AMD Radeon RX Vega M GH
jiashiuan
Post by jiashiuan »
Hello,
I've read some posts about Intel NUCs are not supported by FaH. However, still hope to get a chance...
*********************** Log Started 2020-03-22T10:24:28Z ***********************
10:24:28:************************* Folding@home Client *************************
10:24:28:        Website: https://foldingathome.org/
10:24:28:      Copyright: (c) 2009-2018 foldingathome.org
10:24:28:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:24:28:           Args: --open-web-control
10:24:28:         Config: C:\Users\J\AppData\Roaming\FAHClient\config.xml
10:24:28:******************************** Build ********************************
10:24:28:        Version: 7.5.1
10:24:28:           Date: May 11 2018
10:24:28:           Time: 13:06:32
10:24:28:     Repository: Git
10:24:28:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
10:24:28:         Branch: master
10:24:28:       Compiler: Visual C++ 2008
10:24:28:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
10:24:28:       Platform: win32 10
10:24:28:           Bits: 32
10:24:28:           Mode: Release
10:24:28:******************************* System ********************************
10:24:28:            CPU: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
10:24:28:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
10:24:28:           CPUs: 8
10:24:28:         Memory: 31.96GiB
10:24:28:    Free Memory: 24.14GiB
10:24:28:        Threads: WINDOWS_THREADS
10:24:28:     OS Version: 6.2
10:24:28:    Has Battery: false
10:24:28:     On Battery: false
10:24:28:     UTC Offset: 8
10:24:28:            PID: 3892
10:24:28:            CWD: C:\Users\J\AppData\Roaming\FAHClient
10:24:28:             OS: Windows 10 Enterprise
10:24:28:        OS Arch: AMD64
10:24:28:           GPUs: 1
10:24:28:          GPU 0: Bus:1 Slot:0 Func:0 AMD:4 [Radeon RX Vega M XT]
10:24:28:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll':
10:24:28:                 找不到指定的模組。
10:24:28:
10:24:28:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:2766.5
10:24:28:  Win32 Service: false
10:24:28:***********************************************************************
Thanks!
Re: AMD Radeon RX Vega M GH
Welcome to Folding@Home!
Here is the problem. F@H only works with drivers straight From AMD or Nvidia. In Linux, this frustrates the open source folks, and for you it is frustrating that your driver comes from Intel. AMD does not directly have a driver.
The card is certainly capable, if AMD ever directly supports it, you could fold on it. Sorry.
If I recall correctly, this is an AMD GPU chip that Intel OEM's from AMD and packages on a single chip carrier wit a Kaby Lake CPU. The system switches between the Intel iGPU on the Kaby Lake processor and the AMD chip based on power and video requirements. The drivers from what I understand only come from Intel, prior testing of the GPU folding cores with Intel drivers and OpenCL has not worked without error'ing out.
Unless there has been some change in the meantime, this GPU can't be supported for folding. If that changes, there would still be the need to lock the GPU processing to using just the Vega M, any switching to the iGPU will cause the folding core to not find a device it can fold on and crash.
P.S. Though identified as "Vega M", the chip is more Polaris based as it uses the GCN4 architecture and not the GCN5 the other Vega GPU's from AMD use.
Reason: corrected Vega architecture to being GCN5
jiashiuan
Post by jiashiuan »
Hello guys,
Thanks for your quick reply. Yes this is Intel Hades Canyon NUC, combining a KabyLakeG (i7-8809G) and AMD Radeon RX Vega M GH (Polaris 22) .
I managed to remove Intel drivers, disabled iGD in BIOS, installed latest Adrenalin from AMD website (and worked), but still got funny "192.0.2.1" errors, which means "not supported" as far as I know.
Thought it's OK running with CPU, still a pity I can't make more contributions to FaH, especially recent COVID-19 projects.
Sorry for the Chinese characters. I am from Taiwan.
*********************** Log Started 2020-03-22T21:37:33Z ***********************
21:38:30:WU01:FS01:Connecting to 65.254.110.245:8080
21:38:31:WU01:FS01:Assigned to work server 192.0.2.1
21:38:31:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:[Radeon RX Vega M XT] from 192.0.2.1
21:38:31:WU01:FS01:Connecting to 192.0.2.1:8080
21:38:52:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
21:38:52:WU01:FS01:Connecting to 192.0.2.1:80
21:39:13:ERROR:WU01:FS01:Exception: Failed to connect to 192.0.2.1:80: 連線嘗試失敗,因為連線對象有一段時間並未正確回應,或是連線建立失敗,因為連線的主機無法回應。
Do you confirm that you can run FAHBench double precision test on your GPU ?
If it works, I'm going to change specie 4 to species 5 for this GPU ...
jiashiuan
Post by jiashiuan »
toTOW wrote:Do you confirm that you can run FAHBench double precision test on your GPU ?
That would be nice!
I just ran FAHBench again to confirm. Please check the screenshot below and let me know if I am doing right.
Thanks!
Ok, I enabled 3 GPUs in this family (Polaris 22 chip) ... Let us know :
- if you get work.
- if it doesn't immediately fail.
0x694c - Polaris 22 XT [Radeon RX Vega M GH]
0x694e - Polaris 22 XL [Radeon RX Vega M GL]
0x694f - Polaris 22 MGL XL [Radeon Pro WX Vega M GL]
jiashiuan
Post by jiashiuan »
toTOW wrote:Ok, I enabled 3 GPUs in this family (Polaris 22 chip) ... Let us know :
- if you get work.
It rocks! Now I am folding with CPU and GPU at the same time. :D
Thank you so much. Now my GPU could do something more than playing games. :D
********************** Log Started 2020-03-23T16:20:31Z ***********************
16:20:31:************************* Folding@home Client *************************
16:20:31:        Website: https://foldingathome.org/
16:20:31:      Copyright: (c) 2009-2018 foldingathome.org
16:20:31:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:20:31:           Args: --open-web-control
16:20:31:         Config: <none>
16:20:31:******************************** Build ********************************
16:20:31:        Version: 7.5.1
16:20:31:           Date: May 11 2018
16:20:31:           Time: 13:06:32
16:20:31:     Repository: Git
16:20:31:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
16:20:31:         Branch: master
16:20:31:       Compiler: Visual C++ 2008
16:20:31:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:20:31:       Platform: win32 10
16:20:31:           Bits: 32
16:20:31:           Mode: Release
16:20:31:******************************* System ********************************
16:20:31:            CPU: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
16:20:31:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
16:20:31:           CPUs: 8
16:20:31:         Memory: 31.96GiB
16:20:31:    Free Memory: 19.62GiB
16:20:31:        Threads: WINDOWS_THREADS
16:20:31:     OS Version: 6.2
16:20:31:    Has Battery: false
16:20:31:     On Battery: false
16:20:31:     UTC Offset: 8
16:20:31:            PID: 10132
16:20:31:            CWD: C:\Users\J\AppData\Roaming\FAHClient
16:20:31:             OS: Windows 10 Enterprise
16:20:31:        OS Arch: AMD64
16:20:31:           GPUs: 0
16:20:31:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll':
16:20:31:                 找不到指定的模組。
16:20:31:
16:20:31:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:2766.5
16:20:31:  Win32 Service: false
16:20:31:***********************************************************************
16:20:31:<config>
16:20:31:  <!-- Folding Slots -->
16:20:31:</config>
16:20:31:Connecting to assign1.foldingathome.org:8080
16:20:31:Updated GPUs.txt
16:20:31:Read GPUs.txt
16:20:31:Trying to access database...
16:20:31:Successfully acquired database lock
16:20:31:Enabled folding slot 00: PAUSED cpu:6 (not configured)
16:20:31:Enabled folding slot 01: PAUSED gpu:0:[Radeon RX Vega M XT] (not configured)
16:20:33:4:127.0.0.1:New Web connection
16:21:27:Set client configured
16:21:27:WU00:FS00:Connecting to 65.254.110.245:8080
16:21:28:WU01:FS01:Connecting to 65.254.110.245:8080
16:21:28:WU00:FS00:Connecting to 65.254.110.245:8080
16:21:29:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:21:29:WU00:FS00:Connecting to 18.218.241.186:80
16:21:29:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
16:21:29:WU01:FS01:Connecting to 18.218.241.186:80
16:21:30:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:21:30:ERROR:WU00:FS00:Exception: Could not get an assignment
16:21:30:WU00:FS00:Connecting to 65.254.110.245:8080
16:21:30:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
16:21:30:ERROR:WU01:FS01:Exception: Could not get an assignment
16:21:30:WU01:FS01:Connecting to 65.254.110.245:8080
16:21:30:WU00:FS00:Assigned to work server 40.114.52.201
16:21:30:WU00:FS00:Requesting new work unit for slot 00: READY cpu:6 from 40.114.52.201
16:21:30:WU00:FS00:Connecting to 40.114.52.201:8080
16:21:31:WU01:FS01:Assigned to work server 128.252.203.10
16:21:31:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:[Radeon RX Vega M XT] from 128.252.203.10
16:21:31:WU01:FS01:Connecting to 128.252.203.10:8080
16:21:32:Saving configuration to config.xml
16:21:32:<config>
16:21:32:  <!-- User Information -->
16:21:32:  <passkey v='********************************'/>
16:21:32:  <team v='31403'/>
16:21:32:  <user v='Josh_Tsai'/>
16:21:32:
16:21:32:  <!-- Folding Slots -->
16:21:32:  <slot id='0' type='CPU'/>
16:21:32:  <slot id='1' type='GPU'/>
16:21:32:</config>
16:22:29:WU01:FS01:Downloading 50.74MiB
16:22:33:Saving configuration to config.xml
16:22:33:<config>
16:22:33:  <!-- Slot Control -->
16:22:33:  <power v='full'/>
16:22:33:
16:22:33:  <!-- User Information -->
16:22:33:  <passkey v='********************************'/>
16:22:33:  <team v='31403'/>
16:22:33:  <user v='Josh_Tsai'/>
16:22:33:
16:22:33:  <!-- Folding Slots -->
16:22:33:  <slot id='0' type='CPU'/>
16:22:33:  <slot id='1' type='GPU'/>
16:22:33:</config>
16:22:35:WU01:FS01:Download 7.39%
16:22:35:WU00:FS00:Downloading 2.14MiB
16:22:41:WU01:FS01:Download 15.52%
16:22:42:WU00:FS00:Download 37.93%
16:22:45:WU00:FS00:Download complete
16:22:45:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13851 run:0 clone:32085 gen:1 core:0xa7 unit:0x00000001287234c95e788324dc31aff1
16:22:45:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah
16:22:45:WU00:FS00:Connecting to cores.foldingathome.org:80
16:22:45:WU00:FS00:FahCore a7: Downloading 6.71MiB
16:22:47:WU01:FS01:Download 22.30%
16:22:51:WU00:FS00:FahCore a7: 28.87%
16:22:53:WU01:FS01:Download 26.98%
16:22:57:WU00:FS00:FahCore a7: 62.39%
16:22:59:WU01:FS01:Download 31.54%
16:23:03:WU00:FS00:FahCore a7: 98.71%
16:23:03:WU00:FS00:FahCore a7: Download complete
16:23:03:WU00:FS00:Valid core signature
16:23:03:WU00:FS00:Unpacked 19.85MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe
16:23:03:WU00:FS00:Unpacked 2.64MiB to cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/libfftw3f-3.dll
16:23:03:WU00:FS00:Starting
16:23:03:WARNING:WU00:FS00:Changed SMP threads from 6 to 7 this can cause some work units to fail
16:23:03:WARNING:WU00:FS00:AS lowered CPUs from 7 to 6
16:23:03:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\J\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 10132 -checkpoint 15 -np 6
16:23:03:WU00:FS00:Started FahCore on PID 12820
16:23:03:WU00:FS00:Core PID:11888
16:23:03:WU00:FS00:FahCore 0xa7 started
16:23:04:WU00:FS00:0xa7:*********************** Log Started 2020-03-23T16:23:03Z ***********************
16:23:04:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:23:04:WU00:FS00:0xa7:       Type: 0xa7
16:23:04:WU00:FS00:0xa7:       Core: Gromacs
16:23:04:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 12820 -checkpoint 15 -np
16:23:04:WU00:FS00:0xa7:             6
16:23:04:WU00:FS00:0xa7:************************************ CBang *************************************
16:23:04:WU00:FS00:0xa7:       Date: Oct 26 2019
16:23:04:WU00:FS00:0xa7:       Time: 01:38:25
16:23:04:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
16:23:04:WU00:FS00:0xa7:     Branch: master
16:23:04:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
16:23:04:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:23:04:WU00:FS00:0xa7:   Platform: win32 10
16:23:04:WU00:FS00:0xa7:       Bits: 64
16:23:04:WU00:FS00:0xa7:       Mode: Release
16:23:04:WU00:FS00:0xa7:************************************ System ************************************
16:23:04:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
16:23:04:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
16:23:04:WU00:FS00:0xa7:       CPUs: 8
16:23:04:WU00:FS00:0xa7:     Memory: 31.96GiB
16:23:04:WU00:FS00:0xa7:Free Memory: 19.47GiB
16:23:04:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
16:23:04:WU00:FS00:0xa7: OS Version: 6.2
16:23:04:WU00:FS00:0xa7:Has Battery: false
16:23:04:WU00:FS00:0xa7: On Battery: false
16:23:04:WU00:FS00:0xa7: UTC Offset: 8
16:23:04:WU00:FS00:0xa7:        PID: 11888
16:23:04:WU00:FS00:0xa7:        CWD: C:\Users\J\AppData\Roaming\FAHClient\work
16:23:04:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
16:23:04:WU00:FS00:0xa7:    Version: 0.0.18
16:23:04:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:23:04:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
16:23:04:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
16:23:04:WU00:FS00:0xa7:       Time: 01:52:30
16:23:04:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
16:23:04:WU00:FS00:0xa7:************************************ Build *************************************
16:23:04:WU00:FS00:0xa7:       SIMD: avx_256
16:23:04:WU00:FS00:0xa7:********************************************************************************
16:23:04:WU00:FS00:0xa7:Project: 13851 (Run 0, Clone 32085, Gen 1)
16:23:04:WU00:FS00:0xa7:Unit: 0x00000001287234c95e788324dc31aff1
16:23:04:WU00:FS00:0xa7:Reading tar file core.xml
16:23:04:WU00:FS00:0xa7:Reading tar file frame1.tpr
16:23:04:WU00:FS00:0xa7:Digital signatures verified
16:23:04:WU00:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -x frame1.xtc -e frame1.edr -cpt 15 -nt 6
16:23:04:WU00:FS00:0xa7:Steps: first=500000 total=500000
16:23:05:WU01:FS01:Download 36.96%
16:23:06:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
16:23:11:WU01:FS01:Download 43.49%
16:23:17:WU01:FS01:Download 49.64%
16:23:23:WU01:FS01:Download 55.31%
16:23:29:WU01:FS01:Download 60.98%
16:23:35:WU01:FS01:Download 66.52%
16:23:41:WU01:FS01:Download 70.71%
16:23:47:WU01:FS01:Download 74.53%
16:23:53:WU01:FS01:Download 79.46%
16:23:59:WU01:FS01:Download 83.40%
16:24:05:WU01:FS01:Download 87.09%
16:24:11:WU01:FS01:Download 91.28%
16:24:17:WU01:FS01:Download 96.46%
16:24:20:WU01:FS01:Download complete
16:24:20:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11762 run:0 clone:7770 gen:10 core:0x22 unit:0x0000000f80fccb0a5e7113d230b82324
16:24:20:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
16:24:20:WU01:FS01:Connecting to cores.foldingathome.org:80
16:24:20:WU01:FS01:FahCore 22: Downloading 4.04MiB
16:24:22:WU01:FS01:FahCore 22: Download complete
16:24:22:WU01:FS01:Valid core signature
16:24:22:WU01:FS01:Unpacked 13.49MiB to cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe
16:24:23:WU01:FS01:Starting
16:24:23:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\J\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 10132 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
16:24:23:WU01:FS01:Started FahCore on PID 7788
16:24:23:WU01:FS01:Core PID:13076
16:24:23:WU01:FS01:FahCore 0x22 started
16:24:23:WU01:FS01:0x22:*********************** Log Started 2020-03-23T16:24:23Z ***********************
16:24:23:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
16:24:23:WU01:FS01:0x22:       Type: 0x22
16:24:23:WU01:FS01:0x22:       Core: Core22
16:24:23:WU01:FS01:0x22:    Website: https://foldingathome.org/
16:24:23:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
16:24:23:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
16:24:23:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
16:24:23:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 7788 -checkpoint 15
16:24:23:WU01:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
16:24:23:WU01:FS01:0x22:     Config: <none>
16:24:23:WU01:FS01:0x22:************************************ Build *************************************
16:24:23:WU01:FS01:0x22:    Version: 0.0.2
16:24:23:WU01:FS01:0x22:       Date: Dec 6 2019
16:24:23:WU01:FS01:0x22:       Time: 21:30:31
16:24:23:WU01:FS01:0x22: Repository: Git
16:24:23:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
16:24:23:WU01:FS01:0x22:     Branch: HEAD
16:24:23:WU01:FS01:0x22:   Compiler: Visual C++ 2008
16:24:23:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:24:23:WU01:FS01:0x22:   Platform: win32 10
16:24:23:WU01:FS01:0x22:       Bits: 64
16:24:23:WU01:FS01:0x22:       Mode: Release
16:24:23:WU01:FS01:0x22:************************************ System ************************************
16:24:23:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
16:24:23:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
16:24:23:WU01:FS01:0x22:       CPUs: 8
16:24:23:WU01:FS01:0x22:     Memory: 31.96GiB
16:24:23:WU01:FS01:0x22:Free Memory: 19.38GiB
16:24:23:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
16:24:23:WU01:FS01:0x22: OS Version: 6.2
16:24:23:WU01:FS01:0x22:Has Battery: false
16:24:23:WU01:FS01:0x22: On Battery: false
16:24:23:WU01:FS01:0x22: UTC Offset: 8
16:24:23:WU01:FS01:0x22:        PID: 13076
16:24:23:WU01:FS01:0x22:        CWD: C:\Users\J\AppData\Roaming\FAHClient\work
16:24:23:WU01:FS01:0x22:         OS: Windows 10 Pro
16:24:23:WU01:FS01:0x22:    OS Arch: AMD64
16:24:23:WU01:FS01:0x22:********************************************************************************
16:24:23:WU01:FS01:0x22:Project: 11762 (Run 0, Clone 7770, Gen 10)
16:24:23:WU01:FS01:0x22:Unit: 0x0000000f80fccb0a5e7113d230b82324
16:24:23:WU01:FS01:0x22:Reading tar file core.xml
16:24:23:WU01:FS01:0x22:Reading tar file integrator.xml
16:24:23:WU01:FS01:0x22:Reading tar file state.xml
16:24:24:WU01:FS01:0x22:Reading tar file system.xml
16:24:25:WU01:FS01:0x22:Digital signatures verified
16:24:25:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
16:24:25:WU01:FS01:0x22:Version 0.0.2
16:24:45:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
16:24:45:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:24:54:FS00:Shutting core down
16:24:54:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 11888
16:24:54:WU00:FS00:0xa7:Exiting, please wait. . .
16:24:55:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
16:24:55:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
16:24:56:WU00:FS00:Starting
16:24:56:WARNING:WU00:FS00:Changed SMP threads from 7 to 6 this can cause some work units to fail
16:24:56:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\J\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 10132 -checkpoint 15 -np 6
16:24:56:WU00:FS00:Started FahCore on PID 5104
16:24:56:WU00:FS00:Core PID:7868
16:24:56:WU00:FS00:FahCore 0xa7 started
16:24:56:WU00:FS00:0xa7:*********************** Log Started 2020-03-23T16:24:56Z ***********************
16:24:56:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:24:56:WU00:FS00:0xa7:       Type: 0xa7
16:24:56:WU00:FS00:0xa7:       Core: Gromacs
16:24:56:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 5104 -checkpoint 15 -np 6
16:24:56:WU00:FS00:0xa7:************************************ CBang *************************************
16:24:56:WU00:FS00:0xa7:       Date: Oct 26 2019
16:24:56:WU00:FS00:0xa7:       Time: 01:38:25
16:24:56:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
16:24:56:WU00:FS00:0xa7:     Branch: master
16:24:56:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
16:24:56:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
16:24:56:WU00:FS00:0xa7:   Platform: win32 10
16:24:56:WU00:FS00:0xa7:       Bits: 64
16:24:56:WU00:FS00:0xa7:       Mode: Release
16:24:56:WU00:FS00:0xa7:************************************ System ************************************
16:24:56:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
16:24:56:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
16:24:56:WU00:FS00:0xa7:       CPUs: 8
16:24:56:WU00:FS00:0xa7:     Memory: 31.96GiB
16:24:56:WU00:FS00:0xa7:Free Memory: 19.00GiB
16:24:56:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
16:24:56:WU00:FS00:0xa7: OS Version: 6.2
16:24:56:WU00:FS00:0xa7:Has Battery: false
16:24:56:WU00:FS00:0xa7: On Battery: false
16:24:56:WU00:FS00:0xa7: UTC Offset: 8
16:24:56:WU00:FS00:0xa7:        PID: 7868
16:24:56:WU00:FS00:0xa7:        CWD: C:\Users\J\AppData\Roaming\FAHClient\work
16:24:56:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
16:24:56:WU00:FS00:0xa7:    Version: 0.0.18
16:24:56:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:24:56:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
16:24:56:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
16:24:56:WU00:FS00:0xa7:       Time: 01:52:30
16:24:56:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
16:24:56:WU00:FS00:0xa7:************************************ Build *************************************
16:24:56:WU00:FS00:0xa7:       SIMD: avx_256
16:24:56:WU00:FS00:0xa7:********************************************************************************
16:24:56:WU00:FS00:0xa7:Project: 13851 (Run 0, Clone 32085, Gen 1)
16:24:56:WU00:FS00:0xa7:Unit: 0x00000001287234c95e788324dc31aff1
16:24:56:WU00:FS00:0xa7:Digital signatures verified
16:24:56:WU00:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -x frame1.xtc -e frame1.edr -cpi state.cpt -cpt 15 -nt 6
16:24:56:WU00:FS00:0xa7:Steps: first=500000 total=500000
16:24:58:WU00:FS00:0xa7:Completed 4582 out of 500000 steps (0%)
16:25:10:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
16:25:36:Saving configuration to config.xml
16:25:36:<config>
16:25:36:  <!-- User Information -->
16:25:36:  <passkey v='********************************'/>
16:25:36:  <team v='31403'/>
16:25:36:  <user v='Josh_Tsai'/>
16:25:36:
16:25:36:  <!-- Folding Slots -->
16:25:36:  <slot id='0' type='CPU'/>
16:25:36:  <slot id='1' type='GPU'/>
16:25:36:</config>
16:27:46:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
One more thing you might check. Restart your system (so FAH's log is reinitialized) and at the very top you'll see something like this
18:40:57:******************************* System ********************************
18:40:57:            CPU: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
18:40:57:         CPU ID: GenuineIntel Family 6 Model 26 Stepping 4
18:40:57:           CPUs: 8
18:40:57:         Memory: 5.99GiB
18:40:57:    Free Memory: 3.41GiB
18:40:57:        Threads: WINDOWS_THREADS
18:40:57:     OS Version: 6.1
18:40:57:    Has Battery: false
18:40:57:     On Battery: false
18:40:57:     UTC Offset: -7
18:40:57:            PID: 908
18:40:57:            CWD: C:\Users\bruce\AppData\Roaming\FAHClient
18:40:57:             OS: Windows 7 Home Premium
18:40:57:        OS Arch: AMD64
18:40:57:           GPUs: 2
18:40:57:          GPU 0: Bus:3 Slot:0 Func:0 NVIDIA:3 GK107 [GeForce GT 740]
18:40:57:          GPU 1: Bus:4 Slot:0 Func:0 NVIDIA:5 GM206 [GeForce GTX 960] 2308
18:40:57:  CUDA Device 0: Platform:0 Device:0 Bus:4 Slot:0 Compute:5.2 Driver:10.2
18:40:57:  CUDA Device 1: Platform:0 Device:1 Bus:3 Slot:0 Compute:3.0 Driver:10.2
18:40:57:OpenCL Device 0: Platform:0 Device:0 Bus:4 Slot:0 Compute:1.2 Driver:442.19
18:40:57:OpenCL Device 1: Platform:0 Device:1 Bus:3 Slot:0 Compute:1.2 Driver:442.19
18:40:57:  Win32 Service: false
the line(s) describing OpenCL must say it is Compute: 1.2 or greater.
jiashiuan
Post by jiashiuan »
bruce wrote:One more thing you might check. Restart your system (so FAH's log is reinitialized) and at the very top you'll see something like this
Thanks for the heads up. I checked my log again, and it looks ok:
*********************** Log Started 2020-03-24T03:03:08Z ***********************
03:03:08:************************* Folding@home Client *************************
03:03:08:        Website: https://foldingathome.org/
03:03:08:      Copyright: (c) 2009-2018 foldingathome.org
03:03:08:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:03:08:           Args:
03:03:08:         Config: C:\Users\J\AppData\Roaming\FAHClient\config.xml
03:03:08:******************************** Build ********************************
03:03:08:        Version: 7.5.1
03:03:08:           Date: May 11 2018
03:03:08:           Time: 13:06:32
03:03:08:     Repository: Git
03:03:08:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
03:03:08:         Branch: master
03:03:08:       Compiler: Visual C++ 2008
03:03:08:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
03:03:08:       Platform: win32 10
03:03:08:           Bits: 32
03:03:08:           Mode: Release
03:03:08:******************************* System ********************************
03:03:08:            CPU: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
03:03:08:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
03:03:08:           CPUs: 8
03:03:08:         Memory: 31.96GiB
03:03:08:    Free Memory: 25.68GiB
03:03:08:        Threads: WINDOWS_THREADS
03:03:08:     OS Version: 6.2
03:03:08:    Has Battery: false
03:03:08:     On Battery: false
03:03:08:     UTC Offset: 8
03:03:08:            PID: 17088
03:03:08:            CWD: C:\Users\J\AppData\Roaming\FAHClient
03:03:08:             OS: Windows 10 Enterprise
03:03:08:        OS Arch: AMD64
03:03:08:           GPUs: 1
03:03:08:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 [Radeon RX Vega M XT]
03:03:08:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll':
03:03:08:                 找不到指定的模組。
03:03:08:
03:03:08:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:2766.5
03:03:08:  Win32 Service: false
03:03:08:***********************************************************************
Now both CPU and GPU are running.
Thanks again for everything!
MrKai
Post by MrKai »
Seeing this made me hopeful for my version, the RX Vega M XT in the model above yours.
Hopefully, soon :)
-K
jwh212
Post by jwh212 »
That would be nice!
Thanks!
Ok, I am seeing a different graphics card show up in FAH bench than jiashiuan's, maybe he is running a slightly different NUC model or maybe we are running different product generations?
The specific model I have of the Hades Canyon is : Intel NUC 8 Performance-G Kit (NUC8i7HVK) - Core i7 100W
Note: I disabled the Intel integrated graphics in BIOS
here is what I see in FAHBench (gfx902 vs his which is gfx804):
I have tried several video driver sets, ultimately doing "factory reset" option on the AMD and reverting to use the same version he posted success with:
But I have the same issues that MrKai and I discuss in the other thread on Intel NUC Hades Canyon, the FAH bench will lock up the computer, the mouse has tons of interrupts and I usually have to reboot to clear the issue. If I pause the GPU thread things work ok on the CPU only.
I did some googling and found a tidbit about the gfx804 vs gfx902:
https://community.amd.com/thread/251100
https://community.amd.com/thread/251040
https://www.tonymacx86.com/threads/inte ... 600/page-8
*********************** Log Started 2020-04-26T09:04:05Z ***********************
09:04:05:****************************** FAHClient ******************************
09:04:05:        Version: 7.6.9
09:04:05:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:04:05:      Copyright: 2020 foldingathome.org
09:04:05:       Homepage: https://foldingathome.org/
09:04:05:           Date: Apr 17 2020
09:04:05:           Time: 11:13:06
09:04:05:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
09:04:05:         Branch: master
09:04:05:       Compiler: Visual C++ 2008
09:04:05:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:04:05:       Platform: win32 10
09:04:05:           Bits: 32
09:04:05:           Mode: Release
09:04:05:           Args: --open-web-control
09:04:05:         Config: C:\Users\abysm\AppData\Roaming\FAHClient\config.xml
09:04:05:******************************** CBang ********************************
09:04:05:           Time: 11:10:09
09:04:05:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
09:04:05:           Bits: 32
09:04:05:******************************* System ********************************
09:04:05:            CPU: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
09:04:05:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
09:04:05:           CPUs: 8
09:04:05:         Memory: 31.96GiB
09:04:05:    Free Memory: 24.44GiB
09:04:05:        Threads: WINDOWS_THREADS
09:04:05:     OS Version: 6.2
09:04:05:    Has Battery: false
09:04:05:     On Battery: false
09:04:05:     UTC Offset: -4
09:04:05:            PID: 12520
09:04:05:            CWD: C:\Users\abysm\AppData\Roaming\FAHClient
09:04:05:             OS: Windows 10 Enterprise
09:04:05:        OS Arch: AMD64
09:04:05:           GPUs: 1
09:04:05:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 [Radeon RX Vega M XT/ M GH]
09:04:05:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
09:04:05:                 specified module could not be found.
09:04:05:
09:04:05:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:3004.8
09:04:05:  Win32 Service: false
09:04:05:******************************* libFAH ********************************
09:04:05:           Date: Apr 15 2020
09:04:05:           Time: 14:53:14
09:04:05:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
09:04:05:           Bits: 32
09:04:05:***********************************************************************
09:04:05:<config>
09:04:05:  <!-- Folding Slot Configuration -->
09:04:05:  <cause v='COVID_19'/>
09:04:05:
09:04:05:  <!-- Network -->
09:04:05:  <proxy v=':8080'/>
09:04:05:
09:04:05:  <!-- Slot Control -->
09:04:05:  <power v='FULL'/>
09:04:05:
09:04:05:  <!-- User Information -->
09:04:05:  <passkey v='*****'/>
09:04:05:  <team v='262160'/>
09:04:05:  <user v='jwh212'/>
09:04:05:
09:04:05:  <!-- Folding Slots -->
09:04:05:  <slot id='0' type='CPU'/>
09:04:05:  <slot id='1' type='GPU'>
09:04:05:    <paused v='true'/>
09:04:05:  </slot>
09:04:05:</config>
09:04:05:Trying to access database...
09:04:05:Successfully acquired database lock
09:04:05:Enabled folding slot 00: READY cpu:7
09:04:05:Enabled folding slot 01: PAUSED gpu:0:[Radeon RX Vega M XT/ M GH] (by user)
09:04:05:WU03:FS00:Starting
09:04:05:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\abysm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 706 -lifeline 12520 -checkpoint 15 -np 7
09:04:05:WU03:FS00:Started FahCore on PID 11224
09:04:06:WU03:FS00:Core PID:13788
09:04:06:WU03:FS00:FahCore 0xa7 started
09:04:06:WU03:FS00:0xa7:*********************** Log Started 2020-04-26T09:04:06Z ***********************
09:04:06:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:04:06:WU03:FS00:0xa7:       Type: 0xa7
09:04:06:WU03:FS00:0xa7:       Core: Gromacs
09:04:06:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 706 -lifeline 11224 -checkpoint 15 -np
09:04:06:WU03:FS00:0xa7:             7
09:04:06:WU03:FS00:0xa7:************************************ CBang *************************************
09:04:06:WU03:FS00:0xa7:       Date: Oct 26 2019
09:04:06:WU03:FS00:0xa7:       Time: 01:38:25
09:04:06:WU03:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
09:04:06:WU03:FS00:0xa7:     Branch: master
09:04:06:WU03:FS00:0xa7:   Compiler: Visual C++ 2008
09:04:06:WU03:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:04:06:WU03:FS00:0xa7:   Platform: win32 10
09:04:06:WU03:FS00:0xa7:       Bits: 64
09:04:06:WU03:FS00:0xa7:       Mode: Release
09:04:06:WU03:FS00:0xa7:************************************ System ************************************
09:04:06:WU03:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
09:04:06:WU03:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
09:04:06:WU03:FS00:0xa7:       CPUs: 8
09:04:06:WU03:FS00:0xa7:     Memory: 31.96GiB
09:04:06:WU03:FS00:0xa7:Free Memory: 24.40GiB
09:04:06:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
09:04:06:WU03:FS00:0xa7: OS Version: 6.2
09:04:06:WU03:FS00:0xa7:Has Battery: false
09:04:06:WU03:FS00:0xa7: On Battery: false
09:04:06:WU03:FS00:0xa7: UTC Offset: -4
09:04:06:WU03:FS00:0xa7:        PID: 13788
09:04:06:WU03:FS00:0xa7:        CWD: C:\Users\abysm\AppData\Roaming\FAHClient\work
09:04:06:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
09:04:06:WU03:FS00:0xa7:    Version: 0.0.18
09:04:06:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:04:06:WU03:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:04:06:WU03:FS00:0xa7:   Homepage: https://foldingathome.org/
09:04:06:WU03:FS00:0xa7:       Time: 01:52:30
09:04:06:WU03:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
09:04:06:WU03:FS00:0xa7:************************************ Build *************************************
09:04:06:WU03:FS00:0xa7:       SIMD: avx_256
09:04:06:WU03:FS00:0xa7:********************************************************************************
09:04:06:WU03:FS00:0xa7:Project: 16406 (Run 844, Clone 4, Gen 121)
09:04:06:WU03:FS00:0xa7:Unit: 0x00000084a8f5c67d5e801f7baaa5afdb
09:04:06:WU03:FS00:0xa7:Digital signatures verified
09:04:06:WU03:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
09:04:06:WU03:FS00:0xa7:Calling: mdrun -s frame121.tpr -o frame121.trr -x frame121.xtc -cpi state.cpt -cpt 15 -nt 6
09:04:06:WU03:FS00:0xa7:ERROR:Guru Meditation #2027f959c8643608.134f125b658490c8 (103494.104666) '03/01/md.log'
09:04:06:WU03:FS00:0xa7:WARNING:Unexpected exit() call
09:04:06:WU03:FS00:0xa7:WARNING:Unexpected exit from science code
09:04:06:WU03:FS00:0xa7:Saving result file ..\logfile_01.txt
09:04:06:WU03:FS00:0xa7:Saving result file frame121.trr
09:04:06:WU03:FS00:0xa7:Saving result file frame121.xtc
09:04:06:WU03:FS00:0xa7:Saving result file md.log
09:04:07:WU01:FS00:Starting
09:04:07:WARNING:WU01:FS00:AS lowered CPUs from 7 to 3
09:04:07:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\abysm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 12520 -checkpoint 15 -np 3
09:04:07:WU01:FS00:Started FahCore on PID 19652
09:04:07:WU01:FS00:Core PID:9500
09:04:07:WU01:FS00:FahCore 0xa7 started
09:04:07:WARNING:WU03:FS00:FahCore returned an unknown error code which probably indicates that it crashed
09:04:07:WARNING:WU03:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
09:04:07:WU01:FS00:0xa7:*********************** Log Started 2020-04-26T09:04:07Z ***********************
09:04:07:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:04:07:WU01:FS00:0xa7:       Type: 0xa7
09:04:07:WU01:FS00:0xa7:       Core: Gromacs
09:04:07:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 19652 -checkpoint 15 -np
09:04:07:WU01:FS00:0xa7:             3
09:04:07:WU01:FS00:0xa7:************************************ CBang *************************************
09:04:07:WU01:FS00:0xa7:       Date: Oct 26 2019
09:04:07:WU01:FS00:0xa7:       Time: 01:38:25
09:04:07:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
09:04:07:WU01:FS00:0xa7:     Branch: master
09:04:07:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
09:04:07:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:04:07:WU01:FS00:0xa7:   Platform: win32 10
09:04:07:WU01:FS00:0xa7:       Bits: 64
09:04:07:WU01:FS00:0xa7:       Mode: Release
09:04:07:WU01:FS00:0xa7:************************************ System ************************************
09:04:07:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
09:04:07:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
09:04:07:WU01:FS00:0xa7:       CPUs: 8
09:04:07:WU01:FS00:0xa7:     Memory: 31.96GiB
09:04:07:WU01:FS00:0xa7:Free Memory: 24.32GiB
09:04:07:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
09:04:07:WU01:FS00:0xa7: OS Version: 6.2
09:04:07:WU01:FS00:0xa7:Has Battery: false
09:04:07:WU01:FS00:0xa7: On Battery: false
09:04:07:WU01:FS00:0xa7: UTC Offset: -4
09:04:07:WU01:FS00:0xa7:        PID: 9500
09:04:07:WU01:FS00:0xa7:        CWD: C:\Users\abysm\AppData\Roaming\FAHClient\work
09:04:07:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
09:04:07:WU01:FS00:0xa7:    Version: 0.0.18
09:04:07:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:04:07:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:04:07:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
09:04:07:WU01:FS00:0xa7:       Time: 01:52:30
09:04:07:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
09:04:07:WU01:FS00:0xa7:************************************ Build *************************************
09:04:07:WU01:FS00:0xa7:       SIMD: avx_256
09:04:07:WU01:FS00:0xa7:********************************************************************************
09:04:07:WU01:FS00:0xa7:Project: 14620 (Run 1767, Clone 1, Gen 42)
09:04:07:WU01:FS00:0xa7:Unit: 0x0000002d9bf7a4d55e876bf89eb9a695
09:04:07:WU01:FS00:0xa7:Digital signatures verified
09:04:07:WU01:FS00:0xa7:Calling: mdrun -s frame42.tpr -o frame42.trr -cpi state.cpt -cpt 15 -nt 3
09:04:07:WU01:FS00:0xa7:Steps: first=0 total=250000
09:04:08:WU01:FS00:0xa7:Completed 5339 out of 250000 steps (2%)
09:04:08:17:127.0.0.1:New Web session
09:05:51:WU01:FS00:0xa7:Completed 7500 out of 250000 steps (3%)
09:07:46:WU01:FS00:0xa7:Completed 10000 out of 250000 steps (4%)
09:09:49:WU01:FS00:0xa7:Completed 12500 out of 250000 steps (5%)
09:11:48:WU01:FS00:0xa7:Completed 15000 out of 250000 steps (6%)
09:13:47:WU01:FS00:0xa7:Completed 17500 out of 250000 steps (7%)
jwh212
Post by jwh212 »
OK, I got it working now, works very smoothly with the original Intel Branded AMD driver located at this URL:
https://downloadcenter.intel.com/downlo ... M-Graphics
It appears this is probably an "oddball" GPU given its integration on chip with the intel CPU and it being a relatively limited run. People in the AMD forum links I posted above think that it may be an issue with the way the newer AMD drivers are identifying the hardware, and there appear to be some tickets open about this with AMD now, FAH is specifically mentioned in those forum posts :)
Upon loading the older driver that intel itself published, FAHbench correctly shows it as gfx804 instead of gfx902
Anyway, happy camper for now!
*********************** Log Started 2020-04-26T09:42:52Z ***********************
09:42:52:****************************** FAHClient ******************************
09:42:52:        Version: 7.6.9
09:42:52:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:42:52:      Copyright: 2020 foldingathome.org
09:42:52:       Homepage: https://foldingathome.org/
09:42:52:           Date: Apr 17 2020
09:42:52:           Time: 11:13:06
09:42:52:       Revision: 398c2b17fa535e0cc6c9d10856b2154c32771646
09:42:52:         Branch: master
09:42:52:       Compiler: Visual C++ 2008
09:42:52:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:42:52:       Platform: win32 10
09:42:52:           Bits: 32
09:42:52:           Mode: Release
09:42:52:           Args: --open-web-control
09:42:52:         Config: C:\Users\abysm\AppData\Roaming\FAHClient\config.xml
09:42:52:******************************** CBang ********************************
09:42:52:           Time: 11:10:09
09:42:52:       Revision: 2fb0be7809c5e45287a122ca5fbc15b5ae859a3b
09:42:52:           Bits: 32
09:42:52:******************************* System ********************************
09:42:52:            CPU: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
09:42:52:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
09:42:52:           CPUs: 8
09:42:52:         Memory: 31.96GiB
09:42:52:    Free Memory: 26.38GiB
09:42:52:        Threads: WINDOWS_THREADS
09:42:52:     OS Version: 6.2
09:42:52:    Has Battery: false
09:42:52:     On Battery: false
09:42:52:     UTC Offset: -4
09:42:52:            PID: 19428
09:42:52:            CWD: C:\Users\abysm\AppData\Roaming\FAHClient
09:42:52:             OS: Windows 10 Enterprise
09:42:52:        OS Arch: AMD64
09:42:52:           GPUs: 1
09:42:52:          GPU 0: Bus:1 Slot:0 Func:0 AMD:5 [Radeon RX Vega M XT/ M GH]
09:42:52:           CUDA: Not detected: Failed to open dynamic library 'nvcuda.dll': The
09:42:52:                 specified module could not be found.
09:42:52:
09:42:52:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:2766.5
09:42:52:  Win32 Service: false
09:42:52:******************************* libFAH ********************************
09:42:52:           Date: Apr 15 2020
09:42:52:           Time: 14:53:14
09:42:52:       Revision: 216968bc7025029c841ed6e36e81a03a316890d3
09:42:52:           Bits: 32
09:42:52:***********************************************************************
09:42:52:<config>
09:42:52:  <!-- Folding Slot Configuration -->
09:42:52:  <cause v='COVID_19'/>
09:42:52:
09:42:52:  <!-- Network -->
09:42:52:  <proxy v=':8080'/>
09:42:52:
09:42:52:  <!-- Slot Control -->
09:42:52:  <power v='FULL'/>
09:42:52:
09:42:52:  <!-- User Information -->
09:42:52:  <passkey v='*****'/>
09:42:52:  <team v='262160'/>
09:42:52:  <user v='jwh212'/>
09:42:52:
09:42:52:  <!-- Folding Slots -->
09:42:52:  <slot id='0' type='CPU'>
09:42:52:    <paused v='true'/>
09:42:52:  </slot>
09:42:52:  <slot id='1' type='GPU'>
09:42:52:  </slot>
09:42:52:</config>
09:42:52:Trying to access database...
09:42:52:Successfully acquired database lock
09:42:52:Enabled folding slot 00: PAUSED cpu:7 (by user)
09:42:52:Enabled folding slot 01: PAUSED gpu:0:[Radeon RX Vega M XT/ M GH] (by user)
09:42:56:3:127.0.0.1:New Web session
09:43:06:FS00:Unpaused
09:43:06:FS01:Unpaused
09:43:06:WU02:FS01:Starting
09:43:06:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\abysm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 706 -lifeline 19428 -checkpoint 15 -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
09:43:06:WU02:FS01:Started FahCore on PID 9604
09:43:06:WU02:FS01:Core PID:16044
09:43:06:WU02:FS01:FahCore 0x22 started
09:43:06:WU03:FS00:Starting
09:43:06:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\abysm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 706 -lifeline 19428 -checkpoint 15 -np 7
09:43:06:WU03:FS00:Started FahCore on PID 4960
09:43:07:WU03:FS00:Core PID:9584
09:43:07:WU03:FS00:FahCore 0xa7 started
09:43:07:WU02:FS01:0x22:*********************** Log Started 2020-04-26T09:43:06Z ***********************
09:43:07:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
09:43:07:WU02:FS01:0x22:       Type: 0x22
09:43:07:WU02:FS01:0x22:       Core: Core22
09:43:07:WU02:FS01:0x22:    Website: https://foldingathome.org/
09:43:07:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
09:43:07:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
09:43:07:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
09:43:07:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 706 -lifeline 9604 -checkpoint 15
09:43:07:WU02:FS01:0x22:             -gpu-vendor amd -opencl-platform 0 -opencl-device 0 -gpu 0
09:43:07:WU02:FS01:0x22:     Config: <none>
09:43:07:WU02:FS01:0x22:************************************ Build *************************************
09:43:07:WU02:FS01:0x22:    Version: 0.0.2
09:43:07:WU02:FS01:0x22:       Date: Dec 6 2019
09:43:07:WU02:FS01:0x22:       Time: 21:30:31
09:43:07:WU02:FS01:0x22: Repository: Git
09:43:07:WU02:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
09:43:07:WU02:FS01:0x22:     Branch: HEAD
09:43:07:WU02:FS01:0x22:   Compiler: Visual C++ 2008
09:43:07:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:43:07:WU02:FS01:0x22:   Platform: win32 10
09:43:07:WU02:FS01:0x22:       Bits: 64
09:43:07:WU02:FS01:0x22:       Mode: Release
09:43:07:WU02:FS01:0x22:************************************ System ************************************
09:43:07:WU02:FS01:0x22:        CPU: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
09:43:07:WU02:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
09:43:07:WU02:FS01:0x22:       CPUs: 8
09:43:07:WU02:FS01:0x22:     Memory: 31.96GiB
09:43:07:WU02:FS01:0x22:Free Memory: 25.69GiB
09:43:07:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
09:43:07:WU02:FS01:0x22: OS Version: 6.2
09:43:07:WU02:FS01:0x22:Has Battery: false
09:43:07:WU02:FS01:0x22: On Battery: false
09:43:07:WU02:FS01:0x22: UTC Offset: -4
09:43:07:WU02:FS01:0x22:        PID: 16044
09:43:07:WU02:FS01:0x22:        CWD: C:\Users\abysm\AppData\Roaming\FAHClient\work
09:43:07:WU03:FS00:0xa7:*********************** Log Started 2020-04-26T09:43:07Z ***********************
09:43:07:WU02:FS01:0x22:         OS: Windows 10 Pro
09:43:07:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:43:07:WU02:FS01:0x22:    OS Arch: AMD64
09:43:07:WU03:FS00:0xa7:       Type: 0xa7
09:43:07:WU02:FS01:0x22:********************************************************************************
09:43:07:WU03:FS00:0xa7:       Core: Gromacs
09:43:07:WU02:FS01:0x22:Project: 11761 (Run 0, Clone 13499, Gen 11)
09:43:07:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 706 -lifeline 4960 -checkpoint 15 -np 7
09:43:07:WU02:FS01:0x22:Unit: 0x0000001880fccb0a5e7114012f174385
09:43:07:WU03:FS00:0xa7:************************************ CBang *************************************
09:43:07:WU02:FS01:0x22:Reading tar file core.xml
09:43:07:WU03:FS00:0xa7:       Date: Oct 26 2019
09:43:07:WU02:FS01:0x22:Reading tar file integrator.xml
09:43:07:WU03:FS00:0xa7:       Time: 01:38:25
09:43:07:WU02:FS01:0x22:Reading tar file state.xml
09:43:07:WU03:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
09:43:07:WU02:FS01:0x22:Reading tar file system.xml
09:43:07:WU03:FS00:0xa7:     Branch: master
09:43:07:WU03:FS00:0xa7:   Compiler: Visual C++ 2008
09:43:07:WU03:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:43:07:WU03:FS00:0xa7:   Platform: win32 10
09:43:07:WU03:FS00:0xa7:       Bits: 64
09:43:07:WU03:FS00:0xa7:       Mode: Release
09:43:07:WU03:FS00:0xa7:************************************ System ************************************
09:43:07:WU03:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
09:43:07:WU03:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
09:43:07:WU03:FS00:0xa7:       CPUs: 8
09:43:07:WU03:FS00:0xa7:     Memory: 31.96GiB
09:43:07:WU03:FS00:0xa7:Free Memory: 25.69GiB
09:43:07:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
09:43:07:WU03:FS00:0xa7: OS Version: 6.2
09:43:07:WU03:FS00:0xa7:Has Battery: false
09:43:07:WU03:FS00:0xa7: On Battery: false
09:43:07:WU03:FS00:0xa7: UTC Offset: -4
09:43:07:WU03:FS00:0xa7:        PID: 9584
09:43:07:WU03:FS00:0xa7:        CWD: C:\Users\abysm\AppData\Roaming\FAHClient\work
09:43:07:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
09:43:07:WU03:FS00:0xa7:    Version: 0.0.18
09:43:07:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:43:07:WU03:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:43:07:WU03:FS00:0xa7:   Homepage: https://foldingathome.org/
09:43:07:WU03:FS00:0xa7:       Time: 01:52:30
09:43:07:WU03:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
09:43:07:WU03:FS00:0xa7:************************************ Build *************************************
09:43:07:WU03:FS00:0xa7:       SIMD: avx_256
09:43:07:WU03:FS00:0xa7:********************************************************************************
09:43:07:WU03:FS00:0xa7:Project: 16406 (Run 844, Clone 4, Gen 121)
09:43:07:WU03:FS00:0xa7:Unit: 0x00000084a8f5c67d5e801f7baaa5afdb
09:43:07:WU03:FS00:0xa7:Digital signatures verified
09:43:07:WU03:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
09:43:07:WU03:FS00:0xa7:Calling: mdrun -s frame121.tpr -o frame121.trr -x frame121.xtc -cpi state.cpt -cpt 15 -nt 6
09:43:07:WU03:FS00:0xa7:ERROR:Guru Meditation #2027f959c8643608.134f125b658490c8 (103494.104666) '03/01/md.log'
09:43:07:WU03:FS00:0xa7:WARNING:Unexpected exit() call
09:43:07:WU03:FS00:0xa7:WARNING:Unexpected exit from science code
09:43:07:WU03:FS00:0xa7:Saving result file ..\logfile_01.txt
09:43:07:WU03:FS00:0xa7:Saving result file frame121.trr
09:43:07:WU03:FS00:0xa7:Saving result file frame121.xtc
09:43:07:WU03:FS00:0xa7:Saving result file md.log
09:43:07:WU02:FS01:0x22:Digital signatures verified
09:43:07:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
09:43:07:WU02:FS01:0x22:Version 0.0.2
09:43:08:WARNING:WU03:FS00:FahCore returned an unknown error code which probably indicates that it crashed
09:43:08:WARNING:WU03:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
09:43:08:WU03:FS00:Starting
09:43:08:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\abysm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 706 -lifeline 19428 -checkpoint 15 -np 7
09:43:08:WU03:FS00:Started FahCore on PID 16588
09:43:08:WU03:FS00:Core PID:15872
09:43:08:WU03:FS00:FahCore 0xa7 started
09:43:09:WU03:FS00:0xa7:*********************** Log Started 2020-04-26T09:43:08Z ***********************
09:43:09:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:43:09:WU03:FS00:0xa7:       Type: 0xa7
09:43:09:WU03:FS00:0xa7:       Core: Gromacs
09:43:09:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 706 -lifeline 16588 -checkpoint 15 -np
09:43:09:WU03:FS00:0xa7:             7
09:43:09:WU03:FS00:0xa7:************************************ CBang *************************************
09:43:09:WU03:FS00:0xa7:       Date: Oct 26 2019
09:43:09:WU03:FS00:0xa7:       Time: 01:38:25
09:43:09:WU03:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
09:43:09:WU03:FS00:0xa7:     Branch: master
09:43:09:WU03:FS00:0xa7:   Compiler: Visual C++ 2008
09:43:09:WU03:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:43:09:WU03:FS00:0xa7:   Platform: win32 10
09:43:09:WU03:FS00:0xa7:       Bits: 64
09:43:09:WU03:FS00:0xa7:       Mode: Release
09:43:09:WU03:FS00:0xa7:************************************ System ************************************
09:43:09:WU03:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
09:43:09:WU03:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
09:43:09:WU03:FS00:0xa7:       CPUs: 8
09:43:09:WU03:FS00:0xa7:     Memory: 31.96GiB
09:43:09:WU03:FS00:0xa7:Free Memory: 25.53GiB
09:43:09:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
09:43:09:WU03:FS00:0xa7: OS Version: 6.2
09:43:09:WU03:FS00:0xa7:Has Battery: false
09:43:09:WU03:FS00:0xa7: On Battery: false
09:43:09:WU03:FS00:0xa7: UTC Offset: -4
09:43:09:WU03:FS00:0xa7:        PID: 15872
09:43:09:WU03:FS00:0xa7:        CWD: C:\Users\abysm\AppData\Roaming\FAHClient\work
09:43:09:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
09:43:09:WU03:FS00:0xa7:    Version: 0.0.18
09:43:09:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:43:09:WU03:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:43:09:WU03:FS00:0xa7:   Homepage: https://foldingathome.org/
09:43:09:WU03:FS00:0xa7:       Time: 01:52:30
09:43:09:WU03:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
09:43:09:WU03:FS00:0xa7:************************************ Build *************************************
09:43:09:WU03:FS00:0xa7:       SIMD: avx_256
09:43:09:WU03:FS00:0xa7:********************************************************************************
09:43:09:WU03:FS00:0xa7:Project: 16406 (Run 844, Clone 4, Gen 121)
09:43:09:WU03:FS00:0xa7:Unit: 0x00000084a8f5c67d5e801f7baaa5afdb
09:43:09:WU03:FS00:0xa7:Digital signatures verified
09:43:09:WU03:FS00:0xa7:Reducing thread count from 7 to 6 to avoid domain decomposition by a prime number > 3
09:43:09:WU03:FS00:0xa7:Calling: mdrun -s frame121.tpr -o frame121.trr -x frame121.xtc -cpi state.cpt -cpt 15 -nt 6
09:43:09:WU03:FS00:0xa7:ERROR:Guru Meditation #2027f959c8643608.134f125b658490c8 (103494.104666) '03/01/md.log'
09:43:09:WU03:FS00:0xa7:WARNING:Unexpected exit() call
09:43:09:WU03:FS00:0xa7:WARNING:Unexpected exit from science code
09:43:09:WU03:FS00:0xa7:Saving result file ..\logfile_01.txt
09:43:09:WU03:FS00:0xa7:Saving result file frame121.trr
09:43:09:WU03:FS00:0xa7:Saving result file frame121.xtc
09:43:09:WU03:FS00:0xa7:Saving result file md.log
09:43:09:WARNING:WU03:FS00:FahCore returned an unknown error code which probably indicates that it crashed
09:43:09:WARNING:WU03:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
09:43:09:WU01:FS00:Starting
09:43:09:WARNING:WU01:FS00:AS lowered CPUs from 7 to 3
09:43:09:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\abysm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 19428 -checkpoint 15 -np 3
09:43:09:WU01:FS00:Started FahCore on PID 18548
09:43:09:WU01:FS00:Core PID:4940
09:43:09:WU01:FS00:FahCore 0xa7 started
09:43:10:WU01:FS00:0xa7:*********************** Log Started 2020-04-26T09:43:09Z ***********************
09:43:10:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:43:10:WU01:FS00:0xa7:       Type: 0xa7
09:43:10:WU01:FS00:0xa7:       Core: Gromacs
09:43:10:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 18548 -checkpoint 15 -np
09:43:10:WU01:FS00:0xa7:             3
09:43:10:WU01:FS00:0xa7:************************************ CBang *************************************
09:43:10:WU01:FS00:0xa7:       Date: Oct 26 2019
09:43:10:WU01:FS00:0xa7:       Time: 01:38:25
09:43:10:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
09:43:10:WU01:FS00:0xa7:     Branch: master
09:43:10:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
09:43:10:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:43:10:WU01:FS00:0xa7:   Platform: win32 10
09:43:10:WU01:FS00:0xa7:       Bits: 64
09:43:10:WU01:FS00:0xa7:       Mode: Release
09:43:10:WU01:FS00:0xa7:************************************ System ************************************
09:43:10:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
09:43:10:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
09:43:10:WU01:FS00:0xa7:       CPUs: 8
09:43:10:WU01:FS00:0xa7:     Memory: 31.96GiB
09:43:10:WU01:FS00:0xa7:Free Memory: 25.49GiB
09:43:10:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
09:43:10:WU01:FS00:0xa7: OS Version: 6.2
09:43:10:WU01:FS00:0xa7:Has Battery: false
09:43:10:WU01:FS00:0xa7: On Battery: false
09:43:10:WU01:FS00:0xa7: UTC Offset: -4
09:43:10:WU01:FS00:0xa7:        PID: 4940
09:43:10:WU01:FS00:0xa7:        CWD: C:\Users\abysm\AppData\Roaming\FAHClient\work
09:43:10:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
09:43:10:WU01:FS00:0xa7:    Version: 0.0.18
09:43:10:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:43:10:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:43:10:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
09:43:10:WU01:FS00:0xa7:       Time: 01:52:30
09:43:10:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
09:43:10:WU01:FS00:0xa7:************************************ Build *************************************
09:43:10:WU01:FS00:0xa7:       SIMD: avx_256
09:43:10:WU01:FS00:0xa7:********************************************************************************
09:43:10:WU01:FS00:0xa7:Project: 14620 (Run 1767, Clone 1, Gen 42)
09:43:10:WU01:FS00:0xa7:Unit: 0x0000002d9bf7a4d55e876bf89eb9a695
09:43:10:WU01:FS00:0xa7:Digital signatures verified
09:43:10:WU01:FS00:0xa7:Calling: mdrun -s frame42.tpr -o frame42.trr -cpi state.cpt -cpt 15 -nt 3
09:43:10:WU01:FS00:0xa7:Steps: first=0 total=250000
09:43:10:WU01:FS00:0xa7:Completed 40477 out of 250000 steps (16%)
09:43:17:WU02:FS01:0x22:Completed 0 out of 2000000 steps (0%)
09:43:17:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
09:43:53:Removing old file 'configs/config-20200426-074418.xml'
09:43:53:Saving configuration to config.xml
09:43:53:<config>
09:43:53:  <!-- Folding Slot Configuration -->
09:43:53:  <cause v='COVID_19'/>
09:43:53:
09:43:53:  <!-- Network -->
09:43:53:  <proxy v=':8080'/>
09:43:53:
09:43:53:  <!-- Slot Control -->
09:43:53:  <power v='FULL'/>
09:43:53:
09:43:53:  <!-- User Information -->
09:43:53:  <passkey v='*****'/>
09:43:53:  <team v='262160'/>
09:43:53:  <user v='jwh212'/>
09:43:53:
09:43:53:  <!-- Folding Slots -->
09:43:53:  <slot id='0' type='CPU'/>
09:43:53:  <slot id='1' type='GPU'/>
09:43:53:</config>
09:44:31:FS00:Shutting core down
09:44:32:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 4940
09:44:32:WU01:FS00:0xa7:Exiting, please wait. . .
09:44:32:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
09:44:33:WU03:FS00:Starting
09:44:33:WARNING:WU03:FS00:Changed SMP threads from 7 to 6 this can cause some work units to fail
09:44:33:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\abysm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 706 -lifeline 19428 -checkpoint 15 -np 6
09:44:33:WU03:FS00:Started FahCore on PID 10012
09:44:33:WU03:FS00:Core PID:4684
09:44:33:WU03:FS00:FahCore 0xa7 started
09:44:33:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
09:44:33:WU03:FS00:0xa7:*********************** Log Started 2020-04-26T09:44:33Z ***********************
09:44:33:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:44:33:WU03:FS00:0xa7:       Type: 0xa7
09:44:33:WU03:FS00:0xa7:       Core: Gromacs
09:44:33:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 706 -lifeline 10012 -checkpoint 15 -np
09:44:33:WU03:FS00:0xa7:             6
09:44:33:WU03:FS00:0xa7:************************************ CBang *************************************
09:44:33:WU03:FS00:0xa7:       Date: Oct 26 2019
09:44:33:WU03:FS00:0xa7:       Time: 01:38:25
09:44:33:WU03:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
09:44:33:WU03:FS00:0xa7:     Branch: master
09:44:33:WU03:FS00:0xa7:   Compiler: Visual C++ 2008
09:44:33:WU03:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:44:33:WU03:FS00:0xa7:   Platform: win32 10
09:44:33:WU03:FS00:0xa7:       Bits: 64
09:44:33:WU03:FS00:0xa7:       Mode: Release
09:44:33:WU03:FS00:0xa7:************************************ System ************************************
09:44:33:WU03:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
09:44:33:WU03:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
09:44:33:WU03:FS00:0xa7:       CPUs: 8
09:44:33:WU03:FS00:0xa7:     Memory: 31.96GiB
09:44:33:WU03:FS00:0xa7:Free Memory: 25.39GiB
09:44:33:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
09:44:33:WU03:FS00:0xa7: OS Version: 6.2
09:44:33:WU03:FS00:0xa7:Has Battery: false
09:44:33:WU03:FS00:0xa7: On Battery: false
09:44:33:WU03:FS00:0xa7: UTC Offset: -4
09:44:33:WU03:FS00:0xa7:        PID: 4684
09:44:33:WU03:FS00:0xa7:        CWD: C:\Users\abysm\AppData\Roaming\FAHClient\work
09:44:33:WU03:FS00:0xa7:******************************** Build - libFAH ********************************
09:44:33:WU03:FS00:0xa7:    Version: 0.0.18
09:44:33:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:44:33:WU03:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:44:33:WU03:FS00:0xa7:   Homepage: https://foldingathome.org/
09:44:33:WU03:FS00:0xa7:       Time: 01:52:30
09:44:33:WU03:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
09:44:33:WU03:FS00:0xa7:************************************ Build *************************************
09:44:33:WU03:FS00:0xa7:       SIMD: avx_256
09:44:33:WU03:FS00:0xa7:********************************************************************************
09:44:33:WU03:FS00:0xa7:Project: 16406 (Run 844, Clone 4, Gen 121)
09:44:33:WU03:FS00:0xa7:Unit: 0x00000084a8f5c67d5e801f7baaa5afdb
09:44:33:WU03:FS00:0xa7:Digital signatures verified
09:44:33:WU03:FS00:0xa7:Calling: mdrun -s frame121.tpr -o frame121.trr -x frame121.xtc -cpi state.cpt -cpt 15 -nt 6
09:44:33:WU03:FS00:0xa7:ERROR:Guru Meditation #2027f959c8643608.134f125b658490c8 (103494.104666) '03/01/md.log'
09:44:34:WU03:FS00:0xa7:WARNING:Unexpected exit() call
09:44:34:WU03:FS00:0xa7:WARNING:Unexpected exit from science code
09:44:34:WU03:FS00:0xa7:Saving result file ..\logfile_01.txt
09:44:34:WU03:FS00:0xa7:Saving result file frame121.trr
09:44:34:WU03:FS00:0xa7:Saving result file frame121.xtc
09:44:34:WU03:FS00:0xa7:Saving result file md.log
09:44:34:WU03:FS00:0xa7:ERROR:Guru Meditation #2027f959c8643608.134f125b658490c8 (103494.104666) '03/01/md.log'
09:44:34:WARNING:WU03:FS00:FahCore returned an unknown error code which probably indicates that it crashed
09:44:34:WARNING:WU03:FS00:FahCore returned: UNKNOWN_ENUM (-1073740791 = 0xc0000409)
09:44:34:WARNING:WU03:FS00:Too many errors, failing
09:44:34:WU03:FS00:Sending unit results: id:03 state:SEND error:FAILED project:16406 run:844 clone:4 gen:121 core:0xa7 unit:0x00000084a8f5c67d5e801f7baaa5afdb
09:44:34:WU03:FS00:Uploading 220.50KiB to 168.245.198.125
09:44:34:WU01:FS00:Starting
09:44:34:WU03:FS00:Connecting to 168.245.198.125:8080
09:44:34:WARNING:WU01:FS00:Changed SMP threads from 7 to 6 this can cause some work units to fail
09:44:34:WARNING:WU01:FS00:AS lowered CPUs from 6 to 3
09:44:34:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\abysm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 19428 -checkpoint 15 -np 3
09:44:34:WU01:FS00:Started FahCore on PID 14352
09:44:34:WU01:FS00:Core PID:5684
09:44:34:WU01:FS00:FahCore 0xa7 started
09:44:34:WU01:FS00:0xa7:*********************** Log Started 2020-04-26T09:44:34Z ***********************
09:44:34:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:44:34:WU01:FS00:0xa7:       Type: 0xa7
09:44:34:WU01:FS00:0xa7:       Core: Gromacs
09:44:34:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 14352 -checkpoint 15 -np
09:44:34:WU01:FS00:0xa7:             3
09:44:34:WU01:FS00:0xa7:************************************ CBang *************************************
09:44:34:WU01:FS00:0xa7:       Date: Oct 26 2019
09:44:34:WU01:FS00:0xa7:       Time: 01:38:25
09:44:34:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
09:44:34:WU01:FS00:0xa7:     Branch: master
09:44:34:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
09:44:34:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:44:34:WU01:FS00:0xa7:   Platform: win32 10
09:44:34:WU01:FS00:0xa7:       Bits: 64
09:44:34:WU01:FS00:0xa7:       Mode: Release
09:44:34:WU01:FS00:0xa7:************************************ System ************************************
09:44:34:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
09:44:34:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
09:44:34:WU01:FS00:0xa7:       CPUs: 8
09:44:34:WU01:FS00:0xa7:     Memory: 31.96GiB
09:44:34:WU01:FS00:0xa7:Free Memory: 25.38GiB
09:44:34:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
09:44:34:WU01:FS00:0xa7: OS Version: 6.2
09:44:34:WU01:FS00:0xa7:Has Battery: false
09:44:34:WU01:FS00:0xa7: On Battery: false
09:44:34:WU01:FS00:0xa7: UTC Offset: -4
09:44:34:WU01:FS00:0xa7:        PID: 5684
09:44:34:WU01:FS00:0xa7:        CWD: C:\Users\abysm\AppData\Roaming\FAHClient\work
09:44:34:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
09:44:34:WU01:FS00:0xa7:    Version: 0.0.18
09:44:34:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:44:34:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:44:34:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
09:44:35:WU01:FS00:0xa7:       Date: Oct 26 2019
09:44:35:WU01:FS00:0xa7:       Time: 01:52:30
09:44:35:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
09:44:35:WU01:FS00:0xa7:     Branch: master
09:44:35:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
09:44:35:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:44:35:WU01:FS00:0xa7:   Platform: win32 10
09:44:35:WU01:FS00:0xa7:       Bits: 64
09:44:35:WU01:FS00:0xa7:       Mode: Release
09:44:35:WU01:FS00:0xa7:************************************ Build *************************************
09:44:35:WU01:FS00:0xa7:       SIMD: avx_256
09:44:35:WU01:FS00:0xa7:********************************************************************************
09:44:35:WU01:FS00:0xa7:Project: 14620 (Run 1767, Clone 1, Gen 42)
09:44:35:WU01:FS00:0xa7:Unit: 0x0000002d9bf7a4d55e876bf89eb9a695
09:44:35:WU01:FS00:0xa7:Digital signatures verified
09:44:35:WU01:FS00:0xa7:Calling: mdrun -s frame42.tpr -o frame42.trr -cpi state.cpt -cpt 15 -nt 3
09:44:35:WU01:FS00:0xa7:Steps: first=0 total=250000
09:44:35:WU03:FS00:Upload complete
09:44:35:WU03:FS00:Server responded WORK_QUIT (404)
09:44:35:WARNING:WU03:FS00:Server did not like results, dumping
09:44:35:WU03:FS00:Cleaning up
09:44:35:WU01:FS00:0xa7:Completed 42126 out of 250000 steps (16%)
09:44:53:WU01:FS00:0xa7:Completed 42500 out of 250000 steps (17%)
09:44:54:Removing old file 'configs/config-20200426-074419.xml'
09:44:54:Saving configuration to config.xml
09:44:54:<config>
09:44:54:  <!-- Folding Slot Configuration -->
09:44:54:  <cause v='COVID_19'/>
09:44:54:
09:44:54:  <!-- Network -->
09:44:54:  <proxy v=':8080'/>
09:44:54:
09:44:54:  <!-- User Information -->
09:44:54:  <passkey v='*****'/>
09:44:54:  <team v='262160'/>
09:44:54:  <user v='jwh212'/>
09:44:54:
09:44:54:  <!-- Folding Slots -->
09:44:54:  <slot id='0' type='CPU'/>
09:44:54:  <slot id='1' type='GPU'/>
09:44:54:</config>
09:45:04:FS00:Shutting core down
09:45:04:WU01:FS00:0xa7:WARNING:Console control signal 1 on PID 5684
09:45:04:WU01:FS00:0xa7:Exiting, please wait. . .
09:45:05:WU01:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
09:45:06:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
09:45:34:WU01:FS00:Starting
09:45:34:WARNING:WU01:FS00:Changed SMP threads from 6 to 7 this can cause some work units to fail
09:45:34:WARNING:WU01:FS00:AS lowered CPUs from 7 to 3
09:45:34:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\abysm\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 706 -lifeline 19428 -checkpoint 15 -np 3
09:45:34:WU01:FS00:Started FahCore on PID 7252
09:45:34:WU01:FS00:Core PID:6760
09:45:34:WU01:FS00:FahCore 0xa7 started
09:45:35:WU01:FS00:0xa7:*********************** Log Started 2020-04-26T09:45:34Z ***********************
09:45:35:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
09:45:35:WU01:FS00:0xa7:       Type: 0xa7
09:45:35:WU01:FS00:0xa7:       Core: Gromacs
09:45:35:WU01:FS00:0xa7:       Args: -dir 01 -suffix 01 -version 706 -lifeline 7252 -checkpoint 15 -np 3
09:45:35:WU01:FS00:0xa7:************************************ CBang *************************************
09:45:35:WU01:FS00:0xa7:       Date: Oct 26 2019
09:45:35:WU01:FS00:0xa7:       Time: 01:38:25
09:45:35:WU01:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
09:45:35:WU01:FS00:0xa7:     Branch: master
09:45:35:WU01:FS00:0xa7:   Compiler: Visual C++ 2008
09:45:35:WU01:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
09:45:35:WU01:FS00:0xa7:   Platform: win32 10
09:45:35:WU01:FS00:0xa7:       Bits: 64
09:45:35:WU01:FS00:0xa7:       Mode: Release
09:45:35:WU01:FS00:0xa7:************************************ System ************************************
09:45:35:WU01:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
09:45:35:WU01:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
09:45:35:WU01:FS00:0xa7:       CPUs: 8
09:45:35:WU01:FS00:0xa7:     Memory: 31.96GiB
09:45:35:WU01:FS00:0xa7:Free Memory: 25.18GiB
09:45:35:WU01:FS00:0xa7:    Threads: WINDOWS_THREADS
09:45:35:WU01:FS00:0xa7: OS Version: 6.2
09:45:35:WU01:FS00:0xa7:Has Battery: false
09:45:35:WU01:FS00:0xa7: On Battery: false
09:45:35:WU01:FS00:0xa7: UTC Offset: -4
09:45:35:WU01:FS00:0xa7:        PID: 6760
09:45:35:WU01:FS00:0xa7:        CWD: C:\Users\abysm\AppData\Roaming\FAHClient\work
09:45:35:WU01:FS00:0xa7:******************************** Build - libFAH ********************************
09:45:35:WU01:FS00:0xa7:    Version: 0.0.18
09:45:35:WU01:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
09:45:35:WU01:FS00:0xa7:  Copyright: 2019 foldingathome.org
09:45:35:WU01:FS00:0xa7:   Homepage: https://foldingathome.org/
09:45:35:WU01:FS00:0xa7:       Time: 01:52:30
09:45:35:WU01:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
09:45:35:WU01:FS00:0xa7:************************************ Build *************************************
09:45:35:WU01:FS00:0xa7:       SIMD: avx_256
09:45:35:WU01:FS00:0xa7:********************************************************************************
09:45:35:WU01:FS00:0xa7:Project: 14620 (Run 1767, Clone 1, Gen 42)
09:45:35:WU01:FS00:0xa7:Unit: 0x0000002d9bf7a4d55e876bf89eb9a695
09:45:35:WU01:FS00:0xa7:Digital signatures verified
09:45:35:WU01:FS00:0xa7:Calling: mdrun -s frame42.tpr -o frame42.trr -cpi state.cpt -cpt 15 -nt 3
09:45:35:WU01:FS00:0xa7:Steps: first=0 total=250000
09:45:35:WU01:FS00:0xa7:Completed 42724 out of 250000 steps (17%)
09:45:55:Removing old file 'configs/config-20200426-074459.xml'
09:45:55:Saving configuration to config.xml
09:45:55:<config>
09:45:55:  <!-- Folding Slot Configuration -->
09:45:55:  <cause v='COVID_19'/>
09:45:55:
09:45:55:  <!-- Network -->
09:45:55:  <proxy v=':8080'/>
09:45:55:
09:45:55:  <!-- Slot Control -->
09:45:55:  <power v='full'/>
09:45:55:
09:45:55:  <!-- User Information -->
09:45:55:  <passkey v='*****'/>
09:45:55:  <team v='262160'/>
09:45:55:  <user v='jwh212'/>
09:45:55:
09:45:55:  <!-- Folding Slots -->
09:45:55:  <slot id='0' type='CPU'/>
09:45:55:  <slot id='1' type='GPU'/>
09:45:55:</config>
09:46:17:WU02:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
09:47:22:WU01:FS00:0xa7:Completed 45000 out of 250000 steps (18%)
09:49:13:WU02:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
09:49:14:WU01:FS00:0xa7:Completed 47500 out of 250000 steps (19%)
09:51:20:WU01:FS00:0xa7:Completed 50000 out of 250000 steps (20%)
09:52:14:WU02:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
09:53:22:WU01:FS00:0xa7:Completed 52500 out of 250000 steps (21%)
09:55:12:WU02:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
09:55:24:WU01:FS00:0xa7:Completed 55000 out of 250000 steps (22%)
09:57:29:WU01:FS00:0xa7:Completed 57500 out of 250000 steps (23%)
09:58:10:WU02:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
09:59:36:WU01:FS00:0xa7:Completed 60000 out of 250000 steps (24%)
10:01:11:WU02:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
MrKai
Re: AMD Radeon RX Vega M GH
Post by MrKai »
I got jwh's email this morning and can confirm that reverting to/installing the drivers linked to got everything working as expected. I can now add another machine in my "home arcade" to the fray!
Thanks so much jwh!
-K
jwh212
Post by jwh212 »
MrKai wrote:I got jwh's email this morning and can confirm that reverting to/installing the drivers linked to got everything working as expected. I can now add another machine in my "home arcade" to the fray!
Thanks so much jwh!
-K
most welcome!! Hades Canyon army!!
