packet
[05:06:36] - Connecting to assignment server
[05:07:36] Couldn't send HTTP request to server (wininet)
[05:07:36] + Could not connect to Assignment Server
[05:08:36] Couldn't send HTTP request to server (wininet)
[05:08:36] + Could not connect to Assignment Server 2
[05:08:36] + Couldn't get work instructions.
[05:08:36] - Error: Attempt #8  to get work failed, and no other work to do.
[05:19:28] + Attempting to get work packet
[05:19:28] - Connecting to assignment server
[05:20:28] Couldn't send HTTP request to server (wininet)
[05:20:28] + Could not connect to Assignment Server
[05:21:29] Couldn't send HTTP request to server (wininet)
[05:21:29] + Could not connect to Assignment Server 2
[05:21:29] + Couldn't get work instructions.
[05:21:29] - Error: Attempt #9  to get work failed, and no other work to do.
[05:43:01] + Attempting to get work packet
[05:43:01] - Connecting to assignment server
[05:44:01] Couldn't send HTTP request to server (wininet)
[05:44:01] + Could not connect to Assignment Server
[05:45:01] Couldn't send HTTP request to server (wininet)
[05:45:01] + Could not connect to Assignment Server 2
[05:45:01] + Couldn't get work instructions.
[05:45:01] - Error: Attempt #10  to get work failed, and no other work to do.
[06:27:35] + Attempting to get work packet
[06:27:35] - Connecting to assignment server
[06:28:35] Couldn't send HTTP request to server (wininet)
[06:28:35] + Could not connect to Assignment Server
[06:29:35] Couldn't send HTTP request to server (wininet)
[06:29:35] + Could not connect to Assignment Server 2
[06:29:35] + Couldn't get work instructions.
[06:29:35] - Error: Attempt #11  to get work failed, and no other work to do.
--- Opening Log file [June 14 05:46:29]
[05:46:29] - Ask before connecting: Yes
[05:46:29] - Use IE connection settings: Yes
[05:46:29] - User name: Lithe_Joint_f@h (Team 128409)
[05:46:29] - User ID: 6815B00355288775
[05:46:29] - Machine ID: 1
[05:46:29]
[05:46:29] Loaded queue successfully.
[05:46:29] Deleting incompletely fetched item (4) from queue position #3
[05:46:30] Initialization complete
[05:46:30] + Benchmarking ...
[05:46:34] - Preparing to get new work unit...
[05:46:34] - Presenting message box asking to network.
[05:46:34] + Attempting to send results
[05:46:35] - Presenting message box asking to network.
[05:46:41] + Attempting to get work packet
[05:46:41] - Connecting to assignment server
[05:46:57] Couldn't send HTTP request to server (wininet)
[05:46:57] + Could not connect to Work Server (results)
[05:46:57]     (171.64.122.136:8080)
[05:46:57] - Error: Could not transmit unit 01 (completed June 7) to work server.
[05:46:57] + Attempting to send results
[05:47:05] Couldn't send HTTP request to server (wininet)
[05:47:05] + Could not connect to Assignment Server
Folding@Home Client Shutdown.
--- Opening Log file [June 15 07:20:00]
[07:20:00] - Ask before connecting: Yes
[07:20:00] - Use IE connection settings: Yes
[07:20:00] - User name: Lithe_Joint_f@h (Team 128409)
[07:20:00] - User ID: 6815B00355288775
[07:20:00] - Machine ID: 1
[07:20:00]
[07:20:00] Loaded queue successfully.
[07:20:01] Initialization complete
[07:20:01] + Benchmarking ...
[07:20:05] - Preparing to get new work unit...
[07:20:05] - Presenting message box asking to network.
[07:20:05] + Attempting to send results
[07:20:06] - Presenting message box asking to network.
--- Opening Log file [June 16 04:58:20]
[04:58:20] - Ask before connecting: Yes
[04:58:20] - Use IE connection settings: Yes
[04:58:20] - User name: Lithe_Joint_f@h (Team 128409)
[04:58:20] - User ID: 6815B00355288775
[04:58:20] - Machine ID: 1
[04:58:20]
[04:58:20] Loaded queue successfully.
[04:58:20] Initialization complete
[04:58:20] + Benchmarking ...
[04:58:24] - Preparing to get new work unit...
[04:58:24] - Presenting message box asking to network.
[04:58:24] + Attempting to send results
[04:58:25] - Presenting message box asking to network.
--- Opening Log file [June 16 11:49:52]
[11:49:52] - Ask before connecting: Yes
[11:49:52] - Use IE connection settings: Yes
[11:49:52] - User name: Lithe_Joint_f@h (Team 128409)
[11:49:52] - User ID: 6815B00355288775
[11:49:52] - Machine ID: 1
[11:49:52]
[11:49:52] Loaded queue successfully.
[11:49:52] Initialization complete
[11:49:52] + Benchmarking ...
[11:49:55] - Preparing to get new work unit...
[11:49:55] - Presenting message box asking to network.
[11:49:55] + Attempting to send results
[11:49:56] - Presenting message box asking to network.
[11:51:21] + Attempting to get work packet
[11:51:21] - Connecting to assignment server
[11:51:40] - Successful: assigned to (171.64.65.65).
[11:51:40] + News From Folding@Home: Welcome to Folding@Home
[11:51:40] Loaded queue successfully.
[11:52:03] Couldn't send HTTP request to server (wininet)
[11:52:03] + Could not connect to Work Server (results)
[11:52:03]     (171.64.122.136:8080)
[11:52:03] - Error: Could not transmit unit 01 (completed June 7) to work server.
[11:52:03] + Attempting to send results
[11:52:40] Couldn't send HTTP request to server (wininet)
[11:52:40] + Could not connect to Work Server (results)
[11:52:40]     (171.64.122.76:8080)
[11:52:40]   Could not transmit unit 01 to Collection server; keeping in queue.
[11:52:40] + Attempting to send results
[11:53:21] Couldn't send HTTP request to server (wininet)
[11:53:21] + Could not connect to Work Server (results)
[11:53:21]     (171.65.103.160:80)
[11:53:21] - Error: Could not transmit unit 02 (completed June 11) to work server.
[11:53:21] + Attempting to send results
[11:54:18] Couldn't send HTTP request to server (wininet)
[11:54:18] + Could not connect to Work Server (results)
[11:54:18]     (171.64.122.76:80)
[11:54:18]   Could not transmit unit 02 to Collection server; keeping in queue.
[11:59:25] Opening C:\Program Files\Folding@Home\MyFolding.html...
[11:59:49] Opening http://vspx27.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=128409...
[12:11:23] + Connections closed: You may now disconnect
[12:11:23]
[12:11:23] + Processing work unit
[12:11:23] Core required: FahCore_78.exe
[12:11:23] Core found.
[12:11:23] Working on Unit 03 [June 16 12:11:23]
[12:11:23] + Working ...
[12:11:24]
[12:11:24] *------------------------------*
[12:11:24] Folding@Home Gromacs Core
[12:11:24] Version 1.90 (March 8, 2006)
[12:11:24]
[12:11:24] Preparing to commence simulation
[12:11:24] - Looking at optimizations...
[12:11:24] - Created dyn
[12:11:24] - Files status OK
[12:11:31] - Expanded 3853615 -> 20813811 (decompressed 540.1 percent)
[12:11:31] - Starting from initial work packet
[12:11:31]
[12:11:31] Project: 2611 (Run 1, Clone 544, Gen 46)
[12:11:31]
[12:11:33] Assembly optimizations on if available.
[12:11:33] Entering M.D.
[12:11:40] Protein: p2611_POPE
[12:11:40]
[12:11:40] Writing local files
[12:11:45] Extra SSE boost OK.
[12:11:45] Writing local files
[12:11:46] Completed 0 out of 250000 steps  (0)
[12:19:11] Printing Queue Information
CURRENT QUEUE:
00  EMPTY
03 *ACTIVE    "Folding@Home" (78) 171.64.65.65:8080  June 16 12:11 | July 26 12:11
04  EMPTY
05  EMPTY
06  EMPTY
07  EMPTY
08  EMPTY
09  EMPTY
[12:24:56] Opening C:\Program Files\Folding@Home\MyFolding.html...
[12:31:13] Writing local files
[12:31:14] Completed 2500 out of 250000 steps  (1)
[12:41:27] CoreStatus = 1 (1)
[12:41:27] Client-core communications error: ERROR 0x1
[12:41:27] Deleting current work unit & continuing...
[12:41:47] + Attempting to send results
[12:41:47] - Presenting message box asking to network.
[12:42:23] Couldn't send HTTP request to server (wininet)
[12:42:23] + Could not connect to Work Server (results)
[12:42:23]     (171.64.122.136:8080)
[12:42:23] - Error: Could not transmit unit 01 (completed June 7) to work server.
[12:42:23] + Attempting to send results
[12:43:05] Couldn't send HTTP request to server (wininet)
[12:43:05] + Could not connect to Work Server (results)
[12:43:05]     (171.64.122.76:8080)
[12:43:05]   Could not transmit unit 01 to Collection server; keeping in queue.
[12:43:05] + Attempting to send results
[12:43:53] Couldn't send HTTP request to server (wininet)
[12:43:53] + Could not connect to Work Server (results)
[12:43:53]     (171.65.103.160:80)
[12:43:53] - Error: Could not transmit unit 02 (completed June 11) to work server.
[12:43:53] + Attempting to send results
[12:44:51] Couldn't send HTTP request to server (wininet)
[12:44:51] + Could not connect to Work Server (results)
[12:44:51]     (171.64.122.76:80)
[12:44:51]   Could not transmit unit 02 to Collection server; keeping in queue.
[12:44:51] - Preparing to get new work unit...
[12:44:51] + Attempting to get work packet
[12:44:51] - Connecting to assignment server
[12:45:20] - Successful: assigned to (171.65.103.160).
[12:45:20] + News From Folding@Home: Welcome to Folding@Home
[12:45:20] Loaded queue successfully.
[12:46:36] + Connections closed: You may now disconnect
[12:46:41]
[12:46:41] + Processing work unit
[12:46:41] Core required: FahCore_82.exe
[12:46:41] Core found.
[12:46:41] Working on Unit 04 [June 16 12:46:41]
[12:46:41] + Working ...
[12:46:41]
[12:46:41] *------------------------------*
[12:46:41] Folding@Home PMD Core
[12:46:41] Version 1.03 (September 7, 2005)
[12:46:41]
[12:46:41] Preparing to commence simulation
[12:46:41] - Looking at optimizations...
[12:46:41] - Created dyn
[12:46:41] - Files status OK
[12:46:41] - Expanded 93034 -> 599777 (decompressed 644.6 percent)
[12:46:41]
[12:46:41] Project: 2170 (Run 68, Clone 163, Gen 8)
[12:46:41]
[12:46:41] Assembly optimizations on if available.
[12:46:41] Entering M.D.
[12:46:48] Protein: p2170_lambda_obc_300K
[12:46:48]
[12:46:48] Completed 0 out of 500000 steps  (0)
[12:48:10] Printing Queue Information
CURRENT QUEUE:
00  EMPTY
03  EMPTY
04 *ACTIVE    "Folding@Home" (82) 171.65.103.160:8080  June 16 12:46 | August 21 12:46
05  EMPTY
06  EMPTY
07  EMPTY
08  EMPTY
09  EMPTY
[13:01:47] Writing checkpoint files
--- Opening Log file [June 18 14:47:20]
[14:47:20] - Ask before connecting: Yes
[14:47:20] - Use IE connection settings: Yes
[14:47:20] - User name: Lithe_Joint_f@h (Team 128409)
[14:47:20] - User ID: 6815B00355288775
[14:47:20] - Machine ID: 1
[14:47:20]
[14:47:21] Loaded queue successfully.
[14:47:21] Initialization complete
[14:47:21] + Benchmarking ...
[14:47:25]
[14:47:25] + Processing work unit
[14:47:25] Core required: FahCore_82.exe
[14:47:25] Core found.
[14:47:25] + Attempting to send results
[14:47:25] Working on Unit 04 [June 18 14:47:25]
[14:47:25] + Working ...
[14:47:26] - Presenting message box asking to network.
[14:47:35]
[14:47:35] *------------------------------*
[14:47:35] Folding@Home PMD Core
[14:47:35] Version 1.03 (September 7, 2005)
[14:47:35]
[14:47:35] Preparing to commence simulation
[14:47:35] - Looking at optimizations...
[14:47:35] - Files status OK
[14:47:36] - Expanded 93034 -> 599777 (decompressed 644.6 percent)
[14:47:36]
[14:47:36] Project: 2170 (Run 68, Clone 163, Gen 8)
[14:47:36]
[14:47:37] Assembly optimizations on if available.
[14:47:37] Entering M.D.
--- Opening Log file [June 19 04:46:31]
[04:46:31] - Ask before connecting: Yes
[04:46:31] - Use IE connection settings: Yes
[04:46:31] - User name: Lithe_Joint_f@h (Team 128409)
[04:46:31] - User ID: 6815B00355288775
[04:46:31] - Machine ID: 1
[04:46:31]
[04:46:32] Loaded queue successfully.
[04:46:32] Initialization complete
[04:46:32] + Benchmarking ...
[04:46:36]
[04:46:36] + Processing work unit
[04:46:36] Core required: FahCore_82.exe
[04:46:36] + Attempting to send results
[04:46:36] Core found.
[04:46:37] Working on Unit 04 [June 19 04:46:37]
[04:46:37] + Working ...
[04:46:38] - Presenting message box asking to network.
[04:46:49]
[04:46:49] *------------------------------*
[04:46:49] Folding@Home PMD Core
[04:46:49] Version 1.03 (September 7, 2005)
[04:46:49]
[04:46:49] Preparing to commence simulation
[04:46:49] - Looking at optimizations...
[04:46:49] - Files status OK
[04:46:49] - Expanded 93034 -> 599777 (decompressed 644.6 percent)
[04:46:49]
[04:46:49] Project: 2170 (Run 68, Clone 163, Gen 8)
[04:46:49]
[04:46:49] Assembly optimizations on if available.
[04:46:49] Entering M.D.
[04:47:01] Protein: p2170_lambda_obc_300K
[04:47:01]
[04:47:01] Completed 2000 out of 500000 steps  (0)
[04:48:44] Error: Got status code 407 from server
[04:48:44] + Could not connect to Work Server (results)
[04:48:44]     (171.64.122.136:8080)
[04:48:44] - Error: Could not transmit unit 01 (completed June 7) to work server.
[04:48:44] + Attempting to send results
[04:49:44] Couldn't send HTTP request to server (wininet)
[04:49:44] + Could not connect to Work Server (results)
[04:49:44]     (171.64.122.76:8080)
[04:49:44]   Could not transmit unit 01 to Collection server; keeping in queue.
[04:49:47] + Attempting to send results
[04:50:48] Couldn't send HTTP request to server (wininet)
[04:50:48] + Could not connect to Work Server (results)
[04:50:48]     (171.65.103.160:80)
[04:50:48] - Error: Could not transmit unit 02 (completed June 11) to work server.
[04:50:48] + Attempting to send results
[04:51:48] Couldn't send HTTP request to server (wininet)
[04:51:48] + Could not connect to Work Server (results)
[04:51:48]     (171.64.122.76:80)
[04:51:48]   Could not transmit unit 02 to Collection server; keeping in queue.
[05:01:56] Writing checkpoint files
[05:09:43] Writing local files
[05:09:43] Completed 5000 out of 500000 steps  (1)
[05:16:56] Writing checkpoint files
[05:32:05] Writing checkpoint files
[05:46:44] Writing local files
[05:46:44] Completed 10000 out of 500000 steps  (2)
[05:47:06] Writing checkpoint files
[06:02:07] Writing checkpoint files
[06:17:08] Writing checkpoint files
[06:23:45] Writing local files
[06:23:45] Completed 15000 out of 500000 steps  (3)
[06:32:12] Writing checkpoint files
[06:47:18] Writing checkpoint files
[07:00:32] Writing local files
[07:00:32] Completed 20000 out of 500000 steps  (4)
[07:02:23] Writing checkpoint files
[07:17:29] Writing checkpoint files
[07:32:38] Writing checkpoint files
[07:37:27] Writing local files
[07:37:27] Completed 25000 out of 500000 steps  (5)
[07:37:27] Writing checkpoint files
[07:52:36] Writing checkpoint files
[08:07:45] Writing checkpoint files
[08:14:22] Writing local files
[08:14:22] Completed 30000 out of 500000 steps  (6)
[08:22:52] Writing checkpoint files
[08:38:04] Writing checkpoint files
[08:51:27] Writing local files
[08:51:27] Completed 35000 out of 500000 steps  (7)
[08:53:07] Writing checkpoint files
[09:08:13] Writing checkpoint files
[09:23:17] Writing checkpoint files
[09:28:39] Writing local files
[09:28:39] Completed 40000 out of 500000 steps  (8)
[09:38:18] Writing checkpoint files
[09:53:29] Writing checkpoint files
[10:05:39] Writing local files
[10:05:39] Completed 45000 out of 500000 steps  (9)
[10:08:34] Writing checkpoint files
[10:23:39] Writing checkpoint files
[10:38:50] Writing checkpoint files
[10:42:31] Writing local files
[10:42:31] Completed 50000 out of 500000 steps  (10)
[10:42:31] Writing checkpoint files
[10:51:47] + Attempting to send results
[10:52:48] Couldn't send HTTP request to server (wininet)
[10:52:48] + Could not connect to Work Server (results)
[10:52:48]     (171.64.122.136:8080)
[10:52:48] - Error: Could not transmit unit 01 (completed June 7) to work server.
[10:52:48] + Attempting to send results
[10:53:48] Couldn't send HTTP request to server (wininet)
[10:53:48] + Could not connect to Work Server (results)
[10:53:48]     (171.64.122.76:8080)
[10:53:48]   Could not transmit unit 01 to Collection server; keeping in queue.
[10:53:48] + Attempting to send results
[10:54:48] Couldn't send HTTP request to server (wininet)
[10:54:48] + Could not connect to Work Server (results)
[10:54:48]     (171.65.103.160:80)
[10:54:48] - Error: Could not transmit unit 02 (completed June 11) to work server.
[10:54:48] + Attempting to send results
[10:55:48] Couldn't send HTTP request to server (wininet)
[10:55:48] + Could not connect to Work Server (results)
[10:55:48]     (171.64.122.76:80)
[10:55:48]   Could not transmit unit 02 to Collection server; keeping in queue.
[10:57:42] Writing checkpoint files
[11:12:43] Writing checkpoint files
[11:19:31] Writing local files
[11:19:31] Completed 55000 out of 500000 steps  (11)
[11:27:49] Writing checkpoint files
[11:42:49] Writing checkpoint files
[11:56:34] Writing local files
[11:56:34] Completed 60000 out of 500000 steps  (12)
[11:57:52] Writing checkpoint files
[12:13:02] Writing checkpoint files
[12:28:10] Writing checkpoint files
[12:33:32] Writing local files
[12:33:32] Completed 65000 out of 500000 steps  (13)
[12:43:18] Writing checkpoint files
[12:58:26] Writing checkpoint files
[13:10:28] Writing local files
[13:10:28] Completed 70000 out of 500000 steps  (14)
[13:13:27] Writing checkpoint files
[13:28:29] Writing checkpoint files
[13:43:40] Writing checkpoint files
[13:47:34] Writing local files
[13:47:34] Completed 75000 out of 500000 steps  (15)
[13:47:34] Writing checkpoint files
[14:02:43] Writing checkpoint files
[14:17:55] Writing checkpoint files
[14:24:32] Writing local files
[14:24:32] Completed 80000 out of 500000 steps  (16)
[14:33:00] Writing checkpoint files
--- Opening Log file [June 19 19:42:07]
[19:42:07] - Ask before connecting: No
[19:42:07] - Use IE connection settings: Yes
[19:42:07] - User name: Lithe_Joint_f@h (Team 128409)
[19:42:07] - User ID: 6815B00355288775
[19:42:07] - Machine ID: 1
[19:42:07]
[19:42:07] Loaded queue successfully.
[19:42:07] Initialization complete
[19:42:07] + Benchmarking ...
[19:42:11]
[19:42:11] + Processing work unit
[19:42:11] + Attempting to send results
[19:42:11] Core required: FahCore_82.exe
[19:42:11] Core found.
[19:42:12] Working on Unit 04 [June 19 19:42:12]
[19:42:12] + Working ...
[19:42:22]
[19:42:22] *------------------------------*
[19:42:22] Folding@Home PMD Core
[19:42:22] Version 1.03 (September 7, 2005)
[19:42:22]
[19:42:22] Preparing to commence simulation
[19:42:22] - Looking at optimizations...
[19:42:22] - Files status OK
[19:42:22] - Expanded 93034 -> 599777 (decompressed 644.6 percent)
[19:42:22]
[19:42:22] Project: 2170 (Run 68, Clone 163, Gen 8)
[19:42:22]
[19:42:23] Assembly optimizations on if available.
[19:42:23] Entering M.D.
[19:42:49] Couldn't send HTTP request to server (wininet)
[19:42:49] + Could not connect to Work Server (results)
[19:42:49]     (171.64.122.136:8080)
[19:42:49] - Error: Could not transmit unit 01 (completed June 7) to work server.
[19:42:49] + Attempting to send results
[19:43:23] Couldn't send HTTP request to server (wininet)
[19:43:23] + Could not connect to Work Server (results)
[19:43:23]     (171.64.122.76:8080)
[19:43:23]   Could not transmit unit 01 to Collection server; keeping in queue.
[19:43:23] + Attempting to send results
[19:43:31] Protein: p2170_lambda_obc_300K
[19:43:31]
[19:43:31] Completed 81150 out of 500000 steps  (16)
[19:44:07] Couldn't send HTTP request to server (wininet)
[19:44:07] + Could not connect to Work Server (results)
[19:44:07]     (171.65.103.160:80)
[19:44:07] - Error: Could not transmit unit 02 (completed June 11) to work server.
[19:44:07] + Attempting to send results
[19:44:53] Couldn't send HTTP request to server (wininet)
[19:44:53] + Could not connect to Work Server (results)
[19:44:53]     (171.64.122.76:80)
[19:44:53]   Could not transmit unit 02 to Collection server; keeping in queue.
[19:57:26] Writing checkpoint files
[19:58:51] Opening http://vspx27.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=128409...
[19:59:40] Opening C:\Program Files\Folding@Home\MyFolding.html...
[20:00:11] Printing Queue Information
CURRENT QUEUE:
00  EMPTY
03  EMPTY
04 *READY     "Folding@Home" (82) 171.65.103.160:8080  June 16 12:46 | August 21 12:46
05  EMPTY
06  EMPTY
07  EMPTY
08  EMPTY
09  EMPTY
[20:01:12] Opening C:\Program Files\Folding@Home\MyFolding.html...
[20:12:04] Writing local files
[20:12:04] Completed 85000 out of 500000 steps  (17)
[20:12:27] Writing checkpoint files
[20:17:25] Opening C:\Program Files\Folding@Home\MyFolding.html...
[20:17:42] Printing Queue Information
CURRENT QUEUE:
00  EMPTY
03  EMPTY
05  EMPTY
06  EMPTY
07  EMPTY
08  EMPTY
09  EMPTY
[20:27:37] Writing checkpoint files
[20:42:43] Writing checkpoint files
[20:48:59] Writing local files
[20:48:59] Completed 90000 out of 500000 steps  (18)
[20:49:37] Printing Queue Information
CURRENT QUEUE:
00  EMPTY
03  EMPTY
05  EMPTY
06  EMPTY
07  EMPTY
08  EMPTY
09  EMPTY
[04:36:08] + Attempting to send results
[04:36:10] Couldn't send HTTP request to server (wininet)
[04:36:10] + Could not connect to Work Server (results)
[04:36:10]     (171.64.122.136:8080)
[04:36:10] - Error: Could not transmit unit 01 (completed June 7) to work server.
[04:36:10] + Attempting to send results
[04:36:10]     (171.64.122.76:8080)
[04:36:10]   Could not transmit unit 01 to Collection server; keeping in queue.
[04:36:12] Couldn't send HTTP request to server (wininet)
[04:36:12] + Could not connect to Work Server (results)
[04:36:12]     (171.65.103.160:80)
[04:36:12] - Error: Could not transmit unit 02 (completed June 11) to work server.
[04:36:12] + Attempting to send results
[04:36:15] Couldn't send HTTP request to server (wininet)
[04:36:15] + Could not connect to Work Server (results)
[04:36:15]     (171.64.122.76:80)
[04:36:15]   Could not transmit unit 02 to Collection server; keeping in queue.
[04:36:19] Writing checkpoint files
Thanks again!
Kind Regards,
LJ
ChelseaOilman
Lithe_Joint_f@h wrote:[04:40:08] - Use IE connection settings: Yes
Just change that setting to No and you should be all set.
