connection timed out
I am installed on a MacPro running sierra, installation was fine. when I run the web control it just keeps saying client connection timed out. It says the FAH control is online it has attempted 9 times and has been on for at least 2 hours with no change. Any ideas?
Re: connection timed out
here is the log.*********************** Log Started 2020-03-22T21:47:28Z ***********************
21:47:28:************************* Folding@home Client *************************
21:47:28: Website: https://foldingathome.org/
21:47:28: Copyright: (c) 2009-2018 foldingathome.org
21:47:28: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:47:28: Args:
21:47:28: Config: /Library/Application Support/FAHClient/config.xml
21:47:28:******************************** Build ********************************
21:47:28: Version: 7.5.1
21:47:28: Date: May 11 2018
21:47:28: Time: 12:57:01
21:47:28: Repository: Git
21:47:28: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
21:47:28: Branch: master
21:47:28: Compiler: GNU 4.2.1 Compatible Apple LLVM 7.3.0 (clang-703.0.31)
21:47:28: Options: -std=gnu++98 -O3 -funroll-loops -mmacosx-version-min=10.6
21:47:28: -Wno-unused-local-typedefs
21:47:28: Platform: darwin 15.6.0
21:47:28: Bits: 64
21:47:28: Mode: Release
21:47:28:******************************* System ********************************
21:47:28: CPU: Intel(R) Xeon(R) CPU X5472 @ 3.00GHz
21:47:28: CPU ID: GenuineIntel Family 6 Model 23 Stepping 6
21:47:28: CPUs: 8
21:47:28: Memory: 16.00GiB
21:47:28:Free Memory: 1.77GiB
21:47:28: Threads: POSIX_THREADS
21:47:28: OS Version: 10.12
21:47:28:Has Battery: false
21:47:28: On Battery: false
21:47:28: UTC Offset: 0
21:47:28: PID: 3896
21:47:28: CWD: /Library/Application Support/FAHClient
21:47:28: OS: Darwin 16.7.0 x86_64
21:47:28: OS Arch: AMD64
21:47:28: GPUs: 1
21:47:28: GPU 0: Bus:2 Slot:0 Func:0 NVIDIA:1 G96 [GeForce 9500 GT]
21:47:28: CUDA: Not detected: Failed to open dynamic library 'libcuda.dylib':
21:47:28: dlopen(libcuda.dylib, 1): image not found
21:47:28: OpenCL: Not detected: Failed to open dynamic library 'libOpenCL.dylib':
21:47:28: dlopen(libOpenCL.dylib, 1): image not found
21:47:28:***********************************************************************
21:47:28:<config>
21:47:28: <!-- Network -->
21:47:28: <proxy v=':8080'/>
21:47:28:
21:47:28: <!-- User Information -->
21:47:28: <user v='MattBlack'/>
21:47:28:
21:47:28: <!-- Folding Slots -->
21:47:28: <slot id='0' type='CPU'/>
21:47:28:</config>
21:47:28:Trying to access database...
21:47:28:Successfully acquired database lock
21:47:28:Enabled folding slot 00: READY cpu:7
21:47:29:WU00:FS00:Connecting to 65.254.110.245:8080
21:47:30:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:47:30:WU00:FS00:Connecting to 18.218.241.186:80
21:47:31:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:47:31:ERROR:WU00:FS00:Exception: Could not get an assignment
21:47:31:WU00:FS00:Connecting to 65.254.110.245:8080
21:47:31:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:47:31:WU00:FS00:Connecting to 18.218.241.186:80
21:47:32:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:47:32:ERROR:WU00:FS00:Exception: Could not get an assignment
21:48:31:WU00:FS00:Connecting to 65.254.110.245:8080
21:48:31:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:48:31:WU00:FS00:Connecting to 18.218.241.186:80
21:48:32:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:48:32:ERROR:WU00:FS00:Exception: Could not get an assignment
21:50:08:WU00:FS00:Connecting to 65.254.110.245:8080
21:50:09:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:50:09:WU00:FS00:Connecting to 18.218.241.186:80
21:50:09:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:50:09:ERROR:WU00:FS00:Exception: Could not get an assignment
21:52:45:WU00:FS00:Connecting to 65.254.110.245:8080
21:52:46:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:52:46:WU00:FS00:Connecting to 18.218.241.186:80
21:52:46:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:52:46:ERROR:WU00:FS00:Exception: Could not get an assignment
21:57:00:WU00:FS00:Connecting to 65.254.110.245:8080
21:57:00:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
21:57:00:WU00:FS00:Connecting to 18.218.241.186:80
21:57:01:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
21:57:01:ERROR:WU00:FS00:Exception: Could not get an assignment
22:03:51:WU00:FS00:Connecting to 65.254.110.245:8080
22:03:52:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:03:52:WU00:FS00:Connecting to 18.218.241.186:80
22:03:52:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:03:52:ERROR:WU00:FS00:Exception: Could not get an assignment
22:14:57:WU00:FS00:Connecting to 65.254.110.245:8080
22:14:57:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:14:57:WU00:FS00:Connecting to 18.218.241.186:80
22:14:58:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:14:58:ERROR:WU00:FS00:Exception: Could not get an assignment
22:32:54:WU00:FS00:Connecting to 65.254.110.245:8080
22:32:54:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
22:32:54:WU00:FS00:Connecting to 18.218.241.186:80
22:32:54:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
22:32:54:ERROR:WU00:FS00:Exception: Could not get an assignment
23:01:56:WU00:FS00:Connecting to 65.254.110.245:8080
23:01:56:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:01:56:WU00:FS00:Connecting to 18.218.241.186:80
23:01:57:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:01:57:ERROR:WU00:FS00:Exception: Could not get an assignment
21:47:28: Args:
21:47:28: Bits: 64
21:47:28: CPUs: 8
21:47:28: PID: 3896
21:47:28: GPUs: 1
21:47:28:<config>
21:47:28:
21:47:28:
21:47:28:</config>
I have found on my Mac using Safari I need to change the Web Control URL from https to http and refresh a time or two if that has caused any issues.
As for getting a WU, the turnout has been overwhelming and the servers can not keep up with all of the request for work. It may take a while, but eventually you should get an assignment.
