Some WUs send without points
Frontiers
Hardware configuration: Ryzen 5 5600x
G.Skill 2x16 GB 3200@3333
GTX 1070
Lancool II Mesh Perf.
Linux Mint 21.3
some drives, some cooler, some peripherials
Post by Frontiers »
Hi,
In addition to "No WUs for this configuration" and "WorkServer connection failed on port 8080 trying 80" between WUs - there is another problem for last or so 10 days.
Some core_22 WUs crunched without any errors to 100%, then results send, then server shows resond WORK_ACK (400) and shows final credit estimate nearly 10 times lower, looks like without QRB at all.
And for such WUs without QRB - there are no points at all in overall statistics when look at EOC stats, 0 WU with 0 points during these updates. This thing happen for me sometwhat between 4 to 7 times for last few days.
Please check for errors new servers/new projects.
log part:
18:58:13:WU01:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
18:59:21:WU01:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
18:59:27:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
18:59:27:WU01:FS01:0x22:Saving result file checkpointState.xml
18:59:27:WU01:FS01:0x22:Saving result file checkpt.crc
18:59:27:WU01:FS01:0x22:Saving result file positions.xtc
18:59:27:WU01:FS01:0x22:Saving result file science.log
18:59:27:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
18:59:28:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:59:28:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11780 run:0 clone:5751 gen:1 core:0x22 unit:0x000000020d5a98395e75894e69619ab7
18:59:28:WU01:FS01:Uploading 33.37MiB to 13.90.152.57
18:59:28:WU01:FS01:Connecting to 13.90.152.57:8080
18:59:49:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
18:59:49:WU01:FS01:Connecting to 13.90.152.57:80
19:00:10:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 13.90.152.57:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
19:00:10:WU01:FS01:Trying to send results to collection server
19:00:10:WU01:FS01:Uploading 33.37MiB to 155.247.164.214
19:00:10:WU01:FS01:Connecting to 155.247.164.214:8080
19:00:20:WU01:FS01:Upload complete
19:00:20:WU01:FS01:Server responded WORK_ACK (400)
19:00:20:WU01:FS01:Final credit estimate, 7685.00 points
19:00:20:WU01:FS01:Cleaning up
Re: Some WUs send without points
Thank you for the report. I think this is a sample of a newly create problem but I'm going to bump it upstairs and let the experts solve it.
ykdave
Post by ykdave »
Having some issues here too
so far today 6 wu's and its only showing 18,193pts and the very first wu i submitted shows 97,324 in the log :!:
Have you completed and returned 10 or more WUs after setting your passkey in the client? If so, this may be due to the issue bruce posted about and someone will be working on this, and eventually it will get fixed.
If you have not yet returned 10 WUs with the passkey, then they will just get the base points. Due to limitations of the client it can not verify whether the username and passkey pair is qualified for the bonus, and calculates the estimated points just based on whether or not a passkey is entered.
Zippie
Post by Zippie »
I am having the same issue on some work units. It seems if they dont connect to the work server and send to the collection server it comes back with base points awarded only. I have certainly gone well past the 10 work unit requirement and have been getting bonus points for a while now. I have no failed work units, and no errors in the work units themselves, just the connection issues. This seems to have started since the influx of new users. It does not happen to every work unit, just the ones that dont upload to the first server it tries
Robby_Firefox
Hardware configuration: Homebuilt Windows 10
Intel Core i7-4770 ~ started in early 2014 or 2015
32 GB RAM (up from 8 GB in 2018)
64-Bit Operating System
On 31 Mar 2020, installed a GigaByte GEFORCE GTX 1660 GPU
Post by Robby_Firefox »
Am having similar problems here. There are some jobs that were done on March 22nd and 23rd (Central Daylight Time) that did not show points at extremeoverclocking. I'd assume that this problem was related to the general FAH system overload brought by many new contributors? The logs below show lots of ideal time given a magnificent number of new users now on-board.
I am using a passkey in this and another computer I have. The other computer last did a job on March 22nd for ~1300 points. It has been idle ever since, but got another job just recently. This computer is finally working again after being idle most of Monday.
Thanks,
Robby
Last.... Anyone has any hints on fixing my signature? I've looked through a number of posts, have not found anything that works yet. Am using this BB's coding [URL] rather than a=href, etc...
*********************** Log Started 2020-03-16T13:58:25Z ***********************
13:58:25:************************* Folding@home Client *************************
13:58:25:        Website: https://foldingathome.org/
13:58:25:      Copyright: (c) 2009-2018 foldingathome.org
13:58:25:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:58:25:           Args:
13:58:25:         Config: <none>
13:58:25:******************************** Build ********************************
13:58:25:        Version: 7.5.1
13:58:25:           Date: May 11 2018
13:58:25:           Time: 13:06:32
13:58:25:     Repository: Git
13:58:25:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
13:58:25:         Branch: master
13:58:25:       Compiler: Visual C++ 2008
13:58:25:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:58:25:       Platform: win32 10
13:58:25:           Bits: 32
13:58:25:           Mode: Release
13:58:25:******************************* System ********************************
13:58:25:            CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
13:58:25:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
13:58:25:           CPUs: 8
13:58:25:         Memory: 15.89GiB
13:58:25:    Free Memory: 13.09GiB
13:58:25:        Threads: WINDOWS_THREADS
13:58:25:     OS Version: 6.2
13:58:25:    Has Battery: true
13:58:25:     On Battery: false
13:58:25:     UTC Offset: -5
13:58:25:            PID: 3760
13:58:25:            CWD: C:\WINDOWS\system32
13:58:25:             OS: Windows 10 Home
13:58:25:        OS Arch: AMD64
13:58:25:           GPUs: 0
13:58:25:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
13:58:25:                 specified module could not be found.
13:58:25:
13:58:25:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:1.2 Driver:20.19
13:58:25:  Win32 Service: true
13:58:25:***********************************************************************
13:58:25:<config>
13:58:25:  <!-- Folding Slots -->
13:58:25:</config>
13:58:25:Connecting to assign1.foldingathome.org:8080
13:58:25:Updated GPUs.txt
13:58:25:Read GPUs.txt
13:58:25:Trying to access database...
13:58:26:Successfully acquired database lock
13:58:26:Enabled folding slot 00: PAUSED cpu:3 (not configured)
13:58:26:ERROR:Exception: Failed to register systray icon: Unspecified error
13:58:32:11:127.0.0.1:New Web connection
13:59:08:Set client configured
13:59:09:WU00:FS00:Connecting to 65.254.110.245:8080
13:59:09:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:59:09:WU00:FS00:Connecting to 18.218.241.186:80
13:59:09:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:59:09:ERROR:WU00:FS00:Exception: Could not get an assignment
13:59:10:WU00:FS00:Connecting to 65.254.110.245:8080
13:59:10:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:59:10:WU00:FS00:Connecting to 18.218.241.186:80
13:59:10:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:59:10:ERROR:WU00:FS00:Exception: Could not get an assignment
13:59:27:Saving configuration to config.xml
13:59:27:<config>
13:59:27:  <!-- User Information -->
13:59:27:  <passkey v='********************************'/>
13:59:27:  <team v='1'/>
13:59:27:  <user v='Robby'/>
13:59:27:
13:59:27:  <!-- Folding Slots -->
13:59:27:  <slot id='0' type='CPU'/>
13:59:27:</config>
14:00:10:WU00:FS00:Connecting to 65.254.110.245:8080
14:00:10:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:00:10:WU00:FS00:Connecting to 18.218.241.186:80
14:00:10:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:00:10:ERROR:WU00:FS00:Exception: Could not get an assignment
14:01:47:WU00:FS00:Connecting to 65.254.110.245:8080
14:01:47:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:01:47:WU00:FS00:Connecting to 18.218.241.186:80
14:01:47:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:01:47:ERROR:WU00:FS00:Exception: Could not get an assignment
14:04:24:WU00:FS00:Connecting to 65.254.110.245:8080
14:04:24:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:04:24:WU00:FS00:Connecting to 18.218.241.186:80
14:04:24:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:04:24:ERROR:WU00:FS00:Exception: Could not get an assignment
14:06:28:Saving configuration to config.xml
14:06:28:<config>
14:06:28:  <!-- Network -->
14:06:28:  <proxy v=':8080'/>
14:06:28:
14:06:28:  <!-- User Information -->
14:06:28:  <passkey v='********************************'/>
14:06:28:  <team v='1'/>
14:06:28:  <user v='Robby'/>
14:06:28:
14:06:28:  <!-- Work Unit Control -->
14:06:28:  <next-unit-percentage v='100'/>
14:06:28:
14:06:28:  <!-- Folding Slots -->
14:06:28:  <slot id='0' type='CPU'/>
14:06:28:</config>
14:06:34:Saving configuration to config.xml
14:06:34:<config>
14:06:34:  <!-- Network -->
14:06:34:  <proxy v=':8080'/>
14:06:34:
14:06:34:  <!-- User Information -->
14:06:34:  <passkey v='********************************'/>
14:06:34:  <team v='1'/>
14:06:34:  <user v='Robby'/>
14:06:34:
14:06:34:  <!-- Work Unit Control -->
14:06:34:  <next-unit-percentage v='100'/>
14:06:34:
14:06:34:  <!-- Folding Slots -->
14:06:34:  <slot id='0' type='CPU'/>
14:06:34:</config>
14:08:38:WU00:FS00:Connecting to 65.254.110.245:8080
14:08:39:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:08:39:WU00:FS00:Connecting to 18.218.241.186:80
14:08:39:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:08:39:ERROR:WU00:FS00:Exception: Could not get an assignment
14:15:30:WU00:FS00:Connecting to 65.254.110.245:8080
14:15:30:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:15:30:WU00:FS00:Connecting to 18.218.241.186:80
14:15:30:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:15:30:ERROR:WU00:FS00:Exception: Could not get an assignment
14:26:35:WU00:FS00:Connecting to 65.254.110.245:8080
14:26:57:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:27:00:WU00:FS00:Connecting to 18.218.241.186:80
14:27:12:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:27:12:ERROR:WU00:FS00:Exception: Could not get an assignment
14:44:32:WU00:FS00:Connecting to 65.254.110.245:8080
14:44:43:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:44:47:WU00:FS00:Connecting to 18.218.241.186:80
14:44:58:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:45:03:ERROR:WU00:FS00:Exception: Could not get an assignment
15:13:34:WU00:FS00:Connecting to 65.254.110.245:8080
15:13:35:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:13:35:WU00:FS00:Connecting to 18.218.241.186:80
15:13:35:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:13:35:ERROR:WU00:FS00:Exception: Could not get an assignment
16:00:33:WU00:FS00:Connecting to 65.254.110.245:8080
16:00:51:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:00:54:WU00:FS00:Connecting to 18.218.241.186:80
16:01:03:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:01:06:ERROR:WU00:FS00:Exception: Could not get an assignment
17:16:34:WU00:FS00:Connecting to 65.254.110.245:8080
17:16:49:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:16:49:WU00:FS00:Connecting to 18.218.241.186:80
17:17:00:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:17:00:ERROR:WU00:FS00:Exception: Could not get an assignment
19:19:34:WU00:FS00:Connecting to 65.254.110.245:8080
19:19:34:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
19:19:34:WU00:FS00:Connecting to 18.218.241.186:80
19:19:34:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
19:19:34:ERROR:WU00:FS00:Exception: Could not get an assignment
******************************* Date: 2020-03-16 *******************************
22:38:34:WU00:FS00:Connecting to 65.254.110.245:8080
13:50:06:WU00:FS00:0xa7:*********************** Log Started 2020-03-21T13:50:06Z ***********************
13:50:06:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:50:06:WU00:FS00:0xa7:       Type: 0xa7
13:50:06:WU00:FS00:0xa7:       Core: Gromacs
13:50:06:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 22348 -checkpoint 15 -np
13:50:06:WU00:FS00:0xa7:             3 -service
13:50:06:WU00:FS00:0xa7:************************************ CBang *************************************
13:50:06:WU00:FS00:0xa7:       Date: Oct 26 2019
13:50:06:WU00:FS00:0xa7:       Time: 01:38:25
13:50:06:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
13:50:06:WU00:FS00:0xa7:     Branch: master
13:50:06:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
13:50:06:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
13:50:06:WU00:FS00:0xa7:   Platform: win32 10
13:50:06:WU00:FS00:0xa7:       Bits: 64
13:50:06:WU00:FS00:0xa7:       Mode: Release
13:50:06:WU00:FS00:0xa7:************************************ System ************************************
13:50:06:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
13:50:06:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
13:50:06:WU00:FS00:0xa7:       CPUs: 8
13:50:06:WU00:FS00:0xa7:     Memory: 15.89GiB
13:50:06:WU00:FS00:0xa7:Free Memory: 9.45GiB
13:50:06:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
13:50:06:WU00:FS00:0xa7: OS Version: 6.2
13:50:06:WU00:FS00:0xa7:Has Battery: true
13:50:06:WU00:FS00:0xa7: On Battery: false
13:50:06:WU00:FS00:0xa7: UTC Offset: -5
13:50:06:WU00:FS00:0xa7:        PID: 23004
13:50:06:WU00:FS00:0xa7:        CWD: C:\Users\bobb1\AppData\Roaming\FAHClient\work
13:50:06:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
13:50:06:WU00:FS00:0xa7:    Version: 0.0.18
13:50:06:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:50:06:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
13:50:06:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
13:50:06:WU00:FS00:0xa7:       Time: 01:52:30
13:50:06:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
13:50:06:WU00:FS00:0xa7:************************************ Build *************************************
BREAK   BREAK   BREAK
13:53:42:WU01:FS00:0xa7:       Bits: 64
13:53:42:WU01:FS00:0xa7:       Mode: Release
13:53:42:WU01:FS00:0xa7:************************************ Build *************************************
13:53:42:WU01:FS00:0xa7:       SIMD: avx_256
13:53:42:WU01:FS00:0xa7:********************************************************************************
13:53:42:WU01:FS00:0xa7:Project: 14523 (Run 771, Clone 0, Gen 7)
13:53:42:WU01:FS00:0xa7:Unit: 0x0000000980fccb0a5e459bcc20371d51
13:53:42:WU01:FS00:0xa7:Reading tar file core.xml
13:53:42:WU01:FS00:0xa7:Reading tar file frame7.tpr
13:53:42:WU01:FS00:0xa7:Digital signatures verified
13:53:42:WU01:FS00:0xa7:Calling: mdrun -s frame7.tpr -o frame7.trr -x frame7.xtc -cpt 15 -nt 8
13:53:42:WU01:FS00:0xa7:Steps: first=1750000 total=250000
13:53:43:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
13:54:19:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
13:54:55:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
13:55:31:WU01:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
13:56:06:WU01:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
13:56:42:WU01:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
13:57:18:WU01:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
13:57:53:WU01:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
13:58:29:WU01:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
13:59:05:WU01:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
13:59:41:WU01:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
14:00:16:WU01:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
14:00:52:WU01:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
14:01:28:WU01:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
14:02:05:WU01:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
14:02:41:WU01:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
14:03:17:WU01:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
14:03:53:WU01:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
14:04:28:WU01:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
14:05:05:WU01:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
14:05:40:WU01:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
14:06:16:WU01:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
14:06:52:WU01:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
14:07:28:WU01:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
14:08:04:WU01:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
14:08:39:WU01:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
14:09:16:WU01:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
14:09:51:WU01:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
14:10:27:WU01:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
14:11:03:WU01:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
14:11:40:WU01:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
14:12:15:WU01:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
14:12:51:WU01:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
14:13:27:WU01:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
14:14:03:WU01:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
14:14:39:WU01:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
14:15:15:WU01:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
14:15:51:WU01:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
14:16:27:WU01:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
14:17:03:WU01:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
14:17:39:WU01:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
14:18:15:WU01:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
14:18:51:WU01:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
14:19:27:WU01:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
14:20:03:WU01:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
14:20:39:WU01:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
14:21:15:WU01:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
14:21:51:WU01:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
14:22:27:WU01:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
14:23:03:WU01:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
14:23:39:WU01:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
14:24:16:WU01:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
14:24:52:WU01:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
14:25:37:WU01:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
14:26:13:WU01:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
14:26:49:WU01:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
14:27:25:WU01:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
14:28:01:WU01:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
14:28:38:WU01:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
14:29:14:WU01:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
14:29:52:WU01:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
14:30:28:WU01:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
14:31:05:WU01:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
14:31:42:WU01:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
14:32:19:WU01:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
14:32:55:WU01:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
14:33:31:WU01:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
14:34:07:WU01:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
14:34:43:WU01:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
14:35:20:WU01:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
14:35:56:WU01:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
14:36:32:WU01:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
14:37:08:WU01:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
14:37:44:WU01:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
14:38:20:WU01:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
14:38:56:WU01:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
14:39:33:WU01:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
14:40:17:WU01:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
14:40:53:WU01:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
14:41:29:WU01:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
14:42:05:WU01:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
14:42:41:WU01:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
14:43:18:WU01:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
14:43:54:WU01:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
14:44:30:WU01:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
14:45:06:WU01:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
14:45:43:WU01:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
14:46:19:WU01:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
14:46:55:WU01:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
14:47:32:WU01:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
14:48:08:WU01:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
14:48:44:WU01:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
14:49:21:WU01:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
14:49:57:WU01:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
14:50:33:WU01:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
14:51:08:WU01:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
14:51:44:WU01:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
14:52:20:WU01:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
14:52:56:WU01:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
BREAK   BREAK   BREAK
01:41:12:WU01:FS00:FahCore 0xa7 started
01:41:13:WU01:FS00:0xa7:*********************** Log Started 2020-03-22T01:41:12Z ***********************
01:41:13:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
01:41:13:WU01:FS00:0xa7:       Type: 0xa7
01:41:13:WU01:FS00:0xa7:       Core: Gromacs
01:41:13:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 705 -lifeline 12332 -checkpoint 15 -np
01:41:13:WU01:FS00:0xa7:             8 -service
01:41:13:WU01:FS00:0xa7:************************************ CBang *************************************
01:41:13:WU01:FS00:0xa7:       Date: Oct 26 2019
01:41:13:WU01:FS00:0xa7:       Time: 01:38:25
01:41:13:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
01:41:13:WU01:FS00:0xa7:     Branch: master
01:41:13:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
01:41:13:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
01:41:13:WU01:FS00:0xa7:   Platform: win32 10
01:41:13:WU01:FS00:0xa7:       Bits: 64
01:41:13:WU01:FS00:0xa7:       Mode: Release
01:41:13:WU01:FS00:0xa7:************************************ System ************************************
01:41:13:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
01:41:13:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
01:41:13:WU01:FS00:0xa7:       CPUs: 8
01:41:13:WU01:FS00:0xa7:     Memory: 15.89GiB
01:41:13:WU01:FS00:0xa7:Free Memory: 9.38GiB
01:41:13:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
01:41:13:WU01:FS00:0xa7: OS Version: 6.2
01:41:13:WU01:FS00:0xa7:Has Battery: true
01:41:13:WU01:FS00:0xa7: On Battery: false
01:41:13:WU01:FS00:0xa7: UTC Offset: -5
01:41:13:WU01:FS00:0xa7:        PID: 6188
01:41:13:WU01:FS00:0xa7:        CWD: C:\Users\bobb1\AppData\Roaming\FAHClient\work
01:41:13:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
01:41:13:WU01:FS00:0xa7:    Version: 0.0.18
01:41:13:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:41:13:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
01:41:13:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
01:41:13:WU01:FS00:0xa7:       Time: 01:52:30
01:41:13:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
01:41:13:WU01:FS00:0xa7:************************************ Build *************************************
01:41:13:WU01:FS00:0xa7:       SIMD: avx_256
01:41:13:WU01:FS00:0xa7:********************************************************************************
01:41:13:WU01:FS00:0xa7:Project: 14531 (Run 0, Clone 1684, Gen 6)
01:41:13:WU01:FS00:0xa7:Unit: 0x0000000a80fccb0a5e69789c4af2f9c5
01:41:13:WU01:FS00:0xa7:Reading tar file core.xml
01:41:13:WU01:FS00:0xa7:Reading tar file frame6.tpr
01:41:13:WU01:FS00:0xa7:Digital signatures verified
01:41:13:WU01:FS00:0xa7:Calling: mdrun -s frame6.tpr -o frame6.trr -cpt 15 -nt 8
01:41:13:WU01:FS00:0xa7:Steps: first=1500000 total=250000
01:41:14:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
01:42:07:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
01:42:59:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
01:43:51:WU01:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
01:44:43:WU01:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
01:45:34:WU01:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
01:46:27:WU01:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
01:47:18:WU01:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
01:48:10:WU01:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
01:49:02:WU01:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
01:49:54:WU01:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
01:50:47:WU01:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
01:51:45:WU01:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
01:52:37:WU01:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
01:53:28:WU01:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
01:54:20:WU01:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
01:55:12:WU01:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
01:56:03:WU01:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
01:56:56:WU01:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
01:57:47:WU01:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
01:58:39:WU01:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
01:59:31:WU01:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
02:00:22:WU01:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
02:01:13:WU01:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
02:02:05:WU01:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
02:02:56:WU01:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
02:03:47:WU01:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
02:04:39:WU01:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
02:05:30:WU01:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
02:06:22:WU01:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
02:07:13:WU01:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
02:08:04:WU01:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
02:08:55:WU01:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
02:09:47:WU01:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
02:10:39:WU01:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
02:11:31:WU01:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
02:12:22:WU01:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
02:13:14:WU01:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
02:14:05:WU01:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
02:14:56:WU01:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
02:15:47:WU01:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
02:16:39:WU01:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
02:17:31:WU01:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
02:18:22:WU01:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
02:19:14:WU01:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
02:20:04:WU01:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
02:20:55:WU01:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
02:21:46:WU01:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
02:22:37:WU01:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
02:23:28:WU01:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
02:24:20:WU01:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
02:25:12:WU01:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
02:26:04:WU01:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
02:26:57:WU01:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
02:27:49:WU01:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
02:28:40:WU01:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
02:29:31:WU01:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
02:30:23:WU01:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
02:31:15:WU01:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
02:32:06:WU01:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
02:32:57:WU01:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
02:33:48:WU01:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
02:34:40:WU01:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
02:35:32:WU01:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
02:36:23:WU01:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
02:37:17:WU01:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
02:38:09:WU01:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
02:39:01:WU01:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
02:39:52:WU01:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
02:40:43:WU01:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
02:41:35:WU01:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
02:42:26:WU01:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
02:43:17:WU01:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
02:44:08:WU01:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
02:44:59:WU01:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
02:45:49:WU01:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
02:46:41:WU01:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
02:47:31:WU01:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
02:48:22:WU01:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
02:49:14:WU01:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
02:50:04:WU01:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
02:50:55:WU01:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
02:51:46:WU01:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
02:52:37:WU01:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
02:53:27:WU01:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
02:54:19:WU01:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
02:55:10:WU01:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
02:56:00:WU01:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
02:56:52:WU01:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
02:57:43:WU01:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
02:58:34:WU01:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
02:59:25:WU01:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
03:00:16:WU01:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
03:01:06:WU01:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
03:01:57:WU01:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
03:02:48:WU01:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
03:03:39:WU01:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
03:04:29:WU01:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
03:05:20:WU01:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
03:06:12:WU01:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
03:07:02:WU01:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
03:07:03:WU00:FS00:Connecting to 65.254.110.245:8080
03:07:03:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:07:03:WU00:FS00:Connecting to 18.218.241.186:80
03:07:04:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:07:04:ERROR:WU00:FS00:Exception: Could not get an assignment
03:07:04:WU00:FS00:Connecting to 65.254.110.245:8080
03:07:04:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:07:04:WU00:FS00:Connecting to 18.218.241.186:80
03:07:05:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
03:07:05:WU01:FS00:0xa7:Saving result file frame6.trr
03:07:05:WU01:FS00:0xa7:Saving result file md.log
03:07:05:WU01:FS00:0xa7:Saving result file science.log
03:07:05:WU01:FS00:0xa7:Saving result file traj_comp.xtc
03:07:05:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
03:07:05:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:07:06:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:14531 run:0 clone:1684 gen:6 core:0xa7 unit:0x0000000a80fccb0a5e69789c4af2f9c5
03:07:06:WU01:FS00:Uploading 5.25MiB to 128.252.203.10
03:07:06:WU01:FS00:Connecting to 128.252.203.10:8080
03:07:27:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
03:07:27:WU01:FS00:Connecting to 128.252.203.10:80
03:07:48:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 128.252.203.10:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
03:07:48:WU01:FS00:Trying to send results to collection server
03:07:48:WU01:FS00:Uploading 5.25MiB to 155.247.166.219
03:07:48:WU01:FS00:Connecting to 155.247.166.219:8080
03:07:49:WU01:FS00:Upload complete
03:07:49:WU01:FS00:Server responded WORK_ACK (400)
03:07:49:WU01:FS00:Final credit estimate, 2576.00 points
03:07:49:WU01:FS00:Cleaning up
03:08:04:WU00:FS00:Connecting to 65.254.110.245:8080
03:08:04:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:08:04:WU00:FS00:Connecting to 18.218.241.186:80
03:08:04:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:08:04:ERROR:WU00:FS00:Exception: Could not get an assignment
03:09:41:WU00:FS00:Connecting to 65.254.110.245:8080
03:09:41:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:09:41:WU00:FS00:Connecting to 18.218.241.186:80
03:09:41:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:09:41:ERROR:WU00:FS00:Exception: Could not get an assignment
03:12:18:WU00:FS00:Connecting to 65.254.110.245:8080
03:12:19:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:12:19:WU00:FS00:Connecting to 18.218.241.186:80
03:12:19:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:12:19:ERROR:WU00:FS00:Exception: Could not get an assignment
03:16:33:WU00:FS00:Connecting to 65.254.110.245:8080
03:16:33:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:16:33:WU00:FS00:Connecting to 18.218.241.186:80
03:16:33:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:16:33:ERROR:WU00:FS00:Exception: Could not get an assignment
03:23:24:WU00:FS00:Connecting to 65.254.110.245:8080
03:23:24:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:23:24:WU00:FS00:Connecting to 18.218.241.186:80
03:23:25:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:23:25:ERROR:WU00:FS00:Exception: Could not get an assignment
03:34:30:WU00:FS00:Connecting to 65.254.110.245:8080
03:34:30:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:34:30:WU00:FS00:Connecting to 18.218.241.186:80
03:34:30:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:34:30:ERROR:WU00:FS00:Exception: Could not get an assignment
03:52:27:WU00:FS00:Connecting to 65.254.110.245:8080
03:52:27:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
03:52:27:WU00:FS00:Connecting to 18.218.241.186:80
03:52:27:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
03:52:27:ERROR:WU00:FS00:Exception: Could not get an assignment
04:21:29:WU00:FS00:Connecting to 65.254.110.245:8080
04:21:29:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:21:29:WU00:FS00:Connecting to 18.218.241.186:80
04:21:29:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:21:29:ERROR:WU00:FS00:Exception: Could not get an assignment
05:08:28:WU00:FS00:Connecting to 65.254.110.245:8080
05:08:28:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:08:28:WU00:FS00:Connecting to 18.218.241.186:80
05:08:28:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:08:28:ERROR:WU00:FS00:Exception: Could not get an assignment
06:24:28:WU00:FS00:Connecting to 65.254.110.245:8080
06:24:29:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:24:29:WU00:FS00:Connecting to 18.218.241.186:80
06:24:29:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:24:29:ERROR:WU00:FS00:Exception: Could not get an assignment
******************************* Date: 2020-03-22 *******************************
08:27:28:WU00:FS00:Connecting to 65.254.110.245:8080
08:27:28:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:27:28:WU00:FS00:Connecting to 18.218.241.186:80
08:27:28:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:27:28:ERROR:WU00:FS00:Exception: Could not get an assignment
11:46:29:WU00:FS00:Connecting to 65.254.110.245:8080
11:46:29:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:46:29:WU00:FS00:Connecting to 18.218.241.186:80
11:46:29:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:46:29:ERROR:WU00:FS00:Exception: Could not get an assignment
17:08:28:WU00:FS00:Connecting to 65.254.110.245:8080
17:08:29:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:08:29:WU00:FS00:Connecting to 18.218.241.186:80
17:08:29:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:08:29:ERROR:WU00:FS00:Exception: Could not get an assignment
23:08:29:WU00:FS00:Connecting to 65.254.110.245:8080
23:08:29:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:08:29:WU00:FS00:Connecting to 18.218.241.186:80
23:08:29:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:08:29:ERROR:WU00:FS00:Exception: Could not get an assignment
******************************* Date: 2020-03-23 *******************************
05:08:29:WU00:FS00:Connecting to 65.254.110.245:8080
05:08:46:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
05:08:46:WU00:FS00:Connecting to 18.218.241.186:80
05:08:52:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
05:08:55:ERROR:WU00:FS00:Exception: Could not get an assignment
11:08:29:WU00:FS00:Connecting to 65.254.110.245:8080
11:08:37:WU00:FS00:Assigned to work server 40.114.52.201
11:08:44:WU00:FS00:Requesting new work unit for slot 00: READY cpu:8 from 40.114.52.201
11:08:44:WU00:FS00:Connecting to 40.114.52.201:8080
11:08:47:WU00:FS00:Downloading 2.14MiB
11:08:47:WU00:FS00:Download complete
11:08:55:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13850 run:0 clone:22593 gen:0 core:0xa7 unit:0x00000000287234c95e788f4ca437f3e2
11:09:01:WU00:FS00:Starting
11:09:01:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobb1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 3760 -checkpoint 15 -np 8 -service
11:09:01:WU00:FS00:Started FahCore on PID 27580
11:09:54:WU00:FS00:Core PID:27004
11:09:54:WU00:FS00:FahCore 0xa7 started
11:09:54:WU00:FS00:0xa7:*********************** Log Started 2020-03-23T11:09:54Z ***********************
11:09:54:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:09:54:WU00:FS00:0xa7:       Type: 0xa7
11:09:54:WU00:FS00:0xa7:       Core: Gromacs
11:09:54:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 27580 -checkpoint 15 -np
11:09:54:WU00:FS00:0xa7:             8 -service
11:09:54:WU00:FS00:0xa7:************************************ CBang *************************************
11:09:54:WU00:FS00:0xa7:       Date: Oct 26 2019
11:09:54:WU00:FS00:0xa7:       Time: 01:38:25
11:09:54:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
11:09:54:WU00:FS00:0xa7:     Branch: master
11:09:54:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
11:09:54:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
11:09:54:WU00:FS00:0xa7:   Platform: win32 10
11:09:54:WU00:FS00:0xa7:       Bits: 64
11:09:54:WU00:FS00:0xa7:       Mode: Release
11:09:54:WU00:FS00:0xa7:************************************ System ************************************
11:09:54:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
11:09:54:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
11:09:54:WU00:FS00:0xa7:       CPUs: 8
11:09:54:WU00:FS00:0xa7:     Memory: 15.89GiB
11:09:54:WU00:FS00:0xa7:Free Memory: 11.78GiB
11:09:54:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
11:09:54:WU00:FS00:0xa7: OS Version: 6.2
11:09:54:WU00:FS00:0xa7:Has Battery: true
11:09:54:WU00:FS00:0xa7: On Battery: false
11:09:54:WU00:FS00:0xa7: UTC Offset: -5
11:09:54:WU00:FS00:0xa7:        PID: 27004
11:09:54:WU00:FS00:0xa7:        CWD: C:\Users\bobb1\AppData\Roaming\FAHClient\work
11:09:54:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
11:09:54:WU00:FS00:0xa7:    Version: 0.0.18
11:09:54:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:09:54:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
11:09:54:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
11:09:54:WU00:FS00:0xa7:       Time: 01:52:30
11:09:54:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
11:09:54:WU00:FS00:0xa7:************************************ Build *************************************
11:09:54:WU00:FS00:0xa7:       SIMD: avx_256
11:09:54:WU00:FS00:0xa7:********************************************************************************
11:09:54:WU00:FS00:0xa7:Project: 13850 (Run 0, Clone 22593, Gen 0)
11:09:54:WU00:FS00:0xa7:Unit: 0x00000000287234c95e788f4ca437f3e2
11:09:54:WU00:FS00:0xa7:Reading tar file core.xml
11:09:54:WU00:FS00:0xa7:Reading tar file frame0.tpr
11:09:54:WU00:FS00:0xa7:Digital signatures verified
11:09:54:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -x frame0.xtc -e frame0.edr -cpt 15 -nt 8
11:09:54:WU00:FS00:0xa7:Steps: first=0 total=500000
11:09:56:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
11:12:02:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
11:14:07:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
11:16:40:WU00:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
11:18:50:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
11:21:03:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
11:23:07:WU00:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
11:26:03:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
11:28:19:WU00:FS00:0xa7:Completed 40000 out of 500000 steps (8%)
11:30:30:WU00:FS00:0xa7:Completed 45000 out of 500000 steps (9%)
11:32:40:WU00:FS00:0xa7:Completed 50000 out of 500000 steps (10%)
11:34:52:WU00:FS00:0xa7:Completed 55000 out of 500000 steps (11%)
11:37:08:WU00:FS00:0xa7:Completed 60000 out of 500000 steps (12%)
11:39:18:WU00:FS00:0xa7:Completed 65000 out of 500000 steps (13%)
11:42:18:WU00:FS00:0xa7:Completed 70000 out of 500000 steps (14%)
11:44:31:WU00:FS00:0xa7:Completed 75000 out of 500000 steps (15%)
11:46:45:WU00:FS00:0xa7:Completed 80000 out of 500000 steps (16%)
11:48:58:WU00:FS00:0xa7:Completed 85000 out of 500000 steps (17%)
11:51:21:WU00:FS00:0xa7:Completed 90000 out of 500000 steps (18%)
11:53:44:WU00:FS00:0xa7:Completed 95000 out of 500000 steps (19%)
11:56:50:WU00:FS00:0xa7:Completed 100000 out of 500000 steps (20%)
11:59:06:WU00:FS00:0xa7:Completed 105000 out of 500000 steps (21%)
12:01:22:WU00:FS00:0xa7:Completed 110000 out of 500000 steps (22%)
12:03:34:WU00:FS00:0xa7:Completed 115000 out of 500000 steps (23%)
12:05:45:WU00:FS00:0xa7:Completed 120000 out of 500000 steps (24%)
12:08:04:WU00:FS00:0xa7:Completed 125000 out of 500000 steps (25%)
12:10:56:WU00:FS00:0xa7:Completed 130000 out of 500000 steps (26%)
12:13:07:WU00:FS00:0xa7:Completed 135000 out of 500000 steps (27%)
12:15:18:WU00:FS00:0xa7:Completed 140000 out of 500000 steps (28%)
12:17:28:WU00:FS00:0xa7:Completed 145000 out of 500000 steps (29%)
12:19:43:WU00:FS00:0xa7:Completed 150000 out of 500000 steps (30%)
12:22:00:WU00:FS00:0xa7:Completed 155000 out of 500000 steps (31%)
12:24:12:WU00:FS00:0xa7:Completed 160000 out of 500000 steps (32%)
12:27:18:WU00:FS00:0xa7:Completed 165000 out of 500000 steps (33%)
12:29:32:WU00:FS00:0xa7:Completed 170000 out of 500000 steps (34%)
12:31:41:WU00:FS00:0xa7:Completed 175000 out of 500000 steps (35%)
12:33:50:WU00:FS00:0xa7:Completed 180000 out of 500000 steps (36%)
12:36:04:WU00:FS00:0xa7:Completed 185000 out of 500000 steps (37%)
12:38:17:WU00:FS00:0xa7:Completed 190000 out of 500000 steps (38%)
12:41:17:WU00:FS00:0xa7:Completed 195000 out of 500000 steps (39%)
12:43:31:WU00:FS00:0xa7:Completed 200000 out of 500000 steps (40%)
12:45:49:WU00:FS00:0xa7:Completed 205000 out of 500000 steps (41%)
12:47:56:WU00:FS00:0xa7:Completed 210000 out of 500000 steps (42%)
12:50:04:WU00:FS00:0xa7:Completed 215000 out of 500000 steps (43%)
12:52:11:WU00:FS00:0xa7:Completed 220000 out of 500000 steps (44%)
12:54:23:WU00:FS00:0xa7:Completed 225000 out of 500000 steps (45%)
12:57:23:WU00:FS00:0xa7:Completed 230000 out of 500000 steps (46%)
12:59:32:WU00:FS00:0xa7:Completed 235000 out of 500000 steps (47%)
13:01:44:WU00:FS00:0xa7:Completed 240000 out of 500000 steps (48%)
13:04:01:WU00:FS00:0xa7:Completed 245000 out of 500000 steps (49%)
13:06:20:WU00:FS00:0xa7:Completed 250000 out of 500000 steps (50%)
13:08:39:WU00:FS00:0xa7:Completed 255000 out of 500000 steps (51%)
13:11:38:WU00:FS00:0xa7:Completed 260000 out of 500000 steps (52%)
13:13:55:WU00:FS00:0xa7:Completed 265000 out of 500000 steps (53%)
13:16:14:WU00:FS00:0xa7:Completed 270000 out of 500000 steps (54%)
13:18:27:WU00:FS00:0xa7:Completed 275000 out of 500000 steps (55%)
13:20:46:WU00:FS00:0xa7:Completed 280000 out of 500000 steps (56%)
13:23:09:WU00:FS00:0xa7:Completed 285000 out of 500000 steps (57%)
13:25:12:WU00:FS00:0xa7:Completed 290000 out of 500000 steps (58%)
13:27:13:WU00:FS00:0xa7:Completed 295000 out of 500000 steps (59%)
13:29:14:WU00:FS00:0xa7:Completed 300000 out of 500000 steps (60%)
13:31:14:WU00:FS00:0xa7:Completed 305000 out of 500000 steps (61%)
13:33:14:WU00:FS00:0xa7:Completed 310000 out of 500000 steps (62%)
13:35:14:WU00:FS00:0xa7:Completed 315000 out of 500000 steps (63%)
13:37:15:WU00:FS00:0xa7:Completed 320000 out of 500000 steps (64%)
13:39:16:WU00:FS00:0xa7:Completed 325000 out of 500000 steps (65%)
13:41:17:WU00:FS00:0xa7:Completed 330000 out of 500000 steps (66%)
13:43:18:WU00:FS00:0xa7:Completed 335000 out of 500000 steps (67%)
13:45:19:WU00:FS00:0xa7:Completed 340000 out of 500000 steps (68%)
13:47:20:WU00:FS00:0xa7:Completed 345000 out of 500000 steps (69%)
13:49:21:WU00:FS00:0xa7:Completed 350000 out of 500000 steps (70%)
13:51:53:WU00:FS00:0xa7:Completed 355000 out of 500000 steps (71%)
13:54:01:WU00:FS00:0xa7:Completed 360000 out of 500000 steps (72%)
13:56:10:WU00:FS00:0xa7:Completed 365000 out of 500000 steps (73%)
13:58:27:WU00:FS00:0xa7:Completed 370000 out of 500000 steps (74%)
14:00:26:WU00:FS00:0xa7:Completed 375000 out of 500000 steps (75%)
14:02:32:WU00:FS00:0xa7:Completed 380000 out of 500000 steps (76%)
14:05:11:WU00:FS00:0xa7:Completed 385000 out of 500000 steps (77%)
14:07:19:WU00:FS00:0xa7:Completed 390000 out of 500000 steps (78%)
14:09:31:WU00:FS00:0xa7:Completed 395000 out of 500000 steps (79%)
14:11:45:WU00:FS00:0xa7:Completed 400000 out of 500000 steps (80%)
14:14:02:WU00:FS00:0xa7:Completed 405000 out of 500000 steps (81%)
14:16:14:WU00:FS00:0xa7:Completed 410000 out of 500000 steps (82%)
14:19:00:WU00:FS00:0xa7:Completed 415000 out of 500000 steps (83%)
14:20:59:WU00:FS00:0xa7:Completed 420000 out of 500000 steps (84%)
14:22:59:WU00:FS00:0xa7:Completed 425000 out of 500000 steps (85%)
14:25:01:WU00:FS00:0xa7:Completed 430000 out of 500000 steps (86%)
14:27:14:WU00:FS00:0xa7:Completed 435000 out of 500000 steps (87%)
14:29:23:WU00:FS00:0xa7:Completed 440000 out of 500000 steps (88%)
14:31:25:WU00:FS00:0xa7:Completed 445000 out of 500000 steps (89%)
14:33:25:WU00:FS00:0xa7:Completed 450000 out of 500000 steps (90%)
14:35:23:WU00:FS00:0xa7:Completed 455000 out of 500000 steps (91%)
14:37:21:WU00:FS00:0xa7:Completed 460000 out of 500000 steps (92%)
14:39:20:WU00:FS00:0xa7:Completed 465000 out of 500000 steps (93%)
14:41:19:WU00:FS00:0xa7:Completed 470000 out of 500000 steps (94%)
14:43:17:WU00:FS00:0xa7:Completed 475000 out of 500000 steps (95%)
14:45:16:WU00:FS00:0xa7:Completed 480000 out of 500000 steps (96%)
14:47:15:WU00:FS00:0xa7:Completed 485000 out of 500000 steps (97%)
14:49:14:WU00:FS00:0xa7:Completed 490000 out of 500000 steps (98%)
14:51:12:WU00:FS00:0xa7:Completed 495000 out of 500000 steps (99%)
14:53:10:WU00:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
14:53:11:WU01:FS00:Connecting to 65.254.110.245:8080
14:53:11:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:53:11:WU01:FS00:Connecting to 18.218.241.186:80
14:53:12:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:53:12:ERROR:WU01:FS00:Exception: Could not get an assignment
14:53:12:WU01:FS00:Connecting to 65.254.110.245:8080
14:53:12:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:53:12:WU01:FS00:Connecting to 18.218.241.186:80
14:53:12:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
14:53:12:WU00:FS00:0xa7:Saving result file frame0.edr
14:53:12:WU00:FS00:0xa7:Saving result file frame0.trr
14:53:12:WU00:FS00:0xa7:Saving result file frame0.xtc
14:53:12:WU00:FS00:0xa7:Saving result file md.log
14:53:12:WU00:FS00:0xa7:Saving result file science.log
14:53:12:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
14:53:13:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:53:13:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13850 run:0 clone:22593 gen:0 core:0xa7 unit:0x00000000287234c95e788f4ca437f3e2
14:53:13:WU00:FS00:Uploading 2.46MiB to 40.114.52.201
14:53:13:WU00:FS00:Connecting to 40.114.52.201:8080
14:53:34:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
14:53:34:WU00:FS00:Connecting to 40.114.52.201:80
14:53:55:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:53:55:WU00:FS00:Trying to send results to collection server
14:53:55:WU00:FS00:Uploading 2.46MiB to 128.252.203.2
14:53:55:WU00:FS00:Connecting to 128.252.203.2:8080
14:53:56:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
14:53:57:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13850 run:0 clone:22593 gen:0 core:0xa7 unit:0x00000000287234c95e788f4ca437f3e2
14:53:57:WU00:FS00:Uploading 2.46MiB to 40.114.52.201
14:53:57:WU00:FS00:Connecting to 40.114.52.201:8080
14:54:12:WU01:FS00:Connecting to 65.254.110.245:8080
14:54:12:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:54:12:WU01:FS00:Connecting to 18.218.241.186:80
14:54:12:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:54:12:ERROR:WU01:FS00:Exception: Could not get an assignment
14:54:18:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
14:54:18:WU00:FS00:Connecting to 40.114.52.201:80
14:54:39:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
14:54:39:WU00:FS00:Trying to send results to collection server
14:54:39:WU00:FS00:Uploading 2.46MiB to 128.252.203.2
14:54:39:WU00:FS00:Connecting to 128.252.203.2:8080
14:54:41:WU00:FS00:Upload complete
14:54:41:WU00:FS00:Server responded WORK_ACK (400)
14:54:41:WU00:FS00:Final credit estimate, 1000.00 points
14:54:41:WU00:FS00:Cleaning up
14:55:49:WU01:FS00:Connecting to 65.254.110.245:8080
14:55:49:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:55:49:WU01:FS00:Connecting to 18.218.241.186:80
14:55:49:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:55:49:ERROR:WU01:FS00:Exception: Could not get an assignment
14:58:26:WU01:FS00:Connecting to 65.254.110.245:8080
14:58:26:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
14:58:26:WU01:FS00:Connecting to 18.218.241.186:80
14:58:27:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
14:58:27:ERROR:WU01:FS00:Exception: Could not get an assignment
15:02:40:WU01:FS00:Connecting to 65.254.110.245:8080
15:02:41:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:02:41:WU01:FS00:Connecting to 18.218.241.186:80
15:02:41:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:02:41:ERROR:WU01:FS00:Exception: Could not get an assignment
15:09:32:WU01:FS00:Connecting to 65.254.110.245:8080
15:09:32:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:09:32:WU01:FS00:Connecting to 18.218.241.186:80
15:09:32:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:09:32:ERROR:WU01:FS00:Exception: Could not get an assignment
15:20:38:WU01:FS00:Connecting to 65.254.110.245:8080
15:20:38:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:20:38:WU01:FS00:Connecting to 18.218.241.186:80
15:20:38:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:20:38:ERROR:WU01:FS00:Exception: Could not get an assignment
15:38:34:WU01:FS00:Connecting to 65.254.110.245:8080
15:38:34:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
15:38:34:WU01:FS00:Connecting to 18.218.241.186:80
15:38:35:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
15:38:35:ERROR:WU01:FS00:Exception: Could not get an assignment
16:07:37:WU01:FS00:Connecting to 65.254.110.245:8080
16:07:37:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:07:37:WU01:FS00:Connecting to 18.218.241.186:80
16:07:37:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:07:37:ERROR:WU01:FS00:Exception: Could not get an assignment
16:54:36:WU01:FS00:Connecting to 65.254.110.245:8080
16:54:36:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:54:36:WU01:FS00:Connecting to 18.218.241.186:80
16:54:36:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:54:36:ERROR:WU01:FS00:Exception: Could not get an assignment
18:10:36:WU01:FS00:Connecting to 65.254.110.245:8080
18:10:37:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:10:37:WU01:FS00:Connecting to 18.218.241.186:80
18:10:37:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:10:37:ERROR:WU01:FS00:Exception: Could not get an assignment
20:13:36:WU01:FS00:Connecting to 65.254.110.245:8080
20:13:36:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:13:36:WU01:FS00:Connecting to 18.218.241.186:80
20:13:37:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:13:37:ERROR:WU01:FS00:Exception: Could not get an assignment
23:32:37:WU01:FS00:Connecting to 65.254.110.245:8080
23:32:37:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:32:37:WU01:FS00:Connecting to 18.218.241.186:80
23:32:37:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:32:37:ERROR:WU01:FS00:Exception: Could not get an assignment
******************************* Date: 2020-03-24 *******************************
04:54:37:WU01:FS00:Connecting to 65.254.110.245:8080
04:54:37:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
04:54:37:WU01:FS00:Connecting to 18.218.241.186:80
04:54:37:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
04:54:37:ERROR:WU01:FS00:Exception: Could not get an assignment
Processor: I7-4770 Memory: 32Gig RAM GPU: GeForce GTX 1660 MB: GigaByte GA-B85M-D3H
Robby_Firefox
Fresh coding from a past midnight CDT run on March 24 (or after 0600 GMT). Now to see if they make the 6 AM extremeoverclocking list.
Am glad to see FAH's stat list is operating again, THANK!!!
Robby
*********************** Log Started 2020-03-24T06:05:43Z ***********************
06:05:43:************************* Folding@home Client *************************
06:05:43:        Website: https://foldingathome.org/
06:05:43:      Copyright: (c) 2009-2018 foldingathome.org
06:05:43:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:05:43:           Args:
06:05:43:         Config: C:\Users\bobb1\AppData\Roaming\FAHClient\config.xml
06:05:43:******************************** Build ********************************
06:05:43:        Version: 7.5.1
06:05:43:           Date: May 11 2018
06:05:43:           Time: 13:06:32
06:05:43:     Repository: Git
06:05:43:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
06:05:43:         Branch: master
06:05:43:       Compiler: Visual C++ 2008
06:05:43:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:05:43:       Platform: win32 10
06:05:43:           Bits: 32
06:05:43:           Mode: Release
06:05:43:******************************* System ********************************
06:05:43:            CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
06:05:43:         CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
06:05:43:           CPUs: 8
06:05:43:         Memory: 15.89GiB
06:05:43:    Free Memory: 9.43GiB
06:05:43:        Threads: WINDOWS_THREADS
06:05:43:     OS Version: 6.2
06:05:43:    Has Battery: true
06:05:43:     On Battery: false
06:05:43:     UTC Offset: -5
06:05:43:            PID: 6552
06:05:43:            CWD: C:\WINDOWS\system32
06:05:43:             OS: Windows 10 Home
06:05:43:        OS Arch: AMD64
06:05:43:           GPUs: 0
06:05:43:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
06:05:43:                 specified module could not be found.
06:05:43:
06:05:43:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:1.2 Driver:20.19
06:05:43:  Win32 Service: true
06:05:43:***********************************************************************
06:05:43:<config>
06:05:43:  <!-- Network -->
06:05:43:  <proxy v=':8080'/>
06:05:43:
06:05:43:  <!-- Slot Control -->
06:05:43:  <power v='full'/>
06:05:43:
06:05:43:  <!-- User Information -->
06:05:43:  <passkey v='********************************'/>
06:05:43:  <team v='1'/>
06:05:43:  <user v='Robby'/>
06:05:43:
06:05:43:  <!-- Work Unit Control -->
06:05:43:  <next-unit-percentage v='100'/>
06:05:43:
06:05:43:  <!-- Folding Slots -->
06:05:43:  <slot id='0' type='CPU'/>
06:05:43:</config>
06:05:43:Trying to access database...
06:05:43:Successfully acquired database lock
06:05:43:Enabled folding slot 00: READY cpu:8
06:05:43:ERROR:Exception: Failed to register systray icon: Unspecified error
06:05:43:WU00:FS00:Connecting to 65.254.110.245:8080
06:05:44:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:05:44:WU00:FS00:Connecting to 18.218.241.186:80
06:05:45:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:05:45:ERROR:WU00:FS00:Exception: Could not get an assignment
06:05:45:WU00:FS00:Connecting to 65.254.110.245:8080
06:05:46:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
06:05:46:WU00:FS00:Connecting to 18.218.241.186:80
06:05:46:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
06:05:46:ERROR:WU00:FS00:Exception: Could not get an assignment
06:06:45:WU00:FS00:Connecting to 65.254.110.245:8080
06:06:46:WU00:FS00:Assigned to work server 155.247.164.214
06:06:46:WU00:FS00:Requesting new work unit for slot 00: READY cpu:8 from 155.247.164.214
06:06:46:WU00:FS00:Connecting to 155.247.164.214:8080
06:06:47:WU00:FS00:Downloading 1.53MiB
06:06:47:WU00:FS00:Download complete
06:06:47:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14328 run:5 clone:2528 gen:29 core:0xa7 unit:0x000000219bf7a4d65e6d0f5bc413bfb9
06:06:48:WU00:FS00:Starting
06:06:48:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\bobb1\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 6552 -checkpoint 15 -np 8 -service
06:06:48:WU00:FS00:Started FahCore on PID 9564
06:06:48:WU00:FS00:Core PID:24744
06:06:48:WU00:FS00:FahCore 0xa7 started
06:06:48:WU00:FS00:0xa7:*********************** Log Started 2020-03-24T06:06:48Z ***********************
06:06:48:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:06:48:WU00:FS00:0xa7:       Type: 0xa7
06:06:48:WU00:FS00:0xa7:       Core: Gromacs
06:06:48:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 9564 -checkpoint 15 -np 8
06:06:48:WU00:FS00:0xa7:             -service
06:06:48:WU00:FS00:0xa7:************************************ CBang *************************************
06:06:48:WU00:FS00:0xa7:       Date: Oct 26 2019
06:06:48:WU00:FS00:0xa7:       Time: 01:38:25
06:06:48:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
06:06:48:WU00:FS00:0xa7:     Branch: master
06:06:48:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
06:06:48:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
06:06:48:WU00:FS00:0xa7:   Platform: win32 10
06:06:48:WU00:FS00:0xa7:       Bits: 64
06:06:48:WU00:FS00:0xa7:       Mode: Release
06:06:48:WU00:FS00:0xa7:************************************ System ************************************
06:06:48:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
06:06:48:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
06:06:48:WU00:FS00:0xa7:       CPUs: 8
06:06:48:WU00:FS00:0xa7:     Memory: 15.89GiB
06:06:48:WU00:FS00:0xa7:Free Memory: 8.70GiB
06:06:48:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
06:06:48:WU00:FS00:0xa7: OS Version: 6.2
06:06:48:WU00:FS00:0xa7:Has Battery: true
06:06:48:WU00:FS00:0xa7: On Battery: false
06:06:48:WU00:FS00:0xa7: UTC Offset: -5
06:06:48:WU00:FS00:0xa7:        PID: 24744
06:06:48:WU00:FS00:0xa7:        CWD: C:\Users\bobb1\AppData\Roaming\FAHClient\work
06:06:48:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
06:06:48:WU00:FS00:0xa7:    Version: 0.0.18
06:06:48:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:06:48:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
06:06:48:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
06:06:48:WU00:FS00:0xa7:       Time: 01:52:30
06:06:48:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
06:06:48:WU00:FS00:0xa7:************************************ Build *************************************
06:06:48:WU00:FS00:0xa7:       SIMD: avx_256
06:06:48:WU00:FS00:0xa7:********************************************************************************
06:06:48:WU00:FS00:0xa7:Project: 14328 (Run 5, Clone 2528, Gen 29)
06:06:48:WU00:FS00:0xa7:Unit: 0x000000219bf7a4d65e6d0f5bc413bfb9
06:06:48:WU00:FS00:0xa7:Reading tar file core.xml
06:06:48:WU00:FS00:0xa7:Reading tar file frame29.tpr
06:06:48:WU00:FS00:0xa7:Digital signatures verified
06:06:48:WU00:FS00:0xa7:Calling: mdrun -s frame29.tpr -o frame29.trr -cpt 15 -nt 8
06:06:48:WU00:FS00:0xa7:Steps: first=7250000 total=250000
06:06:50:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
06:07:55:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
06:08:58:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
06:10:05:WU00:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
06:11:10:WU00:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
06:12:14:WU00:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
06:13:21:WU00:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
06:14:26:WU00:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
06:15:32:WU00:FS00:0xa7:Completed 20000 out of 250000 steps (8%)
06:16:36:WU00:FS00:0xa7:Completed 22500 out of 250000 steps (9%)
06:17:42:WU00:FS00:0xa7:Completed 25000 out of 250000 steps (10%)
06:18:47:WU00:FS00:0xa7:Completed 27500 out of 250000 steps (11%)
06:19:54:WU00:FS00:0xa7:Completed 30000 out of 250000 steps (12%)
06:21:01:WU00:FS00:0xa7:Completed 32500 out of 250000 steps (13%)
06:22:09:WU00:FS00:0xa7:Completed 35000 out of 250000 steps (14%)
06:23:17:WU00:FS00:0xa7:Completed 37500 out of 250000 steps (15%)
06:24:23:WU00:FS00:0xa7:Completed 40000 out of 250000 steps (16%)
06:25:29:WU00:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
06:26:39:WU00:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
06:27:47:WU00:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
06:28:56:WU00:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
06:30:04:WU00:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
06:31:37:WU00:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
06:33:02:WU00:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
06:34:25:WU00:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
06:35:39:WU00:FS00:0xa7:Completed 62500 out of 250000 steps (25%)
06:37:00:WU00:FS00:0xa7:Completed 65000 out of 250000 steps (26%)
06:38:33:WU00:FS00:0xa7:Completed 67500 out of 250000 steps (27%)
06:39:47:WU00:FS00:0xa7:Completed 70000 out of 250000 steps (28%)
06:41:07:WU00:FS00:0xa7:Completed 72500 out of 250000 steps (29%)
06:42:23:WU00:FS00:0xa7:Completed 75000 out of 250000 steps (30%)
06:43:42:WU00:FS00:0xa7:Completed 77500 out of 250000 steps (31%)
06:44:49:WU00:FS00:0xa7:Completed 80000 out of 250000 steps (32%)
06:45:55:WU00:FS00:0xa7:Completed 82500 out of 250000 steps (33%)
06:47:00:WU00:FS00:0xa7:Completed 85000 out of 250000 steps (34%)
06:48:05:WU00:FS00:0xa7:Completed 87500 out of 250000 steps (35%)
06:49:12:WU00:FS00:0xa7:Completed 90000 out of 250000 steps (36%)
06:50:18:WU00:FS00:0xa7:Completed 92500 out of 250000 steps (37%)
06:51:24:WU00:FS00:0xa7:Completed 95000 out of 250000 steps (38%)
06:52:31:WU00:FS00:0xa7:Completed 97500 out of 250000 steps (39%)
06:53:36:WU00:FS00:0xa7:Completed 100000 out of 250000 steps (40%)
06:54:41:WU00:FS00:0xa7:Completed 102500 out of 250000 steps (41%)
06:55:46:WU00:FS00:0xa7:Completed 105000 out of 250000 steps (42%)
06:56:52:WU00:FS00:0xa7:Completed 107500 out of 250000 steps (43%)
06:57:57:WU00:FS00:0xa7:Completed 110000 out of 250000 steps (44%)
06:59:02:WU00:FS00:0xa7:Completed 112500 out of 250000 steps (45%)
07:00:07:WU00:FS00:0xa7:Completed 115000 out of 250000 steps (46%)
07:01:14:WU00:FS00:0xa7:Completed 117500 out of 250000 steps (47%)
07:02:19:WU00:FS00:0xa7:Completed 120000 out of 250000 steps (48%)
07:03:24:WU00:FS00:0xa7:Completed 122500 out of 250000 steps (49%)
07:04:30:WU00:FS00:0xa7:Completed 125000 out of 250000 steps (50%)
07:05:37:WU00:FS00:0xa7:Completed 127500 out of 250000 steps (51%)
07:06:43:WU00:FS00:0xa7:Completed 130000 out of 250000 steps (52%)
07:07:49:WU00:FS00:0xa7:Completed 132500 out of 250000 steps (53%)
07:08:55:WU00:FS00:0xa7:Completed 135000 out of 250000 steps (54%)
07:10:04:WU00:FS00:0xa7:Completed 137500 out of 250000 steps (55%)
07:11:10:WU00:FS00:0xa7:Completed 140000 out of 250000 steps (56%)
07:12:15:WU00:FS00:0xa7:Completed 142500 out of 250000 steps (57%)
07:13:20:WU00:FS00:0xa7:Completed 145000 out of 250000 steps (58%)
07:14:26:WU00:FS00:0xa7:Completed 147500 out of 250000 steps (59%)
07:15:32:WU00:FS00:0xa7:Completed 150000 out of 250000 steps (60%)
07:16:38:WU00:FS00:0xa7:Completed 152500 out of 250000 steps (61%)
07:17:43:WU00:FS00:0xa7:Completed 155000 out of 250000 steps (62%)
07:18:48:WU00:FS00:0xa7:Completed 157500 out of 250000 steps (63%)
07:19:57:WU00:FS00:0xa7:Completed 160000 out of 250000 steps (64%)
07:21:03:WU00:FS00:0xa7:Completed 162500 out of 250000 steps (65%)
07:22:09:WU00:FS00:0xa7:Completed 165000 out of 250000 steps (66%)
07:23:14:WU00:FS00:0xa7:Completed 167500 out of 250000 steps (67%)
07:24:20:WU00:FS00:0xa7:Completed 170000 out of 250000 steps (68%)
07:25:26:WU00:FS00:0xa7:Completed 172500 out of 250000 steps (69%)
07:26:32:WU00:FS00:0xa7:Completed 175000 out of 250000 steps (70%)
07:27:37:WU00:FS00:0xa7:Completed 177500 out of 250000 steps (71%)
07:28:42:WU00:FS00:0xa7:Completed 180000 out of 250000 steps (72%)
07:29:48:WU00:FS00:0xa7:Completed 182500 out of 250000 steps (73%)
07:30:08:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
07:30:57:WU00:FS00:0xa7:Completed 185000 out of 250000 steps (74%)
07:32:06:WU00:FS00:0xa7:Completed 187500 out of 250000 steps (75%)
07:33:10:WU00:FS00:0xa7:Completed 190000 out of 250000 steps (76%)
07:34:16:WU00:FS00:0xa7:Completed 192500 out of 250000 steps (77%)
07:35:21:WU00:FS00:0xa7:Completed 195000 out of 250000 steps (78%)
07:36:27:WU00:FS00:0xa7:Completed 197500 out of 250000 steps (79%)
07:37:33:WU00:FS00:0xa7:Completed 200000 out of 250000 steps (80%)
07:38:37:WU00:FS00:0xa7:Completed 202500 out of 250000 steps (81%)
07:39:42:WU00:FS00:0xa7:Completed 205000 out of 250000 steps (82%)
07:41:02:WU00:FS00:0xa7:Completed 207500 out of 250000 steps (83%)
07:42:33:WU00:FS00:0xa7:Completed 210000 out of 250000 steps (84%)
07:44:02:WU00:FS00:0xa7:Completed 212500 out of 250000 steps (85%)
07:45:32:WU00:FS00:0xa7:Completed 215000 out of 250000 steps (86%)
07:47:01:WU00:FS00:0xa7:Completed 217500 out of 250000 steps (87%)
07:48:30:WU00:FS00:0xa7:Completed 220000 out of 250000 steps (88%)
07:49:59:WU00:FS00:0xa7:Completed 222500 out of 250000 steps (89%)
07:51:30:WU00:FS00:0xa7:Completed 225000 out of 250000 steps (90%)
07:53:01:WU00:FS00:0xa7:Completed 227500 out of 250000 steps (91%)
07:54:30:WU00:FS00:0xa7:Completed 230000 out of 250000 steps (92%)
07:55:59:WU00:FS00:0xa7:Completed 232500 out of 250000 steps (93%)
07:57:27:WU00:FS00:0xa7:Completed 235000 out of 250000 steps (94%)
07:58:58:WU00:FS00:0xa7:Completed 237500 out of 250000 steps (95%)
08:00:29:WU00:FS00:0xa7:Completed 240000 out of 250000 steps (96%)
08:01:37:WU00:FS00:0xa7:Completed 242500 out of 250000 steps (97%)
08:02:45:WU00:FS00:0xa7:Completed 245000 out of 250000 steps (98%)
08:03:54:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
08:05:01:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
08:05:02:WU01:FS00:Connecting to 65.254.110.245:8080
08:05:02:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:05:02:WU01:FS00:Connecting to 18.218.241.186:80
08:05:03:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:05:03:ERROR:WU01:FS00:Exception: Could not get an assignment
08:05:03:WU01:FS00:Connecting to 65.254.110.245:8080
08:05:03:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:05:03:WU01:FS00:Connecting to 18.218.241.186:80
08:05:04:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:05:04:ERROR:WU01:FS00:Exception: Could not get an assignment
08:05:04:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
08:05:04:WU00:FS00:0xa7:Saving result file frame29.trr
08:05:04:WU00:FS00:0xa7:Saving result file md.log
08:05:05:WU00:FS00:0xa7:Saving result file science.log
08:05:05:WU00:FS00:0xa7:Saving result file traj_comp.xtc
08:05:05:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
08:05:05:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:05:05:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14328 run:5 clone:2528 gen:29 core:0xa7 unit:0x000000219bf7a4d65e6d0f5bc413bfb9
08:05:05:WU00:FS00:Uploading 4.96MiB to 155.247.164.214
08:05:05:WU00:FS00:Connecting to 155.247.164.214:8080
08:05:06:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
08:05:06:WU00:FS00:Trying to send results to collection server
08:05:06:WU00:FS00:Uploading 4.96MiB to 128.252.203.9
08:05:06:WU00:FS00:Connecting to 128.252.203.9:8080
08:05:10:ERROR:WU00:FS00:Exception: Transfer failed
08:05:10:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14328 run:5 clone:2528 gen:29 core:0xa7 unit:0x000000219bf7a4d65e6d0f5bc413bfb9
08:05:11:WU00:FS00:Uploading 4.96MiB to 155.247.164.214
08:05:11:WU00:FS00:Connecting to 155.247.164.214:8080
08:05:14:WU00:FS00:Upload complete
08:05:14:WU00:FS00:Server responded WORK_ACK (400)
08:05:14:WU00:FS00:Final credit estimate, 2044.00 points
08:05:15:WU00:FS00:Cleaning up
08:06:03:WU01:FS00:Connecting to 65.254.110.245:8080
08:06:03:WU01:FS00:Assigned to work server 40.114.52.201
08:06:03:WU01:FS00:Requesting new work unit for slot 00: READY cpu:8 from 40.114.52.201
08:06:03:WU01:FS00:Connecting to 40.114.52.201:8080
08:06:24:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
08:06:24:WU01:FS00:Connecting to 40.114.52.201:80
08:06:45:ERROR:WU01:FS00:Exception: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:07:40:WU01:FS00:Connecting to 65.254.110.245:8080
08:07:40:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:07:40:WU01:FS00:Connecting to 18.218.241.186:80
08:07:41:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:07:41:ERROR:WU01:FS00:Exception: Could not get an assignment
08:10:18:WU01:FS00:Connecting to 65.254.110.245:8080
08:10:18:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:10:18:WU01:FS00:Connecting to 18.218.241.186:80
08:10:18:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:10:18:ERROR:WU01:FS00:Exception: Could not get an assignment
kerryd
Re: Some WUs send without points
Post by kerryd »
Not sure about no points but I do know I got one hung up that been that way so it will get no QRB . And if still hung in 3 hours will get no points . shoud say WU is done but not uploading
Frontiers
Hardware configuration: Ryzen 5 5600x
G.Skill 2x16 GB 3200@3333
GTX 1070
Lancool II Mesh Perf.
Linux Mint 21.3
some drives, some cooler, some peripherials
Post by Frontiers »
Again same issue few hours ago with project 11772, run:0 clone:17972 gen:0 core:0x22 unit:0x00000001287234c95e774bbd5a668d13.
13.82.98.119 responded WORK_ACK final credit estimate 15396 points, but without QRB – estimated points in FAH-client were 102700 for this WU but no points at all for this WU nor in EOC stats nor in stats.foldingathome.org.
This problem in not only mine, it looks system-wide now. I see in EOC stats some cluster crunching with ~3700 Fah_Cores, named CoreWeave in team CoreWeave. Twelve days ago that cluster got close to 100M PPD, for the last 3 days their stats drops to 24-40M PPD.
I highly doubt that they turned off 75% of compute power during these bad times, so such huge visible drop in PPD is statistics bug.
My PC is not hanging up for months. But I have for last 10 days problems with uploads of results - completed WUs sometimes upload as usual, sometimes after multiple retries to upload to different servers - upload may happen up to 2-3 hours later after WU completion.
But this concrete absent WU was uploaded rather quickly after completion.
Log part:
09:05:24:WU00:FS01:0x22:Completed 960000 out of 1000000 steps (96%)
09:07:09:WU00:FS01:0x22:Completed 970000 out of 1000000 steps (97%)
09:08:53:WU00:FS01:0x22:Completed 980000 out of 1000000 steps (98%)
09:10:37:WU00:FS01:0x22:Completed 990000 out of 1000000 steps (99%)
09:12:22:WU00:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
09:12:30:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
09:12:30:WU00:FS01:0x22:Saving result file checkpointState.xml
09:12:30:WU00:FS01:0x22:Saving result file checkpt.crc
09:12:30:WU00:FS01:0x22:Saving result file positions.xtc
09:12:30:WU00:FS01:0x22:Saving result file science.log
09:12:31:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
09:12:31:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:12:31:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11776 run:0 clone:17972 gen:0 core:0x22 unit:0x00000001287234c95e774bbd5a668d13
09:12:31:WU00:FS01:Uploading 49.92MiB to 40.114.52.201
09:12:31:WU00:FS01:Connecting to 40.114.52.201:8080
09:12:52:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
09:12:53:WU00:FS01:Connecting to 40.114.52.201:80
09:13:14:WARNING:WU00:FS01:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:13:14:WU00:FS01:Trying to send results to collection server
09:13:14:WU00:FS01:Uploading 49.92MiB to 13.82.98.119
09:13:14:WU00:FS01:Connecting to 13.82.98.119:8080
09:13:20:WU00:FS01:Upload 2.25%
09:13:26:WU00:FS01:Upload 13.90%
09:13:32:WU00:FS01:Upload 81.75%
09:13:33:WU00:FS01:Upload complete
09:13:34:WU00:FS01:Server responded WORK_ACK (400)
09:13:34:WU00:FS01:Final credit estimate, 15396.00 points
09:13:34:WU00:FS01:Cleaning up
Frontiers
GTX 1070
Linux Mint 21.3
Post by Frontiers »
Joe_H wrote:Have you completed and returned 10 or more WUs after setting your passkey in the client? If so, this may be due to the issue bruce posted about and someone will be working on this, and eventually it will get fixed.
I had completed 10000 WUs with passkey.
Because some completed WUs not granted in statistics even with base points - obviously this problem is not with passkey /no passkey, but somewhere at servers side - at work servers or at statistic server.
Frontiers
GTX 1070
Linux Mint 21.3
Post by Frontiers »
Another problem - very slow uploads for last 3-4 days. My connection speed is 50 Mbit and before uploads were fast, sending was just 3-10 seconds per WU.
Nothing changed in network configuration, or in firewall or router options, but now uploads looking like this:
11:31:03:WU00:FS01:0x22:Completed 1980000 out of 2000000 steps (99%)
11:32:20:WU00:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
11:32:23:WU00:FS01:0x22:Saving result file ..\logfile_01.txt
11:32:23:WU00:FS01:0x22:Saving result file checkpointState.xml
11:32:24:WU00:FS01:0x22:Saving result file checkpt.crc
11:32:24:WU00:FS01:0x22:Saving result file positions.xtc
11:32:24:WU00:FS01:0x22:Saving result file science.log
11:32:24:WU00:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
11:32:24:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:32:24:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11777 run:0 clone:19847 gen:1 core:0x22 unit:0x00000004287234c95e774a4e4e73aaf7
11:32:24:WU00:FS01:Uploading 23.06MiB to 40.114.52.201
11:32:24:WU00:FS01:Connecting to 40.114.52.201:8080
11:32:45:WARNING:WU00:FS01:WorkServer connection failed on port 8080 trying 80
11:32:45:WU00:FS01:Connecting to 40.114.52.201:80
11:32:45:WU00:FS01:Upload 0.27%
11:33:04:WU00:FS01:Upload 0.81%
11:33:13:WU00:FS01:Upload 2.17%
11:33:21:WU00:FS01:Upload 2.71%
11:33:32:WU00:FS01:Upload 3.25%
11:33:40:WU00:FS01:Upload 3.79%
11:33:50:WU00:FS01:Upload 4.06%
11:33:58:WU00:FS01:Upload 4.34%
11:34:09:WU00:FS01:Upload 4.61%
11:34:22:WU00:FS01:Upload 4.88%
11:34:28:WU00:FS01:Upload 5.15%
11:34:36:WU00:FS01:Upload 5.42%
11:34:45:WU00:FS01:Upload 5.69%
11:34:54:WU00:FS01:Upload 5.96%
11:35:03:WU00:FS01:Upload 6.23%
11:35:10:WU00:FS01:Upload 6.77%
11:35:16:WU00:FS01:Upload 7.05%
11:35:32:WU00:FS01:Upload 7.59%
11:35:40:WU00:FS01:Upload 7.86%
11:35:50:WU00:FS01:Upload 8.13%
11:35:57:WU00:FS01:Upload 8.67%
11:36:04:WU00:FS01:Upload 9.21%
11:36:10:WU00:FS01:Upload 9.76%
11:36:16:WU00:FS01:Upload 10.30%
11:36:23:WU00:FS01:Upload 10.84%
11:36:34:WU00:FS01:Upload 11.38%
11:36:40:WU00:FS01:Upload 11.92%
11:36:46:WU00:FS01:Upload 12.19%
11:36:53:WU00:FS01:Upload 12.47%
11:36:59:WU00:FS01:Upload 12.74%
11:37:08:WU00:FS01:Upload 13.28%
11:37:15:WU00:FS01:Upload 13.82%
11:37:21:WU00:FS01:Upload 14.36%
11:37:28:WU00:FS01:Upload 14.90%
11:37:35:WU00:FS01:Upload 15.45%
11:37:42:WU00:FS01:Upload 15.99%
11:37:49:WU00:FS01:Upload 16.53%
11:37:55:WU00:FS01:Upload 17.34%
11:38:01:WU00:FS01:Upload 17.89%
11:38:05:WU01:FS01:Connecting to 65.254.110.245:8080
11:38:06:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:38:06:WU01:FS01:Connecting to 18.218.241.186:80
11:38:07:WU00:FS01:Upload 18.70%
11:38:07:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:38:07:ERROR:WU01:FS01:Exception: Could not get an assignment
11:38:07:WU01:FS01:Connecting to 65.254.110.245:8080
11:38:08:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:38:08:WU01:FS01:Connecting to 18.218.241.186:80
11:38:08:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:38:08:ERROR:WU01:FS01:Exception: Could not get an assignment
11:38:13:WU00:FS01:Upload 19.51%
11:38:21:WU00:FS01:Upload 20.32%
11:38:28:WU00:FS01:Upload 21.14%
11:38:34:WU00:FS01:Upload 21.68%
11:38:42:WU00:FS01:Upload 22.22%
11:38:51:WU00:FS01:Upload 22.76%
11:39:00:WU00:FS01:Upload 23.03%
11:39:07:WU00:FS01:Upload 23.58%
11:39:07:WU01:FS01:Connecting to 65.254.110.245:8080
11:39:08:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:39:08:WU01:FS01:Connecting to 18.218.241.186:80
11:39:08:WU01:FS01:Assigned to work server 40.114.52.201
11:39:08:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1070] 6463 from 40.114.52.201
11:39:08:WU01:FS01:Connecting to 40.114.52.201:8080
11:39:15:WU00:FS01:Upload 24.12%
11:39:21:WU00:FS01:Upload 24.66%
11:39:27:WU00:FS01:Upload 24.93%
11:39:29:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
11:39:29:WU01:FS01:Connecting to 40.114.52.201:80
11:39:37:WU00:FS01:Upload 25.47%
11:39:43:WU00:FS01:Upload 25.74%
11:39:51:ERROR:WU01:FS01:Exception: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
11:39:51:WU00:FS01:Upload 26.29%
11:39:57:WU00:FS01:Upload 26.56%
11:40:03:WU00:FS01:Upload 26.83%
11:40:14:WU00:FS01:Upload 27.37%
11:40:22:WU00:FS01:Upload 27.64%
11:40:29:WU00:FS01:Upload 28.18%
11:40:43:WU00:FS01:Upload 28.45%
11:40:44:WU01:FS01:Connecting to 65.254.110.245:8080
11:40:45:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:40:45:WU01:FS01:Connecting to 18.218.241.186:80
11:40:46:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:40:46:ERROR:WU01:FS01:Exception: Could not get an assignment
11:40:53:WU00:FS01:Upload 29.00%
11:41:00:WU00:FS01:Upload 29.27%
11:41:10:WU00:FS01:Upload 29.81%
11:41:18:WU00:FS01:Upload 30.35%
11:41:24:WU00:FS01:Upload 30.89%
11:41:32:WU00:FS01:Upload 31.71%
11:41:40:WU00:FS01:Upload 32.25%
11:41:47:WU00:FS01:Upload 32.79%
11:41:53:WU00:FS01:Upload 33.33%
11:42:02:WU00:FS01:Upload 33.87%
11:42:11:WU00:FS01:Upload 34.42%
11:42:19:WU00:FS01:Upload 35.23%
11:42:26:WU00:FS01:Upload 36.04%
11:42:32:WU00:FS01:Upload 36.58%
11:42:39:WU00:FS01:Upload 37.40%
11:42:46:WU00:FS01:Upload 37.94%
11:42:53:WU00:FS01:Upload 38.75%
11:42:59:WU00:FS01:Upload 39.29%
11:43:06:WU00:FS01:Upload 40.11%
11:43:13:WU00:FS01:Upload 40.38%
11:43:19:WU00:FS01:Upload 40.65%
11:43:21:WU01:FS01:Connecting to 65.254.110.245:8080
11:43:22:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:43:22:WU01:FS01:Connecting to 18.218.241.186:80
11:43:23:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:43:23:ERROR:WU01:FS01:Exception: Could not get an assignment
11:43:25:WU00:FS01:Upload 41.19%
11:43:31:WU00:FS01:Upload 42.00%
11:43:37:WU00:FS01:Upload 42.55%
11:43:44:WU00:FS01:Upload 43.63%
11:43:51:WU00:FS01:Upload 44.44%
11:43:58:WU00:FS01:Upload 45.26%
11:44:05:WU00:FS01:Upload 46.07%
11:44:11:WU00:FS01:Upload 46.61%
11:44:17:WU00:FS01:Upload 47.42%
11:44:23:WU00:FS01:Upload 47.97%
11:44:33:WU00:FS01:Upload 48.78%
11:44:40:WU00:FS01:Upload 49.32%
11:44:46:WU00:FS01:Upload 49.86%
11:44:54:WU00:FS01:Upload 50.68%
11:45:01:WU00:FS01:Upload 51.22%
11:45:10:WU00:FS01:Upload 51.76%
11:45:16:WU00:FS01:Upload 52.57%
11:45:24:WU00:FS01:Upload 53.39%
11:45:30:WU00:FS01:Upload 54.20%
11:45:36:WU00:FS01:Upload 54.74%
11:45:43:WU00:FS01:Upload 55.83%
11:45:50:WU00:FS01:Upload 56.91%
11:45:56:WU00:FS01:Upload 57.72%
11:46:03:WU00:FS01:Upload 58.81%
11:46:09:WU00:FS01:Upload 59.62%
11:46:17:WU00:FS01:Upload 60.70%
11:46:23:WU00:FS01:Upload 61.52%
11:46:29:WU00:FS01:Upload 62.33%
11:46:36:WU00:FS01:Upload 63.14%
11:46:42:WU00:FS01:Upload 63.68%
11:46:48:WU00:FS01:Upload 64.77%
11:46:54:WU00:FS01:Upload 65.58%
11:47:00:WU00:FS01:Upload 66.67%
11:47:06:WU00:FS01:Upload 67.48%
11:47:13:WU00:FS01:Upload 68.56%
11:47:19:WU00:FS01:Upload 69.65%
11:47:25:WU00:FS01:Upload 70.46%
11:47:31:WU00:FS01:Upload 71.54%
11:47:36:WU01:FS01:Connecting to 65.254.110.245:8080
11:47:36:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:47:36:WU01:FS01:Connecting to 18.218.241.186:80
11:47:37:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:47:37:ERROR:WU01:FS01:Exception: Could not get an assignment
11:47:38:WU00:FS01:Upload 72.63%
11:47:44:WU00:FS01:Upload 73.71%
11:47:50:WU00:FS01:Upload 74.80%
11:47:56:WU00:FS01:Upload 75.88%
11:48:02:WU00:FS01:Upload 76.96%
11:48:09:WU00:FS01:Upload 78.05%
11:48:16:WU00:FS01:Upload 79.13%
11:48:23:WU00:FS01:Upload 80.49%
11:48:23:Started thread 23 on PID 8352
11:48:30:WU00:FS01:Upload 81.84%
11:48:36:WU00:FS01:Upload 82.93%
11:48:43:WU00:FS01:Upload 83.74%
11:48:50:WU00:FS01:Upload 84.82%
11:48:56:WU00:FS01:Upload 85.91%
11:49:04:WU00:FS01:Upload 86.45%
11:49:10:WU00:FS01:Upload 87.26%
11:49:17:WU00:FS01:Upload 88.07%
11:49:24:WU00:FS01:Upload 89.16%
11:49:30:WU00:FS01:Upload 89.43%
11:49:53:WU00:FS01:Upload 89.70%
11:50:06:WU00:FS01:Upload 90.24%
11:50:13:WU00:FS01:Upload 90.78%
11:50:23:WU00:FS01:Upload 91.60%
11:50:32:WU00:FS01:Upload 92.14%
11:50:40:WU00:FS01:Upload 92.68%
11:50:46:WU00:FS01:Upload 93.22%
11:50:53:WU00:FS01:Upload 93.76%
11:51:02:WU00:FS01:Upload 94.58%
11:51:13:WU00:FS01:Upload 94.85%
11:51:22:WU00:FS01:Upload 95.39%
11:51:30:WU00:FS01:Upload 95.93%
11:51:37:WU00:FS01:Upload 96.47%
11:51:43:WU00:FS01:Upload 97.02%
11:51:50:WU00:FS01:Upload 97.83%
11:51:58:WU00:FS01:Upload 98.37%
11:52:07:WU00:FS01:Upload 98.64%
11:52:14:WU00:FS01:Upload 99.18%
11:52:23:WU00:FS01:Upload 100.00%
11:52:41:WU00:FS01:Upload complete
11:52:41:WU00:FS01:Server responded WORK_ACK (400)
11:52:41:WU00:FS01:Final credit estimate, 71549.00 points
11:52:41:WU00:FS01:Cleaning up
Zippie
Post by Zippie »
here it is again - a small excerpt from my logs:
17:55:55:WU02:FS01:0x22:Completed 1000000 out of 1000000 steps (100%)
17:56:02:WU02:FS01:0x22:Saving result file ..\logfile_01.txt
17:56:02:WU02:FS01:0x22:Saving result file checkpointState.xml
17:56:02:WU02:FS01:0x22:Saving result file checkpt.crc
17:56:02:WU02:FS01:0x22:Saving result file positions.xtc
17:56:02:WU02:FS01:0x22:Saving result file science.log
17:56:02:WU02:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
17:56:03:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:56:03:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:11776 run:0 clone:27742 gen:0 core:0x22 unit:0x00000001287234c95e774ae87050d74e
17:56:03:WU02:FS01:Uploading 49.92MiB to 40.114.52.201
17:56:03:WU02:FS01:Connecting to 40.114.52.201:8080
17:56:05:WU01:FS00:0xa7:Completed 75000 out of 125000 steps (60%)
17:56:12:WU00:FS01:Connecting to 65.254.110.245:8080
17:56:12:WARNING:WU00:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:56:12:WU00:FS01:Connecting to 18.218.241.186:80
17:56:12:WARNING:WU00:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:56:12:ERROR:WU00:FS01:Exception: Could not get an assignment
17:56:24:WARNING:WU02:FS01:WorkServer connection failed on port 8080 trying 80
17:56:24:WU02:FS01:Connecting to 40.114.52.201:80
17:56:45:WARNING:WU02:FS01:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:56:45:WU02:FS01:Trying to send results to collection server
17:56:46:WU02:FS01:Uploading 49.92MiB to 128.252.203.2
17:56:46:WU02:FS01:Connecting to 128.252.203.2:8080
17:56:52:WU02:FS01:Upload 22.66%
17:56:58:WU02:FS01:Upload 36.43%
17:57:04:WU02:FS01:Upload 53.83%
17:57:05:WU01:FS00:0xa7:Completed 76250 out of 125000 steps (61%)
17:57:10:WU02:FS01:Upload 67.73%
17:57:16:WU02:FS01:Upload 88.14%
17:57:20:WU02:FS01:Upload complete
17:57:20:WU02:FS01:Server responded WORK_ACK (400)
17:57:20:WU02:FS01:Final credit estimate, 15396.00 points
17:57:20:WU02:FS01:Cleaning up
that work unit should be well over 100k points - folding on a 2080ti @ approx. 1950 mhz
Robby_Firefox
Hardware configuration: Homebuilt Windows 10
Intel Core i7-4770 ~ started in early 2014 or 2015
32 GB RAM (up from 8 GB in 2018)
64-Bit Operating System
On 31 Mar 2020, installed a GigaByte GEFORCE GTX 1660 GPU
Post by Robby_Firefox »
Hi All,
Think it's a system problem, caused in part by the huge number of new folks who have joined FAH (mainly to help find treatment for the COVID-19 virus). Saw one from bruce of a 20-fold increase in participation, which is an enormous load on their infrastructure; a friendly DNS? They are working on it, have no idea of when a "true" resolution will appear. The bad of this is me being just a CPU folder is getting crushed by the multitude of new GPU users; passing me like I'm standing still... Getting pushed from 90th place to the upper 90s now is no fun and will get worst. Guess I'll update this machine or get a new one one of these days, probably after the virus has been conquered. No ill will for the newbies and their faster machines; anything to get this virus beat is worth the hurt.
The job I noted in my second post last last night CDT did finish, but was not counted until the 9 AM CDT extremeoverclocking.com site. Actually got a point more than was was estimated at 0805 GMT or 305 AM CDT. I'll post just this log below. My other computer also received a job last night in the 2 AM timeframe and finished it at 630 AM CDT or 1130 GMT. I surely thought that the job was going to earn 1200-1300 points, but I only got a "measly" 236 per it's logs. It is on a different network and I am short for time, will be glad to send logs from it if you wish, can do so late tonight or early Wed morning my time zone.
Thanks,
Robby
06:05:43:           Args:
06:05:43:           Bits: 32
06:05:43:           CPUs: 8
06:05:43:            PID: 6552
06:05:43:           GPUs: 0
06:05:43:
06:05:43:<config>
06:05:43:
06:05:43:
06:05:43:
06:05:43:
06:05:43:</config>
[b][color=#FF0040]08:05:14:WU00:FS00:Final credit estimate, 2044.00 points[/color][/b]
08:14:32:WU01:FS00:Connecting to 65.254.110.245:8080
08:14:32:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:14:32:WU01:FS00:Connecting to 18.218.241.186:80
08:14:32:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:14:32:ERROR:WU01:FS00:Exception: Could not get an assignment
08:21:23:WU01:FS00:Connecting to 65.254.110.245:8080
08:21:23:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:21:23:WU01:FS00:Connecting to 18.218.241.186:80
08:21:23:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:21:23:ERROR:WU01:FS00:Exception: Could not get an assignment
08:32:29:WU01:FS00:Connecting to 65.254.110.245:8080
08:32:29:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:32:29:WU01:FS00:Connecting to 18.218.241.186:80
08:32:29:WU01:FS00:Assigned to work server 128.252.203.9
08:32:29:WU01:FS00:Requesting new work unit for slot 00: READY cpu:8 from 128.252.203.9
08:32:29:WU01:FS00:Connecting to 128.252.203.9:8080
08:32:50:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
08:32:50:WU01:FS00:Connecting to 128.252.203.9:80
08:33:11:ERROR:WU01:FS00:Exception: Failed to connect to 128.252.203.9:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:50:26:WU01:FS00:Connecting to 65.254.110.245:8080
08:50:26:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:50:26:WU01:FS00:Connecting to 18.218.241.186:80
08:50:26:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:50:26:ERROR:WU01:FS00:Exception: Could not get an assignment
09:19:28:WU01:FS00:Connecting to 65.254.110.245:8080
09:19:28:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
09:19:28:WU01:FS00:Connecting to 18.218.241.186:80
09:19:28:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
09:19:28:ERROR:WU01:FS00:Exception: Could not get an assignment
10:06:26:WU01:FS00:Connecting to 65.254.110.245:8080
10:06:27:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:06:27:WU01:FS00:Connecting to 18.218.241.186:80
10:06:27:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:06:27:ERROR:WU01:FS00:Exception: Could not get an assignment
11:22:27:WU01:FS00:Connecting to 65.254.110.245:8080
11:22:28:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:22:28:WU01:FS00:Connecting to 18.218.241.186:80
11:22:28:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:22:28:ERROR:WU01:FS00:Exception: Could not get an assignment
13:25:27:WU01:FS00:Connecting to 65.254.110.245:8080
13:25:27:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
13:25:27:WU01:FS00:Connecting to 18.218.241.186:80
13:25:27:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
13:25:27:ERROR:WU01:FS00:Exception: Could not get an assignment
16:44:27:WU01:FS00:Connecting to 65.254.110.245:8080
16:44:27:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:44:27:WU01:FS00:Connecting to 18.218.241.186:80
16:44:28:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:44:28:ERROR:WU01:FS00:Exception: Could not get an assignment
kieft1986
Post by kieft1986 »
Hi Folks,
I got the same problem.
1. WU
20:30:43:WU00:FS00:0xa7:Completed 500000 out of 500000 steps (100%)
20:30:45:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
20:30:45:WU00:FS00:0xa7:Saving result file frame0.edr
20:30:45:WU00:FS00:0xa7:Saving result file frame0.trr
20:30:45:WU00:FS00:0xa7:Saving result file frame0.xtc
20:30:45:WU00:FS00:0xa7:Saving result file md.log
20:30:45:WU00:FS00:0xa7:Saving result file science.log
20:30:45:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
20:30:46:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:30:46:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13851 run:0 clone:24340 gen:0 core:0xa7 unit:0x00000001287234c95e7886e81c85c940
20:30:46:WU00:FS00:Uploading 2.59MiB to 40.114.52.201
20:30:46:WU00:FS00:Connecting to 40.114.52.201:8080
20:31:07:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
20:31:07:WU00:FS00:Connecting to 40.114.52.201:80
20:31:28:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 40.114.52.201:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
20:31:28:WU00:FS00:Trying to send results to collection server
20:31:28:WU00:FS00:Uploading 2.59MiB to 128.252.203.2
20:31:28:WU00:FS00:Connecting to 128.252.203.2:8080
20:31:34:WU00:FS00:Upload 84.50%
20:31:52:WU00:FS00:Upload complete
20:31:52:WU00:FS00:Server responded WORK_ACK (400)
20:31:52:WU00:FS00:Final credit estimate, 1000.00 points
20:31:52:WU00:FS00:Cleaning up
estimated 1000 points, but get zero
2.WU
23:54:51:WU01:FS00:Connecting to 65.254.110.245:8080
23:54:51:WU01:FS00:Assigned to work server 128.252.203.9
23:54:51:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 128.252.203.9
23:54:51:WU01:FS00:Connecting to 128.252.203.9:8080
23:55:13:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
23:55:13:WU01:FS00:Connecting to 128.252.203.9:80
23:55:34:ERROR:WU01:FS00:Exception: Failed to connect to 128.252.203.9:80: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.
23:55:35:WU01:FS00:Connecting to 65.254.110.245:8080
23:55:35:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:55:35:WU01:FS00:Connecting to 18.218.241.186:80
23:55:36:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:55:36:ERROR:WU01:FS00:Exception: Could not get an assignment
23:56:35:WU01:FS00:Connecting to 65.254.110.245:8080
23:56:35:WARNING:WU01:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
23:56:35:WU01:FS00:Connecting to 18.218.241.186:80
23:56:36:WARNING:WU01:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
23:56:36:ERROR:WU01:FS00:Exception: Could not get an assignment
23:56:43:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
23:56:49:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
23:56:49:WU00:FS00:0xa7:Saving result file frame22.trr
23:56:50:WU00:FS00:0xa7:Saving result file md.log
23:56:50:WU00:FS00:0xa7:Saving result file science.log
23:56:50:WU00:FS00:0xa7:Saving result file traj_comp.xtc
23:56:50:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
23:56:51:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:56:51:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:14328 run:7 clone:1504 gen:22 core:0xa7 unit:0x0000001b9bf7a4d65e6d0d81fc2ba6ff
23:56:51:WU00:FS00:Uploading 4.96MiB to 155.247.164.214
23:56:51:WU00:FS00:Connecting to 155.247.164.214:8080
23:56:57:WU00:FS00:Upload 44.08%
23:57:03:WU00:FS00:Upload 62.97%
23:57:09:WU00:FS00:Upload 85.64%
23:57:20:WU00:FS00:Upload complete
23:57:21:WU00:FS00:Server responded WORK_ACK (400)
23:57:21:WU00:FS00:Final credit estimate, 1608.00 points
23:57:21:WU00:FS00:Cleaning up
estimate 1608 and get 370
what can i do, that I get these points in my profile?
Profilename BenErdenberger
I see that he has total WU only 1 of 2. So... there is still some problem with the servers?
thx for help!
Just like the Work Servers, the servers for the stats are getting a very high rate of connection, and very large amounts of folding stats to enter. There may also be some setup issues with some of the new servers to be sorted out.
Getting the points recorded is important to the F@h team as the is how they give recognition for your contribution of computer resources. They will work on getting things caught up, and check for missing points, it may just take a bit of time. They do have methods of rechecking if all points that should have been awarded, and sometimes that shows up retroactively.
