Starting with the back story:
I built a few mining rigs during the ethereum bubble with the plans of turning them to folding when the bubble popped. Well the bubble popped a while ago and the rigs have been collecting dust. They double as the winter heat source for my garage, and I have some garage projects to do now. So, it was time to get these up and running. Some comments on the hardware selection ... I won't be running any CPU folding on these machines as you can see the CPU is woefully under spec for managing 6 GPUs and doing anything else. These rigs will focus on folding with the GPUs only.
Common Hardware:
- Motherboard: Biostar H110M-BTC
CPU: Celeron G3930
Ram: 8 GB DDR4
HDD: 500 GB, 7200 RPM, SATA
PowerSupply: 1000W ATX
Case: Open Frame
- PCIe: 1x to 16x Risers with Power Connections
AMD: RX 580
nvidia: GTX 1060
Being that my rigs run with no display and no keyboard, I will be using a second machine to run FAHControl and SSH to access the terminal. For this write-up I'm using an iMac as my support machine. The specs on this machine are not critical as it won't be doing the heavy lifting.
Hardware/BIOS Pre-Installation Setup:
To ensure minimal challenges during setup, I installed all the Common Hardware, but no PCIe risers or GPUs. I am using the on motherboard HDMI connection to the Integrated GPU (Intel HD Graphics) as the display connection for setup. This allows me to get into the BIOS and perform initial setup. I recommend resetting the BIOS to factory defaults before the start of any new build, then adjust the settings needed to support your setup. For this board there are specific items that need to be set, and some optional items that may help as well. Biostar has a mining mode that needs to be enable to properly allocate PCIe lanes to support more than 4 GPUs. I recommend forcing the integrated graphics to be the primary display and force it to enabled; this gives a default target for the OS without bothering your compute GPUs. Optionally, you can disable the onboard sound and serial port controller since we won't be needing them. You can also enable smart CPU fan control so it isn't on all the time and calibrate the speed controller.
Once the BIOS display settings are configured, you can add ONE PCIe riser and GPU to the system. This will give you all the hardware you need for a successful install, without any additional surprises. Once the machine is up and healthy, adding more GPUs is pretty easy. Don't forget to connect the network cable to your router before you proceed with the OS install, it will download updates if needed along the way.
OS Selection and Install:
Ubuntu has been my goto Linux distro for years. It is also supported by the Folding@Home client. Additionally, AMD has drivers for Ubuntu 18.04. Being these machine don't typically have a monitor hooked up, the server version of Ubuntu will do nicely. There is a newer release of Ubuntu available, but it may not have the software and/or driver support needed. So, unless you just really enjoy a challenge, it's best to stick with the officially supported release.
Download Ubuntu Server 18.04 LTS: https://ubuntu.com/download/server
Put this onto a USB Flash drive to use it as the install media. Windows example: https://ubuntu.com/tutorials/tutorial-c ... 1-overview
- During setup you can use the default options for pretty much everything. I would suggest installing openSSH so you can remotely login in and check on the rig later.
Make sure you remember the username and password you choose! You will need it multiple times throughout this process.
Ubuntu Server Installation Guide can be found here: https://ubuntu.com/tutorials/tutorial-i ... 1-overview
You can find the ip address of your new Ubuntu Server by typing "ifconfig" at the terminal. It will give you more information than you need. It should show two adapters; "lo" is the loopback and should be 127.0.0.1; the other adapter should be your ethernet connection. The inet address is the ip address you need to use to access the machine remotely. In the example below you can see mine is "192.168.1.101" You should see something like this come back:
enp2s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.101 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::ba97:5aff:fef9:c699 prefixlen 64 scopeid 0x20<link>
ether b8:97:5a:f9:c6:99 txqueuelen 1000 (Ethernet)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
SSH <user>@192.168.1.101
We will need a way to keep an eye on temperatures. For AMD cards you can see core voltages and fan speeds in the sensors tool. For nvidia cards I will be using nvidia-smi (installed with the drivers later) to watch fan speeds and temperatures. Since my CPUs won't be folding, I'm not too worried about temperatures there.
Install lm-sensors and scan for hardware:
sudo apt install lm-sensors
sudo sensors-detect
sensors
nvidia drivers for opencl are available in a few different locations. The method below worked for me first shot, so I didn't try any of the others.
Add the PPA Graphics Drivers Repository:
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt-get install dkms build-essential
sudo apt-get update
sudo apt list nvidia-driver*
sudo apt install nvidia-driver-440
I used the official AMD drivers available here: https://www.amd.com/en/support/graphics ... eon-rx-580
AMD has a nice writeup to help guide the install: https://amdgpu-install.readthedocs.io/en/latest/
One challenge I ran into here was getting the file onto my Ubuntu Server rig. The path provided by the AMD site is not directly accessible. I downloaded the file and moved it to my rig using a flash drive.
Once the file was on the rig can can unpack the files as instructed by AMD using:
tar -Jxvf amdgpu-pro-YY.XX-NNNNNN.tar.xz
./amdgpu-pro-install -y --opencl=legacy --headless
You may be able to skip this step on some combinations of hardware and drivers, but I found it doesn't hurt anything to have it just in case.
CLinfo will allow you to verify the drivers installed for your cards can actually run OpenCL content.
Install and run CLinfo:
sudo apt install clinfo
clinfo
You can run:
clinfo | grep "Platform Version"
Platform Version OpenCL 2.1 AMD-APP (3004.6)
sudo shutdown -r now
I was having some serious PCIe errors at this point in my setup. After doing some research, I decided the errors were harmless. However, I didn't want the additional overhead of logging thousands of errors.
I modified my grub to disable Advanced Error Reporting to hide these from the log file and reduce system overhead.
Be careful on these next steps, it can stop your rig from booting at all if you type something incorrectly.
You can edit your grub file by using:
sudo nano /etc/default/grub
You will need to add "pci=noaer" to your linux boot lines as shown here:
GRUB_CMDLINE_LINUX_DEFAULT="pci=noaer"
GRUB_CMDLINE_LINUX="pci=noaer"
Once the File is saved you need to update GRUB with the new config by:
sudo update-grub
Download the most recent release:
wget https://download.foldingathome.org/releases/public/release/fahclient/debian-stable-64bit/v7.5/fahclient_7.5.1_amd64.deb
Be sure to specify your Folding Username, Team, etc. during setup ...
sudo dpkg -i fahclient_7.5.1_amd64.deb
sudo wget https://apps.foldingathome.org/GPUs.txt -P /var/lib/fahclient/
I did install the Folding@Home package on my iMac so I could use the FAHControl panel to remotely monitor my rigs. For Windows and Mac these come as one package, unlike the Linus releases.
You can find all the available versions here for your support machine: https://foldingathome.org/alternative-downloads/
AMD Only: Fixing openCL Access:
The nvidia install seems happy to share it's openCL drivers. However, the AMD drivers are restricted to a different user/group than fahclient.
Currently, I worked around this by changing fahclient to run as root. This is acceptable to me on this dedicated folding rig. If you are installing this on a daily use Ubuntu rig, I would look for other solutions. The gap here is just access to the openCL drivers during boot up. Once the rig is up it seems to be able to figure it out, but requires other work arounds.
To run FAHClient as root you need to edit the init.d file:
sudo nano /etc/init.d/FAHClient
It should look like this:
USER=root
htop
To make entering the PassKey easier and adjusting other settings simpler, you can enable remote access and remote web.
You need to edit the FAHClient config file first. Use this command to open your config file for editing:
sudo nano /etc/fahclient/config.xml
Be sure to remove the line that says something like "gpu v='false'''
It will have some items in it already, but you can remove/add lines look like this:
<config>
<!-- Client Control -->
<fold-anon v='true'/>
<!-- HTTP Server -->
<allow v='192.168.1.0/24'/>
<!-- Network -->
<proxy v=':8080'/>
<!-- Remote Command Server -->
<command-allow-no-pass v='192.168.1.0/24'/>
<!-- Slot Control -->
<power v='full'/>
<!-- User Information -->
<user v='BJMcGee'/>
<!-- Folding Slots -->
<slot id='0' type='CPU'/>
</config>
You can stop the client using:
sudo /etc/init.d/FAHClient stop
sudo /etc/init.d/FAHClient start
Stop Folding on Your Support Machine:
My iMac is not very power efficient for folding, and spends most of its time off. When it is on, it's already running hot due to its age. So, to avoid any undue stress on this old machine, I've stopped the local machine from folding. If you have a gaming rig with a newer CPU and a powerful GPU, you can keep folding on your support rig and make an even bigger contribution.
Add Your Folding Rigs to your FAHControl:
Use the "+Add" button at the bottom of the client list window to add your remote rigs (your local client is already added). The port should be default. You can name them however you want to keep track of which is which. Just enter the correct ip address for the rig to get it connected. Once the rig is connected, you can click on it in the client list and click the "Configure" button on the menu bar. You should see Tabs for: Connection, Identity, Slots, Remote Access, Proxy, Advanced and Expert.
On the Identity Tab make sure your Name is correct. You can choose any name, but you might want to check the F@H site to make sure your name isn't taken already, or you'll be giving your points to someone else.
You can search for stats by Donor name here: https://stats.foldingathome.org/donors
If your name returns no data, then you should be good to use it for your folding.
You also want to enter your Passkey on this tab. You have to enter it twice, so it is best to copy paste directly from the email you receive.
You can request a Passkey here: https://apps.foldingathome.org/getpasskey
While a Passkey is optional, it is highly recommended to get the most credits for your work.
More information on Passkeys here: https://foldingathome.org/support/faq/points/passkey/
Enable Slots for Folding on GPUs:
The default config file included with the FAHClient starts folding on the CPU immediately, but it may ignore your GPU. Using FAHControl is the easiest way to add GPUs without worrying about typing mistakes.
Still in the Configure window ... On the Slots Tab you can see the list of hardware actively available for the client. You can click the "+Add" button at the bottom of the list to add new slots (CPUs or GPUs). For most setups you just need to select the radio button for GPU and click OK. I recommend clicking save and making sure the GPU appears one at a time. (Since I only have one GPU in the rig at this point, I stop here until I finish the rest of the setup. Come back to this step as you add GPUs to you rig and need to enable them in the client.) Since my folding rigs have very weak CPUs, I actually remove the CPU slot. This allows the CPU to focus on loading WUs and sending/receiving data on the network. If you have a more powerful CPU, then you can leave it loaded as an active slot.
AMD Fan Control:
My RX580s would run for roughly 10 minutes with the default fan settings before overheating and rebooting the rig. I expected this because they did this when I was mining too.
While cranking up the fan speed is a bit wasteful on power, these cards run hot. So, no choice really.
I found amdgpu-pro-fans that allow me to set the fan speeds for all cards in one step.
You can find more information about it here: https://github.com/DominiLux/amdgpu-pro-fans
To install you have to first make sure you have git:
sudo apt-get install git
git clone https://github.com/dominilux/amdgpu-pro-fans
cd amdgpu-pro-fans
chmod +x amdgpu-pro-fans.sh
If you never used crontab, you can set it up using the defaults.
You can run crontab using this:
sudo crontab -e
@reboot /home/<user>/amdgpu-pro-fans/amdgpu-pro-fans.sh -s 80
This section is TBD. Currently the default fan control is keeping the rig at decent temps. I would like to come back to this to get the temps down a few degrees. It is important to balance power consumption for cooling vs. folding. Over cooling can be a waste of energy and doesn't really gain much in a steady state application like this.
How is it running?
We can use the nvidia-smi command to check on nvidia card temps and fan speeds:
nvidia-smi
sensors
Obviously, you can use FAHControl on your support machine to watch the progress on each slot
I'm sure I missed something somewhere, but I wanted to write down as much as possible so I can setup more rigs in the future and remember how I did it. I hope this helps some others with similar setups. If you have questions/suggestions, please response and I'll do what I can to help explain further. I'm by no means an expert in this area, just a hobbyist.
