Unable to change team Website
wuchzael
Post by wuchzael »
Hey guys!
Started a new team to help fighting corona. The team grows and the users want our website to be linked in the team header. So I tried to add the Website on the "create modify team page" (not allowed to post links). It says "successfully changed" but it seems like the form doesn't save the added Website. All other fields can be changed flawlessly. Not sure if I fail or the form fails... can you help me?
THX
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Re: Unable to change team Website
Post by Jesse_V »
I take it you're trying to modify the team URL, where are you not seeing the update?
wuchzael
Post by wuchzael »
Hey!
Thanks for your reply. It's updated nowhere as far as I can tell.
wuchzael
Post by wuchzael »
Still unable to change the URL. Team-App says "successfully changed" but the URL does not appear :(
Did you try to add the URL with and without the http:// prefix ?
wuchzael
Post by wuchzael »
Yes. No matter if I add http:// or https:// or nothing. I does not change at all.
Gargoile
Post by Gargoile »
Any update on this as I am having the same issue too.
I recommend that the first thing you do is change your password. Once you've done, that, try again with the new password.
