problems with amd ryzen 1700
nuty111
Post by nuty111 »
Hi i have ryzen 1700 (8 core 16 threads 3.8ghz) it works fine for a minute but then just freezes and i have to restart PC. I did some testing to be sure its not processors fault and my overclocking so im pretty sure that's client side error. Also FAHcontrol does not recognize my pc it just says `CPU 15' instead of its name. I tried some mining before as well and it worked well.
jonault
Re: problems with amd ryzen 1700
Post by jonault »
The clients don't identify any of my CPUs either. I think that they don't actually care what model CPU you have, just how many threads you can run (which in your case is 15).
You should post your log file, there might be some useful error messages in there. Sure sounds like overheating to me, but it could be something else.
First guess
* FAH expects to run continuously at 100% cpu so can generate a lot of heat. That may be more than your fan can dissipate. As it heats up, the machine shuts down to prevent if from being damaged by the temperature rise. Mining also runs at 100% CPU but it generally doesn't generate as much heat.
Is the folding power slider set to Full, Medium, or Light?
Near the bottom of the System Info tab, what does it say about GPUs.
nuty111
Post by nuty111 »
bruce wrote:First guess
GPUS are fine. the only thing it does not find as much jobs ... i have rx 580 and then the log says :
'`13:30:13:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration``
now CPU does not overheat as i sayd earlier ive tested the temps voltage and put it on stress test was no errors. so my screen just freezes on 10% of job done any ideas how to fix this?
here is the full log
*********************** Log Started 2020-03-22T22:23:57Z ***********************
22:23:57:************************* Folding@home Client *************************
22:23:57:        Website: https://foldingathome.org/
22:23:57:      Copyright: (c) 2009-2018 foldingathome.org
22:23:57:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:23:57:           Args: --open-web-control
22:23:57:         Config: <none>
22:23:57:******************************** Build ********************************
22:23:57:        Version: 7.5.1
22:23:57:           Date: May 11 2018
22:23:57:           Time: 13:06:32
22:23:57:     Repository: Git
22:23:57:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
22:23:57:         Branch: master
22:23:57:       Compiler: Visual C++ 2008
22:23:57:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:23:57:       Platform: win32 10
22:23:57:           Bits: 32
22:23:57:           Mode: Release
22:23:57:******************************* System ********************************
22:23:57:            CPU: AMD Ryzen 7 1700 Eight-Core Processor
22:23:57:         CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
22:23:57:           CPUs: 16
22:23:57:         Memory: 15.95GiB
22:23:57:    Free Memory: 12.41GiB
22:23:57:        Threads: WINDOWS_THREADS
22:23:57:     OS Version: 6.2
22:23:57:    Has Battery: false
22:23:57:     On Battery: false
22:23:57:     UTC Offset: 0
22:23:57:            PID: 3028
22:23:57:            CWD: C:\Users\nuty\AppData\Roaming\FAHClient
22:23:57:             OS: Windows 10 Enterprise
22:23:57:        OS Arch: AMD64
22:23:57:           GPUs: 0
22:23:57:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
22:23:57:                 specified module could not be found.
22:23:57:
22:23:57:OpenCL Device 0: Platform:0 Device:0 Bus:6 Slot:0 Compute:1.2 Driver:3004.8
22:23:57:  Win32 Service: false
22:23:57:***********************************************************************
22:23:57:<config>
22:23:57:  <!-- Folding Slots -->
22:23:57:</config>
22:23:57:Connecting to assign1.foldingathome.org:8080
22:23:57:Updated GPUs.txt
22:23:57:Read GPUs.txt
22:23:57:Trying to access database...
22:23:57:Successfully acquired database lock
22:23:57:Enabled folding slot 00: PAUSED cpu:14 (not configured)
22:23:57:Enabled folding slot 01: PAUSED gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] (not configured)
22:24:00:13:127.0.0.1:New Web connection
22:24:37:Set client configured
22:24:37:WU00:FS00:Connecting to 65.254.110.245:8080
22:24:38:WU01:FS01:Connecting to 65.254.110.245:8080
22:24:38:WU00:FS00:Connecting to 65.254.110.245:8080
22:24:38:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:24:38:WU00:FS00:Connecting to 18.218.241.186:80
22:24:39:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:24:39:ERROR:WU00:FS00:Exception: Could not get an assignment
22:24:39:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:24:39:WU01:FS01:Connecting to 18.218.241.186:80
22:24:39:WU00:FS00:Connecting to 65.254.110.245:8080
22:24:39:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:24:39:WU00:FS00:Connecting to 18.218.241.186:80
22:24:39:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:24:39:ERROR:WU01:FS01:Exception: Could not get an assignment
22:24:39:WU01:FS01:Connecting to 65.254.110.245:8080
22:24:40:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:24:40:WU01:FS01:Connecting to 18.218.241.186:80
22:24:40:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:24:40:ERROR:WU01:FS01:Exception: Could not get an assignment
22:24:58:Saving configuration to config.xml
22:24:58:<config>
22:24:58:  <!-- User Information -->
22:24:58:  <user v='nuty'/>
22:24:58:
22:24:58:  <!-- Folding Slots -->
22:24:58:  <slot id='0' type='CPU'/>
22:24:58:  <slot id='1' type='GPU'/>
22:24:58:</config>
22:25:39:WU00:FS00:Connecting to 65.254.110.245:8080
22:25:39:WU01:FS01:Connecting to 65.254.110.245:8080
22:25:40:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:25:40:WU01:FS01:Connecting to 18.218.241.186:80
22:25:40:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:25:40:ERROR:WU01:FS01:Exception: Could not get an assignment
22:25:43:WU00:FS00:Assigned to work server 155.247.164.213
22:25:43:WU00:FS00:Requesting new work unit for slot 00: READY cpu:15 from 155.247.164.213
22:25:43:WU00:FS00:Connecting to 155.247.164.213:8080
22:25:44:WU00:FS00:Downloading 1.24MiB
22:25:44:WU00:FS00:Download complete
22:25:45:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14308 run:0 clone:173 gen:28 core:0xa7 unit:0x0000001f9bf7a4d55e66c4619d41404b
22:25:45:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
22:25:45:WU00:FS00:Connecting to cores.foldingathome.org:80
22:25:45:WU00:FS00:FahCore a7: Downloading 6.71MiB
22:25:47:WU00:FS00:FahCore a7: Download complete
22:25:47:WU00:FS00:Valid core signature
22:25:47:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
22:25:47:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
22:25:47:WU00:FS00:Starting
22:25:47:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\nuty\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 3028 -checkpoint 15 -np 15
22:25:47:WU00:FS00:Started FahCore on PID 5972
22:25:48:WU00:FS00:Core PID:7344
22:25:48:WU00:FS00:FahCore 0xa7 started
22:25:48:WU00:FS00:0xa7:*********************** Log Started 2020-03-22T22:25:48Z ***********************
22:25:48:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
22:25:48:WU00:FS00:0xa7:       Type: 0xa7
22:25:48:WU00:FS00:0xa7:       Core: Gromacs
22:25:48:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 5972 -checkpoint 15 -np
22:25:48:WU00:FS00:0xa7:             15
22:25:48:WU00:FS00:0xa7:************************************ CBang *************************************
22:25:48:WU00:FS00:0xa7:       Date: Oct 26 2019
22:25:48:WU00:FS00:0xa7:       Time: 01:38:25
22:25:48:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
22:25:48:WU00:FS00:0xa7:     Branch: master
22:25:48:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
22:25:48:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
22:25:48:WU00:FS00:0xa7:   Platform: win32 10
22:25:48:WU00:FS00:0xa7:       Bits: 64
22:25:48:WU00:FS00:0xa7:       Mode: Release
22:25:48:WU00:FS00:0xa7:************************************ System ************************************
22:25:48:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 1700 Eight-Core Processor
22:25:48:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
22:25:48:WU00:FS00:0xa7:       CPUs: 16
22:25:48:WU00:FS00:0xa7:     Memory: 15.95GiB
22:25:48:WU00:FS00:0xa7:Free Memory: 12.53GiB
22:25:48:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
22:25:48:WU00:FS00:0xa7: OS Version: 6.2
22:25:48:WU00:FS00:0xa7:Has Battery: false
22:25:48:WU00:FS00:0xa7: On Battery: false
22:25:48:WU00:FS00:0xa7: UTC Offset: 0
22:25:48:WU00:FS00:0xa7:        PID: 7344
22:25:48:WU00:FS00:0xa7:        CWD: C:\Users\nuty\AppData\Roaming\FAHClient\work
22:25:48:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
22:25:48:WU00:FS00:0xa7:    Version: 0.0.18
22:25:48:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:25:48:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
22:25:48:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
22:25:48:WU00:FS00:0xa7:       Time: 01:52:30
22:25:48:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
22:25:48:WU00:FS00:0xa7:************************************ Build *************************************
22:25:48:WU00:FS00:0xa7:       SIMD: avx_256
22:25:48:WU00:FS00:0xa7:********************************************************************************
22:25:48:WU00:FS00:0xa7:Project: 14308 (Run 0, Clone 173, Gen 28)
22:25:48:WU00:FS00:0xa7:Unit: 0x0000001f9bf7a4d55e66c4619d41404b
22:25:48:WU00:FS00:0xa7:Reading tar file core.xml
22:25:48:WU00:FS00:0xa7:Reading tar file frame28.tpr
22:25:48:WU00:FS00:0xa7:Digital signatures verified
22:25:48:WU00:FS00:0xa7:Calling: mdrun -s frame28.tpr -o frame28.trr -cpt 15 -nt 15
22:25:48:WU00:FS00:0xa7:Steps: first=14000000 total=500000
22:25:49:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
22:25:59:Saving configuration to config.xml
22:25:59:<config>
22:25:59:  <!-- Slot Control -->
22:25:59:  <power v='FULL'/>
22:25:59:
22:25:59:  <!-- User Information -->
22:25:59:  <user v='nuty'/>
22:25:59:
22:25:59:  <!-- Folding Slots -->
22:25:59:  <slot id='0' type='CPU'/>
22:25:59:  <slot id='1' type='GPU'/>
22:25:59:</config>
22:26:16:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
22:26:46:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
22:27:15:WU00:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
22:27:17:WU01:FS01:Connecting to 65.254.110.245:8080
22:27:17:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:27:17:WU01:FS01:Connecting to 18.218.241.186:80
22:27:18:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:27:18:ERROR:WU01:FS01:Exception: Could not get an assignment
22:27:45:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
22:28:00:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
22:28:16:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
22:28:46:WU00:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
Roadpower
Post by Roadpower »
I would look at F@H as a stress test, if your system is consistently failing on it you have found a stress test that has exposed an issue. IE your other stress test is not exposing the issue while F@H is. In my case I pretty poor at figuring my way around a *nix system and because of this I have had no success getting my RX480 working for F@H and frankly I have given up trying. However my Ryzen3700X works fine, it just rarely gets jobs to do because most of the WU's don't want a CPU, they want a GPU.
(Just for clarity I switched to *nix around the turn of the year because of support for Windows Seven was discontinued and I will NOT under any circumstance use Windows 10. So while I'm a long time computer hobbyist, I'm not competent for the meat and bones of a *nix platform)
Back to the 3700X. I'm a very long time PC builder, some of the things I've always banged on about was stress testing during the build and system stability is first and foremost. Because of this mindset and experience I do not overclock and I do everything I can to keep heat at the lowest possible levels. So last week when the Prism cooler allowed the 3700X to get to 168F (or about 78C) during folding I immediately ordered a better (Noctua) cooler. Keep in mind that these temps are well below AMD's documented limit of 95C. I however do not want thermal cycling that comes anywhere near thermal limits.
Another thing to keep in mind that stress tests can also expose a poor or under spec'd PSU. Admittedly much more likely with a GPU under load than a CPU under load. From what I understand of your case you should probably experiment with default (not overclocked) settings or small voltage adjustments.
