I've downloaded fah today and installed it.
But only one gpu is folding, the other and the cpu is idle
Both GPUs are Radeon R7 200 and the cpu is an AMD 8320 8core.
Thank you for help
Georg
Your GPU ist most probably using 100%, see viewtopic.php?f=61&t=33023.HomerTeni wrote:Another Question: Why is the GPU only at 1-3%? The settings are on full folding power
The active GPU should be at near 100%.HomerTeni wrote:Thanks a lot.
*********************** Log Started 2020-03-29T20:43:53Z ***********************
20:43:53:************************* Folding@home Client *************************
20:43:53: Website: https://foldingathome.org/
20:43:53: Copyright: (c) 2009-2018 foldingathome.org
20:43:53: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:43:53: Args: --open-web-control
20:43:53: Config: <none>
20:43:53:******************************** Build ********************************
20:43:53: Version: 7.5.1
20:43:53: Date: May 11 2018
20:43:53: Time: 13:06:32
20:43:53: Repository: Git
20:43:53: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
20:43:53: Branch: master
20:43:53: Compiler: Visual C++ 2008
20:43:53: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:43:53: Platform: win32 10
20:43:53: Bits: 32
20:43:53: Mode: Release
20:43:53:******************************* System ********************************
20:43:53: CPU: Intel(R) Core(TM) i7-8086K CPU @ 4.00GHz
20:43:53: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
20:43:53: CPUs: 6
20:43:53: Memory: 31.93GiB
20:43:53: Free Memory: 24.82GiB
20:43:53: Threads: WINDOWS_THREADS
20:43:53: OS Version: 6.2
20:43:53: Has Battery: false
20:43:53: On Battery: false
20:43:53: UTC Offset: 2
20:43:53: PID: 12984
20:43:53: CWD: C:\Users\Richard\AppData\Roaming\FAHClient
20:43:53: OS: Windows 10 Enterprise
20:43:53: OS Arch: AMD64
20:43:53: GPUs: 0
20:43:53: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:7.5 Driver:11.0
20:43:53:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:445.75
20:43:53: Win32 Service: false
20:43:53:***********************************************************************
20:43:53:<config>
20:43:53: <!-- Folding Slots -->
20:43:53:</config>
20:43:53:Connecting to assign1.foldingathome.org:8080
20:43:54:Updated GPUs.txt
20:43:54:Read GPUs.txt
20:43:54:Trying to access database...
20:43:54:Successfully acquired database lock
20:43:54:Enabled folding slot 00: PAUSED cpu:4 (not configured)
20:43:54:Enabled folding slot 01: PAUSED gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 (not configured)
20:43:57:10:127.0.0.1:New Web connection
20:44:42:Set client configured
20:44:42:WU00:FS00:Connecting to 65.254.110.245:8080
20:44:42:WU01:FS01:Connecting to 65.254.110.245:8080
20:44:43:WU00:FS00:Connecting to 65.254.110.245:8080
20:44:43:WU01:FS01:Connecting to 65.254.110.245:8080
20:44:43:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:44:43:WU00:FS00:Connecting to 18.218.241.186:80
20:44:43:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:44:43:WU01:FS01:Connecting to 18.218.241.186:80
20:44:43:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:44:43:ERROR:WU00:FS00:Exception: Could not get an assignment
20:44:44:WU00:FS00:Connecting to 65.254.110.245:8080
20:44:44:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:44:44:ERROR:WU01:FS01:Exception: Could not get an assignment
20:44:44:WU01:FS01:Connecting to 65.254.110.245:8080
20:44:44:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:44:44:WU00:FS00:Connecting to 18.218.241.186:80
20:44:44:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:44:44:WU01:FS01:Connecting to 18.218.241.186:80
20:44:45:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:44:45:ERROR:WU00:FS00:Exception: Could not get an assignment
20:44:45:WU01:FS01:Assigned to work server 140.163.4.231
20:44:45:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU102 [GeForce RTX 2080 Ti Rev. A] M 13448 from 140.163.4.231
20:44:45:WU01:FS01:Connecting to 140.163.4.231:8080
20:44:55:Saving configuration to config.xml
20:44:55:<config>
20:44:55: <!-- User Information -->
20:44:55: <team v='245628'/>
20:44:55: <user v='WebMaximus'/>
20:44:55:
20:44:55: <!-- Folding Slots -->
20:44:55: <slot id='0' type='CPU'/>
20:44:55: <slot id='1' type='GPU'/>
20:44:55:</config>
20:45:12:WU01:FS01:Downloading 4.53MiB
20:45:15:WU01:FS01:Download complete
20:45:15:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11748 run:0 clone:3688 gen:18 core:0x22 unit:0x000000208ca304e75e6a7ff30659de17
20:45:15:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
20:45:15:WU01:FS01:Connecting to cores.foldingathome.org:80
20:45:16:WU01:FS01:FahCore 22: Downloading 4.04MiB
20:45:17:WU01:FS01:FahCore 22: Download complete
20:45:18:WU01:FS01:Valid core signature
20:45:18:WU01:FS01:Unpacked 13.49MiB to cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe
20:45:18:WU01:FS01:Starting
20:45:18:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Richard\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 12984 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:45:18:WU01:FS01:Started FahCore on PID 20904
20:45:18:WU01:FS01:Core PID:18388
20:45:18:WU01:FS01:FahCore 0x22 started
20:45:18:WU01:FS01:0x22:*********************** Log Started 2020-03-29T20:45:18Z ***********************
20:45:18:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:45:18:WU01:FS01:0x22: Type: 0x22
20:45:18:WU01:FS01:0x22: Core: Core22
20:45:18:WU01:FS01:0x22: Website: https://foldingathome.org/
20:45:18:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
20:45:18:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:45:18:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
20:45:18:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 20904 -checkpoint 15
20:45:18:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
20:45:18:WU01:FS01:0x22: 0 -gpu 0
20:45:18:WU01:FS01:0x22: Config: <none>
20:45:18:WU01:FS01:0x22:************************************ Build *************************************
20:45:18:WU01:FS01:0x22: Version: 0.0.2
20:45:18:WU01:FS01:0x22: Date: Dec 6 2019
20:45:18:WU01:FS01:0x22: Time: 21:30:31
20:45:18:WU01:FS01:0x22: Repository: Git
20:45:18:WU01:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
20:45:18:WU01:FS01:0x22: Branch: HEAD
20:45:18:WU01:FS01:0x22: Compiler: Visual C++ 2008
20:45:18:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:45:18:WU01:FS01:0x22: Platform: win32 10
20:45:18:WU01:FS01:0x22: Bits: 64
20:45:18:WU01:FS01:0x22: Mode: Release
20:45:18:WU01:FS01:0x22:************************************ System ************************************
20:45:18:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-8086K CPU @ 4.00GHz
20:45:18:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
20:45:18:WU01:FS01:0x22: CPUs: 6
20:45:18:WU01:FS01:0x22: Memory: 31.93GiB
20:45:18:WU01:FS01:0x22:Free Memory: 24.79GiB
20:45:18:WU01:FS01:0x22: Threads: WINDOWS_THREADS
20:45:18:WU01:FS01:0x22: OS Version: 6.2
20:45:18:WU01:FS01:0x22:Has Battery: false
20:45:18:WU01:FS01:0x22: On Battery: false
20:45:18:WU01:FS01:0x22: UTC Offset: 2
20:45:18:WU01:FS01:0x22: PID: 18388
20:45:18:WU01:FS01:0x22: CWD: C:\Users\Richard\AppData\Roaming\FAHClient\work
20:45:18:WU01:FS01:0x22: OS: Windows 10 Pro
20:45:18:WU01:FS01:0x22: OS Arch: AMD64
20:45:18:WU01:FS01:0x22:********************************************************************************
20:45:18:WU01:FS01:0x22:Project: 11748 (Run 0, Clone 3688, Gen 18)
20:45:18:WU01:FS01:0x22:Unit: 0x000000208ca304e75e6a7ff30659de17
20:45:18:WU01:FS01:0x22:Reading tar file core.xml
20:45:18:WU01:FS01:0x22:Reading tar file integrator.xml
20:45:18:WU01:FS01:0x22:Reading tar file state.xml
20:45:18:WU01:FS01:0x22:Reading tar file system.xml
20:45:19:WU01:FS01:0x22:Digital signatures verified
20:45:19:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:45:19:WU01:FS01:0x22:Version 0.0.2
20:45:27:WU01:FS01:0x22:Completed 0 out of 2000000 steps (0%)
20:45:27:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:45:29:FS01:Shutting core down
20:45:29:WU01:FS01:0x22:WARNING:Console control signal 1 on PID 18388
20:45:29:WU01:FS01:0x22:Exiting, please wait. . .
20:45:29:WU01:FS01:0x22:Folding@home Core Shutdown: INTERRUPTED
20:45:29:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
20:45:36:WU01:FS01:Starting
20:45:36:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Richard\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 12984 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
20:45:36:WU01:FS01:Started FahCore on PID 10060
20:45:36:WU01:FS01:Core PID:16536
20:45:36:WU01:FS01:FahCore 0x22 started
20:45:36:WU01:FS01:0x22:*********************** Log Started 2020-03-29T20:45:36Z ***********************
20:45:36:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
20:45:36:WU01:FS01:0x22: Type: 0x22
20:45:36:WU01:FS01:0x22: Core: Core22
20:45:36:WU01:FS01:0x22: Website: https://foldingathome.org/
20:45:36:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
20:45:36:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
20:45:36:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
20:45:36:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 10060 -checkpoint 15
20:45:36:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
20:45:36:WU01:FS01:0x22: 0 -gpu 0
20:45:36:WU01:FS01:0x22: Config: <none>
20:45:36:WU01:FS01:0x22:************************************ Build *************************************
20:45:36:WU01:FS01:0x22: Version: 0.0.2
20:45:36:WU01:FS01:0x22: Date: Dec 6 2019
20:45:36:WU01:FS01:0x22: Time: 21:30:31
20:45:36:WU01:FS01:0x22: Repository: Git
20:45:36:WU01:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
20:45:36:WU01:FS01:0x22: Branch: HEAD
20:45:36:WU01:FS01:0x22: Compiler: Visual C++ 2008
20:45:36:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:45:36:WU01:FS01:0x22: Platform: win32 10
20:45:36:WU01:FS01:0x22: Bits: 64
20:45:36:WU01:FS01:0x22: Mode: Release
20:45:36:WU01:FS01:0x22:************************************ System ************************************
20:45:36:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i7-8086K CPU @ 4.00GHz
20:45:36:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
20:45:36:WU01:FS01:0x22: CPUs: 6
20:45:36:WU01:FS01:0x22: Memory: 31.93GiB
20:45:36:WU01:FS01:0x22:Free Memory: 24.80GiB
20:45:36:WU01:FS01:0x22: Threads: WINDOWS_THREADS
20:45:36:WU01:FS01:0x22: OS Version: 6.2
20:45:36:WU01:FS01:0x22:Has Battery: false
20:45:36:WU01:FS01:0x22: On Battery: false
20:45:36:WU01:FS01:0x22: UTC Offset: 2
20:45:36:WU01:FS01:0x22: PID: 16536
20:45:36:WU01:FS01:0x22: CWD: C:\Users\Richard\AppData\Roaming\FAHClient\work
20:45:36:WU01:FS01:0x22: OS: Windows 10 Pro
20:45:36:WU01:FS01:0x22: OS Arch: AMD64
20:45:36:WU01:FS01:0x22:********************************************************************************
20:45:36:WU01:FS01:0x22:Project: 11748 (Run 0, Clone 3688, Gen 18)
20:45:36:WU01:FS01:0x22:Unit: 0x000000208ca304e75e6a7ff30659de17
20:45:36:WU01:FS01:0x22:Digital signatures verified
20:45:36:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
20:45:36:WU01:FS01:0x22:Version 0.0.2
20:45:39:WU01:FS01:0x22:Completed 0 out of 2000000 steps (0%)
20:45:39:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
20:45:44:WU00:FS00:Connecting to 65.254.110.245:8080
20:45:45:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:45:45:WU00:FS00:Connecting to 18.218.241.186:80
20:45:45:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:45:45:ERROR:WU00:FS00:Exception: Could not get an assignment
20:45:56:Saving configuration to config.xml
20:45:56:<config>
20:45:56: <!-- Slot Control -->
20:45:56: <power v='FULL'/>
20:45:56:
20:45:56: <!-- User Information -->
20:45:56: <team v='245628'/>
20:45:56: <user v='WebMaximus'/>
20:45:56:
20:45:56: <!-- Folding Slots -->
20:45:56: <slot id='0' type='CPU'/>
20:45:56: <slot id='1' type='GPU'/>
20:45:56:</config>
20:46:12:WU01:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
20:46:45:WU01:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
20:46:55:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:47:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:47:19:WU01:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
20:47:21:WU00:FS00:Connecting to 65.254.110.245:8080
20:47:22:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:47:22:WU00:FS00:Connecting to 18.218.241.186:80
20:47:22:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:47:22:ERROR:WU00:FS00:Exception: Could not get an assignment
20:47:52:WU01:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
20:48:26:WU01:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
20:49:00:WU01:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
20:49:34:WU01:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
20:49:58:WU00:FS00:Connecting to 65.254.110.245:8080
20:49:59:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:49:59:WU00:FS00:Connecting to 18.218.241.186:80
20:49:59:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:49:59:ERROR:WU00:FS00:Exception: Could not get an assignment
20:50:09:WU01:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
20:50:42:WU01:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
20:51:15:WU01:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
20:51:49:WU01:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
20:52:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:52:22:WU01:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
20:52:37:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
20:52:57:WU01:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
20:53:30:WU01:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
20:54:03:WU01:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
20:54:09:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
20:54:13:WU00:FS00:Connecting to 65.254.110.245:8080
20:54:13:WU00:FS00:Assigned to work server 13.82.98.119
20:54:13:WU00:FS00:Requesting new work unit for slot 00: READY cpu:5 from 13.82.98.119
20:54:13:WU00:FS00:Connecting to 13.82.98.119:8080
20:54:14:ERROR:WU00:FS00:Exception: Server did not assign work unit
20:54:37:WU01:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
20:55:09:WU01:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
20:55:43:WU01:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
20:56:16:WU01:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
20:56:48:WU01:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
20:57:22:WU01:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
20:57:55:WU01:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
20:58:28:WU01:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
20:59:01:WU01:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
20:59:33:WU01:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
21:00:07:WU01:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
21:00:40:WU01:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
21:01:04:WU00:FS00:Connecting to 65.254.110.245:8080
21:01:04:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:01:04:WU00:FS00:Connecting to 18.218.241.186:80
21:01:05:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:01:05:ERROR:WU00:FS00:Exception: Could not get an assignment
21:01:14:WU01:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
21:01:46:WU01:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
21:02:19:WU01:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
21:02:52:WU01:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
21:03:25:WU01:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
21:03:59:WU01:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
21:04:31:WU01:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
21:05:04:WU01:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
21:05:37:WU01:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
21:06:10:WU01:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
21:06:44:WU01:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
21:07:17:WU01:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
21:07:51:WU01:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
21:08:25:WU01:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
21:08:59:WU01:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
21:09:34:WU01:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
21:10:09:WU01:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
21:10:44:WU01:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
21:11:20:WU01:FS01:0x22:Completed 920000 out of 2000000 steps (46%)
21:11:54:WU01:FS01:0x22:Completed 940000 out of 2000000 steps (47%)
21:12:09:WU00:FS00:Connecting to 65.254.110.245:8080
21:12:10:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:12:10:WU00:FS00:Connecting to 18.218.241.186:80
21:12:10:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:12:10:ERROR:WU00:FS00:Exception: Could not get an assignment
21:12:30:WU01:FS01:0x22:Completed 960000 out of 2000000 steps (48%)
21:13:04:WU01:FS01:0x22:Completed 980000 out of 2000000 steps (49%)
21:13:38:WU01:FS01:0x22:Completed 1000000 out of 2000000 steps (50%)
21:14:13:WU01:FS01:0x22:Completed 1020000 out of 2000000 steps (51%)
21:14:46:WU01:FS01:0x22:Completed 1040000 out of 2000000 steps (52%)
21:15:22:WU01:FS01:0x22:Completed 1060000 out of 2000000 steps (53%)
21:15:56:WU01:FS01:0x22:Completed 1080000 out of 2000000 steps (54%)
21:16:29:WU01:FS01:0x22:Completed 1100000 out of 2000000 steps (55%)
21:17:04:WU01:FS01:0x22:Completed 1120000 out of 2000000 steps (56%)
21:17:38:WU01:FS01:0x22:Completed 1140000 out of 2000000 steps (57%)
21:18:13:WU01:FS01:0x22:Completed 1160000 out of 2000000 steps (58%)
21:18:48:WU01:FS01:0x22:Completed 1180000 out of 2000000 steps (59%)
21:19:23:WU01:FS01:0x22:Completed 1200000 out of 2000000 steps (60%)
21:19:58:WU01:FS01:0x22:Completed 1220000 out of 2000000 steps (61%)
21:20:31:WU01:FS01:0x22:Completed 1240000 out of 2000000 steps (62%)
21:21:06:WU01:FS01:0x22:Completed 1260000 out of 2000000 steps (63%)
21:21:39:WU01:FS01:0x22:Completed 1280000 out of 2000000 steps (64%)
21:22:13:WU01:FS01:0x22:Completed 1300000 out of 2000000 steps (65%)
21:22:49:WU01:FS01:0x22:Completed 1320000 out of 2000000 steps (66%)
21:23:22:WU01:FS01:0x22:Completed 1340000 out of 2000000 steps (67%)
21:23:57:WU01:FS01:0x22:Completed 1360000 out of 2000000 steps (68%)
21:24:31:WU01:FS01:0x22:Completed 1380000 out of 2000000 steps (69%)
21:25:05:WU01:FS01:0x22:Completed 1400000 out of 2000000 steps (70%)
21:25:40:WU01:FS01:0x22:Completed 1420000 out of 2000000 steps (71%)
21:26:14:WU01:FS01:0x22:Completed 1440000 out of 2000000 steps (72%)
21:26:50:WU01:FS01:0x22:Completed 1460000 out of 2000000 steps (73%)
21:27:24:WU01:FS01:0x22:Completed 1480000 out of 2000000 steps (74%)
21:27:59:WU01:FS01:0x22:Completed 1500000 out of 2000000 steps (75%)
21:28:34:WU01:FS01:0x22:Completed 1520000 out of 2000000 steps (76%)
21:29:09:WU01:FS01:0x22:Completed 1540000 out of 2000000 steps (77%)
21:29:44:WU01:FS01:0x22:Completed 1560000 out of 2000000 steps (78%)
21:30:06:WU00:FS00:Connecting to 65.254.110.245:8080
21:30:07:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:30:07:WU00:FS00:Connecting to 18.218.241.186:80
21:30:07:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:30:07:ERROR:WU00:FS00:Exception: Could not get an assignment
21:30:18:WU01:FS01:0x22:Completed 1580000 out of 2000000 steps (79%)
21:30:52:WU01:FS01:0x22:Completed 1600000 out of 2000000 steps (80%)
21:31:27:WU01:FS01:0x22:Completed 1620000 out of 2000000 steps (81%)
21:32:01:WU01:FS01:0x22:Completed 1640000 out of 2000000 steps (82%)
21:32:37:WU01:FS01:0x22:Completed 1660000 out of 2000000 steps (83%)
21:33:11:WU01:FS01:0x22:Completed 1680000 out of 2000000 steps (84%)
21:33:46:WU01:FS01:0x22:Completed 1700000 out of 2000000 steps (85%)
21:34:21:WU01:FS01:0x22:Completed 1720000 out of 2000000 steps (86%)
