CPU status is ready
italyboy927
CPU status is ready
Post by italyboy927 »
GPU is running fine. CPU is status is ready, but not running a job. Below is the logs:
*********************** Log Started 2020-03-21T17:43:41Z ***********************
17:43:41:************************* Folding@home Client *************************
17:43:41:        Website: https://foldingathome.org/
17:43:41:      Copyright: (c) 2009-2018 foldingathome.org
17:43:41:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:43:41:           Args: --open-web-control
17:43:41:         Config: D:\FAHClient\config.xml
17:43:41:******************************** Build ********************************
17:43:41:        Version: 7.5.1
17:43:41:           Date: May 11 2018
17:43:41:           Time: 13:06:32
17:43:41:     Repository: Git
17:43:41:       Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
17:43:41:         Branch: master
17:43:41:       Compiler: Visual C++ 2008
17:43:41:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:43:41:       Platform: win32 10
17:43:41:           Bits: 32
17:43:41:           Mode: Release
17:43:41:******************************* System ********************************
17:43:41:            CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
17:43:41:         CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
17:43:41:           CPUs: 8
17:43:41:         Memory: 63.94GiB
17:43:41:    Free Memory: 56.61GiB
17:43:41:        Threads: WINDOWS_THREADS
17:43:41:     OS Version: 6.2
17:43:41:    Has Battery: false
17:43:41:     On Battery: false
17:43:41:     UTC Offset: -4
17:43:41:            PID: 19468
17:43:41:            CWD: D:\FAHClient
17:43:41:             OS: Windows 10 Enterprise
17:43:41:        OS Arch: AMD64
17:43:41:           GPUs: 1
17:43:41:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP106 [GeForce GTX 1060 3GB] 3935
17:43:41:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:10.2
17:43:41:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:442.74
17:43:41:  Win32 Service: false
17:43:41:***********************************************************************
17:43:41:<config>
17:43:41:  <!-- Network -->
17:43:41:  <proxy v=':8080'/>
17:43:41:
17:43:41:  <!-- Slot Control -->
17:43:41:  <power v='FULL'/>
17:43:41:
17:43:41:  <!-- User Information -->
17:43:41:  <user v='italyboy927'/>
17:43:41:
17:43:41:  <!-- Folding Slots -->
17:43:41:  <slot id='0' type='CPU'/>
17:43:41:  <slot id='1' type='GPU'/>
17:43:41:</config>
17:43:41:Trying to access database...
17:43:41:Successfully acquired database lock
17:43:41:Enabled folding slot 00: READY cpu:7
17:43:41:Enabled folding slot 01: READY gpu:0:GP106 [GeForce GTX 1060 3GB] 3935
17:43:41:WU00:FS00:Connecting to 65.254.110.245:8080
17:43:41:WU01:FS01:Connecting to 65.254.110.245:8080
17:43:42:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:43:42:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:43:42:WU00:FS00:Connecting to 18.218.241.186:80
17:43:42:WU01:FS01:Connecting to 18.218.241.186:80
17:43:42:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:43:42:ERROR:WU01:FS01:Exception: Could not get an assignment
17:43:42:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:43:42:ERROR:WU00:FS00:Exception: Could not get an assignment
17:43:42:WU01:FS01:Connecting to 65.254.110.245:8080
17:43:42:WU00:FS00:Connecting to 65.254.110.245:8080
17:43:43:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:43:43:ERROR:WU00:FS00:Exception: Could not get an assignment
17:44:42:WU00:FS00:Connecting to 65.254.110.245:8080
17:44:42:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:44:42:WU00:FS00:Connecting to 18.218.241.186:80
17:44:42:WU01:FS01:Connecting to 65.254.110.245:8080
17:44:42:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:44:42:ERROR:WU00:FS00:Exception: Could not get an assignment
17:44:43:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:44:43:WU01:FS01:Connecting to 18.218.241.186:80
17:44:43:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:44:43:ERROR:WU01:FS01:Exception: Could not get an assignment
17:45:15:Saving configuration to config.xml
17:45:15:<config>
17:45:15:  <!-- Network -->
17:45:15:  <proxy v=':8080'/>
17:45:15:
17:45:15:  <!-- Slot Control -->
17:45:15:  <power v='FULL'/>
17:45:15:
17:45:15:  <!-- User Information -->
17:45:15:  <user v='italyboy927'/>
17:45:15:
17:45:15:  <!-- Folding Slots -->
17:45:15:  <slot id='0' type='CPU'/>
17:45:15:  <slot id='1' type='GPU'/>
17:45:15:</config>
17:46:19:WU00:FS00:Connecting to 65.254.110.245:8080
17:46:19:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:46:19:WU00:FS00:Connecting to 18.218.241.186:80
17:46:19:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:46:19:ERROR:WU00:FS00:Exception: Could not get an assignment
17:46:19:WU01:FS01:Connecting to 65.254.110.245:8080
17:46:20:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:46:20:WU01:FS01:Connecting to 18.218.241.186:80
17:46:20:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:46:20:ERROR:WU01:FS01:Exception: Could not get an assignment
17:48:56:WU00:FS00:Connecting to 65.254.110.245:8080
17:48:57:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:48:57:WU00:FS00:Connecting to 18.218.241.186:80
17:48:57:WU01:FS01:Connecting to 65.254.110.245:8080
17:48:57:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:48:57:ERROR:WU00:FS00:Exception: Could not get an assignment
17:48:57:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:48:57:WU01:FS01:Connecting to 18.218.241.186:80
17:48:57:WU01:FS01:Assigned to work server 13.90.152.57
17:48:57:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP106 [GeForce GTX 1060 3GB] 3935 from 13.90.152.57
17:48:57:WU01:FS01:Connecting to 13.90.152.57:8080
17:49:18:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
17:49:18:WU01:FS01:Connecting to 13.90.152.57:80
17:50:17:WU01:FS01:Downloading 50.74MiB
17:50:23:WU01:FS01:Download 89.06%
17:50:24:WU01:FS01:Download complete
17:50:24:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11779 run:0 clone:5715 gen:5 core:0x22 unit:0x000000060d5a98395e758990c46ec519
17:50:24:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/win/64bit/Core_22.fah
17:50:24:WU01:FS01:Connecting to cores.foldingathome.org:80
17:50:24:WU01:FS01:FahCore 22: Downloading 4.04MiB
17:50:27:WU01:FS01:FahCore 22: Download complete
17:50:27:WU01:FS01:Valid core signature
17:50:27:WU01:FS01:Unpacked 13.49MiB to cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe
17:50:27:WU01:FS01:Starting
17:50:27:WU01:FS01:Running FahCore: D:\FAHClient/FAHCoreWrapper.exe D:\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 19468 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
17:50:28:WU01:FS01:Started FahCore on PID 18268
17:50:28:WU01:FS01:Core PID:16260
17:50:28:WU01:FS01:FahCore 0x22 started
17:50:29:WU01:FS01:0x22:*********************** Log Started 2020-03-21T17:50:28Z ***********************
17:50:29:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
17:50:29:WU01:FS01:0x22:       Type: 0x22
17:50:29:WU01:FS01:0x22:       Core: Core22
17:50:29:WU01:FS01:0x22:    Website: https://foldingathome.org/
17:50:29:WU01:FS01:0x22:  Copyright: (c) 2009-2018 foldingathome.org
17:50:29:WU01:FS01:0x22:     Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
17:50:29:WU01:FS01:0x22:             <rafal.wiewiora@choderalab.org>
17:50:29:WU01:FS01:0x22:       Args: -dir 01 -suffix 01 -version 705 -lifeline 18268 -checkpoint 15
17:50:29:WU01:FS01:0x22:             -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
17:50:29:WU01:FS01:0x22:             0 -gpu 0
17:50:29:WU01:FS01:0x22:     Config: <none>
17:50:29:WU01:FS01:0x22:************************************ Build *************************************
17:50:29:WU01:FS01:0x22:    Version: 0.0.2
17:50:29:WU01:FS01:0x22:       Date: Dec 6 2019
17:50:29:WU01:FS01:0x22:       Time: 21:30:31
17:50:29:WU01:FS01:0x22: Repository: Git
17:50:29:WU01:FS01:0x22:   Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
17:50:29:WU01:FS01:0x22:     Branch: HEAD
17:50:29:WU01:FS01:0x22:   Compiler: Visual C++ 2008
17:50:29:WU01:FS01:0x22:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
17:50:29:WU01:FS01:0x22:   Platform: win32 10
17:50:29:WU01:FS01:0x22:       Bits: 64
17:50:29:WU01:FS01:0x22:       Mode: Release
17:50:29:WU01:FS01:0x22:************************************ System ************************************
17:50:29:WU01:FS01:0x22:        CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
17:50:29:WU01:FS01:0x22:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
17:50:29:WU01:FS01:0x22:       CPUs: 8
17:50:29:WU01:FS01:0x22:     Memory: 63.94GiB
17:50:29:WU01:FS01:0x22:Free Memory: 56.56GiB
17:50:29:WU01:FS01:0x22:    Threads: WINDOWS_THREADS
17:50:29:WU01:FS01:0x22: OS Version: 6.2
17:50:29:WU01:FS01:0x22:Has Battery: false
17:50:29:WU01:FS01:0x22: On Battery: false
17:50:29:WU01:FS01:0x22: UTC Offset: -4
17:50:29:WU01:FS01:0x22:        PID: 16260
17:50:29:WU01:FS01:0x22:        CWD: D:\FAHClient\work
17:50:29:WU01:FS01:0x22:         OS: Windows 10 Pro
17:50:29:WU01:FS01:0x22:    OS Arch: AMD64
17:50:29:WU01:FS01:0x22:********************************************************************************
17:50:29:WU01:FS01:0x22:Project: 11779 (Run 0, Clone 5715, Gen 5)
17:50:29:WU01:FS01:0x22:Unit: 0x000000060d5a98395e758990c46ec519
17:50:29:WU01:FS01:0x22:Reading tar file core.xml
17:50:29:WU01:FS01:0x22:Reading tar file integrator.xml
17:50:29:WU01:FS01:0x22:Reading tar file state.xml
17:50:29:WU01:FS01:0x22:Reading tar file system.xml
17:50:29:WU01:FS01:0x22:Digital signatures verified
17:50:29:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
17:50:29:WU01:FS01:0x22:Version 0.0.2
17:50:40:WU01:FS01:0x22:Completed 0 out of 1000000 steps (0%)
17:50:40:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:52:25:WU01:FS01:0x22:Completed 10000 out of 1000000 steps (1%)
17:53:11:WU00:FS00:Connecting to 65.254.110.245:8080
17:53:11:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
17:53:11:WU00:FS00:Connecting to 18.218.241.186:80
17:53:11:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
17:53:11:ERROR:WU00:FS00:Exception: Could not get an assignment
17:54:10:WU01:FS01:0x22:Completed 20000 out of 1000000 steps (2%)
17:55:56:WU01:FS01:0x22:Completed 30000 out of 1000000 steps (3%)
17:56:55:ERROR:Receive error: 10054: An existing connection was forcibly closed by the remote host.
17:57:11:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:57:27:ERROR:Receive error: 10053: An established connection was aborted by the software in your host machine.
17:57:43:WU01:FS01:0x22:Completed 40000 out of 1000000 steps (4%)
17:59:28:WU01:FS01:0x22:Completed 50000 out of 1000000 steps (5%)
18:00:02:WU00:FS00:Connecting to 65.254.110.245:8080
18:00:02:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:00:02:WU00:FS00:Connecting to 18.218.241.186:80
18:00:02:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:00:02:ERROR:WU00:FS00:Exception: Could not get an assignment
18:01:17:WU01:FS01:0x22:Completed 60000 out of 1000000 steps (6%)
18:03:05:WU01:FS01:0x22:Completed 70000 out of 1000000 steps (7%)
18:04:01:Saving configuration to config.xml
18:04:01:<config>
18:04:01:  <!-- Network -->
18:04:01:  <proxy v=':8080'/>
18:04:01:
18:04:01:  <!-- Slot Control -->
18:04:01:  <power v='full'/>
18:04:01:
18:04:01:  <!-- User Information -->
18:04:01:  <user v='italyboy927'/>
18:04:01:
18:04:01:  <!-- Folding Slots -->
18:04:01:  <slot id='0' type='CPU'/>
18:04:01:  <slot id='1' type='GPU'/>
18:04:01:</config>
18:04:53:WU01:FS01:0x22:Completed 80000 out of 1000000 steps (8%)
18:06:40:WU01:FS01:0x22:Completed 90000 out of 1000000 steps (9%)
18:08:27:WU01:FS01:0x22:Completed 100000 out of 1000000 steps (10%)
18:10:16:WU01:FS01:0x22:Completed 110000 out of 1000000 steps (11%)
18:11:08:WU00:FS00:Connecting to 65.254.110.245:8080
18:11:08:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
18:11:08:WU00:FS00:Connecting to 18.218.241.186:80
18:11:08:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
18:11:08:ERROR:WU00:FS00:Exception: Could not get an assignment
Re: CPU status is ready
With the large turnout of new contributors to F@h, the demand has exceeded the supply. More servers and projects are being prepared, but in the meantime there may be waits for assignments. They were further along with preparing projects to be run on GPUs, more CPU based projects are in the works and should be released soon.
