New to F@H, I contributed to SETI@HOME way back 15-20 years ago.
Had about 900 pc's running SETI@Home.
I built a new monster to play games on, AMD Threadripper 1950x with 64gb and dual NVIDIA 1080TI 2 years ago.
Nothing every used the dual setup so I put 1 of them in another old AMD Ryzen 7 1800x.
I'm considering putting it back in my monster if F@H will actually utilize the second card.
TLDR:
Does F@H utilize multiple GPUs?
If YES, is there a limit?
Thanks
dual GPU question
- Hardware configuration: AMD Threadripper 1950x
32GB Ram
2TB SSD .m2
dual GPU question
Retired U.S. Army
32GB Ram
2TB SSD .m2
Started with Seti@Home
32GB Ram
2TB SSD .m2
Re: dual GPU question
And the limit is usually the number of PCIE channels, frequently a mother board with two GPUs will run both at x8, by 4 GPUs you are down to x4
with fewer channels you spend more time feeding data into the card, and so less time folding. Oddly Linux is much better at this than Windows, so if you run multiple cards, Linux looks better and better.
Not currently folding
JimboPalmer wrote:And the limit is usually the number of PCIE channels, frequently a mother board with two GPUs will run both at x8, by 4 GPUs you are down to x4
Only with mainstream hardware, Threadripper has enough lanes to run dual or even triple x16.
