GPU is folding, CPU stuck at "Downloading" (Fixed)
gabidigabs
Post by gabidigabs »
I downloaded folding@home a few hours ago and my GPU's been folding since (GTX 1050 Mobile), but my CPU (i5-8300H) seems to be doing nothing. Can somebody help?
My system: MSI GV62-8RC 240PH
Intel i5-8300H
GTX 1050 2GB
8GB DDR4
*********************** Log Started 2020-03-23T05:23:40Z ***********************
05:23:40:************************* Folding@home Client *************************
05:23:40:        Website: https://foldingathome.org/
05:23:40:      Copyright: (c) 2009-2018 foldingathome.org
05:23:40:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
05:23:40:           Args: --open-web-control
05:23:40:         Config: <none>
05:23:40:******************************** Build ********************************
05:23:40:        Version: 7.5.1
05:23:40:           Date: May 11 2018
05:23:40:           Time: 13:06:32
05:23:40:     Repository: Git
05:23:40:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
05:23:40:         Branch: master
05:23:40:       Compiler: Visual C++ 2008
05:23:40:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:23:40:       Platform: win32 10
05:23:40:           Bits: 32
05:23:40:           Mode: Release
05:23:40:******************************* System ********************************
05:23:40:            CPU: Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz
05:23:40:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
05:23:40:           CPUs: 8
05:23:40:         Memory: 7.85GiB
05:23:40:    Free Memory: 3.67GiB
05:23:40:        Threads: WINDOWS_THREADS
05:23:40:     OS Version: 6.2
05:23:40:    Has Battery: true
05:23:40:     On Battery: false
05:23:40:     UTC Offset: 8
05:23:40:            PID: 4036
05:23:40:            CWD: C:\Users\Gabriel Caluya\AppData\Roaming\FAHClient
05:23:40:             OS: Windows 10 Home
05:23:40:        OS Arch: AMD64
05:23:40:           GPUs: 0
05:23:40:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
05:23:40:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:441.20
05:23:40:OpenCL Device 1: Platform:1 Device:0 Bus:NA Slot:NA Compute:2.1 Driver:24.20
05:23:40:  Win32 Service: false
05:23:40:***********************************************************************
05:23:40:<config>
05:23:40:  <!-- Folding Slots -->
05:23:40:</config>
05:23:40:Connecting to assign1.foldingathome.org:8080
05:23:41:Updated GPUs.txt
05:23:41:Read GPUs.txt
05:23:41:Trying to access database...
05:23:41:Successfully acquired database lock
05:23:41:Enabled folding slot 00: PAUSED cpu:3 (not configured)
05:23:41:Enabled folding slot 01: PAUSED gpu:0:GP107M [GeForce GTX 1050 Mobile] (not configured)
05:23:49:10:127.0.0.1:New Web connection
05:24:42:Saving configuration to config.xml
05:24:42:<config>
05:24:42:  <!-- Folding Slots -->
05:24:42:  <slot id='0' type='CPU'/>
05:24:42:  <slot id='1' type='GPU'/>
05:24:42:</config>
05:24:42:Set client configured
05:24:42:WU00:FS00:Connecting to 65.254.110.245:8080
05:24:43:WU00:FS00:Connecting to 65.254.110.245:8080
05:24:44:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:24:44:WU00:FS00:Connecting to 18.218.241.186:80
05:24:44:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:24:44:ERROR:WU00:FS00:Exception: Could not get an assignment
05:24:44:WU00:FS00:Connecting to 65.254.110.245:8080
05:24:45:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:24:45:WU00:FS00:Connecting to 18.218.241.186:80
05:24:46:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:24:46:ERROR:WU00:FS00:Exception: Could not get an assignment
05:25:44:WU00:FS00:Connecting to 65.254.110.245:8080
05:25:45:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:25:45:WU00:FS00:Connecting to 18.218.241.186:80
05:25:46:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:25:46:ERROR:WU00:FS00:Exception: Could not get an assignment
05:27:22:WU00:FS00:Connecting to 65.254.110.245:8080
05:27:22:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:27:23:WU00:FS00:Connecting to 18.218.241.186:80
05:27:23:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:27:23:ERROR:WU00:FS00:Exception: Could not get an assignment
05:29:59:WU00:FS00:Connecting to 65.254.110.245:8080
05:30:00:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:30:00:WU00:FS00:Connecting to 18.218.241.186:80
05:30:00:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:30:00:ERROR:WU00:FS00:Exception: Could not get an assignment
05:30:44:WU01:FS01:Connecting to 65.254.110.245:8080
05:30:45:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:30:45:WU01:FS01:Connecting to 18.218.241.186:80
05:30:46:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:30:46:ERROR:WU01:FS01:Exception: Could not get an assignment
05:30:46:WU01:FS01:Connecting to 65.254.110.245:8080
05:30:47:WU01:FS01:Assigned to work server 140.163.4.231
05:30:47:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Mobile] from 140.163.4.231
05:30:47:WU01:FS01:Connecting to 140.163.4.231:8080
05:30:48:Saving configuration to config.xml
05:30:48:<config>
05:30:48:  <!-- Slot Control -->
05:30:48:  <power v='FULL'/>
05:30:48:
05:30:48:  <!-- User Information -->
05:30:48:  <team v='223518'/>
05:30:48:  <user v='gabidigabs'/>
05:30:48:
05:30:48:  <!-- Folding Slots -->
05:30:48:  <slot id='0' type='CPU'/>
05:30:48:  <slot id='1' type='GPU'/>
05:30:48:</config>
05:30:59:WU00:FS00:Connecting to 65.254.110.245:8080
05:31:00:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:31:00:WU00:FS00:Connecting to 18.218.241.186:80
05:31:01:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:31:01:ERROR:WU00:FS00:Exception: Could not get an assignment
05:31:08:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
05:31:08:WU01:FS01:Connecting to 140.163.4.231:80
05:32:07:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:32:23:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:32:30:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
05:32:30:WU01:FS01:Connecting to 65.254.110.245:8080
05:32:31:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:32:31:WU01:FS01:Connecting to 18.218.241.186:80
05:32:32:WU01:FS01:Assigned to work server 140.163.4.231
05:32:32:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP107M [GeForce GTX 1050 Mobile] from 140.163.4.231
05:32:32:WU01:FS01:Connecting to 140.163.4.231:8080
05:32:36:WU00:FS00:Connecting to 65.254.110.245:8080
05:32:37:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:32:37:WU00:FS00:Connecting to 18.218.241.186:80
05:32:38:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:32:38:ERROR:WU00:FS00:Exception: Could not get an assignment
05:32:39:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:32:51:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:34:27:WU01:FS01:Downloading 13.15MiB
05:34:34:WU01:FS01:Download 1.43%
05:34:42:WU01:FS01:Download 4.75%
05:34:51:WU01:FS01:Download 12.84%
05:34:57:WU01:FS01:Download 16.16%
05:35:03:WU01:FS01:Download 21.87%
05:35:09:WU01:FS01:Download 28.53%
05:35:14:WU00:FS00:Connecting to 65.254.110.245:8080
05:35:14:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:35:14:WU00:FS00:Connecting to 18.218.241.186:80
05:35:15:WU01:FS01:Download 33.75%
05:35:15:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:35:15:ERROR:WU00:FS00:Exception: Could not get an assignment
05:35:21:WU01:FS01:Download 39.94%
05:35:27:WU01:FS01:Download 42.79%
05:35:35:WU01:FS01:Download 52.77%
05:35:41:WU01:FS01:Download 60.85%
05:35:47:WU01:FS01:Download 67.03%
05:35:53:WU01:FS01:Download 72.74%
05:36:01:WU01:FS01:Download 80.82%
05:36:07:WU01:FS01:Download 91.76%
05:36:13:WU01:FS01:Download 98.41%
05:36:13:WU01:FS01:Download complete
05:36:13:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11752 run:0 clone:786 gen:7 core:0x22 unit:0x000000138ca304e75e6a805d4d62b192
05:36:13:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
05:36:13:WU01:FS01:Connecting to cores.foldingathome.org:80
05:36:14:WU01:FS01:FahCore 22: Downloading 4.04MiB
05:36:20:WU01:FS01:FahCore 22: 30.94%
05:36:26:WU01:FS01:FahCore 22: 69.62%
05:36:31:WU01:FS01:FahCore 22: Download complete
05:36:31:WU01:FS01:Valid core signature
05:36:31:WU01:FS01:Unpacked 13.49MiB to cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe
05:36:31:WU01:FS01:Starting
05:36:31:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\Gabriel Caluya\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe" -dir 01 -suffix 01 -version 705 -lifeline 4036 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
05:36:31:WU01:FS01:Started FahCore on PID 8140
05:36:31:WU01:FS01:Core PID:12940
05:36:31:WU01:FS01:FahCore 0x22 started
05:36:31:WU01:FS01:0x22:*********************** Log Started 2020-03-23T05:36:31Z ***********************
05:36:31:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
05:36:31:WU01:FS01:0x22:       Type: 0x22
05:36:31:WU01:FS01:0x22:       Core: Core22
05:36:31:WU01:FS01:0x22:    Website: https://foldingathome.org/
05:36:31:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
05:36:31:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
05:36:31:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
05:36:31:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 8140 -checkpoint 15
05:36:31:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
05:36:31:WU01:FS01:0x22:             0 -gpu 0
05:36:31:WU01:FS01:0x22:     Config: <none>
05:36:31:WU01:FS01:0x22:************************************ Build *************************************
05:36:31:WU01:FS01:0x22:    Version: 0.0.2
05:36:31:WU01:FS01:0x22:       Date: Dec 6 2019
05:36:31:WU01:FS01:0x22:       Time: 21:30:31
05:36:31:WU01:FS01:0x22: Repository: Git
05:36:31:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
05:36:31:WU01:FS01:0x22:     Branch: HEAD
05:36:31:WU01:FS01:0x22:   Compiler: Visual C++ 2008
05:36:31:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:36:31:WU01:FS01:0x22:   Platform: win32 10
05:36:31:WU01:FS01:0x22:       Bits: 64
05:36:31:WU01:FS01:0x22:       Mode: Release
05:36:31:WU01:FS01:0x22:************************************ System ************************************
05:36:31:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz
05:36:31:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
05:36:31:WU01:FS01:0x22:       CPUs: 8
05:36:31:WU01:FS01:0x22:     Memory: 7.85GiB
05:36:32:WU01:FS01:0x22:Free Memory: 1.85GiB
05:36:32:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
05:36:32:WU01:FS01:0x22: OS Version: 6.2
05:36:32:WU01:FS01:0x22:Has Battery: true
05:36:32:WU01:FS01:0x22: On Battery: false
05:36:32:WU01:FS01:0x22: UTC Offset: 8
05:36:32:WU01:FS01:0x22:        PID: 12940
05:36:32:WU01:FS01:0x22:        CWD: C:\Users\Gabriel Caluya\AppData\Roaming\FAHClient\work
05:36:32:WU01:FS01:0x22:         OS: Windows 10 Home Single Language
05:36:32:WU01:FS01:0x22:    OS Arch: AMD64
05:36:32:WU01:FS01:0x22:********************************************************************************
05:36:32:WU01:FS01:0x22:Project: 11752 (Run 0, Clone 786, Gen 7)
05:36:32:WU01:FS01:0x22:Unit: 0x000000138ca304e75e6a805d4d62b192
05:36:32:WU01:FS01:0x22:Reading tar file core.xml
05:36:32:WU01:FS01:0x22:Reading tar file integrator.xml
05:36:32:WU01:FS01:0x22:Reading tar file state.xml
05:36:39:WU01:FS01:0x22:Reading tar file system.xml
05:36:41:WU01:FS01:0x22:Digital signatures verified
05:36:41:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
05:36:41:WU01:FS01:0x22:Version 0.0.2
05:37:24:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
05:37:25:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
05:39:28:WU00:FS00:Connecting to 65.254.110.245:8080
05:39:29:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:39:29:WU00:FS00:Connecting to 18.218.241.186:80
05:39:29:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:39:29:ERROR:WU00:FS00:Exception: Could not get an assignment
05:40:43:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:40:59:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:41:15:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:41:31:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:41:47:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:43:55:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
05:44:42:FS01:Shutting core down
05:44:42:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 12940
05:44:42:WU01:FS01:0x22:Exiting, please wait. . .
05:44:42:WU01:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
05:44:43:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
05:44:43:WU00:FS00:Connecting to 65.254.110.245:8080
05:44:43:WU01:FS01:Starting
05:44:43:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:\Users\Gabriel Caluya\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe" -dir 01 -suffix 01 -version 705 -lifeline 4036 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
05:44:43:WU01:FS01:Started FahCore on PID 12492
05:44:43:WU01:FS01:Core PID:8084
05:44:43:WU01:FS01:FahCore 0x22 started
05:44:43:WU01:FS01:0x22:*********************** Log Started 2020-03-23T05:44:43Z ***********************
05:44:43:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
05:44:43:WU01:FS01:0x22:       Type: 0x22
05:44:43:WU01:FS01:0x22:       Core: Core22
05:44:43:WU01:FS01:0x22:    Website: https://foldingathome.org/
05:44:43:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
05:44:44:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
05:44:44:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
05:44:44:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 12492 -checkpoint 15
05:44:44:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
05:44:44:WU01:FS01:0x22:             0 -gpu 0
05:44:44:WU01:FS01:0x22:     Config: <none>
05:44:44:WU01:FS01:0x22:************************************ Build *************************************
05:44:44:WU01:FS01:0x22:    Version: 0.0.2
05:44:44:WU01:FS01:0x22:       Date: Dec 6 2019
05:44:44:WU01:FS01:0x22:       Time: 21:30:31
05:44:44:WU01:FS01:0x22: Repository: Git
05:44:44:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
05:44:44:WU01:FS01:0x22:     Branch: HEAD
05:44:44:WU01:FS01:0x22:   Compiler: Visual C++ 2008
05:44:44:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
05:44:44:WU01:FS01:0x22:   Platform: win32 10
05:44:44:WU01:FS01:0x22:       Bits: 64
05:44:44:WU01:FS01:0x22:       Mode: Release
05:44:44:WU01:FS01:0x22:************************************ System ************************************
05:44:44:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i5-8300H CPU @ 2.30GHz
05:44:44:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
05:44:44:WU01:FS01:0x22:       CPUs: 8
05:44:44:WU01:FS01:0x22:     Memory: 7.85GiB
05:44:44:WU01:FS01:0x22:Free Memory: 4.42GiB
05:44:44:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
05:44:44:WU01:FS01:0x22: OS Version: 6.2
05:44:44:WU01:FS01:0x22:Has Battery: true
05:44:44:WU01:FS01:0x22: On Battery: false
05:44:44:WU01:FS01:0x22: UTC Offset: 8
05:44:44:WU01:FS01:0x22:        PID: 8084
05:44:44:WU01:FS01:0x22:        CWD: C:\Users\Gabriel Caluya\AppData\Roaming\FAHClient\work
05:44:44:WU01:FS01:0x22:         OS: Windows 10 Home Single Language
05:44:44:WU01:FS01:0x22:    OS Arch: AMD64
05:44:44:WU01:FS01:0x22:********************************************************************************
05:44:44:WU01:FS01:0x22:Project: 11752 (Run 0, Clone 786, Gen 7)
05:44:44:WU01:FS01:0x22:Unit: 0x000000138ca304e75e6a805d4d62b192
05:44:44:WU01:FS01:0x22:Digital signatures verified
05:44:44:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
05:44:44:WU01:FS01:0x22:Version 0.0.2
05:44:45:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:44:45:WU00:FS00:Connecting to 18.218.241.186:80
05:44:46:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:44:46:ERROR:WU00:FS00:Exception: Could not get an assignment
05:44:58:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
05:44:58:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
05:45:43:WU00:FS00:Connecting to 65.254.110.245:8080
05:45:44:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:45:44:WU00:FS00:Connecting to 18.218.241.186:80
05:45:45:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:45:45:ERROR:WU00:FS00:Exception: Could not get an assignment
05:46:03:Saving configuration to config.xml
05:46:03:<config>
05:46:03:  <!-- Slot Control -->
05:46:03:  <power v='full'/>
05:46:03:
05:46:03:  <!-- User Information -->
05:46:03:  <team v='223518'/>
05:46:03:  <user v='gabidigabs'/>
05:46:03:
05:46:03:  <!-- Folding Slots -->
05:46:03:  <slot id='0' type='CPU'/>
05:46:03:  <slot id='1' type='GPU'/>
05:46:03:</config>
05:47:20:WU00:FS00:Connecting to 65.254.110.245:8080
05:47:21:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:47:21:WU00:FS00:Connecting to 18.218.241.186:80
05:47:22:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:47:22:ERROR:WU00:FS00:Exception: Could not get an assignment
05:49:54:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
05:49:58:WU00:FS00:Connecting to 65.254.110.245:8080
05:49:58:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:49:58:WU00:FS00:Connecting to 18.218.241.186:80
05:49:59:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:49:59:ERROR:WU00:FS00:Exception: Could not get an assignment
05:50:12:FS00:Finishing
05:50:52:FS00:Paused
05:50:55:FS00:Unpaused
05:50:58:WU00:FS00:Connecting to 65.254.110.245:8080
05:50:58:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:50:58:WU00:FS00:Connecting to 18.218.241.186:80
05:50:59:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:50:59:ERROR:WU00:FS00:Exception: Could not get an assignment
05:51:24:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
05:52:09:Saving configuration to config.xml
05:52:09:<config>
05:52:09:  <!-- Slot Control -->
05:52:09:  <power v='full'/>
05:52:09:
05:52:09:  <!-- User Information -->
05:52:09:  <team v='223518'/>
05:52:09:  <user v='gabidigabs'/>
05:52:09:
05:52:09:  <!-- Folding Slots -->
05:52:09:  <slot id='0' type='CPU'>
05:52:09:    <idle v='true'/>
05:52:09:  </slot>
05:52:09:  <slot id='1' type='GPU'/>
05:52:09:</config>
05:53:06:WU00:FS00:Connecting to 65.254.110.245:8080
05:53:07:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:53:07:WU00:FS00:Connecting to 18.218.241.186:80
05:53:08:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:53:08:ERROR:WU00:FS00:Exception: Could not get an assignment
05:54:07:WU00:FS00:Connecting to 65.254.110.245:8080
05:54:07:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:54:07:WU00:FS00:Connecting to 18.218.241.186:80
05:54:08:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:54:08:ERROR:WU00:FS00:Exception: Could not get an assignment
05:54:11:Saving configuration to config.xml
05:54:11:<config>
05:54:11:  <!-- Slot Control -->
05:54:11:  <power v='full'/>
05:54:11:
05:54:11:  <!-- User Information -->
05:54:11:  <team v='223518'/>
05:54:11:  <user v='gabidigabs'/>
05:54:11:
05:54:11:  <!-- Folding Slots -->
05:54:11:  <slot id='0' type='CPU'/>
05:54:11:  <slot id='1' type='GPU'/>
05:54:11:</config>
05:55:44:WU00:FS00:Connecting to 65.254.110.245:8080
05:55:45:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:55:45:WU00:FS00:Connecting to 18.218.241.186:80
05:55:45:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:55:45:ERROR:WU00:FS00:Exception: Could not get an assignment
05:57:50:WU01:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
05:58:21:WU00:FS00:Connecting to 65.254.110.245:8080
05:58:22:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:58:22:WU00:FS00:Connecting to 18.218.241.186:80
05:58:23:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:58:23:ERROR:WU00:FS00:Exception: Could not get an assignment
06:02:35:WU00:FS00:Connecting to 65.254.110.245:8080
06:02:36:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:02:36:WU00:FS00:Connecting to 18.218.241.186:80
06:02:37:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:02:37:ERROR:WU00:FS00:Exception: Could not get an assignment
06:04:14:WU01:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
06:05:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:05:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:05:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:05:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:06:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:06:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:06:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:06:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:07:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:07:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:07:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:08:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:08:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:08:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:08:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:09:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:09:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:09:27:WU00:FS00:Connecting to 65.254.110.245:8080
06:09:28:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:09:28:WU00:FS00:Connecting to 18.218.241.186:80
06:09:28:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:09:28:ERROR:WU00:FS00:Exception: Could not get an assignment
06:09:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:09:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:10:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:10:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:10:37:WU01:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
06:10:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:10:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:11:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:11:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:11:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:12:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:12:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:12:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:12:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:13:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:13:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:13:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:13:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:14:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:14:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:14:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:14:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:15:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:15:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:15:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:16:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:16:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:16:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:16:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:17:03:WU01:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
06:17:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:17:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:17:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:17:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:18:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:18:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:18:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:18:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:19:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:19:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:19:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:20:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:20:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:20:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:20:32:WU00:FS00:Connecting to 65.254.110.245:8080
06:20:33:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:20:33:WU00:FS00:Connecting to 18.218.241.186:80
06:20:34:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:20:34:ERROR:WU00:FS00:Exception: Could not get an assignment
06:20:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:21:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:21:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:21:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:21:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:22:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:22:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:22:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:22:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:23:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:23:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:23:34:WU01:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
06:23:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:24:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:24:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:24:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:24:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:25:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:25:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:25:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:25:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:26:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:26:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:26:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:26:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:27:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:27:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:27:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:28:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:28:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:28:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:28:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:29:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:29:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:29:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:29:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:29:56:WU01:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
06:30:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:30:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:30:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:30:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:31:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:31:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:31:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:32:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:32:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:32:32:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:32:48:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:33:04:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:33:20:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:33:36:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:33:52:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:34:08:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:34:24:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:34:40:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:34:56:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:35:12:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:35:28:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:35:44:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:36:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:36:16:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
06:36:18:WU01:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
Re: GPU is folding, CPU stuck at "Downloading"
There is more demand for work that then servers can currently supply. Eventually you should get an assignment. The request timer backs off the time between requests, if the time between requests gets too large you can pause the client for a minutee or so and then resume. Just don't do this too often.
gabidigabs
Aight man, thanks a lot
