RE: new starter [Problem w/ Chrome]
Sgtzraven
Post by Sgtzraven »
Hi all
Im trying to get it to start on my pc however it looks like the web browers contol just get stuck in a loop of refreshing?
it is actually working on jobs as the % are tickign up on my cores etc im jsut confused why the web one is just cycling ?
kind regards,
SgtzRaven
Nathan_P
Not currently folding
Re: RE: new starter
Post by Nathan_P »
try using FAHcontrol instead. It should be on your start menu. Its the advanced version of client control and is much more powerful than the web browser version. It doesn't look as pretty though.
Sgtzraven
Re: RE: new starter
Post by Sgtzraven »
Ah i also just loaded it up in Internet explorer it works fine but in Chrome it just loops,
Looks to be a chrome issue,
Sgtzraven,
Re: RE: new starter
Yes, it is a Chrome issue from a some change Google made a few months ago. Also affects some Chromium based browsers recently updated to new versions.
There are some workarounds for Chrome listed in the FAQ - viewtopic.php?f=24&t=32463
