Failed to send results to work server: Transfer failed
Horsti
Post by Horsti »
Hi all,
it seems I can't upload my finished WUs as I always get the Exception “WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed”. The download works fine for both CPU and GPU WUs. I tried it multiple times with no other application running.
Here is my log:
*********************** Log Started 2020-03-22T08:50:53Z ***********************
08:50:53:************************* Folding@home Client *************************
08:50:53:        Website: https://foldingathome.org/
08:50:53:      Copyright: (c) 2009-2018 foldingathome.org
08:50:53:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:50:53:           Args: --open-web-control
08:50:53:         Config: C:\Users\Max\AppData\Roaming\FAHClient\config.xml
08:50:53:******************************** Build ********************************
08:50:53:        Version: 7.5.1
08:50:53:           Date: May 11 2018
08:50:53:           Time: 13:06:32
08:50:53:     Repository: Git
08:50:53:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
08:50:53:         Branch: master
08:50:53:       Compiler: Visual C++ 2008
08:50:53:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:50:53:       Platform: win32 10
08:50:53:           Bits: 32
08:50:53:           Mode: Release
08:50:53:******************************* System ********************************
08:50:53:            CPU: AMD Ryzen 7 1700X Eight-Core Processor
08:50:53:         CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
08:50:53:           CPUs: 16
08:50:53:         Memory: 15.95GiB
08:50:53:    Free Memory: 13.70GiB
08:50:53:        Threads: WINDOWS_THREADS
08:50:53:     OS Version: 6.2
08:50:53:    Has Battery: false
08:50:53:     On Battery: false
08:50:53:     UTC Offset: 1
08:50:53:            PID: 7784
08:50:53:            CWD: C:\Users\Max\AppData\Roaming\FAHClient
08:50:53:             OS: Windows 10 Enterprise
08:50:53:        OS Arch: AMD64
08:50:53:           GPUs: 1
08:50:53:          GPU 0: Bus:9 Slot:0 Func:0 NVIDIA:3 GK110 [GeForce GTX 780] 3977
08:50:53:  CUDA Device 0: Platform:0 Device:0 Bus:9 Slot:0 Compute:3.5 Driver:10.2
08:50:53:OpenCL Device 0: Platform:0 Device:0 Bus:9 Slot:0 Compute:1.2 Driver:441.12
08:50:53:  Win32 Service: false
08:50:53:***********************************************************************
08:50:53:<config>
08:50:53:  <!-- Network -->
08:50:53:  <proxy v=':8080'/>
08:50:53:
08:50:53:  <!-- Slot Control -->
08:50:53:  <power v='full'/>
08:50:53:
08:50:53:  <!-- User Information -->
08:50:53:  <passkey v='********************************'/>
08:50:53:  <user v='Max'/>
08:50:53:
08:50:53:  <!-- Folding Slots -->
08:50:53:  <slot id='0' type='CPU'/>
08:50:53:  <slot id='1' type='GPU'/>
08:50:53:</config>
08:50:53:Trying to access database...
08:50:54:Successfully acquired database lock
08:50:54:Enabled folding slot 00: READY cpu:15
08:50:54:Enabled folding slot 01: READY gpu:0:GK110 [GeForce GTX 780] 3977
08:50:54:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14533 run:0 clone:6293 gen:3 core:0x22 unit:0x0000000480fccb025e72f251be8fee75
08:50:54:WU01:FS01:Uploading 49.94MiB to 128.252.203.2
08:50:54:WU01:FS01:Connecting to 128.252.203.2:8080
08:50:54:WU02:FS01:Starting
08:50:54:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Max\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 02 -suffix 01 -version 705 -lifeline 7784 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
08:50:54:WU02:FS01:Started FahCore on PID 1232
08:50:54:WU02:FS01:Core PID:10864
08:50:54:WU02:FS01:FahCore 0x22 started
08:50:55:WU02:FS01:0x22:*********************** Log Started 2020-03-22T08:50:54Z ***********************
08:50:55:WU02:FS01:0x22:*************************** Core22 Folding@home Core ***************************
08:50:55:WU02:FS01:0x22:       Type: 0x22
08:50:55:WU02:FS01:0x22:       Core: Core22
08:50:55:WU02:FS01:0x22:    Website: https://foldingathome.org/
08:50:55:WU02:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
08:50:55:WU02:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
08:50:55:WU02:FS01:0x22:             <rafal.wiewiora@choderalab.org>
08:50:55:WU02:FS01:0x22:       Args: -dir 02 -suffix 01 -version 705 -lifeline 1232 -checkpoint 15
08:50:55:WU02:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
08:50:55:WU02:FS01:0x22:             0 -gpu 0
08:50:55:WU02:FS01:0x22:     Config: <none>
08:50:55:WU02:FS01:0x22:************************************ Build *************************************
08:50:55:WU02:FS01:0x22:    Version: 0.0.2
08:50:55:WU02:FS01:0x22:       Date: Dec 6 2019
08:50:55:WU02:FS01:0x22:       Time: 21:30:31
08:50:55:WU02:FS01:0x22: Repository: Git
08:50:55:WU02:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
08:50:55:WU02:FS01:0x22:     Branch: HEAD
08:50:55:WU02:FS01:0x22:   Compiler: Visual C++ 2008
08:50:55:WU02:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:50:55:WU02:FS01:0x22:   Platform: win32 10
08:50:55:WU02:FS01:0x22:       Bits: 64
08:50:55:WU02:FS01:0x22:       Mode: Release
08:50:55:WU02:FS01:0x22:************************************ System ************************************
08:50:55:WU02:FS01:0x22:        CPU: AMD Ryzen 7 1700X Eight-Core Processor
08:50:55:WU02:FS01:0x22:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
08:50:55:WU02:FS01:0x22:       CPUs: 16
08:50:55:WU02:FS01:0x22:     Memory: 15.95GiB
08:50:55:WU02:FS01:0x22:Free Memory: 13.61GiB
08:50:55:WU02:FS01:0x22:    Threads: WINDOWS_THREADS
08:50:55:WU02:FS01:0x22: OS Version: 6.2
08:50:55:WU02:FS01:0x22:Has Battery: false
08:50:55:WU02:FS01:0x22: On Battery: false
08:50:55:WU02:FS01:0x22: UTC Offset: 1
08:50:55:WU02:FS01:0x22:        PID: 10864
08:50:55:WU02:FS01:0x22:        CWD: C:\Users\Max\AppData\Roaming\FAHClient\work
08:50:55:WU02:FS01:0x22:         OS: Windows 10 Education
08:50:55:WU02:FS01:0x22:    OS Arch: AMD64
08:50:55:WU02:FS01:0x22:********************************************************************************
08:50:55:WU02:FS01:0x22:Project: 11760 (Run 0, Clone 580, Gen 14)
08:50:55:WU02:FS01:0x22:Unit: 0x0000001780fccb0a5e6d7ccdd3bbf58e
08:50:55:WU02:FS01:0x22:Digital signatures verified
08:50:55:WU02:FS01:0x22:Folding@home GPU Core22 Folding@home Core
08:50:55:WU02:FS01:0x22:Version 0.0.2
08:50:55:WU02:FS01:0x22:  Found a checkpoint file
08:50:57:WU00:FS00:Connecting to 65.254.110.245:8080
08:50:57:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
08:50:58:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14533 run:0 clone:6293 gen:3 core:0x22 unit:0x0000000480fccb025e72f251be8fee75
08:50:58:WU01:FS01:Uploading 49.94MiB to 128.252.203.2
08:50:58:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:50:58:WU01:FS01:Connecting to 128.252.203.2:8080
08:50:58:WU00:FS00:Connecting to 18.218.241.186:80
08:50:58:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:50:58:ERROR:WU00:FS00:Exception: Could not get an assignment
08:50:58:WU00:FS00:Connecting to 65.254.110.245:8080
08:50:59:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:50:59:WU00:FS00:Connecting to 18.218.241.186:80
08:50:59:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:50:59:ERROR:WU00:FS00:Exception: Could not get an assignment
08:50:59:8:127.0.0.1:New Web connection
08:51:01:29:127.0.0.1:New Web connection
08:51:02:WU02:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
08:51:02:WU02:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
08:51:03:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
08:51:58:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14533 run:0 clone:6293 gen:3 core:0x22 unit:0x0000000480fccb025e72f251be8fee75
08:51:58:WU01:FS01:Uploading 49.94MiB to 128.252.203.2
08:51:58:WU01:FS01:Connecting to 128.252.203.2:8080
08:51:58:WU00:FS00:Connecting to 65.254.110.245:8080
08:51:59:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:51:59:WU00:FS00:Connecting to 18.218.241.186:80
08:51:59:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:51:59:ERROR:WU00:FS00:Exception: Could not get an assignment
08:52:04:WU01:FS01:Upload 8.51%
08:52:10:WU01:FS01:Upload 18.90%
08:52:16:WU01:FS01:Upload 32.67%
08:52:19:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
08:53:35:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14533 run:0 clone:6293 gen:3 core:0x22 unit:0x0000000480fccb025e72f251be8fee75
08:53:35:WU01:FS01:Uploading 49.94MiB to 128.252.203.2
08:53:35:WU01:FS01:Connecting to 128.252.203.2:8080
08:53:36:WU00:FS00:Connecting to 65.254.110.245:8080
08:53:36:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:53:36:WU00:FS00:Connecting to 18.218.241.186:80
08:53:37:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:53:37:ERROR:WU00:FS00:Exception: Could not get an assignment
08:53:41:WU01:FS01:Upload 9.76%
08:53:47:WU01:FS01:Upload 19.78%
08:53:49:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
08:54:16:WU02:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
08:56:12:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14533 run:0 clone:6293 gen:3 core:0x22 unit:0x0000000480fccb025e72f251be8fee75
08:56:12:WU01:FS01:Uploading 49.94MiB to 128.252.203.2
08:56:12:WU01:FS01:Connecting to 128.252.203.2:8080
08:56:13:WU00:FS00:Connecting to 65.254.110.245:8080
08:56:13:WU00:FS00:Assigned to work server 155.247.164.213
08:56:13:WU00:FS00:Requesting new work unit for slot 00: READY cpu:15 from 155.247.164.213
08:56:13:WU00:FS00:Connecting to 155.247.164.213:8080
08:56:14:WU00:FS00:Downloading 1.23MiB
08:56:14:WU00:FS00:Download complete
08:56:14:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14198 run:4 clone:43 gen:39 core:0xa7 unit:0x0000002b9bf7a4d55e655fef71ba0c37
08:56:14:WU00:FS00:Starting
08:56:14:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Max\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/avx/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 705 -lifeline 7784 -checkpoint 15 -np 15
08:56:14:WU00:FS00:Started FahCore on PID 2668
08:56:15:WU00:FS00:Core PID:10488
08:56:15:WU00:FS00:FahCore 0xa7 started
08:56:15:WU00:FS00:0xa7:*********************** Log Started 2020-03-22T08:56:15Z ***********************
08:56:15:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:56:15:WU00:FS00:0xa7:       Type: 0xa7
08:56:15:WU00:FS00:0xa7:       Core: Gromacs
08:56:15:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 705 -lifeline 2668 -checkpoint 15 -np
08:56:15:WU00:FS00:0xa7:             15
08:56:15:WU00:FS00:0xa7:************************************ CBang *************************************
08:56:15:WU00:FS00:0xa7:       Date: Oct 26 2019
08:56:15:WU00:FS00:0xa7:       Time: 01:38:25
08:56:15:WU00:FS00:0xa7:   Revision: c46a1a011a24143739ac7218c5a435f66777f62f
08:56:15:WU00:FS00:0xa7:     Branch: master
08:56:15:WU00:FS00:0xa7:   Compiler: Visual C++ 2008
08:56:15:WU00:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
08:56:15:WU00:FS00:0xa7:   Platform: win32 10
08:56:15:WU00:FS00:0xa7:       Bits: 64
08:56:15:WU00:FS00:0xa7:       Mode: Release
08:56:15:WU00:FS00:0xa7:************************************ System ************************************
08:56:15:WU00:FS00:0xa7:        CPU: AMD Ryzen 7 1700X Eight-Core Processor
08:56:15:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 23 Model 1 Stepping 1
08:56:15:WU00:FS00:0xa7:       CPUs: 16
08:56:15:WU00:FS00:0xa7:     Memory: 15.95GiB
08:56:15:WU00:FS00:0xa7:Free Memory: 12.08GiB
08:56:15:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
08:56:15:WU00:FS00:0xa7: OS Version: 6.2
08:56:15:WU00:FS00:0xa7:Has Battery: false
08:56:15:WU00:FS00:0xa7: On Battery: false
08:56:15:WU00:FS00:0xa7: UTC Offset: 1
08:56:15:WU00:FS00:0xa7:        PID: 10488
08:56:15:WU00:FS00:0xa7:        CWD: C:\Users\Max\AppData\Roaming\FAHClient\work
08:56:15:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
08:56:15:WU00:FS00:0xa7:    Version: 0.0.18
08:56:15:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:56:15:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:56:15:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
08:56:15:WU00:FS00:0xa7:       Time: 01:52:30
08:56:15:WU00:FS00:0xa7:   Revision: c1e3513b1bc0c16013668f2173ee969e5995b38e
08:56:15:WU00:FS00:0xa7:************************************ Build *************************************
08:56:15:WU00:FS00:0xa7:       SIMD: avx_256
08:56:15:WU00:FS00:0xa7:********************************************************************************
08:56:15:WU00:FS00:0xa7:Project: 14198 (Run 4, Clone 43, Gen 39)
08:56:15:WU00:FS00:0xa7:Unit: 0x0000002b9bf7a4d55e655fef71ba0c37
08:56:15:WU00:FS00:0xa7:Reading tar file core.xml
08:56:15:WU00:FS00:0xa7:Reading tar file frame39.tpr
08:56:15:WU00:FS00:0xa7:Digital signatures verified
08:56:15:WU00:FS00:0xa7:Calling: mdrun -s frame39.tpr -o frame39.trr -cpt 15 -nt 15
08:56:15:WU00:FS00:0xa7:Steps: first=19500000 total=500000
08:56:15:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
08:56:16:WU00:FS00:0xa7:Completed 1 out of 500000 steps (0%)
08:56:48:WU00:FS00:0xa7:Completed 5000 out of 500000 steps (1%)
08:57:20:WU00:FS00:0xa7:Completed 10000 out of 500000 steps (2%)
08:57:39:WU02:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
08:57:50:WU00:FS00:0xa7:Completed 15000 out of 500000 steps (3%)
08:58:22:WU00:FS00:0xa7:Completed 20000 out of 500000 steps (4%)
08:58:57:WU00:FS00:0xa7:Completed 25000 out of 500000 steps (5%)
08:59:31:WU00:FS00:0xa7:Completed 30000 out of 500000 steps (6%)
09:00:02:WU00:FS00:0xa7:Completed 35000 out of 500000 steps (7%)
09:00:26:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:14533 run:0 clone:6293 gen:3 core:0x22 unit:0x0000000480fccb025e72f251be8fee75
09:00:26:WU01:FS01:Uploading 49.94MiB to 128.252.203.2
09:00:26:WU01:FS01:Connecting to 128.252.203.2:8080
09:00:27:WARNING:WU01:FS01:Exception: Failed to send results to work server: Transfer failed
Thanks for the help!
Re: Failed to send results to work server: Transfer failed
Post by muziqaz »
That's part of the ongoing server issues, unfortunately :(
FAH Omega tester
