new option just for the Ncov-2019
is there possible adding a option at "I support research fighting" to compute only for the NCOV-2019?
Re: new option just for the Ncov-2019
Frequently asked question, yes, but that would take months as it would require an update to the client and server software and there is just a single developer. They are using the available client and setting the priority high for these projects on the server side.
So , No this will not be done now.
Adding to Joe's answer, a more flexible choice will very likely be implemented in a future version.
