I started folding a few days ago and every single work unit I've completed has finished with the error message above. I'll attach a full log for one of the work units. So far I've tried redownloading the FAH client, and putting an exception on my antivirus to not touch the AppData\Roaming\FAHClient folder, but neither has worked. Any suggestions on how I can get this working?
Here's a log:
07:08:51:WU01:FS01:Connecting to 65.254.110.245:8080
07:08:51:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:08:51:WU01:FS01:Connecting to 18.218.241.186:80
07:08:52:WU01:FS01:Assigned to work server 40.114.52.201
07:08:52:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:TU116 [GeForce GTX 1660 Ti] from 40.114.52.201
07:08:52:WU01:FS01:Connecting to 40.114.52.201:8080
07:09:13:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:09:13:WU01:FS01:Connecting to 40.114.52.201:80
07:09:34:ERROR:WU01:FS01:Exception: Failed to connect to 40.114.52.201:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
07:09:35:WU01:FS01:Connecting to 65.254.110.245:8080
07:09:35:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:09:35:WU01:FS01:Connecting to 18.218.241.186:80
07:09:35:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:09:35:ERROR:WU01:FS01:Exception: Could not get an assignment
07:10:35:WU01:FS01:Connecting to 65.254.110.245:8080
07:10:35:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:10:35:WU01:FS01:Connecting to 18.218.241.186:80
07:10:35:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:10:35:ERROR:WU01:FS01:Exception: Could not get an assignment
07:12:12:WU01:FS01:Connecting to 65.254.110.245:8080
07:12:12:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:12:12:WU01:FS01:Connecting to 18.218.241.186:80
07:12:13:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:12:13:ERROR:WU01:FS01:Exception: Could not get an assignment
07:14:49:WU01:FS01:Connecting to 65.254.110.245:8080
07:14:50:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:14:50:WU01:FS01:Connecting to 18.218.241.186:80
07:14:50:WU01:FS01:Assigned to work server 140.163.4.241
07:14:50:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU116 [GeForce GTX 1660 Ti] from 140.163.4.241
07:14:50:WU01:FS01:Connecting to 140.163.4.241:8080
07:16:27:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
07:19:03:WU01:FS01:Connecting to 65.254.110.245:8080
07:19:04:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:19:04:WU01:FS01:Connecting to 18.218.241.186:80
07:19:04:WU01:FS01:Assigned to work server 128.252.203.10
07:19:04:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU116 [GeForce GTX 1660 Ti] from 128.252.203.10
07:19:04:WU01:FS01:Connecting to 128.252.203.10:8080
07:20:43:ERROR:WU01:FS01:Exception: 10002: Received short response, expected 512 bytes, got 0
07:25:55:WU01:FS01:Connecting to 65.254.110.245:8080
07:25:55:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:25:55:WU01:FS01:Connecting to 18.218.241.186:80
07:25:56:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:25:56:ERROR:WU01:FS01:Exception: Could not get an assignment
07:37:00:WU01:FS01:Connecting to 65.254.110.245:8080
07:37:01:WU01:FS01:Assigned to work server 140.163.4.231
07:37:01:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:TU116 [GeForce GTX 1660 Ti] from 140.163.4.231
07:37:01:WU01:FS01:Connecting to 140.163.4.231:8080
07:38:42:WU01:FS01:Downloading 4.52MiB
07:38:51:WU01:FS01:Download 12.46%
07:38:57:WU01:FS01:Download 53.97%
07:39:03:WU01:FS01:Download 83.04%
07:39:06:WU01:FS01:Download complete
07:39:06:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11749 run:0 clone:9337 gen:3 core:0x22 unit:0x000000098ca304e75e6bb95a7be38c84
07:39:06:WU01:FS01:Starting
07:39:06:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Keilan\AppData\Roaming\FAHClient\cores/cores.foldingathome.org/v7/win/64bit/Core_22.fah/FahCore_22.exe -dir 01 -suffix 01 -version 705 -lifeline 4128 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device 0 -gpu 0
07:39:06:WU01:FS01:Started FahCore on PID 7284
07:39:06:WU01:FS01:Core PID:9344
07:39:06:WU01:FS01:FahCore 0x22 started
07:39:06:WU01:FS01:0x22:*********************** Log Started 2020-03-21T07:39:06Z ***********************
07:39:06:WU01:FS01:0x22:*************************** Core22 Folding@home Core ***************************
07:39:06:WU01:FS01:0x22: Type: 0x22
07:39:06:WU01:FS01:0x22: Core: Core22
07:39:06:WU01:FS01:0x22: Website: https://foldingathome.org/
07:39:06:WU01:FS01:0x22: Copyright: (c) 2009-2018 foldingathome.org
07:39:06:WU01:FS01:0x22: Author: John Chodera <john.chodera@choderalab.org> and Rafal Wiewiora
07:39:06:WU01:FS01:0x22: <rafal.wiewiora@choderalab.org>
07:39:06:WU01:FS01:0x22: Args: -dir 01 -suffix 01 -version 705 -lifeline 7284 -checkpoint 15
07:39:06:WU01:FS01:0x22: -gpu-vendor nvidia -opencl-platform 0 -opencl-device 0 -cuda-device
07:39:06:WU01:FS01:0x22: 0 -gpu 0
07:39:06:WU01:FS01:0x22: Config: <none>
07:39:06:WU01:FS01:0x22:************************************ Build *************************************
07:39:06:WU01:FS01:0x22: Version: 0.0.2
07:39:06:WU01:FS01:0x22: Date: Dec 6 2019
07:39:06:WU01:FS01:0x22: Time: 21:30:31
07:39:06:WU01:FS01:0x22: Repository: Git
07:39:06:WU01:FS01:0x22: Revision: abeb39247cc72df5af0f63723edafadb23d5dfbe
07:39:06:WU01:FS01:0x22: Branch: HEAD
07:39:06:WU01:FS01:0x22: Compiler: Visual C++ 2008
07:39:06:WU01:FS01:0x22: Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
07:39:06:WU01:FS01:0x22: Platform: win32 10
07:39:06:WU01:FS01:0x22: Bits: 64
07:39:06:WU01:FS01:0x22: Mode: Release
07:39:06:WU01:FS01:0x22:************************************ System ************************************
07:39:06:WU01:FS01:0x22: CPU: Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz
07:39:06:WU01:FS01:0x22: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
07:39:06:WU01:FS01:0x22: CPUs: 4
07:39:06:WU01:FS01:0x22: Memory: 15.94GiB
07:39:06:WU01:FS01:0x22:Free Memory: 11.24GiB
07:39:06:WU01:FS01:0x22: Threads: WINDOWS_THREADS
07:39:06:WU01:FS01:0x22: OS Version: 6.2
07:39:06:WU01:FS01:0x22:Has Battery: false
07:39:06:WU01:FS01:0x22: On Battery: false
07:39:06:WU01:FS01:0x22: UTC Offset: -6
07:39:06:WU01:FS01:0x22: PID: 9344
07:39:06:WU01:FS01:0x22: CWD: C:\Users\Keilan\AppData\Roaming\FAHClient\work
07:39:06:WU01:FS01:0x22: OS: Windows 10 Home
07:39:06:WU01:FS01:0x22: OS Arch: AMD64
07:39:06:WU01:FS01:0x22:********************************************************************************
07:39:06:WU01:FS01:0x22:Project: 11749 (Run 0, Clone 9337, Gen 3)
07:39:06:WU01:FS01:0x22:Unit: 0x000000098ca304e75e6bb95a7be38c84
07:39:06:WU01:FS01:0x22:Reading tar file core.xml
07:39:06:WU01:FS01:0x22:Reading tar file integrator.xml
07:39:06:WU01:FS01:0x22:Reading tar file state.xml
07:39:07:WU01:FS01:0x22:Reading tar file system.xml
07:39:07:WU01:FS01:0x22:Digital signatures verified
07:39:07:WU01:FS01:0x22:Folding@home GPU Core22 Folding@home Core
07:39:07:WU01:FS01:0x22:Version 0.0.2
07:39:13:WU01:FS01:0x22:Completed 0 out of 2000000 steps (0%)
07:39:13:WU01:FS01:0x22:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
07:40:35:WU01:FS01:0x22:Completed 20000 out of 2000000 steps (1%)
07:41:57:WU01:FS01:0x22:Completed 40000 out of 2000000 steps (2%)
07:43:21:WU01:FS01:0x22:Completed 60000 out of 2000000 steps (3%)
07:44:44:WU01:FS01:0x22:Completed 80000 out of 2000000 steps (4%)
07:46:06:WU01:FS01:0x22:Completed 100000 out of 2000000 steps (5%)
07:47:31:WU01:FS01:0x22:Completed 120000 out of 2000000 steps (6%)
07:48:53:WU01:FS01:0x22:Completed 140000 out of 2000000 steps (7%)
07:50:18:WU01:FS01:0x22:Completed 160000 out of 2000000 steps (8%)
07:51:41:WU01:FS01:0x22:Completed 180000 out of 2000000 steps (9%)
07:53:04:WU01:FS01:0x22:Completed 200000 out of 2000000 steps (10%)
07:54:29:WU01:FS01:0x22:Completed 220000 out of 2000000 steps (11%)
07:55:52:WU01:FS01:0x22:Completed 240000 out of 2000000 steps (12%)
07:57:17:WU01:FS01:0x22:Completed 260000 out of 2000000 steps (13%)
07:58:39:WU01:FS01:0x22:Completed 280000 out of 2000000 steps (14%)
08:00:02:WU01:FS01:0x22:Completed 300000 out of 2000000 steps (15%)
08:01:27:WU01:FS01:0x22:Completed 320000 out of 2000000 steps (16%)
08:02:50:WU01:FS01:0x22:Completed 340000 out of 2000000 steps (17%)
08:04:15:WU01:FS01:0x22:Completed 360000 out of 2000000 steps (18%)
08:05:38:WU01:FS01:0x22:Completed 380000 out of 2000000 steps (19%)
08:07:01:WU01:FS01:0x22:Completed 400000 out of 2000000 steps (20%)
08:08:26:WU01:FS01:0x22:Completed 420000 out of 2000000 steps (21%)
08:09:49:WU01:FS01:0x22:Completed 440000 out of 2000000 steps (22%)
08:11:13:WU01:FS01:0x22:Completed 460000 out of 2000000 steps (23%)
08:12:36:WU01:FS01:0x22:Completed 480000 out of 2000000 steps (24%)
08:13:59:WU01:FS01:0x22:Completed 500000 out of 2000000 steps (25%)
08:15:24:WU01:FS01:0x22:Completed 520000 out of 2000000 steps (26%)
08:16:47:WU01:FS01:0x22:Completed 540000 out of 2000000 steps (27%)
08:18:12:WU01:FS01:0x22:Completed 560000 out of 2000000 steps (28%)
08:19:35:WU01:FS01:0x22:Completed 580000 out of 2000000 steps (29%)
08:20:57:WU01:FS01:0x22:Completed 600000 out of 2000000 steps (30%)
08:22:22:WU01:FS01:0x22:Completed 620000 out of 2000000 steps (31%)
08:23:45:WU01:FS01:0x22:Completed 640000 out of 2000000 steps (32%)
08:25:10:WU01:FS01:0x22:Completed 660000 out of 2000000 steps (33%)
08:26:33:WU01:FS01:0x22:Completed 680000 out of 2000000 steps (34%)
08:27:56:WU01:FS01:0x22:Completed 700000 out of 2000000 steps (35%)
08:29:21:WU01:FS01:0x22:Completed 720000 out of 2000000 steps (36%)
08:30:44:WU01:FS01:0x22:Completed 740000 out of 2000000 steps (37%)
08:32:09:WU01:FS01:0x22:Completed 760000 out of 2000000 steps (38%)
08:33:31:WU01:FS01:0x22:Completed 780000 out of 2000000 steps (39%)
08:34:54:WU01:FS01:0x22:Completed 800000 out of 2000000 steps (40%)
08:36:19:WU01:FS01:0x22:Completed 820000 out of 2000000 steps (41%)
08:37:42:WU01:FS01:0x22:Completed 840000 out of 2000000 steps (42%)
08:39:07:WU01:FS01:0x22:Completed 860000 out of 2000000 steps (43%)
08:40:30:WU01:FS01:0x22:Completed 880000 out of 2000000 steps (44%)
08:41:53:WU01:FS01:0x22:Completed 900000 out of 2000000 steps (45%)
08:43:18:WU01:FS01:0x22:Completed 920000 out of 2000000 steps (46%)
08:44:40:WU01:FS01:0x22:Completed 940000 out of 2000000 steps (47%)
08:46:06:WU01:FS01:0x22:Completed 960000 out of 2000000 steps (48%)
08:47:28:WU01:FS01:0x22:Completed 980000 out of 2000000 steps (49%)
08:48:51:WU01:FS01:0x22:Completed 1000000 out of 2000000 steps (50%)
08:50:16:WU01:FS01:0x22:Completed 1020000 out of 2000000 steps (51%)
08:51:39:WU01:FS01:0x22:Completed 1040000 out of 2000000 steps (52%)
08:53:04:WU01:FS01:0x22:Completed 1060000 out of 2000000 steps (53%)
08:54:27:WU01:FS01:0x22:Completed 1080000 out of 2000000 steps (54%)
08:55:50:WU01:FS01:0x22:Completed 1100000 out of 2000000 steps (55%)
08:57:15:WU01:FS01:0x22:Completed 1120000 out of 2000000 steps (56%)
08:58:38:WU01:FS01:0x22:Completed 1140000 out of 2000000 steps (57%)
09:00:03:WU01:FS01:0x22:Completed 1160000 out of 2000000 steps (58%)
09:01:26:WU01:FS01:0x22:Completed 1180000 out of 2000000 steps (59%)
09:02:49:WU01:FS01:0x22:Completed 1200000 out of 2000000 steps (60%)
09:04:14:WU01:FS01:0x22:Completed 1220000 out of 2000000 steps (61%)
09:05:37:WU01:FS01:0x22:Completed 1240000 out of 2000000 steps (62%)
09:07:02:WU01:FS01:0x22:Completed 1260000 out of 2000000 steps (63%)
09:08:24:WU01:FS01:0x22:Completed 1280000 out of 2000000 steps (64%)
09:09:47:WU01:FS01:0x22:Completed 1300000 out of 2000000 steps (65%)
09:11:12:WU01:FS01:0x22:Completed 1320000 out of 2000000 steps (66%)
09:12:35:WU01:FS01:0x22:Completed 1340000 out of 2000000 steps (67%)
09:14:00:WU01:FS01:0x22:Completed 1360000 out of 2000000 steps (68%)
09:15:23:WU01:FS01:0x22:Completed 1380000 out of 2000000 steps (69%)
09:16:46:WU01:FS01:0x22:Completed 1400000 out of 2000000 steps (70%)
09:18:11:WU01:FS01:0x22:Completed 1420000 out of 2000000 steps (71%)
09:19:34:WU01:FS01:0x22:Completed 1440000 out of 2000000 steps (72%)
09:20:58:WU01:FS01:0x22:Completed 1460000 out of 2000000 steps (73%)
09:22:21:WU01:FS01:0x22:Completed 1480000 out of 2000000 steps (74%)
09:23:45:WU01:FS01:0x22:Completed 1500000 out of 2000000 steps (75%)
09:25:09:WU01:FS01:0x22:Completed 1520000 out of 2000000 steps (76%)
09:26:32:WU01:FS01:0x22:Completed 1540000 out of 2000000 steps (77%)
09:27:57:WU01:FS01:0x22:Completed 1560000 out of 2000000 steps (78%)
09:29:20:WU01:FS01:0x22:Completed 1580000 out of 2000000 steps (79%)
09:30:43:WU01:FS01:0x22:Completed 1600000 out of 2000000 steps (80%)
09:32:08:WU01:FS01:0x22:Completed 1620000 out of 2000000 steps (81%)
09:33:31:WU01:FS01:0x22:Completed 1640000 out of 2000000 steps (82%)
09:34:56:WU01:FS01:0x22:Completed 1660000 out of 2000000 steps (83%)
09:36:19:WU01:FS01:0x22:Completed 1680000 out of 2000000 steps (84%)
09:37:41:WU01:FS01:0x22:Completed 1700000 out of 2000000 steps (85%)
09:39:06:WU01:FS01:0x22:Completed 1720000 out of 2000000 steps (86%)
09:40:29:WU01:FS01:0x22:Completed 1740000 out of 2000000 steps (87%)
09:41:54:WU01:FS01:0x22:Completed 1760000 out of 2000000 steps (88%)
09:43:17:WU01:FS01:0x22:Completed 1780000 out of 2000000 steps (89%)
09:44:40:WU01:FS01:0x22:Completed 1800000 out of 2000000 steps (90%)
09:46:05:WU01:FS01:0x22:Completed 1820000 out of 2000000 steps (91%)
09:47:28:WU01:FS01:0x22:Completed 1840000 out of 2000000 steps (92%)
09:48:53:WU01:FS01:0x22:Completed 1860000 out of 2000000 steps (93%)
09:50:16:WU01:FS01:0x22:Completed 1880000 out of 2000000 steps (94%)
09:51:38:WU01:FS01:0x22:Completed 1900000 out of 2000000 steps (95%)
09:53:04:WU01:FS01:0x22:Completed 1920000 out of 2000000 steps (96%)
09:54:27:WU01:FS01:0x22:Completed 1940000 out of 2000000 steps (97%)
09:55:52:WU01:FS01:0x22:Completed 1960000 out of 2000000 steps (98%)
09:57:14:WU01:FS01:0x22:Completed 1980000 out of 2000000 steps (99%)
09:58:37:WU01:FS01:0x22:Completed 2000000 out of 2000000 steps (100%)
09:58:40:WU01:FS01:0x22:Saving result file ..\logfile_01.txt
09:58:40:WU01:FS01:0x22:Saving result file checkpointState.xml
09:58:41:WU01:FS01:0x22:Saving result file checkpt.crc
09:58:41:WU01:FS01:0x22:Saving result file positions.xtc
09:58:43:WU01:FS01:0x22:Saving result file science.log
09:58:43:WU01:FS01:0x22:Folding@home Core Shutdown: FINISHED_UNIT
09:58:43:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:58:43:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11749 run:0 clone:9337 gen:3 core:0x22 unit:0x000000098ca304e75e6bb95a7be38c84
09:58:43:WU01:FS01:Uploading 12.56MiB to 140.163.4.231
09:58:43:WU01:FS01:Connecting to 140.163.4.231:8080
09:58:52:WU01:FS01:Upload 0.99%
******************************* Date: 2020-03-21 *******************************
10:00:58:WU01:FS01:Upload 1.49%
10:01:04:WU01:FS01:Upload 20.89%
10:01:10:WU01:FS01:Upload 55.22%
10:01:16:WU01:FS01:Upload 99.99%
10:01:16:WU01:FS01:Upload complete
10:01:16:WU01:FS01:Server responded WORK_QUIT (404)
10:01:16:WARNING:WU01:FS01:Server did not like results, dumping
10:01:16:WU01:FS01:Cleaning up
