I just setup F@H on my main computer and also wanted to set it up on my Dual Xeon Server.
It runs a minimal CentOS, I installed it the way the documentation explains it.
Here is my /etc/fahclient/config.xml:
<config>
<gpu v='false'/>
<!-- Slot Control -->
<power v='full'/>
<!-- User Information -->
<passkey v='XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX'/>
<team v='223518'/>
<user v='atlas'/>
<!-- Folding Slots -->
<slot id='0' type='CPU'/>
<allow>127.0.0.1 192.168.178.29</allow>
</config>I then tried to connect my control on my main PC which is 192.168.178.29.
The firewall is disabled and I can see the open Port on netstat. I can also connect via telnet on the port.
I can add it into my Control, and when I'm not on it, it says Status = online.
But when I click on it to see what it's doing, it changes to "Updating" and I can't see anything.
Also, when I add <web-allow>127.0.0.1 192.168.178.29</web-allow> to my config, it won't start at all, no errors in the log, so I can't check what its doing from the web interface.
Hopefully some of you know how to fix it.
