Point Inconsistency
Imnohbdy
Hardware configuration: System is currently air cooled with no overclocking except for ram and AMD's standard boost clocking
MB: ASUS Crosshair Hero VIII
CPU: Ryzen 7 3800X
GPU: RTX 2070 Super
Ram: 32Gb 3600Mhz (I know it's overkill but I like all 4 slots filled)
31.9Gb available when not using chrome
Point Inconsistency
Post by Imnohbdy »
So, this is not a big deal as I'm not folding for the imaginary currency, however, this may be a bug and I wanted to double check before submitting it. I started out folding without a passkey, as it was taking forever to get to my inbox. After browsing the forums I decided to try my .edu email address and got one. Once I added it to my account though the points displayed on my web console reset to zero. clicking on see stats still displayed my old point contributions (about 24k). Now though my web console updates, but my stats page does not. I've added another 16k according to the web console -bonuses haven't kicked in yet I guess- but the stats page still shows 24k. To be clear, I just want to know if this is: 1. Something that will straighten out on it's own when the local data finally transmits to the servers? 2. A bug and if so should I report it or is it a known bug? 3. Just me misunderstanding something? or 4. Not a bug but a "feature" :lol: ?
Currently installing upgrade to LAWYER 1.0/Known Bugs: hated by humanity/Patch Available: Stirring Speech *Patch requires Politician DLC
“Nearly all men can stand adversity, but if you want to test a man's character, give him power.”
― Abraham Lincoln
Re: Point Inconsistency
The Web Control shows you points based on a search based on both your username and passkey. So when the passkey was set, it does not show the points earned without. A search on your username on the stats site should show all points with and without passkey.. So sort of a bit of 3 and a bit of 4, and definitely yes on 1.
Also the stats database can be a bit behind right now, all points should get entered eventually. Occasionally loading process gets stuck and has to be restarted.
Imnohbdy
CPU: Ryzen 7 3800X
GPU: RTX 2070 Super
Post by Imnohbdy »
Thank you @Joe_H.
― Abraham Lincoln
treckin
Post by treckin »
I just wanted to add that my points havent increased in 36 hours roughly, despite turning in quite a few WUs.
I messaged the chap at Overclockers to see if he was aware.
Best,
