Please add the Radeon RX 590
TarMoh
- Hardware configuration: Intel Core i5-8400
Radeon RX 590
16GB 2400MHz RAM C16
It crashes every few minutes, and I've now just realized that it is not on the compatibility list
Re: Please add the Readon RX 590
We will need a device ID for the card to have it added. Utilities such as GPU-Z will display that, or it can be found in the Device Manager.
TarMoh
Radeon RX 590
Re: Please add the Radeon RX 590
1002 67DF - 1682 9587
Hopefully this works!
Unfortunately, AMD keeps re-using the same hardware code 1002 67DF for a variety of GPUs. I've added the 590 to the human-readable name, but FAH recognizes them as identical hardware. I can't explain the crashes so I will bump this problem up to the OpenMM support team.
Please post the top couple of pages of FAH's log, per my Sig.
TarMoh
Radeon RX 590
*********************** Log Started 2020-03-22T18:41:28Z ***********************
18:41:28:************************* Folding@home Client *************************
18:41:28: Website: https://foldingathome.org/
18:41:28: Copyright: (c) 2009-2018 foldingathome.org
18:41:28: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:41:28: Args: --open-web-control
18:41:28: Config: <none>
18:41:28:******************************** Build ********************************
18:41:28: Version: 7.5.1
18:41:28: Date: May 11 2018
18:41:28: Time: 13:06:32
18:41:28: Repository: Git
18:41:28: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
18:41:28: Branch: master
18:41:28: Compiler: Visual C++ 2008
18:41:28: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:41:28: Platform: win32 10
18:41:28: Bits: 32
18:41:28: Mode: Release
18:41:28:******************************* System ********************************
18:41:28: CPU: Intel(R) Core(TM) i5-8400 CPU @ 2.80GHz
18:41:28: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
18:41:28: CPUs: 6
18:41:28: Memory: 15.94GiB
18:41:28: Free Memory: 8.32GiB
18:41:28: Threads: WINDOWS_THREADS
18:41:28: OS Version: 6.2
18:41:28: Has Battery: false
18:41:28: On Battery: false
18:41:28: UTC Offset: -4
18:41:28: PID: 12796
18:41:28: CWD: C:\Users\green\AppData\Roaming\FAHClient
18:41:28: OS: Windows 10 Home
18:41:28: OS Arch: AMD64
18:41:28: GPUs: 0
18:41:28: CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
18:41:28: specified module could not be found.
18:41:28:
18:41:28:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3004.8
18:41:28: Win32 Service: false
18:41:28:***********************************************************************
18:41:28:<config>
18:41:28: <!-- Folding Slots -->
18:41:28:</config>
18:41:28:Connecting to assign1.foldingathome.org:8080
18:41:28:Updated GPUs.txt
18:41:28:Read GPUs.txt
18:41:28:Trying to access database...
18:41:29:Successfully acquired database lock
18:41:29:Enabled folding slot 00: PAUSED cpu:4 (not configured)
18:41:29:Enabled folding slot 01: PAUSED gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] (not configured)
18:41:29:ERROR:Exception: Failed to register systray icon: Unspecified error
18:41:31:10:127.0.0.1:New Web connection
18:42:30:Saving configuration to config.xml
18:42:30:<config>
18:42:30: <!-- Folding Slots -->
18:42:30: <slot id='0' type='CPU'/>
18:42:30: <slot id='1' type='GPU'/>
18:42:30:</config>
18:42:30:Set client configured
18:42:30:WU00:FS00:Connecting to 65.254.110.245:8080
18:42:30:WU01:FS01:Connecting to 65.254.110.245:8080
18:42:30:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:42:30:WU00:FS00:Connecting to 18.218.241.186:80
18:42:30:WU01:FS01:Assigned to work server 40.114.52.201
18:42:30:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580/590] from 40.114.52.201
18:42:30:WU01:FS01:Connecting to 40.114.52.201:8080
18:42:30:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:42:30:ERROR:WU00:FS00:Exception: Could not get an assignment
18:42:31:WU00:FS00:Connecting to 65.254.110.245:8080
18:42:31:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:42:31:WU00:FS00:Connecting to 18.218.241.186:80
18:42:31:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:42:31:ERROR:WU00:FS00:Exception: Could not get an assignment
18:42:51:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
18:42:51:WU01:FS01:Connecting to 40.114.52.201:80
18:43:31:WU00:FS00:Connecting to 65.254.110.245:8080
18:43:31:Saving configuration to config.xml
18:43:31:<config>
18:43:31: <!-- Network -->
18:43:31: <proxy v=':8080'/>
18:43:31:
18:43:31: <!-- User Information -->
18:43:31: <passkey v='********************************'/>
18:43:31: <team v='223518'/>
18:43:31: <user v='Tarran_M'/>
18:43:31:
18:43:31: <!-- Folding Slots -->
18:43:31: <slot id='0' type='CPU'/>
18:43:31: <slot id='1' type='GPU'/>
18:43:31:</config>
18:43:31:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:43:31:WU00:FS00:Connecting to 18.218.241.186:80
18:43:31:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:43:31:ERROR:WU00:FS00:Exception: Could not get an assignment
18:44:19:WU01:FS01:Downloading 29.59MiB
18:44:26:WU01:FS01:Download 0.84%
18:44:32:Saving configuration to config.xml
18:44:32:<config>
18:44:32: <!-- Network -->
18:44:32: <proxy v=':8080'/>
18:44:32:
18:44:32: <!-- User Information -->
18:44:32: <passkey v='********************************'/>
18:44:32: <team v='223518'/>
18:44:32: <user v='Tarran_M'/>
18:44:32:
18:44:32: <!-- Folding Slots -->
18:44:32: <slot id='0' type='CPU'/>
18:44:32: <slot id='1' type='GPU'/>
18:44:32:</config>
18:44:33:WU01:FS01:Download 5.07%
18:44:40:WU01:FS01:Download 11.41%
18:44:47:WU01:FS01:Download 37.39%
18:44:55:WU01:FS01:Download 50.27%
18:45:04:WU01:FS01:Download 59.78%
18:45:08:WU00:FS00:Connecting to 65.254.110.245:8080
18:45:08:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:45:08:WU00:FS00:Connecting to 18.218.241.186:80
18:45:08:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:45:08:ERROR:WU00:FS00:Exception: Could not get an assignment
18:45:11:WU01:FS01:Download 69.49%
18:45:20:WU01:FS01:Download 76.04%
18:45:26:WU01:FS01:Download 85.55%
18:45:32:WU01:FS01:Download 88.93%
18:45:40:WU01:FS01:Download 92.10%
18:45:48:WU01:FS01:Download 95.26%
18:45:53:WU01:FS01:Download complete
18:45:53:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11778 run:0 clone:4198 gen:6 core:0x22 unit:0x0000000a287234c95e73c406bac4cac6
18:45:53:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
18:45:53:WU01:FS01:Connecting to cores.foldingathome.org:80
18:45:53:WU01:FS01:FahCore 22: Downloading 4.04MiB
18:45:54:WU01:FS01:FahCore 22: Download complete
18:45:54:WU01:FS01:Valid core signature
18:45:54:WU01:FS01:Unpacked 13.49MiB to cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe
18:45:54:WU01:FS01:Starting
18:45:54:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\green\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 12796 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:45:54:WU01:FS01:Started FahCore on PID 19320
18:45:55:WU01:FS01:Core PID:9020
18:45:55:WU01:FS01:FahCore 0x22 started
18:45:56:WU01:FS01:0x22:*********************** Log Started 2020-03-22T18:45:56Z ***********************
18:45:56:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
18:45:56:WU01:FS01:0x22: Type: 0x22
18:45:56:WU01:FS01:0x22: Core: Core22
18:45:56:WU01:FS01:0x22: Website: https://foldingathome.org/
18:45:56:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
18:45:56:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
18:45:56:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
18:45:56:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 19320 -checkpoint 15
18:45:56:WU01:FS01:0x22: -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
18:45:56:WU01:FS01:0x22: Config: <none>
18:45:56:WU01:FS01:0x22:************************************ Build *************************************
18:45:56:WU01:FS01:0x22: Version: 0.0.2
18:45:56:WU01:FS01:0x22: Date: Dec 6 2019
18:45:56:WU01:FS01:0x22: Time: 21:30:31
18:45:56:WU01:FS01:0x22: Repository: Git
18:45:56:WU01:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
18:45:56:WU01:FS01:0x22: Branch: HEAD
18:45:56:WU01:FS01:0x22: Compiler: Visual C++ 2008
18:45:56:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
18:45:56:WU01:FS01:0x22: Platform: win32 10
18:45:56:WU01:FS01:0x22: Bits: 64
18:45:56:WU01:FS01:0x22: Mode: Release
18:45:56:WU01:FS01:0x22:************************************ System ************************************
18:45:56:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i5-8400 CPU @ 2.80GHz
18:45:56:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 158 Stepping 10
18:45:56:WU01:FS01:0x22: CPUs: 6
18:45:56:WU01:FS01:0x22: Memory: 15.94GiB
18:45:56:WU01:FS01:0x22:Free Memory: 8.77GiB
18:45:56:WU01:FS01:0x22: Threads: WINDOWS_THREADS
18:45:56:WU01:FS01:0x22: OS Version: 6.2
18:45:56:WU01:FS01:0x22:Has Battery: false
18:45:56:WU01:FS01:0x22: On Battery: false
18:45:56:WU01:FS01:0x22: UTC Offset: -4
18:45:56:WU01:FS01:0x22: PID: 9020
18:45:56:WU01:FS01:0x22: CWD: C:\Users\green\AppData\Roaming\FAHClient\work
18:45:56:WU01:FS01:0x22: OS: Windows 10 Home
18:45:56:WU01:FS01:0x22: OS Arch: AMD64
18:45:56:WU01:FS01:0x22:********************************************************************************
18:45:56:WU01:FS01:0x22:Project: 11778 (Run 0, Clone 4198, Gen 6)
18:45:56:WU01:FS01:0x22:Unit: 0x0000000a287234c95e73c406bac4cac6
18:45:56:WU01:FS01:0x22:Reading tar file core.xml
18:45:56:WU01:FS01:0x22:Reading tar file integrator.xml
18:45:56:WU01:FS01:0x22:Reading tar file state.xml
18:45:56:WU01:FS01:0x22:Reading tar file system.xml
18:45:56:WU01:FS01:0x22:Digital signatures verified
18:45:56:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
18:45:56:WU01:FS01:0x22:Version 0.0.2
18:46:05:WU01:FS01:0x22:Completed 0 out of 2000000 steps (0%)
18:46:05:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:47:35:Saving configuration to config.xml
18:47:35:<config>
18:47:35: <!-- Network -->
18:47:35: <proxy v=':8080'/>
18:47:35:
18:47:35: <!-- Slot Control -->
18:47:35: <power v='full'/>
18:47:35:
18:47:35: <!-- User Information -->
18:47:35: <passkey v='********************************'/>
18:47:35: <team v='223518'/>
18:47:35: <user v='Tarran_M'/>
18:47:35:
18:47:35: <!-- Folding Slots -->
18:47:35: <slot id='0' type='CPU'/>
18:47:35: <slot id='1' type='GPU'/>
18:47:35:</config>
18:47:45:WU00:FS00:Connecting to 65.254.110.245:8080
18:47:45:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:47:45:WU00:FS00:Connecting to 18.218.241.186:80
18:47:46:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:47:46:ERROR:WU00:FS00:Exception: Could not get an assignment
18:47:47:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
18:48:00:WU01:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
18:48:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.*********************** Log Started 2020-03-22T18:41:28Z ***********************
18:41:28: Bits: 32
18:41:28: CPUs: 6
18:41:28: GPUs: 0
18:41:28:
18:41:28:<config>
18:41:28:</config>
18:42:30:<config>
18:42:30:</config>
18:43:31:<config>
18:43:31:
18:43:31:
18:43:31:</config>
18:44:32:<config>
18:44:32:
18:44:32:
18:44:32:</config>
18:47:35:<config>
18:47:35:
18:47:35:
18:47:35:
18:47:35:</config>
18:48:22:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.Re: Please add the Radeon RX 590
I think the first issue is explained here
(not configured)
FAH Configures the GPUs when i first runs but only if valid driers are present. Which drivers are you using?
(not configured)
TarMoh
Radeon RX 590
Adrenaline 20.3.1
I don't see anything wrong with your GPU in the log you posted ...
TarMoh
Radeon RX 590
Thanks for the help anyway. Also what does it mean if the status is ‘downloading’ exactly? What is it downloading?
1) a download that happens for new installers is GPUs.txt which desribes the allowed and disallowed GPUs.
2) CORE_a7 is the CPU scientific code currently used. CORE_21 and CORE_22 are the GPU code in current use. F@H is transitioning to CORE_22 over time.
3) each Work Unit you solve for F@H downloads
Most usually a hangup at Downloading means your firewall is blocking F@H. If you are at home, that is most likely software on your PC, if you are not, it is most likely hardware your IT department owns.
You could test this by durning of the Windows Firewall for 10 minutes annd rebooting, than see if every thing starts. If so you need to modify the Windows Firewall to allow F@H. (You may have some other firewall, as well)
TarMoh
Radeon RX 590
What does this mean?
20:19:39:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:19:39:ERROR:WU02:FS01:Exception: Could not get an assignment
20:20:12:Removing old file 'configs/config-20200322-214048.xml'
20:20:12:Saving configuration to config.xml
20:20:12:<config>
20:20:12: <!-- Network -->
20:20:12: <proxy v=':8080'/>
20:20:12:
20:20:12: <!-- Slot Control -->
20:20:12: <power v='full'/>
20:20:12:
20:20:12: <!-- User Information -->
20:20:12: <passkey v='********************************'/>
20:20:12: <team v='223518'/>
20:20:12: <user v='Tarran_M'/>
20:20:12:
20:20:12: <!-- Folding Slots -->
20:20:12: <slot id='0' type='CPU'/>
20:20:12: <slot id='1' type='GPU'/>
20:20:12:</config>
20:21:12:WU02:FS01:Connecting to 65.254.110.245:8080
20:21:12:WARNING:WU02:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
20:21:12:WU02:FS01:Connecting to 18.218.241.186:80
20:21:13:WARNING:WU02:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
20:21:13:ERROR:WU02:FS01:Exception: Could not get an assignment
20:20:12:<config>
20:20:12:
20:20:12:
20:20:12:
20:20:12:</config>
WU shortage. See my post here : Temporary server outages
TarMoh
Radeon RX 590
Ok thanks
