Ubuntu 19.04 machine, fresh installation, without firewall and with direct internet access.
The client is locked in "Update_Core" status.
Reading the log, i try download the files with wget without problems and without strange behaviors like redirections.
I read all the post related with "Failed reading core package header." tring all the workaround in these days without solution.
Someone can suggest me something? I really appreciate every suggestion...
*********************** Log Started 2020-03-20T07:54:28Z ***********************
07:54:28:************************* Folding@home Client *************************
07:54:28: Website: https://foldingathome.org/
07:54:28: Copyright: (c) 2009-2018 foldingathome.org
07:54:28: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:54:28: Args: --child --lifeline 21904 /etc/fahclient/config.xml --run-as
07:54:28: fahclient --pid-file=/var/run/fahclient.pid --daemon
07:54:28: Config: /etc/fahclient/config.xml
07:54:28:******************************** Build ********************************
07:54:28: Version: 7.5.1
07:54:28: Date: May 11 2018
07:54:28: Time: 19:59:04
07:54:28: Repository: Git
07:54:28: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
07:54:28: Branch: master
07:54:28: Compiler: GNU 6.3.0 20170516
07:54:28: Options: -std=gnu++98 -O3 -funroll-loops
07:54:28: Platform: linux2 4.14.0-3-amd64
07:54:28: Bits: 64
07:54:28: Mode: Release
07:54:28:******************************* System ********************************
07:54:28: CPU: Intel(R) Xeon(R) CPU E3-1240 v5 @ 3.50GHz
07:54:28: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
07:54:28: CPUs: 8
07:54:28: Memory: 15.59GiB
07:54:28: Free Memory: 3.52GiB
07:54:28: Threads: POSIX_THREADS
07:54:28: OS Version: 5.0
07:54:28: Has Battery: false
07:54:28: On Battery: false
07:54:28: UTC Offset: 1
07:54:28: PID: 21906
07:54:28: CWD: /var/lib/fahclient
07:54:28: OS: Linux 5.0.0-38-generic x86_64
07:54:28: OS Arch: AMD64
07:54:28: GPUs: 1
07:54:28: GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:2 GF119 [NVS 315]
07:54:28: CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:2.1 Driver:9.1
07:54:28:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.1 Driver:390.116
07:54:28:***********************************************************************
07:54:28:<config>
07:54:28: <!-- Client Control -->
07:54:28: <fold-anon v='true'/>
07:54:28:
07:54:28: <!-- HTTP Server -->
07:54:28: <allow v='127.0.0.1 0.0.0.0/0'/>
07:54:28:
07:54:28: <!-- Network -->
07:54:28: <proxy v=':8080'/>
07:54:28:
07:54:28: <!-- Remote Command Server -->
07:54:28: <command-allow-no-pass v='127.0.0.1 0.0.0.0/0'/>
07:54:28:
07:54:28: <!-- Slot Control -->
07:54:28: <pause-on-start v='true'/>
07:54:28: <power v='full'/>
07:54:28:
07:54:28: <!-- User Information -->
07:54:28: <user v='Tgwowgt'/>
07:54:28:
07:54:28: <!-- Web Server -->
07:54:28: <web-allow v='127.0.0.1 0.0.0.0/0'/>
07:54:28:
07:54:28: <!-- Folding Slots -->
07:54:28: <slot id='0' type='CPU'>
07:54:28: <paused v='true'/>
07:54:28: </slot>
07:54:28: <slot id='1' type='GPU'>
07:54:28: </slot>
07:54:28:</config>
07:54:28:Switching to user fahclient
07:54:28:Trying to access database...
07:54:28:Successfully acquired database lock
07:54:28:Enabled folding slot 00: PAUSED cpu:7 (by user)
07:54:28:Enabled folding slot 01: PAUSED gpu:0:GF119 [NVS 315] (by user)
07:54:28:Set client configured
07:54:37:FS00:Unpaused
07:54:38:WU00:FS00:Connecting to 65.254.110.245:8080
07:54:39:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:54:39:WU00:FS00:Connecting to 18.218.241.186:80
07:54:39:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:54:39:ERROR:WU00:FS00:Exception: Could not get an assignment
07:54:39:WU00:FS00:Connecting to 65.254.110.245:8080
07:54:40:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:54:40:WU00:FS00:Connecting to 18.218.241.186:80
07:54:40:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:54:40:ERROR:WU00:FS00:Exception: Could not get an assignment
07:55:14:FS01:Unpaused
07:55:14:WU01:FS01:Connecting to 65.254.110.245:8080
07:55:15:WU01:FS01:Assigned to work server 140.163.4.241
07:55:15:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GF119 [NVS 315] from 140.163.4.241
07:55:15:WU01:FS01:Connecting to 140.163.4.241:8080
07:55:29:Saving configuration to /etc/fahclient/config.xml
07:55:29:<config>
07:55:29: <!-- Client Control -->
07:55:29: <fold-anon v='true'/>
07:55:29:
07:55:29: <!-- HTTP Server -->
07:55:29: <allow v='127.0.0.1 0.0.0.0/0'/>
07:55:29:
07:55:29: <!-- Network -->
07:55:29: <proxy v=':8080'/>
07:55:29:
07:55:29: <!-- Remote Command Server -->
07:55:29: <command-allow-no-pass v='127.0.0.1 0.0.0.0/0'/>
07:55:29:
07:55:29: <!-- Slot Control -->
07:55:29: <pause-on-start v='true'/>
07:55:29: <power v='full'/>
07:55:29:
07:55:29: <!-- User Information -->
07:55:29: <user v='Tgwowgt'/>
07:55:29:
07:55:29: <!-- Web Server -->
07:55:29: <web-allow v='127.0.0.1 0.0.0.0/0'/>
07:55:29:
07:55:29: <!-- Folding Slots -->
07:55:29: <slot id='0' type='CPU'/>
07:55:29: <slot id='1' type='GPU'/>
07:55:29:</config>
07:55:34:Saving configuration to /etc/fahclient/config.xml
07:55:34:<config>
07:55:34: <!-- Client Control -->
07:55:34: <fold-anon v='true'/>
07:55:34:
07:55:34: <!-- HTTP Server -->
07:55:34: <allow v='127.0.0.1 0.0.0.0/0'/>
07:55:34:
07:55:34: <!-- Network -->
07:55:34: <proxy v=':8080'/>
07:55:34:
07:55:34: <!-- Remote Command Server -->
07:55:34: <command-allow-no-pass v='127.0.0.1 0.0.0.0/0'/>
07:55:34:
07:55:34: <!-- Slot Control -->
07:55:34: <power v='full'/>
07:55:34:
07:55:34: <!-- User Information -->
07:55:34: <user v='Tgwowgt'/>
07:55:34:
07:55:34: <!-- Web Server -->
07:55:34: <web-allow v='127.0.0.1 0.0.0.0/0'/>
07:55:34:
07:55:34: <!-- Folding Slots -->
07:55:34: <slot id='0' type='CPU'/>
07:55:34: <slot id='1' type='GPU'/>
07:55:34:</config>
07:55:39:WU00:FS00:Connecting to 65.254.110.245:8080
07:55:40:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:55:40:WU00:FS00:Connecting to 18.218.241.186:80
07:55:40:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:55:40:ERROR:WU00:FS00:Exception: Could not get an assignment
07:55:47:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:55:47:WU01:FS01:Connecting to 140.163.4.241:80
07:56:30:Saving configuration to /etc/fahclient/config.xml
07:56:30:<config>
07:56:30: <!-- Client Control -->
07:56:30: <fold-anon v='true'/>
07:56:30:
07:56:30: <!-- HTTP Server -->
07:56:30: <allow v='127.0.0.1 0.0.0.0/0'/>
07:56:30:
07:56:30: <!-- Network -->
07:56:30: <proxy v=':8080'/>
07:56:30:
07:56:30: <!-- Remote Command Server -->
07:56:30: <command-allow-no-pass v='127.0.0.1 0.0.0.0/0'/>
07:56:30:
07:56:30: <!-- Slot Control -->
07:56:30: <power v='full'/>
07:56:30:
07:56:30: <!-- User Information -->
07:56:30: <user v='Tgwowgt'/>
07:56:30:
07:56:30: <!-- Web Server -->
07:56:30: <web-allow v='127.0.0.1 0.0.0.0/0'/>
07:56:30:
07:56:30: <!-- Folding Slots -->
07:56:30: <slot id='0' type='CPU'/>
07:56:30: <slot id='1' type='GPU'/>
07:56:30:</config>
07:56:47:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_GATEWAY_TIME_OUT
07:56:47:WU01:FS01:Connecting to 65.254.110.245:8080
07:56:48:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:56:48:WU01:FS01:Connecting to 18.218.241.186:80
07:56:48:WU01:FS01:Assigned to work server 13.90.152.57
07:56:48:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GF119 [NVS 315] from 13.90.152.57
07:56:48:WU01:FS01:Connecting to 13.90.152.57:8080
07:57:16:WU00:FS00:Connecting to 65.254.110.245:8080
07:57:17:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:57:17:WU00:FS00:Connecting to 18.218.241.186:80
07:57:17:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:57:17:ERROR:WU00:FS00:Exception: Could not get an assignment
07:57:20:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
07:57:20:WU01:FS01:Connecting to 13.90.152.57:80
07:58:20:ERROR:WU01:FS01:Exception: 10001: Server responded: HTTP_GATEWAY_TIME_OUT
07:58:20:WU01:FS01:Connecting to 65.254.110.245:8080
07:58:21:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:58:21:WU01:FS01:Connecting to 18.218.241.186:80
07:58:22:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:58:22:ERROR:WU01:FS01:Exception: Could not get an assignment
07:59:54:WU00:FS00:Connecting to 65.254.110.245:8080
07:59:54:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:59:54:WU00:FS00:Connecting to 18.218.241.186:80
07:59:54:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:59:54:ERROR:WU00:FS00:Exception: Could not get an assignment
07:59:58:WU01:FS01:Connecting to 65.254.110.245:8080
07:59:58:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
07:59:58:WU01:FS01:Connecting to 18.218.241.186:80
07:59:58:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
07:59:58:ERROR:WU01:FS01:Exception: Could not get an assignment
08:02:35:WU01:FS01:Connecting to 65.254.110.245:8080
08:02:35:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:02:35:WU01:FS01:Connecting to 18.218.241.186:80
08:02:35:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:02:35:ERROR:WU01:FS01:Exception: Could not get an assignment
08:04:08:WU00:FS00:Connecting to 65.254.110.245:8080
08:04:08:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:04:08:WU00:FS00:Connecting to 18.218.241.186:80
08:04:09:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:04:09:ERROR:WU00:FS00:Exception: Could not get an assignment
08:06:49:WU01:FS01:Connecting to 65.254.110.245:8080
08:06:49:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:06:49:WU01:FS01:Connecting to 18.218.241.186:80
08:06:50:WARNING:WU01:FS01:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
08:06:50:ERROR:WU01:FS01:Exception: Could not get an assignment
08:10:59:WU00:FS00:Connecting to 65.254.110.245:8080
08:11:00:WU00:FS00:Assigned to work server 13.90.152.57
08:11:00:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 13.90.152.57
08:11:00:WU00:FS00:Connecting to 13.90.152.57:8080
08:11:31:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
08:11:31:WU00:FS00:Connecting to 13.90.152.57:80
08:13:03:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_GATEWAY_TIME_OUT
08:13:41:WU01:FS01:Connecting to 65.254.110.245:8080
08:13:41:WARNING:WU01:FS01:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:13:41:WU01:FS01:Connecting to 18.218.241.186:80
08:13:41:WU01:FS01:Assigned to work server 155.247.166.220
08:13:41:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GF119 [NVS 315] from 155.247.166.220
08:13:41:WU01:FS01:Connecting to 155.247.166.220:8080
08:13:42:WU01:FS01:Downloading 5.79MiB
08:13:48:WU01:FS01:Download 16.19%
08:13:54:WU01:FS01:Download 29.14%
08:14:00:WU01:FS01:Download 41.01%
08:14:06:WU01:FS01:Download 58.28%
08:14:12:WU01:FS01:Download 72.30%
08:14:18:WU01:FS01:Download 85.25%
08:14:24:WU01:FS01:Download 96.05%
08:14:26:WU01:FS01:Download complete
08:14:27:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:14310 run:95 clone:89 gen:0 core:0x21 unit:0x000000010002894c5e6cf70372f279ed
08:14:27:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/Core_21.fah
08:14:27:WU01:FS01:Connecting to cores.foldingathome.org:80
08:14:27:ERROR:WU01:FS01:Exception: Failed reading core package header.
08:15:27:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/Core_21.fah
08:15:27:WU01:FS01:Connecting to cores.foldingathome.org:80
08:15:27:ERROR:WU01:FS01:Exception: Failed reading core package header.
08:17:04:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/Core_21.fah
08:17:04:WU01:FS01:Connecting to cores.foldingathome.org:80
08:17:04:ERROR:WU01:FS01:Exception: Failed reading core package header.
08:19:41:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/Core_21.fah
08:19:41:WU01:FS01:Connecting to cores.foldingathome.org:80
08:19:41:ERROR:WU01:FS01:Exception: Failed reading core package header.
08:22:05:WU00:FS00:Connecting to 65.254.110.245:8080
08:22:07:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
08:22:07:WU00:FS00:Connecting to 18.218.241.186:80
08:22:07:WU00:FS00:Assigned to work server 155.247.166.219
08:22:07:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 155.247.166.219
08:22:07:WU00:FS00:Connecting to 155.247.166.219:8080
08:22:10:WU00:FS00:Downloading 6.65MiB
08:22:16:WU00:FS00:Download 23.51%
08:22:22:WU00:FS00:Download 36.67%
08:22:28:WU00:FS00:Download 47.01%
08:22:34:WU00:FS00:Download 55.47%
08:22:40:WU00:FS00:Download 81.80%
08:22:46:WU00:FS00:Download 93.08%
08:22:52:WU00:FS00:Download 96.84%
08:22:55:WU00:FS00:Download complete
08:22:55:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:14190 run:28 clone:89 gen:4 core:0xa7 unit:0x000000060002894b5d5d2cb5b1ef214d
08:22:55:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah
08:22:55:WU00:FS00:Connecting to cores.foldingathome.org:80
08:22:55:ERROR:WU00:FS00:Exception: Failed reading core package header.
08:23:55:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah
08:23:55:WU00:FS00:Connecting to cores.foldingathome.org:80
08:23:55:ERROR:WU00:FS00:Exception: Failed reading core package header.
08:23:55:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/Core_21.fah
08:23:55:WU01:FS01:Connecting to cores.foldingathome.org:80
08:23:56:ERROR:WU01:FS01:Exception: Failed reading core package header.
08:25:32:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah
08:25:32:WU00:FS00:Connecting to cores.foldingathome.org:80
08:25:32:ERROR:WU00:FS00:Exception: Failed reading core package header.
08:28:09:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah
08:28:09:WU00:FS00:Connecting to cores.foldingathome.org:80
08:28:10:ERROR:WU00:FS00:Exception: Failed reading core package header.
08:30:47:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/Core_21.fah
08:30:47:WU01:FS01:Connecting to cores.foldingathome.org:80
08:30:47:ERROR:WU01:FS01:Exception: Failed reading core package header.
08:32:23:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah
08:32:23:WU00:FS00:Connecting to cores.foldingathome.org:80
08:32:24:ERROR:WU00:FS00:Exception: Failed reading core package header.
08:39:15:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah
08:39:15:WU00:FS00:Connecting to cores.foldingathome.org:80
08:39:16:ERROR:WU00:FS00:Exception: Failed reading core package header.
08:41:52:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/Core_21.fah
08:41:52:WU01:FS01:Connecting to cores.foldingathome.org:80
08:41:52:ERROR:WU01:FS01:Exception: Failed reading core package header.
08:50:21:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah
08:50:21:WU00:FS00:Connecting to cores.foldingathome.org:80
08:50:22:ERROR:WU00:FS00:Exception: Failed reading core package header.
08:59:49:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/Core_21.fah
08:59:49:WU01:FS01:Connecting to cores.foldingathome.org:80
08:59:49:ERROR:WU01:FS01:Exception: Failed reading core package header.
09:08:17:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah
09:08:17:WU00:FS00:Connecting to cores.foldingathome.org:80
09:08:18:ERROR:WU00:FS00:Exception: Failed reading core package header.
09:28:51:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/Core_21.fah
09:28:51:WU01:FS01:Connecting to cores.foldingathome.org:80
09:28:52:ERROR:WU01:FS01:Exception: Failed reading core package header.
09:37:20:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah
09:37:20:WU00:FS00:Connecting to cores.foldingathome.org:80
09:37:20:ERROR:WU00:FS00:Exception: Failed reading core package header.
10:15:50:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/Core_21.fah
10:15:50:WU01:FS01:Connecting to cores.foldingathome.org:80
10:15:51:ERROR:WU01:FS01:Exception: Failed reading core package header.
10:24:18:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah
10:24:18:WU00:FS00:Connecting to cores.foldingathome.org:80
10:24:19:ERROR:WU00:FS00:Exception: Failed reading core package header.
11:31:51:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/Core_21.fah
11:31:51:WU01:FS01:Connecting to cores.foldingathome.org:80
11:31:51:ERROR:WU01:FS01:Exception: Failed reading core package header.
11:40:19:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah
11:40:19:WU00:FS00:Connecting to cores.foldingathome.org:80
11:40:20:ERROR:WU00:FS00:Exception: Failed reading core package header.
13:34:51:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/Core_21.fah
13:34:51:WU01:FS01:Connecting to cores.foldingathome.org:80
13:34:51:ERROR:WU01:FS01:Exception: Failed reading core package header.
13:43:19:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah
13:43:19:WU00:FS00:Connecting to cores.foldingathome.org:80
13:43:19:ERROR:WU00:FS00:Exception: Failed reading core package header.
******************************* Date: 2020-03-20 *******************************
16:53:51:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/Core_21.fah
16:53:51:WU01:FS01:Connecting to cores.foldingathome.org:80
16:53:51:ERROR:WU01:FS01:Exception: Failed reading core package header.
17:02:19:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah
17:02:19:WU00:FS00:Connecting to cores.foldingathome.org:80
17:02:20:ERROR:WU00:FS00:Exception: Failed reading core package header.
22:15:51:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/Core_21.fah
22:15:51:WU01:FS01:Connecting to cores.foldingathome.org:80
22:15:52:ERROR:WU01:FS01:Exception: Failed reading core package header.
22:24:19:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah
22:24:19:WU00:FS00:Connecting to cores.foldingathome.org:80
22:24:20:ERROR:WU00:FS00:Exception: Failed reading core package header.
******************************* Date: 2020-03-21 *******************************
04:15:51:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/Core_21.fah
04:15:51:WU01:FS01:Connecting to cores.foldingathome.org:80
04:15:52:ERROR:WU01:FS01:Exception: Failed reading core package header.
04:24:20:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah
04:24:20:WU00:FS00:Connecting to cores.foldingathome.org:80
04:24:20:ERROR:WU00:FS00:Exception: Failed reading core package header.
10:15:51:WU01:FS01:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/Core_21.fah
10:15:51:WU01:FS01:Connecting to cores.foldingathome.org:80
10:15:52:ERROR:WU01:FS01:Exception: Failed reading core package header.
10:24:20:WU00:FS00:Downloading core from http://cores.foldingathome.org/v7/lin/64bit/avx/Core_a7.fah
10:24:20:WU00:FS00:Connecting to cores.foldingathome.org:80
10:24:20:ERROR:WU00:FS00:Exception: Failed reading core package header.
11:30:22:FS00:Paused
11:30:22:FS01:Paused
11:30:26:FS00:Unpaused
11:30:26:FS01:Unpaused
