i cant think atm, i am ill...but i can give u my cpu power.
pls help me with that issue:
its not "folding"
i installed yesterday client, controle and viewer.
it runs one time over the night and uploaded. since then no new folding.
i am not sure what is the issue...here the today logs:
*********************** Log Started 2020-03-21T10:44:41Z ***********************
10:44:41:************************* Folding@home Client *************************
10:44:41: Website: https://foldingathome.org/
10:44:41: Copyright: (c) 2009-2018 foldingathome.org
10:44:41: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:44:41: Args: --child --lifeline 1775 /etc/fahclient/config.xml --run-as
10:44:41: fahclient --pid-file=/var/run/fahclient.pid --daemon
10:44:41: Config: /etc/fahclient/config.xml
10:44:41:******************************** Build ********************************
10:44:41: Version: 7.5.1
10:44:41: Date: May 11 2018
10:44:41: Time: 19:59:04
10:44:41: Repository: Git
10:44:41: Revision: 4705bf53c635f88b8fe85af7675557e15d491ff0
10:44:41: Branch: master
10:44:41: Compiler: GNU 6.3.0 20170516
10:44:41: Options: -std=gnu++98 -O3 -funroll-loops
10:44:41: Platform: linux2 4.14.0-3-amd64
10:44:41: Bits: 64
10:44:41: Mode: Release
10:44:41:******************************* System ********************************
10:44:41: CPU: AMD Ryzen 7 2700X Eight-Core Processor
10:44:41: CPU ID: AuthenticAMD Family 23 Model 8 Stepping 2
10:44:41: CPUs: 16
10:44:41: Memory: 15.66GiB
10:44:41: Free Memory: 14.74GiB
10:44:41: Threads: POSIX_THREADS
10:44:41: OS Version: 4.15
10:44:41: Has Battery: false
10:44:41: On Battery: false
10:44:41: UTC Offset: 1
10:44:41: PID: 1778
10:44:41: CWD: /var/lib/fahclient
10:44:41: OS: Linux 4.15.0-91-generic x86_64
10:44:41: OS Arch: AMD64
10:44:41: GPUs: 0
10:44:41: CUDA Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:6.1 Driver:10.1
10:44:41:OpenCL Device 0: Platform:0 Device:0 Bus:8 Slot:0 Compute:1.2 Driver:435.21
10:44:41:***********************************************************************
10:44:41:<config>
10:44:41: <!-- Client Control -->
10:44:41: <fold-anon v='true'/>
10:44:41:
10:44:41: <!-- Folding Slot Configuration -->
10:44:41: <gpu v='false'/>
10:44:41:
10:44:41: <!-- Network -->
10:44:41: <proxy v=':8080'/>
10:44:41:
10:44:41: <!-- Slot Control -->
10:44:41: <power v='light'/>
10:44:41:
10:44:41: <!-- User Information -->
10:44:41: <passkey v='XXXXX'/>
10:44:41: <team v='XXXXX'/>
10:44:41: <user v='XXXXX'/>
10:44:41:
10:44:41: <!-- Folding Slots -->
10:44:41: <slot id='0' type='CPU'/>
10:44:41:</config>
10:44:41:Switching to user fahclient
10:44:41:Trying to access database...
10:44:41:Successfully acquired database lock
10:44:41:Enabled folding slot 00: READY cpu:7
10:44:42:WU00:FS00:Connecting to 65.254.110.245:8080
10:44:43:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:44:43:WU00:FS00:Connecting to 18.218.241.186:80
10:44:44:WU00:FS00:Assigned to work server 128.252.203.9
10:44:44:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 128.252.203.9
10:44:44:WU00:FS00:Connecting to 128.252.203.9:8080
10:45:10:ERROR:WU00:FS00:Exception: Server did not assign work unit
10:45:10:WU00:FS00:Connecting to 65.254.110.245:8080
10:45:10:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:45:10:WU00:FS00:Connecting to 18.218.241.186:80
10:45:11:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:45:11:ERROR:WU00:FS00:Exception: Could not get an assignment
10:46:10:WU00:FS00:Connecting to 65.254.110.245:8080
10:46:11:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:46:11:WU00:FS00:Connecting to 18.218.241.186:80
10:46:11:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:46:11:ERROR:WU00:FS00:Exception: Could not get an assignment
10:47:47:WU00:FS00:Connecting to 65.254.110.245:8080
10:47:48:WU00:FS00:Assigned to work server 155.247.166.219
10:47:48:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 155.247.166.219
10:47:48:WU00:FS00:Connecting to 155.247.166.219:8080
10:47:48:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
10:50:25:WU00:FS00:Connecting to 65.254.110.245:8080
10:50:25:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:50:25:WU00:FS00:Connecting to 18.218.241.186:80
10:50:26:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:50:26:ERROR:WU00:FS00:Exception: Could not get an assignment
10:54:39:WU00:FS00:Connecting to 65.254.110.245:8080
10:54:39:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
10:54:39:WU00:FS00:Connecting to 18.218.241.186:80
10:54:40:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
10:54:40:ERROR:WU00:FS00:Exception: Could not get an assignment
11:01:30:WU00:FS00:Connecting to 65.254.110.245:8080
11:01:31:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:01:31:WU00:FS00:Connecting to 18.218.241.186:80
11:01:31:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:01:31:ERROR:WU00:FS00:Exception: Could not get an assignment
11:12:36:WU00:FS00:Connecting to 65.254.110.245:8080
11:12:37:WARNING:WU00:FS00:Failed to get assignment from '65.254.110.245:8080': No WUs available for this configuration
11:12:37:WU00:FS00:Connecting to 18.218.241.186:80
11:12:38:WARNING:WU00:FS00:Failed to get assignment from '18.218.241.186:80': No WUs available for this configuration
11:12:38:ERROR:WU00:FS00:Exception: Could not get an assignment
11:30:33:WU00:FS00:Connecting to 65.254.110.245:8080
11:30:34:WU00:FS00:Assigned to work server 155.247.166.219
11:30:34:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 155.247.166.219
11:30:34:WU00:FS00:Connecting to 155.247.166.219:8080
11:30:34:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_SERVICE_UNAVAILABLE
and here the system info:
